View Full Version : Sportster Models
- servicing the harley
- Stumbling in the rain
- 2012 Sportster 48 Upgrades
- Intake/Exhaust question.
- Need help with Error P0154 - Rear Oxygen sensor - Big Problem?!
- Need some on some apes.
- New to harley world with a used bike.
- proven 3 way toggle rocker waterproof ignition switch and relay preference?
- Yup, she's red.
- 84 vs 86 primary cover
- Shifting down
- BlkSheep's Iron
- Oil on spark plug threads.
- gas leak right side
- Starting issue!!!!
- Newbie question
- Nightster won’t start, just clicks...
- Quarter Fairing
- Sportster 02 sensor
- Hum When Backing
- Installing 12.5 " progressive 412's, Do I need to jack the bike
- Question about primary/transmission design.
- Handlebar top clamp bolts?
- weird sound coming when starting up lights flickering
- 2013 forty-eight strange hard acceleration noise/issue
- wheel fitment
- speedometer adjustment
- 2.2 Gallon Tank for Carburated Sporty
- Iron on the road
- 1200 Custom starting issue
- Jerky throttle over bumps......solved!!!!!!!
- Need some advice about my 48
- 07 sporty and a tuner question
- new sportster to do list? (advice request)
- Next Mod: Heavy Breather / Tuner?
- 48 with side shots
- Best new tires to buy?
- Survey-What engine and tranny oil do YOU use?
- DK Thunder Torque Inserts w/ Xied's
- Heavy Breathing..bolts
- Cover up your stock graphics?
- Ideas n advice appreciated
- Ignition upgrade
- Gears slipping
- Sporty question?
- Wife's 883 Iron
- What do you use to keep Rust Off!
- P/N for battery cover mounting clip
- ***New Here***
- First mod ordered!!!!!
- 2008 1200 custom needing fuel map
- The official "fuel-cap" picture thread
- Sportster Tranny Whining Question
- Derby cover screw thread stripped...
- Question about Progressive suspension.
- Drag Bar help
- muffler support has broken... what gives?
- Is it time to turn to a tuner?
- 08 Nightster Front Turn Signal Mounts NEED HELP
- Suggestions were to start looking. (oil leak) w pics
- 2008 Nightster Check Engine Light & Battery Light on
- Engine Light On But No Diagnostic Codes
- 05 sportster brake light staying on
- Need help identifying a bagger plz
- are the engine covers Cosmetic or serve a purpose?
- Changing oil filter
- 1400 miles on a Sportster
- security remote
- Question about my VIN / bike type
- Fuel Cap - Joker Machine Flip Up, HD Flush, or ?
- Baker Drivetrain
- XL883N Rear Fender Reflector
- Off-run and start button queston
- Just did a tank swap, have some questions.
- 97 S model work in progress
- Rush Slip-on's Baffle choice
- I got some elses head ache
- Rush Slip-on muffler baffle size
- Making my Sportster "Dali-Worthy"
- ~~ HI-DEF Truck & Forty Eight Shoot ~~ PIC HEAVY!
- Rear tire/wheel question
- 2014 iron 883 cost
- Oil splatter? not sure where from
- indicator lights: codes or battery/electrical issue? VIDEO
- Sweet Buell Bobber.
- Anybody recognize this bike?
- Exhuast/Intake Upgrading Question
- Help Me Choose A New Sportster Between These 3
- My 2012 48 w/ Progressive 412 12.5" Shocks
- ATTN: DK Customs, have you heard or had anyone else with this issue?
- upgrade with high milage
- charging issue on 79 sportster
- 07, 1200 xl
- Used XIED surging now?
- Just manipulated my wife
- Question about mufflers
- Clip On's for a 48
- 2008 Sportster XL883 , need to lower
- Nightster Ape to Drag.. Help.
- Trying to track the owner of this!
- Charging system
- Has anyone taken apart a backrest pad?
- Valve Train Noise 2013 1200C
- 883 rubber mount location
- V&H short shots vs. big radius?
- Oil temp on a 2013 1200?
- Remove 98 Sportster carburator
- I finally did it!
- my version of the iron
- 14 inch apes on a 883R help with brake line
- 1995 sportster 1200c help
- swapping fuel tanks
- good mpg!! :)
- Trans issue
- Mods and tricks to stock throttle tension star screw.
- 2009 Sportster XL Drag Bars
- Tunes for your Iron/Sporty?
- IRON are not touring bikes....!
- 2012 sporster 72 lights
- Do I need to re map?
- Turn signal options ? ? ?
- 2013 Iron 883
- where are all the XR1200 guys
- New harley owner here.
- 05 sportster rear brake light switch
- New member needed a little help from the veterans.
- Rear Fender assembly
- Led Sled Floorboards with Bobcat exhaust?
- How many kilometers have you got out of a 48 tank
- 883 Sporty Saddle
- 2014 48
- Need Opinion on shock size
- Met up with smoove today
- nightster wire tuck question
- Is this a fair price?
- Punch the front forks out 3 inches
- Newbie question on cable kit length for apes
- Forward controls for Nightster...
- Best black braided cables for 12" z bar ape hangers?
- Sportster XL 1200C to 48 mid glide triple trees conversion?
- Newest mod - Anti cell phone driving message
- Taller shocks - Longer jiffy stand?
- Foot levers
- Quick thoughts on DK's Outlaw 587 Air Cleaner
- Help with rear lower blocks on Sportster 48!!!
- Fork Drain Plugs
- Headlight bucket part# and which years are the same
- Settle a bet for slip on exhausts
- do you have to relocate speedometer if you get tbars on iron 883
- Before & After
- Question about buying HD parts online
- 1995 Sportster 1200 Brake caliper Attachment
- Music with your ride?
- Saddle Bag Supports that can be used with Detachable Hardware
- aghh!!
- 2000 Sportster blowing oil out of Vent
- Your Next Bike, after the Sportster
- Rear pulley teeth?
- Custom Dynamics
- Question on 3/4 helmets
- Ape Hangers
- Will HD adjustable highway pegs work on my 1200C with V&H short shots?
- Installed the clutch and it's still messed up
- Increased price for Iron 883 2014
- Well I found my vibration problem...Patriot Defender bracket snapped off
- Contential Motorcycle Tires
- Interchanging parts ?
- 2005 sporster
- Selling my Sportster, weird buyer need advice!
- Vance and Hines Big Radius issue
- pre mod short shots
- My pipes are too loud
- Crankshaft oil seal.
- Ignition wiring question Sportster '95
- Dyna wheels on Sportster?
- Unable to static time Ultima Programmable ignition
- Deer hide seat
- New Sporty vibration question
- Pan Seat for 883
- clutch help!
- Forward or Mid Controls? What say you?
- Rear Brake Bleed Problem
- Future Biker with a typical Dilemma
- Tyre pressure for AVON SM II's
- Footboards on Forty eight
- My take on the DIY air filter...
- Scraping the road in corners
- New rider, new bike with issues
- Faaker See 2013
- Soaking a new clutch
- Starting to mod my first bike...
- Finally got the Sporty to my liking
- Gas leak - on replaced tank
- first gear pause then lurch forward
- Need a little help.
- Primary/Trans breather fix?
- Thunder torque placement
- fender hitting belt gaurd
- Smoking Breather Bolts
- Screeching Noise in fuel tank
- Need Help. Sportster stalls at stop lights.
- Larger pad for one pieces sissy bar
- XR1200 caliper on a 72?
- 39mm pvc preload what size and how much?
- Aftermarket knurled shifter/rear brake knob
- Short sissy bar
- A few mods to my Iron
- 300 Miles on the Zombie Nightster
- I love Sportsters but they are NOT the value they once were.
- Bobbed 48
- Petcock. What and where is it?
- Stator Fixed Back On Road
- Yet, another problem..
- Oil behind Deco plate
- Speed/odometer not working
- primary chain sets?
- Easy Pull Clutch
- Iron Update (Pictures)
- My new Iron
- Need Info on Sportster Grips
- 07 Sportster Throttle no Response
- Performance machine fast air intake...
- Screamin Eagle Stage 1 for 06 1200C
- R/S Shift Iron Head Lower with Evo Upper
- Tinnitus victim: Need the quietest exhaust possible
- Sportster Custom rear wiring
- Upgrading my 2010 48
- Price Check - Fixing Bent Shift Fork
- Went to a 7" light on my 2009 XL1200C
- Badlands Load Equalizer dimensions...
- Riding to Chicago in October
- Nightster Woes sputtering/hesitation
- Little problem..
- Help... Tank lift install question.....
- How do you position a jack/lift?
- Am I the only one here with a 72???
- Happy Friday!
- Harley New Chizeled Handlebars
- Rip
- Throw Over Saddle Bag Support Help
- Slip-Ons for full system?
- Mid Controls & Patriot Defender?
- Softail rear signal lightbar install tips?
- Trade in Value of a 2013 Iron 883
- New guy here
- Next upgrade Stage 1
- Hot Bike Power Tour Ride Report
- Removing factory tank badges?
- Check engine light...
- thoughts on a bike for the wife
