View Full Version : Sportster Models
- Fat Tire Setup--Wider Front Rim Width than in Back?
- Sportster Headlamp Visor Kit Item 68129-97
- Need Help Identifying This License Plate Frame, and Possible Replacements
- accident advice please.
- Sportster Transmission Help!
- Nightster fork boot problem ...
- Is the 72 a weekend warrior Harley?
- pics of the iron
- Pictures of your sportster 1200 low !!!!!!
- 48 wire tuck (no lift) problem
- Nightster before and after
- I stripped a bolt on my primary cover..now what?
- need help no start
- Worry about this spark color or not?
- Damn! I Really Need the 1250 Kit!
- 2009 sportster 883Xl
- Charging Issue.
- DIY Cosmetic screw caps?
- Harley going cheap route...
- Singing electronic fuel pump
- 1200 bbk vs stage 1 vs stage 2
- Anyone running a velocity stack w/EFI Sportster?
- 2012 nightster i just want highway pegs, do not have crash bar.
- Offset bearing cups
- Replacing 2011 1200n rear fender PITA
- Another Problem
- Whst do I need to make 72 seat work on a iron
- Broken exhaust mount bolts... Suggestions?
- A couple of ?? on riser installation
- 4 speed vs 5 speed questions
- About to give up..
- Customize Nightster Headlight
- Wrong oil filter
- Need really good instrucitons for replacing front lower isolator motor mounts..
- Riding sporty in heavy rain - dies
- Roland Sands King Apes 16"
- 02 1200 running fine, then suddenly coughs and sputters
- Waiting for shipments sucks. :)
- Recommended tire pressure...
- 2013 New bikes
- Mustang Tripper
- Brake pad recommendation
- 1986 sportster, led signals installed, lights not flashing/blinking, on steady
- Iron solo seat on a forty-eight??
- Looking for a back rest - 2000HD, Sportster
- 1200 custom advice
- my sportster
- Electrical Gremlins
- Cracked intake manifold?
- 94 sportster primary squeal issue
- 2001 1200XLC fixed
- Fuel Pak tunable?
- Power Vision worship. Read this if you want to love your EFI Sporty.
- oil from clutch cable
- DK Customs
- im a dummy please help
- Combo digital speedo/analog tach
- 2003 1200c died at 70mph on the Hwy
- 1200C light bar
- sportster help
- Harley Mufflers
- Side License Plate for XR1200
- Speedometer Spec On Fatbob
- how many EFI sportster 1200 guys here have a stumble at cold? video inside
- 2012 nightster: how do you remove the front turn signals?
- Burning Smell, is it normal?
- WWYD with my 04 sportster?
- Radiantz Tail Light / Brake Light LED's Too Bright?
- intake filter mod
- Sportster Wheels, 2002 vs 2012
- Anyone with burly narrow 14" apes on a iron?/what are some cheap/free mods
- Indian Larry Sportster
- Newly developed oil leak from '01 XL1200C
- Drilling lower triple for headlight
- coil/ignition switch relocated
- 883C acceleration problem
- What is a "swing arm" ?
- Which Service Manual do I Want?
- What sounds like a serious problem
- Headlight install question
- 2009 Sportster 1200 Custom recall (fuel filler neck)
- 1200V Seventy-Two V&H pipes bluing
- Best upgrade to front suspension?
- Are 48/72 seats interchangeable with the Iron/Nightster?
- quick question?
- Would anyone trade in their Sportster 1200C for a Fat Bob?
- Criss Angel "Insane" Sportster
- No 2013 Nightster?
- Good set of small rear fender mount turn signals?
- Detachable Sissy Bar Help
- The HD site has been updated with the 2013 bikes
- 2013 HD Spring Seat
- Khrome Werks vs. Cycle Shack Sound Off
- Strange electrical problem with running lights
- Long Ride shield
- Still coughing through carb along with other problems.
- Spring Plate: Why is it there?
- UK riders check out The Trip Out
- DK Customs Thunder Torque Inserts Review
- Warming up Carb'd Bike
- 4 months and the iron is gone
- 1200S Ignition Coil: OEM vs Aftermarket
- Clutch Spring Plate
- A Sweet Seat for the 72...
- Leaking after service, HELP identify
- Starter Issues
- 2008 XL1200 Leaking Head Gasket
- Quick detach rack locking
- So I got this new headlight...
- thinking about trading in tomorrow
- ignition module
- michelin scorcher tires
- Saddleman saddle bags
- These pipes look sick and sound nice
- What size z bars to buy??
- New tire's
- You know I hate to admit this (pics)
- Sportster 48 tuning,torque cones vs baffles??
- 10" bars, need new lines?
- cam gears
- new intake, oil blowby coming out of filter, will this k&n intake help?
- Headlight not working after re-wire
- Replacement foot pegs for 48 and 72?
- looking for right sissy bar.
- Smart Security Chirpping
- What's involved in doing a coil relocation ?
- Passenger Seat
- Installing progressive 412's-HELP
- Sportster Pegs
- Rear wheel
- Prison Headlight Cowling ???
- How do I remove this fitting?
- Limiter??
- 250cc to 1200?
- SE Slip-on for 2011 Sporty 48
- Softail frame
- Let's see those customized superlows
- I went to the dealer and ended up swapping my Sundowner for a Mustang.
- $4k depreciation in the first year, wow.
- Fuel milage again
- How many Sportster/Jeep owners out there ?
- Slow speeds in first gear seems wrong??
- Graffiti Removal...
- had larosa solo bag for 2days, got rid of it for the HD oem bag WAY BETTER
- Sparkplug pics...before & after PC-V
- rough craft pipes 'ouch'
- coil relocation kit
- License plate fender holes - how do I fill them?
- 04 exhaust on a 2000?
- star shaped wheel
- my harley is burning oil to fast 2012 sporster 1200 model 72
- Carb jet question - which to use?
- gas tank
- Memory Foam/Gel Stock Seat Kit
- Lower 1200 Custom?
- 2012 "48" headlight problems
- bending the stock plate mount back?
- mcpartsoutlet.com
- Brake light stays on...
- Trouble with my '07 1200C
- Any update on DK Speedo Relo??
- Hollywood handlebar on Iron?
- Fuelpak AND X14ied's??
- Help! New pipes and air cleaner..
- Turn signals/horn not working
- Direct Harley Parts
- High Miles on a 1200?
- New seat!! What do ya think? (Pics)
- 2013 forty eight pricing
- 883 to 1250
- short shot baffles
- VIED worth the extra?
- 883 clutch
- Screaming Eagle High Flo air filter
- Sissy bar for 06 1200C
- Part Compatibility Question
- Can someone with sportster custom take a riser measurement for me?
- DIY Qs: tank relo bolts and sissy brackets
- No 2013 48?
- 2001 1200XLC Head misting oil
- superlow 2012
- 2012 72 and 2010 48 tank lift, coil/ignition relo
- rear passenger peg question
- Anyone whose got a their turn signal relocated help
- Seller on ebay Selling Forward Controls $210 Shipped.
- Looking for gloss"vivid" black front turn signal relocation brackets
- 2003 Sportster 883r?
- Need help with finding an A/C
- Clutch adjustment screw?
- '09 Custom handlebar options
- edumacate me on pipes please!?????
- wierd problem today 2012 sportster with v&h short shots, hesistation WOT first gear
- Upper belt guard removal
- Vss?
- Lets talk bars
- What are the common nightster problems
- Need help on a 73 guys
- Sick Saddles 72 Solo Seat Review
- need serious help and opinions
- Factory HD Paint Question
- Outlaw ax-30030 helmet
- V&H shortshots
- installing passenger pegs
- Street Glide Air Shocks with Rigid Saddlebags
- LEO encounter
- Project 2008 Sportster 1200n Club Bike Build Ventura California Style
- Help! Brake light works but tail light doesnt
- Quick Clutch Question
- Anyone Running a Gunfighter?
- V&H Short Shots on 87 sporty
- Erratic speedo and speed caused bad ignition module?
- Transmission question (metal on metal sound)
- Does the Power Vision autotune?
- New Pipes without Stage 1 upgrade
- Stock 48 bars to Biltwell Keystones. Easy job?
- Can I run a solid 94 rear wheel in front too?
- Is it possible.........
- Detachable saddlebags, backrest and luggage rack...
- Good Mechanic for XL1200n in Atlanta,GA
- Rush pipes on XL1200N
- Studded Sundowner Seat
- Small Crash
- Neutral sensor switch - part no.& price
- gauge help please
- i need help fast
- licks solo bag with passenger pegs ?
- Sportster on the bench
- DK Custom 2" Riser Kit Stock Iron Handlebars
- coil relocation
- V&H Big Radius 2-2 and mid controls on forty-eight..doable?
- paint scheme?
- Some problems after tank lift and coil/ign relocate.
- front fender off a 2011
- Shorted the battery!
- rebuilding a project
- 2009 883 spring seat
- Rear tire alignment
- '72 ECM question.
- Relocated my coil/ignition and lifted tank on my 72
- V&H Big Radius 2-2 with forward controls?
- tank lift coil/ign. relocation
- Sportster model comparison
- 48 owners - low fuel light
- Need help please about exhaust pipe color
- King and queen seat on a nightster?
- Check out this link..
- Custom Ear Plugs
- Longer fork tubes???
- Power Commander Vs. FuelPak
