View Full Version : Sportster Models
- Air cleaner required with slip-ons?
- Which years are best? Buying the wife a Sportster.
- Sportster 2001 front master Cylinder problem
- Tuesday's the day!
- Anything to look out for during clutch upgrade?
- Used Vance & Hines Advice
- Fuses location?
- 1997 sporty 1200 C wont start
- 03 XLH 883 Vac Lines Diagram
- Got my Mustang
- New from Denver!
- installed bowman 10" sissy bar
- Did the "wire tuck" mod!
- No Acceleration (cough, puke, die)
- Error codes
- JP Cycles Coupon Code/ Discount Code?
- Harley Sporster 05...compatible seat?
- Finally getting the bike back!
- Anyone else have numbness problems??
- Break-in & Upgrades
- Sportster after one year
- Where to keep MC papers...?
- 72 Slip on question...
- Powder Coating ?????
- Help with a sputtering 2011 48
- Brake bleeding problem
- goblue90's 48
- 2001 - 1200 Motor oil Tank- Vent line Help
- Single Seat for Comfort and Style
- Air Filter Soaked
- Newb 48 seat question
- Gear cover bushings
- Question on foward controls
- arlen ness big sucker vs vance and hines v02
- 1200 Custom 100 Anniversary Edition
- Iron 883 drained and only took 1.5 qt oil
- Better pipes for the money??
- Hesitating start?
- Headlight Connector Pin Removal Help
- Quick Help please?
- 2013 1200C Speedometer oscillating dealer can't figure out
- Foot pegs and accessories
- Need to Replace Rear Tire XL50
- Lay down licence plate holder
- DIY Bar end mirrors for RSD Clip-ons
- Smoke or Clear??? Help me decide
- 2000 sportster 883 custom vacuum hose size
- Thinking of Trading the 48
- 2013 iron 883
- stainless steel handlebars
- Sportster Mods so Far
- Extended Brake Line.
- 94 sportster charging issues
- 2010 Iron 883 Shifting Issues
- 02 Hugger Exhaust
- Evening ride under a gorgeous sky!
- Introduction and a short '14 Sportster evolution
- $49.00 fairing
- Hurricane Sandy Sportsters still floating around
- 48 hardtail build complete
- I think these forks need painting
- Hard Saddle Bags
- Nuf Said
- Modifying the cowbell horn bracket to mount coil?
- Speakers (+Amp) recommendations for Sportster XL1200C
- Coker Firestone sizing
- 2014 Iron 883 ABS on a 2013?
- Oil Drain Tube Clamp (tool?)
- Bike Is Dead, Won' t Start. NEED HELP!
- Need some advice...
- New Guy...
- My hello, Here's my 48 & Dyno PV tuning Question
- Hammer performance 1250 Build...help!
- Hammer Performance 1250 kit for my Cafe Sportster
- Upper and lower belt guard
- Key replacement or Duplicate for Gas Tank Cap??
- Sportster Rear Fender Heights
- Tire Levers? headache? Worth it?
- Tall dude wants a sporty...
- evo sporty electrical issues HELP!
- braking
- Saddlebags with gas cans for '14 Iron?
- Daytonas or buck horns? .... with pictures
- 2013 XL883N Iron Ignition Key
- Iron 883 exhaust choice
- Why are black left side covers so hard to find?
- jACK FOR 48
- Changing to a 7" headlight questions
- Whining noise
- take off shutter (2007 xl883c)
- Finally bought my first Harley! 2009 Nightster
- 1400 sporty
- hey all you really smart guys or a regular dumby like me who has done throttle swaps.
- 2015 Iron - Upper Fork Question
- RSD PROSTEP HANDLEBAR 12" anybody have these?
- Buying my 1st Harley
- The evolution of my Sportster.....
- Loaded and ready!
- 2013 883 Iron: recommended upgrade path?
- New exhaust
- 'Gold' chrome accessories wanted
- Tire Sizing
- How much range is lost with a tank lift?
- well this fit my 98 sportster 883 hugger?
- not a dirty carb or misfire! ... well, kinda
- Painting a raw gas tank
- Forward Controls question
- finding stock tank decals
- Got Me a New 72
- LED H4 problems
- audio for my sportster
- who has put a new throtlle and relocated switches are thier 48
- 48 front end conversion on my 09 883 sportster
- DAYMAKER Headlight - 5 3/4
- Installing the speedometer on a 1997 XL1200C Sportster
- Chain Problems-'90XLH
- Shinko 777
- Front Left Turn Signal - stays illuminated
- An alternative to traditional leather side bags
- Forty Eight Fender Side Reflectors
- Should I buy???
- Sporty seat question!!!
- Superlow 883 rear tire upgrade
- Buying used bike, maintenance??
- 2006 sportster 1200 frame swap
- Nightster tail light
- 1995 1200c rear turn signals/running lights
- I have a lust for rust. few more pieces to do
- Can this be made to work?
- 2010 Iron -Rear Fender Chop, round one...
- First Harley
- First Harley
- Changed the oil and drain tube on my 2007 1200C
- exhaust bolts
- Forward Controls On My Iron 883
- Bike only charges with the headlight out
- gumout!?
- Finnish style Sportster Chopper in correct...
- Front LED turn/marker combo?
- Just installed Short Shots, please help!
- My 2013 Iron 883
- '72 tires
- Deceleration popping
- mustang seat..
- Finished DK Custom - Coil and Ignition Switch Relocation Project
- Saddlemen Americano cafe seat...opinions?
- Check Eng. Light after cleaning Air Filter Help
- Running light issue
- How Hard Do You Run Your Iron
- just ran out of fuel! :(
- 14 inch santee apes on an 883
- Run / Turn / Brake signals
- Do I need to maintain a 12v supply to the bike when disconnecting the battery?
- Help!
- Shocks for a 2004 xl883
- It sounds like a whale...
- Handlebar questions.
- First Upgrade!
- easy off?
- red bulbs for rear
- Turn Signals Not Cancelling
- Holy Service Charges!!!
- XL1200T Rear Shocks
- help wiring problem
- Risers on Stock Speedo
- California Ride Recommendation.
- Saddlebags
- Effin T-27s - torx - derby cover
- Harley Ownership is a family thing...
- Matte Black, gloss black or Polished Aluminum
- new smaller lithium ion battery vs. stock HD battery
- Exhaust options & powercable on Iron ?
- Burly cable problem!!!!!
- Wrapped my pipes ... Pics inside
- Help instaling a Hypercharger needed
- Won't start
- Putting 13" shocks on a stock 883 Hugger...anyone else?
- 48 shock question
- Wire coming from rear cylinder head
- Possible Headlight discovery.....solution.
- Burly or the HD quick detach Sissy bar
- Oil Drain Tube Cracked and Leaking
- What is it?
- 2007 sporty starter hesitates when first cranked
- Might have to sell the 48
- Retro T-Sport bags for Sportsters?
- My First HD
- one mans trash another mans treasure
- Headlights upgrade
- 2008 Sporty 12C, been sitting, rough idle...
- Anyone sell an HD and buyer used HD financing?
- 2015 iron 883 slip ons?
- For Those Of Us That Live Where It Snows
- Always 4way flashers!
- Looking at buying a 72
- 2000 sportster oil change
- new member!
- Recommend some bars...
- Indicator Help
- 2015 Harley Davidson 48
- Sato Racing frame sliders for Sportsters
- new bike..possible issue
- 2.8 or the whole 3 quarts of oil
- before I crank her...
- Installed some Vibranators on my 883
- Deutsch Connectors - what a pain in the ass
- Tire Pressure
- anyone have the corbin solo hollywood seat for 48/72?
- Post pics of your exhaust
- Overfilled Oil?
- Rain Sock for Auto Zone 3" AC?
- Jetting Question
- handle bar change
- Hammer 1200 kit
- wiring problem!!!
- Dual front brakes
- couple shots of my iron.
- 1987 harley sportster engine not getting gas
- Newb Question About Plate
- Head Bolt Covers
- Sportster fuel pump problem
- 94 Sportster Blows Fuse on Start
- 2005 883C High RPM on Highway Pulley Change
- What triggers the auto turn signal to turn off signal.
- how difficult changing switch housings???
- Mustang vintage or wide vintage
- About to order Ricor rear shocks... tuning?
- Swapping horn and run switch?
- Sportster indicator light relocation problems after installing new handlebar
- XR1200 exhaust fit a Nightster?
- Bobber Fender for Sporty 48
- Dual Headlamp Nightster/Spportster
- How to flip mirrors on 2015 Iron 883
- Help
- H4 Wattage for Stock Wiring?
- Sportster wont turn over after speedo install
- You can Take floorboards out of my life but you can't keep them off my bike
- Smoke from engine.... New to harley... Iron883
- Modification Questions
- Any of you with Non Harley forward controls?!?
- Xl883(xx) xl1200(xx) sportster front spoiler(chin fairing) kit install instructions
- sissy bars, crazy shipping price...
- ignition problem on my 90 883
- Is there an idiots guide to the Screamin' Eagle pro street tuner?
- Night Rod Special Fairing on a Nightster
- Intake Question
- 1998 Sportster XL883 Hugger
- IRON883 Sportster 2015 BRAND NEW .... Does not Start!
- 2008 sportster security won't work
- V&H fuel pak install on 07 nightster
