View Full Version : Sportster Models
- Adding fog lights (and other lights) to the 883
- DK Sporty in Current issue of Hot Bike Mag
- New user,my 883N.
- What kind of wheels are these???
- Anyone put 883 Superlow handlebars on a 1200 Custom ?
- OMG, I did a [breather] mod...
- Speedometer/Tach Combo Vin Error
- My first bike. 2005 883L
- Out with the old, In with the new upgrades
- Difference In Ride Quality
- Crash bars or lowers for a sportster
- 1991 1200XLH Stock Pushrod Reinstall
- Throttle cable adjustment: going into my 100th attempt
- Hammer 1250 build
- softail calipers on a sportster front end?
- what should my "must have" customizations be?
- Need some advice on shocks, 883 Superlow
- New to the Sportster 883 and forum!
- Amber Whiskey Iron 883
- Cleaning engine aluminum
- Guys with chain kit and bigger rear tire
- 2005 XL1200 sportster misfire under load
- Hello from Alaska
- Thoughts on these shocks
- Harle Iron Seat Mounting Kit?
- Blacked out shocks?
- bulb killer
- Anyone's Spokes On Their 72 Still Giving Them Trouble?
- exhaust question
- Sparky brake light switch
- Air cleaner advice
- Sportster exhaust question
- wheel changes
- New tank lift, wire tuck, coil/ignition relocation and bars
- Attention South Florida Riders!
- 2013 883 Iron upgrade help
- Questions and you to this thank you for answers
- Wrecked Sportster
- sportster fender
- 2014 Watercooled 750 and 500 Harley
- hagon nitros fitted and tested
- Oil Coolers ... Advice?
- Needing Help/Advice
- A Shelby tribute iron
- Springer Seat ECM Switch Issue
- OK, this chaps my hide, Street bike with a sixth gear.
- Do I have to put my bike away?
- Sporty won't start up after S&S install?
- Do you do anything special for winterizing?
- Fattest tire on my 13' Iron 883
- Help with next mod
- XLH 1200 1997... sweet but ??
- winter coming!!!
- Woodlands TX dealership lol's
- Sportster Speedo
- Clutch or tranny problem?
- Avon Gansta white walls anyone?
- Turn signal relocation - which looks best?
- White smoke/fouled spark plug
- 2006 1200 sportster exhaust
- No start 2007 1200cc Sportster low fuel pressure
- Winter is coming
- My Winter Storage Tips
- Security fob cover
- 2007 Sporty Low Transmission Response
- S&s
- upgrade 883 to 1200 or buy 2014 street bob
- 94 Speedo Swap
- Clutch Questions and Help
- mustang solo wide day tripper
- Whats a good year to buy?
- What Hp is your sporty putting down on dyno
- Headlamp w/ Incorporated Front Turn Signals
- My 48
- Sportster trans issue
- Ape hanger help
- 03 sportster 1200c
- Another Sportster?
- Back on sportsters again!
- Hollow bolts for handlebar wiring?
- Red LED's
- 2000 sporty bobber build rear fender help
- 2013 HD Super Low 883
- All polished up and put up for winter.....
- Name that Shock
- Doing a wire tuck, have one extra plug?
- Fuel pump
- replaced choke on a 2000 sporty
- What year is this Sportster?
- New Harley Owner, Front Brake Rubbing
- New seat, mother roads customs springer
- Suspension question
- 2014 iron 883 baffle question?
- Anyone running 88/90 big bore kits on their Sporty's?
- Air pressure in RK shocks.
- sportster extra plate clutch kit writeup
- 2000 Sporty clutch replace
- Front end hit, how to align again?
- s&s slipons
- is this normal? Take a look........
- 1st gear hard to find
- helmet for 72
- will it fit?
- Need softer ride....
- took a long time
- Front tire loosing pressure
- Spent some hours detailing my bike
- Anyone with apes on their 48?
- Installing detachable plates and sissy bar
- Sportster controls swap?
- For professors!!! Shock travel comparison
- Performance exhaust
- 97 xl1200c exhaust w/crossover
- Are these good numbers? Dyno stats
- 1998 Harley Sportser XL 1200
- Best (inexpensive) shocks for me
- fuel pump or what?
- Opinions on sportster tour trunk
- Vance and hine short shots ??
- Is the Burly Slammer that bad???
- New HD sportster?
- Need Help Finding This Part
- Dyno Results
- Bell Rogue Helmet design flaw?
- Nrhs rocks~
- Progressive shocks
- B1155: Neutral Short to Battery
- Bar Riser! Big Deal or Not!
- Help!! Bike won't move
- Just replaced my LED Daymaker with and updated version
- Sportster Saddlebag support bolt too short
- Shock bolts/proper length?
- 2012 iron 883 blacked out
- What's the difference between 1200 engines?
- sweet little iron...
- Ride Report 900 Miles on my Sporty
- started the cafe project..
- Cometic rocker gasket part numbers
- vance and hines 2014 available?
- Got my new C&C Seat!!!!!!!! (pics)
- online HD parts
- Some pics of the iron at the beach
- Gross sound...
- Begging to swap parts out
- Slip on options that are not crazy loud...
- who makes these pipes?
- 412s or RK air shocks for my sporty?
- Updated Daymaker LED Headlamp
- Sportster Ammo Box Panniers
- terminal block?
- 2007 Sportster 1200 Low Known Issues
- Bike dreams
- Energy 1 + NRHS 1250 conversion WOW!
- Performance intake?
- Thinking of changing the skinny wheel with a wider ones
- Oil Light comes on when ignition is turned on is this normal?
- New shoes
- sportster 08 fuse relay block cover
- how often do you clean throttle body with ac that breathes in it
- 05 Sportster engine light
- taillights quit working 01 sportster 883
- New to the Sportster Scene
- Front Friggin' Rocker Box Cover
- Aftermarket turn signals...
- early sunday morning ride
- Blame it on the hot new neighbour, went down :(
- ID this Sportster and Modifications
- Where to start advice wanted
- How much oil should there be inside the oil reservoir under the seat?
- Need Help: Bike Iron 883 Won't Run
- In love with a Sporty, but worried
- Finally installed the fork covers, got her done!~
- drag specialties steering damper pic ????
- Few things i have done to my iron so far
- brother thinking of buying sportster advice please
- Xl1200n grip guards/wind deflectors
- Will these pipes fit a 2007 nightster?
- Rotella T6 motor oil
- 1992 883 Quiet Exhaust Options
- I have a 100/80 headlight bulb. Can I plug in my gloves?
- 2002 Sportster will not start
- Installed Kuryakin ISO grips
- Anyone have the CYCLE STANDARD 5-3/4" headlight?
- Upgrades for Iron?
- put upswept fishtails on the sportster!!
- Sissy bar light from the battery
- I really like my Sportster....
- Rear Shock Question
- 1200 to 1250, worth it?
- DK Headlight relocation help?
- Way to go!
- commander II tires
- 2.2-3.3 Badlander seat with a 4.5 tank?
- Packed up and ready to go
- New Damper Rods
- Help needed installing fork shroud covers..
- Bigger tank options for a 72?
- 17 inch rear wheel on a Nightster
- Puff of smoke during attempted ignition
- New to the sporty
- 1979 HD Sportster 1000 XLCH
- Handle Bar Advise
- Please help with front turn signal wiring
- evo topend iron bottomend. i have one
- Stupid Stud
- 2009 XL1200C Fuel Problems
- checking oil??
- Cool weather Jacket...leather, or?
- To all of you with V&H short shots and V&H big radius
- pipes finished
- Iron stock seat modding? worth it?
- For those with a wire tuck, zip tie the throttle cables or just let them stay free?
- Lean 2012xlc
- Dakota Digital low fuel light problem
- Need advice on a bike I wanna buy
- Tips for adjusting primary chain
- change front tire on my 91 sporty to a 16 inch
- DK Customs Coil Relocation & 1" Lowering
- Clock werks on a sporty
- Keystones or Friscos?
- Probably trashed my bike... opinions wanted
- Why Hammer over Wiseco?
- Frustrating
- 94 HD Sportster 883 How Much Transmission Oil Change
- Internal wiring of stock bars ... Anyone done it?
- Corbin or Lepera
- duel fire coils
- Guy too Manly for Sportsters apparently....
- Back rest or No Back Rest
- Lower leg reflectors
- Drive Belt issues
- 883 4 speed front sprocket
- 1250 5th gear pull
- 883 sprocket problem,help
- Commuting on a Nightster
- Iron fuel gauge?
- Range Rover Revenge
- spare parts build (take 2)
- solo seats
- Lollipops
- Sportster home made lowers (wind deflecters)
- HD swingarm bag issues; help needed
- Changing oil in a Sportster.........
- Reg oil or Synthetic?
- Tips for using craftsman red jack for sportster?
- Some pictures of my 883 slaying the dragon. 1600 mile trip, no trailers.
- Screaming Eagle air filter
- Thought I would share my Sportster story
- Z bars or outlaw style ... Anyone got em?
