View Full Version : Sportster Models
- help
- '08 1200 Custom Stock Riser Removal
- Power vision help
- Engine running rough or surging at lower speeds
- inner tubes
- EFI Quick disconnect
- Whitewalls or not?
- My '14 48 w rear sets
- new noise..97 1200c.......clutch?
- Jibber Jabber
- Sportster Lowering Kits
- 48 Seat or ???? on Nightster
- 2 Months out of warranty :(
- 04 883 XLC won't start
- Any MD/DC Sporties with rearsets?
- Early Season Oil Leak
- I luv dk customs products!!!
- (Problem) - Extending Upper Brake Line - 2014 48 w/ABS
- Fair Dealer price on 2014 Iron 883?
- my 2013 iron hardtailed
- Biltwell EXFIL-7 Bag
- Nightster No Start
- Battery killing engine power?
- What Spark Plug Wires? '03 883R
- Wiring help
- Odd Idle Mix setting
- Seat question
- Module turn signal blinker brake light unit
- Hell's Angels & helmets
- V&H Straightshots/3"Slashcuts
- Baffles (dbkiller) for Spitfire Motorcycles turn-out exhaust
- new cables on my 05 883 sporty
- Vance & Hines Twin Slash 3 Inch Slip-Ons quick question
- Would this make my 883 sound more throaty?
- Sportster facelift
- Bad tune?
- Engine Guard and Fog Lamps...
- 98 1200 sporster situation
- Forty Eight fender chop without frame chop
- Chopping my 48
- Nightster 2008 issue: rattling
- gas light on with full tank
- 2014 Brake and Clutch Levers
- 6" or 8" rise? Help
- Can you help me design a seat?
- Fat Bob Dual Headlight vs Stock 48
- chugging
- Tour-pak luggage / Solo trunk
- Bad Squeal!! Please help!!!!!!
- Replacement shocks for sportster superlow
- Headlight
- XL2008c Problem with codes
- New rider choosing a bike
- My Sportster is big enough...
- pissed off
- Rear brake pedal adjustment
- Rear fender chop & brake/turn/sigal module
- Figured it out, headlight fairing on 48
- seat & handlebar conradiction...
- 8000 mile trip journal thread!
- clutch lever differences
- Axle mounted license plate question
- 17 year old tires..safe?
- Heated seat install
- 2010 Iron relays ?
- Plug reading
- Torqua clamps torque spec and exhaust leak on cycle shacks
- Looking to get different bars on my Sportster
- Custom Dynamics Mini Beast Air Horn
- Fluid levels on 883
- Query on V&H FP3 on Iron 883 ...
- Two weeks old and bye bye Harley
- Decel popping after coil relocation!
- 2007 Sportster 1200C - Died in neutral, then solid oil light?
- UK 2013 Harley Sportster 883 Iron - Build Thread
- Rear wheel swap question
- shock swap
- Road 6 Custom
- New Fat Bob Wheels on 48?
- New exhaust needs?
- Baffles for an iron 883
- HELP ! i know someone is smarter than me
- Looking for a good 2 into 1 exhaust. Suggestions?
- Need help with axle bearings
- Fuel issue..
- Screaming Eagle Air Filter Kit Install Help
- Installed Air Shocks
- Nightster "Frankenstein" Trike
- Iron brake line length
- First mods
- Tank Lift + low Fuel Indicator not working?
- LAF pipes
- UK 2012 883 Iron black stock exhausts
- Combination Digital Speedometer/Analog Tachometer-70900100C
- Sportster and wind..
- 2013 model 72 headlight bulb
- What's a good alternative to the OEM ignition switch?
- New tires for my 883c with 21" Front
- '04 Load equalizer??
- Just curious
- Sportster clutch problem
- getting the shift off
- NHRS 88" and 90" big bore kits?
- 1K check
- Cant remove air filter? Help
- Speedo relocation on a budget.
- Further back seat
- Dead batt
- Need a very knowledgable mechanic, ignition issues, 1200S
- Want a thicker rear tire on your sporty?
- flipped mirrors on 2001 883 hugger?
- 2014 Harley Sportster 883 - Squeeky Brakes
- New Taillight Wiring Help
- brake lever question
- New 48, oil light on ride home
- Cafe sportster done-sort of
- 8" Chub question
- Harley Nightster — SuperBrace Installation Video
- 99 dyna wheels on a 97 Sportster?
- Horn Relocation Kit Questions
- My review of Garmin Zumo 665 GPS unit
- Stupid kids...
- Slippery Seat
- Chopen my iron
- Banjo bolt question
- Wobble on a 2008 Nightster considered normal?
- Lets see your 170 rear tire on the sporty
- seat for my sportster XL883L
- 48 front end for an Iron?
- Speedometer Mounting Bracket
- New to the Harley World and need shock help
- Paint is back
- Bad IAC motor?
- Starting Issues Found (I Think, Pics) - Need Best Fix
- Extending the Custom Riser
- 1988 Harley Sportster XLH1200
- Turn signal problem
- Boring 883 to 1200.
- 2014 48 - my battery getting drained over night
- Sportster Forty-Eight - Northern Ireland
- woke up to ride and...that ain't happen
- My worst fear happened while installing new rocker box covers.
- 883xl - what gear?
- Vibration / shudder under load?
- Help a Newb out... Possible wiring issue
- Sunday Ride
- 12" vs 14" apes?
- Starting problem
- sportster 48 2014 error??
- Firing up the 883.. choke vs throttle lock?
- Cruise control Throttle mate
- Lowering Blocks
- My mods complete...nothing special, but she's mine and the way I like it!!
- Tyre pressure. Anyone running Avon Cobras on their 48?
- Dream the Impossible Dream?
- Front brake updade looking painful on the wallet.
- New XL1200T all set up now
- Do foot boards make much of a difference?
- Just a random post from my day on my sporty
- Rear Brake switch 2007 883XL
- I'm stuck, bike won't start.
- Primary/Transmission Lube 2012 Mod 48
- Looking for someone in the Memphis area...
- First Sportster! What's Up HDForum
- My Sporty won't start?
- Clutch engages late after adjustment.
- New Harley Owner: Give in to the Nightster
- Installed CVP Premium Carb Kit Bike still runs like hell
- Looking at a 79
- Front end wobble 08 Nighster
- Funny Noises - Are they normal?
- Poor mpg after changing from a 27T to a 30T pulley
- True story, Penis Pump vacuum to drain gas tank
- DK Custom WOLO Horn
- detailing question
- will it fit??
- 99 dyna wheels fit 97 sportster??
- 09 Nightster burning oil smell on decleration...
- DK tank lift, coil and ignition relocation write up?
- Rear fender protection
- Suggestions for a cool looking Sissy Bar?
- 1964 Sportster XLCH kick starting and sputtering questions
- Engine Guard and Forward Controls
- Troubleshoot amp & speakers on Sportsters
- 2014 vs 2013 iron 883
- Seat #2 (or 3)
- 13" floating rotor?
- big radius pipes drag
- 88 ci Sportster is finally finished!
- Iron 1200 Upgrade Kit Problems
- bassani sweepers for 2011 sporty 48
- Upgrading Shocks
- and now for something completely different...
- Need everyones opinion, please vote
- What to look for in older sportsters
- noob - needing assistance with apes
- best tuner
- Sportster Front Turnsignal Question Part 2
- Pinned Ohio
- On the Subject of Loud Pipes....
- power vision vs. power pro
- Will heads off a 05 1200 sportster fit on a 02 1200?
- Oil at bottom of open A/C
- Black tires with white lettering...How?
- Engine Guard Installation
- sportster 2005 xl headlamp issue
- Chain conversion
- 2012 Harley Iron 883 Misfire
- Rear rotor and belt pulley info on 2012 48?
- Loud pipes: waking the neighbors?
- Circuit Breaker Question on 2003 Sportster
- V&h side shots or v&h short shots???
- just bought a nice bike... now it won't start :(
- 2009 Sportster 1200 problem
- The 48, quietest Harley I've ever heard
- Air filter spitting sound?
- Something similar to the old 900's available still?
- Upgraded to air shocks on my 13 Iron w/pics!
- Portable tool kits...
- Big Round of Mods complete
- Let me get this straight...
- sportster 2013 seat
- Wiring Extension Kit Length
- Saddlebags big enough for a laptop
- I want Black Denim so bad but I'm reading mixed instructions ...
- Headlight replacement and remounting
- Sportster buying advice (2000 model)
- finally got one!...
- 2011 sportster 48 exhaust
- Sportster saddlebags Live Free Motor Stylish
- Now she is all DONE ..
- 1996 fuel tank options?
- Loose sidestand
- New 48 - Handlebars and Seats
- DK Customs external breather help!?!
- HD Solo Spring seat on a LaRosa Seat Pan?
- Sputtering and Hesitation on Acceleration....bad gas?
- Goodbye DrainPlug
- '03 883R - Right Turn Signals Not Working?
- Big Radius 2-into-2 Pipes... thoughts?
- Paying taxes questions.
- Roll bar on XL1200T HD
- which rear brake pads
- New bars installed! Love em
- Clutch Shell for '04 XL1200C
- Boom audio 77117-10 headsets
- Help - New '12 Sportster 72 = Broken Shoulder
- Nightster build
- Baffle on catted pipes
- Headlight fairing on forty eight??
