View Full Version : Sportster Models
- High idle
- Kuryakyn Chrome Clutch Cable Adjuster Cover
- How are sportys in cool weather?
- What tuner to get?
- Anyone got one of those black headlight visor things?
- Advice on nightster shocks and sissy bar
- Safety Switches?
- Painted Helmet
- Roadster wheel on a Custom
- 2001 sportster 1200 oil leak
- short video
- Fuel Tank Emblem or Decal
- Wattage stat
- Cycle Shack S/Os
- Roland Sands speedo/headlight re-locator on a Dyna
- Help with Bassani sweepers way too lould!!!
- 48 1/4 mile times
- New Battery already dead
- Jack Points
- '05 883 Starting Issues
- Wife wants a saddle seat
- Sportster Exhaust Drag Pipes Sikpipes
- replacing the turn signal/brake light on the Iron
- quick question, tire fitment?
- Nightster vs 1200C
- Thunderheader rejet question
- 01 883 carb farts
- question about mid mount controls
- tranny wants to stick while downshifting
- Need Advice Quick Please
- where im at on my modern retro
- Lugging
- Iron 883 tire options?
- Clutch Tension Adjustment (repeatedly looses tension)
- 2006 Sportster XL 1200 Custom Carb Problem?
- Wyotech motorcycle program opinions.
- 100/90-19 replacement tire? HELP!
- harley hard leather bags.
- 1998 sportster wiring diagram?
- ok to leave larger jet in?
- 08-12 factory seat deminsions
- Going from 1st to 2nd and getting stuck in neutral
- Exhaust Removal and Installation
- Keepin my sportster
- This Bites
- new direction, now want fat front tire
- Iron 883 rear shock removal
- Cant find neutral
- dyna vs 1200?
- My 48, after one year
- bike starts sometimes
- Harley Shortster
- New Progressive Suspension
- 1987 sportster xlh883 1200 kit
- Having a hard time finding...
- oil leak around clutch cable
- Can you identify this sporty motor?
- (HELP) 2005 Sportster 1200
- Questions regarding 48
- xl1200x frame swap?
- Lights burning out
- My 2002 883 is having issues please help!!
- I finally did it.
- cv carb problems
- Oil and Primary Equipment Location
- 2006 Sportster XL1200C
- spring seat ?
- Stupid Cager
- Reserve???
- Iron 883 Performance Question
- SF Bay area locals?
- Pipes and air cleaner question?!
- Bad Gas?
- Exhasut Choices for 2003 Xl1200 W/forward controls
- Rear Struts
- Exhaust Question
- Addition to the Garage
- turn singnal relocation?
- Removing muffler
- Primary oil in engine oil
- Want open risers
- So they screwed up my order
- South florida
- Swapping Gas tank on a '09 XL1200C
- I have a 2003, Will 2004 exhaust fit???
- I have a 2003, Will 2004 exhasut fit???
- Back in the hunt for another ride
- Do Slip Ons need Gaskets?
- How do I install these mirrors?
- fork off
- what years are seats interchangable?
- Quick questions in regards to Air filter maintenance
- Aftermarket options for tail lights
- "top fuel ii"
- Good or Bad movea/
- Cobra Fi2000 PowrPro AutoTuner Installed !!!
- Lucky to be Alive...
- Back rocker box leak
- Are fat front tyres better?
- I need some carb troubleshooting assistance...
- Central Florida Dyno shops?
- flush mount caps
- While I'm @ it.... Kuryakyn Air Filter "rich"
- Clutch or Primary Or Tranny??? ahhhhhhh
- Mickey Mouse SH*t!
- any 2012 custom owners out there?
- test rides on demo bikes - my impressions
- Joker Machine Air Filter Turning Black
- Exausts for Sportster 48
- To drill out baffles, or not to drill out baffles
- Seems to have play
- My baby got a few upgrades!!!! :) (Before & After Pics)
- 2002 Sportster 883C Electrical Problem
- Bottom Mount Headlight Bracket
- Making your own exhaust?
- Iron in the Street class.
- Help please-pic request
- 2008 Nightster pics
- 48 proformance help
- Rear Rubbing Noise
- What to do what to do....
- Hot Springs Biker Rally
- Bulb acting possessed
- bars on my 1200
- Noob question
- Thoughts on first Sportster?
- Saying goodbye to my sporty
- Fuel light on after stage 1 upgrade
- Sideshots installation issues
- Anyone have window bars?
- Step by step front brake line swap and riser exensions
- bad battery?
- 2012 Iron in Blue
- Front Wheel Bearings
- Ironhead question
- A little cut & little
- neat sportster / skateboarding vid
- help 05 front brake bleed
- 1976 Sportster parts. Help for a guy I met.
- Spankin' new Sportster......
- Engine 883 to 1200 conversion vs stock 1200
- Sportster 48 2010 GAS tank Question
- another new guy exhaust question
- Converting from 3/4 axle to 1 inch axle
- Handlebars on my 48?!?!?!
- Cams+Heads complete!
- negative battery cable
- 2011 XL Spark Knock / Detonation?
- need help changing riding positon
- 09 Rocker Wheels on a 06 883c
- want to try something on my ride
- Windshield that actually works
- sportster 48 tank lift???
- Sportster??
- Rear wheel slide
- Harley problem
- Increased Torque 1084 Gear Set
- Riser bolts... check 'em.
- Sportster 1200R + PowerCommander3+ V-twin curvado pipes - anyone have a good map?
- Speedometerless handlebar clamp with dummy lights
- 2005 XL1200R - 1" Risers?
- Top triple clamp/risers
- missing on accel
- DIY Step by Step with photos: DK coil and ignition relocate with wire tuck, no lift.
- First Bike
- Burnouts are fun!
- ignition systems
- start switch threads ????
- Bar-end mirrors installation ? ? ?
- cv carb kit
- 08 Nightster Elec. Prob. HELP!!!
- My Next Sporster
- relays #s
- Mikuni HRS 42 on my 03, 1200C
- 08 Nightster Elect. HELP!!
- when does your oil light come on and is it too already too late?
- there's a nut on I-405...
- Wire cleanup without a tank lift.
- New exhaust / install and needs
- k and n help plz
- sportster performance
- Almost jumped ship.
- Tire Question
- Swap out foot pegs
- Couple of questions
- riding style and MPG!!!! My nightster only got 35mpg
- primary oil change
- From efi to carb????
- depression overdrive
- Winter Mods already ?
- Custom Cable nightmare....
- I have a choice: 2004 883R or 2010 Iron 883
- 07-09 sporty electrical issues
- new guy with downshift problem
- clutch makin wierd noise
- Remove Pulley Cover.
- What am I missing? Help!
- Weird Clutch Issue
- Show me your solo replacement for 2-up seat!
- Key problems.
- alarm or electrical issue?
- Got my first bike.
- Winter storage?
- Oil cap popped after I ride...
- The time as come for new fork tubes
- Stock Sportster to Retro Bobber - Step by Step
- Need to find another place for my License plate..
- Run your own diagnostics
- Rev Limiter
- Cycle World Sportster Comparison
- Dyna Guy here, looking for some guidance.
- Front fork springs
- Front cylinder is not firing
- Stator Out Riding Over For Now
- what is the widest rear tire i can fit on my sportster
- 2009 1200L Disturbing Clatter
- Tire help please...
- Yet another CV carb thread....
- My new bike is coming along....slowly..
- Front Brakes too sensitive?
- Differences between german and US nightster (according to Harley website)
- Bike's dirty
- Sportster 74 or 75?
- "Popping" sound
- Had a unique opportunity to be a good samaritan yesterday
- Iron with white wall tires and red spoke wheels (or any aftermarket wheels)...
- PIGSTER on my EFI 883 sounds great!!!
- Tires for my 2008 1200
- Ness Big Sucker air cleaner trim
- SE AC Install 2010 Nightster
- night glasses
- First time on a bike today, 2004 883R
- Plug wire reversal
- Cold Natured Engine?
- 1987 sportster xlh883/1200 kit
- Replacing Seat on The Nightster
- Stage one EFI download?
- Wrapped the exhaust, slip-ons and Xied's on the 48
- wheel bearing failure ALREADY- 24K miles
- 883 vs 1200 Frame? Noob Q
- 2008 XL1200 C - Fun to ride?
- Could have ended today.
- seat recomendations? ?
- Floorboards so far
- Solo bag???
- Clutch Lever
- Best Speakers for my ride!
- New to Harley
- Mobil 1 V-twin 20w50 = Smoother shifting
- Engine life.
