View Full Version : Sportster Models
- Harley drag bar width?
- EFI Tuner spec's
- Licks z bars 10'
- Sportster suspension and Handling,,,,,
- O2 Sensor
- Nightster w/bad ECM. Now what??? :(
- Burly = CRAP
- Trip from Phoenix to Sierra Vista
- Air cleaners are expensive!!!
- Tips for changing kickstand spring?
- Broke Brake
- wrapped short shots
- Exhaust wrap then removal....
- ****Nightster Pics****
- Fork Brace,,What It's for
- New ride new to harley
- HELP !! electrical---wont start
- New to Harley's and Forum but not new to riding.
- Air Cleaner... Kuryakyn
- .....is this thing on?
- Nightster to Cafe'ster...Pics
- Fuelpak installation. :(
- Speedo question
- Bags
- licks mirrors flipped
- Buying used, 2001 HD XL888
- From stock to mine!
- Floorboards
- Windsheilds
- Smoke Taillight+Turn Signals
- Mustang seat won't fit advice needed ?
- Difference in sportster models?
- Forward control help?????
- Need some advice on bars for the 48
- Fuel management with v&h straight shots??????
- I need a passenger seat for my bike...
- Mean City Cycles?
- Just installed V&H short shots with quiet baffles
- 1973 Sportster XLCH Electric Start Conversion
- Welding
- Seat Recommendation??
- Poor man's fender
- I'm in hell
- Would the handle bar for dyna wide fit my 09 sporster custom?
- straight pipes on 09 nightster
- 2009 Nightster Exhaust Suggestions
- Well, at least it's on sale! Geez!
- Bobber in progress!!! (project in the making)
- Bassani Street Pro
- About an 09 Nightster
- Fork oil
- changing grips?
- Derby Cover
- Anyone running an hid's??
- My new SuperLow
- clutch and brake lever replacment on a 05
- 883/1200 conversion underway 2003 SPORTSTER
- Roland Sands Venturi Air Cleaner 5 or 7?
- new headlight ideas?
- New 1200 Custom
- Slow cranking only in warm weather.
- Rear axle socket size on a 92 Sportster
- Heat resistant rust converter
- Looking for a smaller battery
- 61' sporster
- No stupid questions? Let's see..
- Solo Seat
- Sportster Primary Fluid
- Helmet
- broken fuel pump plug
- 1993 Sportster XLH greenish tint liquid leak?
- Headlight bulb number
- Chrome Fuel Tank Trim - 2011 883
- what gear do you run your 883's in?
- 2Up Riding on Sportster Forty-Eight Question?
- sportster trouble
- Need advice on new bike
- tow dolly
- HELP!!! Speedo question..
- Gas Tank Issue
- Need a Neat Sprocket Cover
- Battery Lesson
- Quarter Fairing
- Which dealer did you buy your Iron and how much did you pay in PA?
- east coast motorcycle resorts?
- Soon to be Nightster owner...
- Ironhead rear motor mount stud
- What gear do you wear?
- Fatter front tire
- Mag Wheels
- Front Wheel Spacers **NEED HELP PLEASE**
- Lowering rear 1"
- 2003 XLH 883 spark plug gapping
- Crossbones stock seat on a 48?
- Newbie w/ an Iron..
- Nightster Risers?
- Security Lock Help..!!!!!!!!
- I think I'm done (for now) - pics
- New rigid build.....
- Engine Knock??
- Will not start seems like weak spark
- Nightster engine noise...probably just paranoid
- Red line V-Twin transmission oil with shockproof...
- Vulcan Triples
- 06 custom ?
- Slips, air, and remap
- Got a 1991 883 Sportster
- 2005 Custom XL 1200 issues
- Wifes new HD1 Sporty
- The One to drool over,,,
- Aftermarket Air Cleaner Bracket question
- Seat for new 2011 Superlow
- other than 20W50 oil in warmer climates?
- New Sporty for the wife...ok, me too
- Amsoil oil and filter change
- 99 1200 Sportster Mufflers
- Nightster 1200 Exhaust Issue
- 200 tire on forty eight
- 1st fluid change, this trans lube look OK?
- Georges garage exhaust stud remover or easy out
- Anyone have a V&H fuelpak?
- Need help with my front brakes after pad change
- front end
- Rocker Arm Cover Bolts Breaking
- dunlop or Metzeler ?
- '08' and later Chrome Screamin Eagle Heavy Breather
- Rush 2-1
- Plug wire change...
- New HD Sportster owner & Member
- 07 1200 XL Hard vs. Soft Mount Exhaust
- Anyone else fed up with spring weather?
- Bag for superlow without backrest
- Back problems vs. stock suspension.
- New some metal bending advice
- Nightster has NO spark
- Valve tappets
- Dakota Digital Temperature
- (help a new guy) what am I looking at here?
- Some Before and After
- Part number help
- Sportster shopping
- Clunk
- need quick run down for prim/tranny oil change
- LePera Barebones vs Reduced Reach Solo
- help with headlight removal
- Saddle for tall riders?
- crankcase breather
- Front Turn Signal relocation mounts - Flat Black
- Lowbrow Velocity Stack
- Pipe Bluing
- powder coating handlebars?
- Stupid question of the day: overinflated tire
- Side plates for 2007 Sportster 1200L
- Ordered new handlebars, how hard are they to install?
- Clutchless shifting
- Just bought V&H side shots with quiet baffles...
- My winter mods (lots of pics)
- Question about plug wire compatability
- Avoiding High Prices, Making my own parts.
- Help! Nighster headlight relocation
- New Windshield Installed - Man Am I A Believer Now!
- Hot Engine Temps
- -07 Nightster 480 miles. Extended warranty or not?
- Floorboards or Willie G's?
- A/C Question
- I'm bummin
- Can someone post what I need?
- Finally Done! 2011 Nighster mild mods.
- Big Sucker or VO2
- Hi everyone new member here
- Logic and Lubrication
- Different digital Speedo
- Anything He needs to know...
- sportster xl seats
- Will I Have Clearance Issues with Engine Guards?
- easy pull
- Exhaust Gaskets...grrrrrrrr
- Quick turn signal relocation question
- New to HDs, looking for opinions
- 04 883 xl oil question
- New rider, 2002 883R, carb tuning questions
- Snag with RSD bars on a 48!
- Kuryakyn LED installed
- Help
- Tight clutch?? 2010 Forty-eight
- Found bolt and don't know what it's for...
- Someone's on crack LOL!
- not sure what kind of air-cleaner...
- 03 Sportster Exhausts?
- Which bars do I have?
- "jerky" engine perf in certain specific conditions
- High Idle, Bad Gas Mileage, fouled plugs
- Frustrated! I have an exhaust question for you all...
- Fuel tank lift questions
- Iron fork
- 2:1 Blackoutt & Mustang Seat
- bent forks?
- Sporty exhaust baffles
- Un-stab-il... Ugh
- STEERING DAMPER/STABALIZER for an IRON
- Bassani FireSweep Exhaust Installed !!!
- how far can you push the forks down in the trees?
- V&H Sideshots with S/E Heavy Breather
- 1200 conversion ?'s
- 48 seat question
- Chopped/Painted Nightster - What you think?
- Sportster 883 fouled spark
- C&C solo seat problem
- Oil Leak - Rocker covers?
- Want to buy Black Nightster Tank
- 883 face lift
- Help/advice/pics for installing my lowering blocks
- German Exhaust on a 48 BADASS !!!
- Lookin for upswept pipes for 2011 Forty Eight
- Rush Slip on install problem
- Exhaust question
- Installing fuelpak iron 883
- Tire recomendations
- Front end
- pics of new wheeels and rk shocks w 250 tire
- got a sweet deal on my new tank...
- Installed a new LED taillight
- Is this the stock kickstand for a 09 Iron
- a couple of questions about 883...
- exhaust question
- 2010 883L Leaking after first dealer service....
- Where is the fuse panel (1989 Sportster 883 XLH)
- Forward controls/Air intake Question
- Electrical short
- Road King Shocks & Speedo Relocation Complete
- SE Stage I Air Cleaner Kit or RSD Venturi Air Cleaner Speed 5
- Upgraded my shocks
- Progressive Suspension Fork Springs Kit on a 48?
- Joker Machine Air Cleaner: Real Fitment? / Velocity Stacks
- spots on new paint
- Face Mask!
- Sugar Skulls on tank....
- some seat time on new bike
- iron, nightster and 48 guys?
- 2008 Nightster/Bobber (in progress)
- Big guy on Sportster question
- Rear turn signal
- New to me ironhead
- Yellow light comes on - total mystery why
- No more "clunk"
- Pics: Installed Dakota Digital Speedo - Side Mounted Fork Bag
- Dynotune cost
- Changed oil now no power
- New dude
