View Full Version : Sportster Models
- Exhaust wrapping
- 2008 vs 2013 Manual Question
- Wheel alignment
- Need help: No School Choppers '33 Style Tail
- purchasing
- Chopped Rear fender
- Cam upgrade.... Any thoughts"
- Sporty pics from Timonium
- ironhead build almost done
- 96 XL 1200 custom, choke question
- Don't want to use burly 12 kit what length over stock would be safe?
- 883c detachable solo rack mount kit difference?
- 2011-Later XL883L Replacement Tire(s)
- Relocating the ignition and coil
- clutch cable broke
- Transformation
- coil relocation?
- Custom?? what do you think
- advice for 883-1200 conversion
- Small Tool Bag
- Oil lines from oil pump routing 99 sportster
- Hollow riser bolts?
- Suction Cup mount on tank
- Is there a good "middle of the road" shock setting?
- Hazard Flasher Question
- Faded rear fender
- Caught A Small Break For A Change
- been a minute, updated Nightster
- 21" 40 spoke front rim options
- Stock 93 wide glide forks on 84 sportster
- V Twin Oil Needed in XL1200 ??
- Sundowner on Nightster
- Lost my only key...
- Re-Joining Loom
- Is a dakota digital gauge really just plug and play??
- power vision and short shots
- DIY Sportster Highway Pegs
- turn signal canceller not blinking
- Air Filters... CFM... What's the verdict?
- Tank Chrome Trim
- just installed my Supertrapp Supermeg 2:1
- Nightster side stand fault code
- Pipes, Air Cleaner, Tuned...
- intro and choices
- Stage 1 = tuner question
- 2013 '72 turn signal question
- best price on rush slip ons?
- to glue or not to glue?
- Sikpipes? Anyone have any experience with them?
- Thunderheader on a "tall" sportster??? pics?
- power commander question
- 2013 Iron 883 Hesitation problems.
- Nightster
- Iron With Apes?
- Lighter footpeg mounts?!
- We all like saving a buck with genuine HD products
- Sick Saddles Fork Covers (for 48)
- Ironhead not starting!
- Ignition housing question
- Anyone Interested in 883 Iron Engine Parts????
- spitfire pipes
- Rocker covers question
- new to forums , back rest question
- Chopped fenders and tailight wiring
- For the record, Don't use car headlamp bulbs...
- Wanting to get some forward controls
- Request help with ground wire.
- Figure machine air cleaners
- Just put in a K&N A/F, about to change exhaust, do I need to remap?
- 2009 and up chasis the same?
- Iron 883 drag bars
- Height and forward controls
- Poor performance when cold.
- Rigid Sportster head pipes
- Python to Supertrapp, fuel system tuned?
- forks
- 08 Nightster leaks
- Anyone have the roland sands slant exhaust? Need something that doesn't scrape..
- Wide glide wheels on sportsters
- Open or Closed LOOP ?
- Saddleman Americano
- Stock Rubber Sporty Foot Pegs
- new to 883
- 883 to 1250 conversion question
- Speedometer/VSS issues with check engine light
- The Bike won't start,2007 sportster, missing something
- 1995 sportster 1200 issues
- First actual ride on the Sporty
- rocker box help please!
- 1989 Sportster Transmission Issues (Novice - Need Help)
- does this make sense about tuner??
- starting problem
- Sportster 48 Fairing Options?
- Addition to my 09 1200C
- Air Up grade..
- What do sportser owners look like on their bikes? Pls post pics
- 89 1200 Tank Question
- rear fender
- laced wheel question
- New Sportster well knda
- A few upgrades to my Sporty Roadster
- Anyone know what brand shocks these may be?
- Easy wheel question
- Brake Fluid Question
- Help on a Dealer question
- Urgent?
- Leather fork wrap/gaiters
- Securing fork boots?
- Mini-apes on 07 XL1200L
- No cold weather start
- My latest mods: new wheels/pulley
- 2006 Sportster XL 1200 Starting Issue
- lower sportster
- xieds or tuner??
- DK Custom - DIY How To: Trap Style Brake Lever
- Diy bmx pedals
- DK Custom - DIY How To: Installing Trap Style Shift Peg
- Rear Turn Signal Lights
- Just ordered my Builtwell Keystones, need shorter cables, are stock length best?
- Transmission is slipping.
- Resell value on stock vs. customized
- Putting together a tool kit
- Missing Riding
- 2005 bob shocks
- garage and tools
- Ever Smoke an Big Twin Evo or Twin-Cam?
- air shocks
- Jack Daniel's A/C Cover
- Gas mileage question
- Help, Constantly running out of gas
- Exhaust question
- 2013 48 base decal sticker plate
- what bars are these?
- Kuryakyn velocity stack air cleaner?
- Replace tank decal! Do you have pics?
- still waiting :(
- Alternate A/C to SE for stage 1
- Changing controls: Mid to forward?
- Four legged Harley Riders
- Rubber foot pegs
- long time no see
- New owner quick question
- cutting out at half throttle or more. please help
- Scotchbrite Chrome
- oil cooler?
- Installing intergrated tail light, advice needed.
- 2 up seat for a 883 lo
- Updates to the Iron
- Anyone know anything about the Comfort Flex Shocks?
- Finally getting to ride
- 2013 Harley 48
- Help on a transmission deal ring?
- EFI Fuel Pumps
- new here with a question????
- Winter rat project
- think i found some handlebars to replace my friscos
- riser the same on superlow and custom
- drag bar question
- Dual headlight/Dyna T-sport Fairing on a Sporty
- Snow Ride
- Great support
- 2011 883 to 1200 - Gearing
- First ride, first impression of my2013 xl1200c (+ pics)
- Paint codes ?
- Bolt on Block/Head Temp Gauge.
- Passenger Pegs.
- Finally Got My Sporty
- Quick Air Filter Question
- Bongs on mufflers to mounting bracket
- Is this a stock exhaust?
- What Exhaust is this?
- 2009 nightster motor build
- quick removal of rear suspension?
- Custom Paint almost done
- Removing front end from frame on 94 sporty
- Updated Nightster Build Blog
- 96 Sporty with FXSTS springer front end
- Looking for a little more power..
- ohlins shocks
- Running 12 in H-bars on Sportster , which cable need stretch ?
- Enter: Semi-Drunk Rant. 883 vs 1200
- Andrews Cams
- Thinking of going to a 21 laced front wheel, advice and suggestion wanted
- what is this?
- Got a gas question.......
- Converting my narrowglide?
- New 48 to the Stable
- Starting to get pissed - THUNDERHEADER
- Unusual handlebar pics
- 90 Cubic inch upgrade
- Does it ever end?!?
- Any similar pipes to these?
- Pic Request: Mustang Fastback Seat On Iron or Nightster
- Le Pera Cherokee Seat on 72!
- Factory security malfunctioning
- 1958 Sportster help
- Removing Tank questions and insight please
- Polishing Aluminum?
- Crying Over Spilled Fuel; Denim Black Tank
- Battery Charger
- Will 2006 Sportster Mags fit an 03?
- foot clutch and jockey shift
- Mustang solo seat
- Question on Stage 1*
- 72's
- 1976 Bicentennial Edition Restoration!
- New Sick saddles seat
- Biltwell Frisco Bars on Iron 883, any pics?
- Will these bars fit?
- part numbers for carb 883 to 1200se kit
- OEM Saddlebag Help
- front wheel question
- What to do? Tank ideas?
- 71 Ironhead rocker cover oil leak
- Sportster swing arm removal
- 1990 Sportster 1200
- Changing 08 1200c stock seat
- issues with sporter LED tail light and HD licence lay back kit.
- Paint concepts - photoshop
- Wheelie on 883? What is the secret?
- Finally got another Sporty (Iron)
- Oil change question
- problem installing turn signal relocation kit w/ license layback
- Fram oil filter on a Sportster
- Softail Fatboy Tank on a 2003 Sportster
- tuners?
- Just brought a 2011 Sporster Custom
- DS forward controls
- all you want to know about wide tire for 48
- bummin.......
- Not Done But Getting There.......
- The wait is over, I proudly present to you my 1200c!
- Seat and Tank question
- waving?
- Can someone help me out please?
- How to *TEST* your XIED fuel management plug-ins?? *Tutorial*
- replace all gaskets and o-rings whike im in there
- Can I use a 1" axle?
- want to buy stock sportster rear fender
- Le Pera Bare Bones LT Solo Seat Installed + How-To
- 72 cleaned
- 1974 ironhead
- 2007 Sportster Nightster with 3000 mile???
- 04+ Sportster seats. What's the diff?
- Air filter noise?
- Diff between '00 & '06 rear fenders
- loud long staggered pipes
- Fat tire conversion
