View Full Version : Sportster Models
- What seat puts you furthest back?
- Sportster performance stages
- New tank on my Forty Eight
- Oil getting into, and dripping out of the starter. Help!
- New XR1200 owner
- vintage tires
- need air cleaner cover opinions from actual bikers...
- Crankcase breather hose
- timing
- DIY Belt Tensioner for taller shocks and Cafe Bikes
- article about the new 2016 Sportster suspension
- 5th Gear Failure
- smaller battery?
- Remove wheel bearings without a puller..
- 09 sportster bars and risers help
- iron speedo relocation with good visibility?
- Rear fender
- First ride with a windshield...what have I done!
- forward controls
- Reduced Reach Forward Control Conversion Kit
- Thunder Torque Inserts
- Reduce heat exposure from exhaust
- Replacement Part
- 2000 xl1200s your thoughts please
- Nearly went down
- Swapping 27t with a 26t?
- Changing Tank/painting
- Came close to a catastrophe
- Problem with HD QR windshield on XL1200C
- 1972
- How far back can a solo seat go? Yet another seat question.
- Solo seat, sissy bar, passenger?
- power vision help
- Fuelpak fp3 cause ecm to go out??
- 06-07 XL883R Handlebars
- Trading 48 for a new 48?
- What do I have?
- Looking for a Cheap Two-Up Setup
- Dk customs coil and ignition relocate
- Help... This lady needs assistance on her 01 sporty
- Demon Cycle Handlebar Kits
- Front Fender Structural ?
- Throttle body not fully open at full throttle
- 2011 Sportster Custom rattle
- Throttle Adjustment Issues
- Sporty died on me
- Stock vs. Stage 1 AC
- Ya ever just...
- XR1200 have I lost my mind
- Bike won't start.
- Swapping bars regularly?
- anyone know who makes this air cleaner cover?
- poor running 2012 Custom
- Side Mount License Plate Bracket for 2015 Iron883.
- Fender strut bolt too long?
- Just want to show off my Sportster
- What Would You Do - Build Question
- 09 xl1200c headlight mount change
- any rules about a sissy bar with a solo seat?
- Where did the oil tank and battery go??
- Sportster/Nightster wiring help
- Carb or fuel-injected Roadster delima
- Turn signal wiring help
- Loading Ramp
- New here and already problem with my 13 72 sportster
- Iron front shock oil
- L.A.F Pipe + Joker AC = V&H Fuelpak?
- '05 1200 crank question
- 89 883 basket case, won't start.
- 2014 Iron 883 Rear Break Caliper bolts
- De-catting the head pipes
- Touring Fender On A Sporty
- Smartpartz hard kores, V&H quiet baffles, DK's TTIs, best combo for a quieter bike?
- Opinions on options -- Screaming Eagle slip-ons and LED light
- Help with dtc codes
- Sportster speedometer sensor part #
- 2016 Models Announced - 48, Iron etc
- Help identifying tank on XL1200N
- Stage 1 Dobeck-D&D-DK Custom review
- Battery Question ?
- Loving my HD Low Profile seat
- Grinding Noise slowing down/stopping XL883/1200
- 1200C to Low handlebars?
- Service Manual?
- DK Customs 2" forward control extenders
- Sportster hardtail
- Kuryakyn
- I'm back
- My new to me 48
- introduction and a question.
- Badlander vs stock 48 seat
- Re installing can cover on a 2011, 1200 nighster
- Indy referral - Vancouver, BC Canada
- Over 900 miles on the Speedometer and yes, I CAN drive 55
- 2015 Sportser 48 and Raised White Letterd Ties
- 1250 upgrade and tuner
- Oil Cooler Kit
- performance air filter element in stock A/C
- screamin eagle tuner for 2012 sporty?
- Mid controls for a 48?
- Removal of head light visor
- Need some help regarding 'Forty Eight'...
- sporty forks
- Need help to buy new shock springs (just springs)
- PCV Mapping help needed
- 883R brake light mod options
- Sidestand switch turns off SportsterIron 2015
- d02 - Speed sensor power output shorted high or open
- About laid it over...at 0 mph
- Oils! - Mineral vs Semi-Synth?
- Looking for Sportster
- White Wall Cleaning Tips
- Swiss Sportster
- Seeking CARB approved slipons for 2015 forty eight
- Rear Fender Fitment for 2015 Iron 883
- HORNS - Anyone use Air Horns?
- Battery mount tabs broken!?
- 1200C Stock Shifter Linkage
- Check engine light after coil relocation
- Does Sporty need a 6th gear
- New 48 owner : I want to change my shocks
- Laid the bike down...need some help
- Securing luggage question
- Nightster 3.3 Tank Lift Issue
- Shut down won't start help
- big bore kit questions
- Anyone Know What Handlebars These Are ?
- 06 883
- 883 Iron Break In!
- Sportster Dilemma
- 05 Sporty Performance Upgrade?
- New sportster owner
- Rear shock ID?
- Engine suddenly turning off ?
- Roadster or not
- Bike turned itself off and will not turn back on.
- Bike sputters and dies at high rpm
- 883 Super Low Wheel Width?
- I give up
- 2015 Forty Eight with SE parts
- Helmet Lock Positioning - where did you mount?
- said no to 2012, must wait for 2016
- HD QR windshield and turn signal relocation kit
- sportster 1200 exhaust
- High Idle on startup
- Will Iron 883 wheels fit on 2005 Sportster XL883?
- Sportster for Track Days?
- 2012 Nightster - Highway Pegs?
- Vance and Hines PN # 75-118-09 2-1 comp
- Mustang seats help please??
- Progressive 444 shocks
- Solo bag to fit left side of a 2015 Iron 883?
- What bars work with stock cables?
- I want a big fat tank for my Sportster. Where can I get one?
- Nightster Whitewalls
- Side bags options with passenger pegs?
- Rear lights not working when LED put in
- 883 Primary
- Has anyone drilled hole through muffler WITH a catalytic converter?
- CV carb mods
- FP3 Autotune
- Stranded. Popping. Smoke. Fun.
- My Sporty Bobber build
- Primary Oil Change
- Power Vision
- preemptive clutch repair
- V&H Naked Vo2 Air Cleaner question
- Issue with neutral indicator/switch?
- Probably paranoid - but maybe not...
- progressive springs or monotubes?
- Won't start
- Larger Tank on 883?
- Speedo no go. Lunge at start.
- VOES adjustment ???
- Question for the cleaning GURUs
- Tank lift, coil relocate on a 88 sportster?
- Supporting mods for a 1200 upgrade?
- 4 speed vs 5 speed
- diagnostic link connector location
- Took a little trip on the sporty
- need help finding chrome fork lowers please
- Moved from Ultra Glide and Fat Bob to Sportster - Need Handlebar Advice
- Holeshot???
- Removing tail light and filling in fender
- Anyone use this company before?
- '72 Seats UK
- UK 883 - Where is the rear brake light?
- exhaust and aur intake mods
- Mechanical help! - front brake dragging
- Strange to me.
- 1992 Sportster 1200
- Forward controls or highway pegs on 883xl
- Sportster starting problem, with battery
- DK Customs 2" Forward Control Ext. - Licks 8" Bars
- Getting withdrawal symptoms - been raining here 3 days straight
- Bike just quit
- Sportster 883 parts details
- Drag Bars - Sportster Iron
- Mini apes on 05 XL883L
- Saddlebag options/opinions
- Help me find this air cleaner please
- What Handlebars do you have?
- Tickity tackity lifters
- Reduced reach levers?
- Let me apologize for the huge question about RK air shocks
- Couple of questions
- Sportster for 16 year old
- Sportster forward cotrols
- Forks leaking
- Long Distance Seat issues/solutions
- Using 10w-60 synthetic oil
- New Solo Seat - My First Mod
- big bore for the 1200
- Iron 883 running rough after V&H Short Shots Exhaust Install
- Larger fuel tank on 09' 1200c?
- Sissy Showcase!
- New Member in Nashville, TN
- 09 XL883L solo seats and forward controls
- New to Sportsters
- Thou '48, Defeater of the Saxons
- 883 Low Rider and classic "Old/New" Info needed
- Burly Sissy Bar
- Indicator stop and water
- fork tube diams.
- DK Customs Bundle Ordered: XiED, TTI, Hiflow 587
- 1200 engine specs
- V&H Short Shots on 2014 Iron 883
- Looking for custom sportster tanks
- bmx grips on sporty ?
- DTC's - What's the "b" mean?- Speedo
- Sportster 1200 sport for beginner
- Low price/DIY mods
- 1987 Sportster Repaint Project
- Strange error on display and won't start after siren install
- AMSOIL... did I miss something?
- Passenger pegs + Swingarm bag?
- 1999 XL1200C Mid control conversion
- HD swims arm solo bag pending obsolete
- Factory air filter
- Hollywood handlebars on a 2007 1200 custom
- Jug Swap??
- 2010 883 iron / white wall tires question
- how do tell if a 883 has been converted to 1200
- Mustang Seats
- rear mag wheel on from of IRON 883. Can It be done?
- My '48. Behold a pale horse. Upon it sat Death and he'll followed him
- jiffy stand ????
- Can one side of a coil go bad?
- 2015 Iron 883 Bar Swap
- '63 XLH Bagger
