PDA
View Full Version : Sportster Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298
  1. Mods to my 883 Iron / Pics
  2. Iron 883 stock rear shock question
  3. Loving the Sportster
  4. Transmission fluid route question
  5. 2 questions/recommendations
  6. i hsve a 1998 1200s wirh 4 plugs on the head s. had my 14 year old rout battrey went to put new one in there is hot and negative wires but also a smallar wire goes to the battrey what sibe pos ...neg
  7. Strange Electrical Problem
  8. Need help from a '16-'18 Roadster owner please
  9. Xl1200cb 2017 exhaust
  10. Blue flame out of only 1 pipe
  11. Intake popping
  12. Best tire prices??
  13. 12" ape hanger cable extensions
  14. 48 sportster 585 cams
  15. Brake fluid question
  16. Oil temp question
  17. Charging
  18. Where does these two wires go?
  19. New or Old?
  20. 97 sportster 1200C intake popping
  21. Tin Set Interchangeability
  22. Stock bars on custom sportster 2011 curved inward to apear like mini bikini bars has
  23. I'm getting some popping noise from my engine
  24. fork upgrade
  25. 1997 Sporty 1200xlhc sweating oil from rocker box. Is that normal?
  26. S&S Carb / Air Filter question
  27. tail light running light not working but brake light does
  28. Rear tire size for a 2012 Harley Davidson 883 Super Low
  29. Nightster OEM air filter
  30. Slgght oil. Leak comin from rocker box
  31. Acm short shots any one tried them?
  32. How to test a new seat?
  33. 1997 XLH Brake Light Stuck “On”
  34. quality forwards for an '88 plus excess shifter play
  35. New bike and new rider!
  36. New rider, first bike need advice.
  37. Forty-Eight Battery cover
  38. New Le Pera Cherokee seat on My 48!
  39. Burly Bars Cable Install Questions
  40. Best Oil to use in a 09 sporster?
  41. Sounds like a siren
  42. RSD Sportster 48 is Masterfully Designed
  43. Speedline Bars
  44. Hello all
  45. 2003 XL 1200C good buy?
  46. Air filter compatibility
  47. 2005 883
  48. Sportster leaking charcoal?
  49. Mixing tires
  50. Sportster 48 handlebar riser 49mm fork
  51. wide glide saddle bag removal
  52. BDL vs energy one high performance clutch?
  53. Iron883 primary oil question
  54. HD Tranny issues
  55. Upgrade Rear tire for 2017 iron 883
  56. Sporty missing/ jumping
  57. Samson Rip Saws Exhaust
  58. Finished my project - New paint & Accessories
  59. Battery or charging system problem
  60. oil check
  61. 2005 Sportster XL1200C Turn Signals
  62. ? On forward controls
  63. Clutch lever suggestions
  64. Im about to do the 1200 conversion and I need some advice!
  65. Carbed sporty won’t stay running, intermediate
  66. 76 Frame Help
  67. Hi; FP3 vs dyno tune
  68. Lower engine case leak.
  69. Some good stuff from Hammer.
  70. Rear brake light question
  71. HD Sportster Service manual cost
  72. Retread
  73. Wiring turn key ignition switch
  74. Sissy Bar w/ Pad
  75. CHEAP, small, extra fuel (1/2 gallon) for 48
  76. Signature Shaw Speed: Harley 48 Custom
  77. Rocker box to head torque on a 1977 Sportster.
  78. Primary inspection oil leak
  79. Speedometer Bezel Replacement
  80. Oil feed and return lines replaced tonight.
  81. Fuel leak on the carb
  82. Windshield
  83. '06 rear master cylinder upgrade
  84. headlight options (can't see)
  85. Shifting
  86. 2013 Iron 883 with Bad Oil
  87. Need headlight harness
  88. 2008 1200 Won't start, electrical issue.
  89. 2007 Dyna Low Rider vibrates a lot
  90. Sportster won’t start
  91. Fuel line clip?
  92. Front a Turn Signal Bracket
  93. 2016 Iron 883 Electric Problem
  94. LED Headlight Issue
  95. foot clutch adjustment/ 48 FL
  96. 16 inch rear rim fitment
  97. Changing tires, how much time have you been charged?
  98. fatbob tank on 1988 Sportster
  99. Biggest rim on a nightster 08
  100. Lifter noise or knock due to exhaust leak?
  101. Idle, but wont run
  102. 2014 forty eight no fob(not battery)
  103. Wisamic 5 3/4 headlamp problems
  104. 2004 Harley Sportster (883 rebuilt to 1200) sputtered and died several times, started back up fine.
  105. Iron 883 instrument panel
  106. hammer performance 1275 kit
  107. 26 tooth front pully
  108. Sportster 1200 elevated jetting
  109. Signal Help Appreciated
  110. Changing stock low speedo to custom speedo
  111. Oil light
  112. Test 1990 oil pump?
  113. Help with LED Halo headlight replacement
  114. 1981 Sportster Will Not Idle Down
  115. Fitment
  116. '06 XL883C seat post
  117. VO2 Cage Fighter or VO2 Rogue
  118. HD 48 and Corbin standard solo
  119. Nightster Hiccuping on Gear Change
  120. 09 1200c low fuel light
  121. 2007 Dyna low rider odometer not working HELP
  122. Mini Apes on 2000,1200 sportster
  123. Engine rattle
  124. 2005 XL1200C Bad Gas Mileage
  125. India-Built Custom Iron 883 Looks like the Future
  126. P0132 code show up when auto tuning fp3 vance and hines.. help!!
  127. Oil change link
  128. Rear brake piston
  129. Sportster 48 engine bad acceleration
  130. Help lowering an Iron.
  131. 1561 mile road trip!
  132. Handlebar speedo
  133. Rocker head gasket replacement cost?
  134. no rear brake pressure, 05 xl1200c
  135. Diagnostic code and part number
  136. Vibration
  137. 48 dies after a few seconds and blows smoke from intake🤷🏽*♂️
  138. V&H FP3 missing firmware
  139. Wont start without half throttle
  140. 883 to 1200 kit
  141. Man i love my bike!
  142. Looking at my first Harley Sportster
  143. Getting there...
  144. turn signal
  145. My 48 mods
  146. I jumped ship today...
  147. V&H pipes
  148. speedometer,instrument lights, turn signals
  149. Checking belt tension
  150. 1200c
  151. starting issue
  152. Sportster pipes
  153. Need help identifying part
  154. Cranks but wont start
  155. battery
  156. 1986 Sportster lost all power
  157. Bitwell Chumps or ????
  158. Axel nut torque ?
  159. No longer own my Sporty
  160. Oil change
  161. No start no crank
  162. Major mess up. A little while trying to slide the controls on, my question is now tha
  163. What's a reasonable offer?
  164. front suspension - looking for feedback
  165. Quest for the best not so loud exhaust for Iron 883
  166. Do I need anything else for these Handlebars?
  167. RSD and Technics Collab for Perfect Project
  168. Too much oil rocker head leakage
  169. Oil Leaking from Air Cleaner
  170. Front Brake Cable ?s: New 7" bars
  171. The perfect H-D (for me)
  172. Brake Upgrades
  173. speedo
  174. speedometer on a 05 sportster 883
  175. Biltwell Maynard bars
  176. IAC cycling
  177. New Sporty and it's marking it's territory
  178. Rough Crafts' Apocalyptic Forty-Eight
  179. Rejetting
  180. Steering Head Race Puller
  181. 2015 Iron 883 HELP calling all HD Sportster Experts
  182. Sportster 1200XL won't go past 2nd after being sat for 10 years
  183. need help with my sporty 1200
  184. Which slips on and why.
  185. Rear shock leakage
  186. Dynatek 2000 inst
  187. 2013-48-Blackout 2 into 1-Thunder Torque
  188. 2-up suspension
  189. Fuel Pump fuse location?
  190. Hurray! Leaky fork seal.
  191. Need some help on wiring in led rear turnsignals
  192. New solo seat for 2009 nightster
  193. 48 gas tank swap for other sportster tanks?
  194. Front turn signal relocation
  195. Fork tube size for 2013 xl cb?
  196. Part Number Assistance
  197. 08 oil change
  198. front tire feels like not rolling freely
  199. Socket sizes for Tool Roll
  200. Handlebar fitment
  201. 08 883XLC Idle High
  202. 07 Sportster to Flat Track
  203. Oil dipstick stuck
  204. '08 Nightster shorting out on start.
  205. new emulsion shocks made a dig difference...
  206. New to the forum
  207. fouling out?
  208. Loss of power
  209. Hammer Performance 1275
  210. Rear turn signal lights
  211. Sportster starting,
  212. Rear end sway
  213. Bodyparts xl883C 2001
  214. New on HD and in US
  215. First tnt after a long azz winter
  216. Iron 883 with 10,5" shocks
  217. 2015 iron blinker problems
  218. transmission removal trap door
  219. Sportster Sickness US
  220. Sportster Turn Signal Swap - Non LED
  221. What is this cable for?
  222. 2003 883 Hugger
  223. Mounting stock “sissy” bar
  224. Which oil? 2007 Nightster..bored out
  225. 883-1200 upgrade
  226. 2012 xl1200c question..
  227. new suspension setup for the 48
  228. New roadster rear brake squeaking
  229. Iron 883 tall boy handlebar install
  230. 88 Sportster 1200 not charging
  231. s&s super e carb
  232. 1998 hugger
  233. What is Squeaking/Grinding on my bike?
  234. It's the little things that can make me smile...
  235. Motogadget Motoscope Mini Review
  236. Flywheel issues
  237. 2003 Sportster right foot peg mounting bolt.
  238. engine light stays on before turning bike on
  239. Can you negotiate price on a new Sportster?
  240. Best chrome triple tree
  241. 883R no brake pressure
  242. Top end rebuild - parts that SHOULD be replaced
  243. Passenger footpegs problem
  244. 04 Sportster 883 start issue
  245. Drive chain adjustment
  246. Is it save to test ride new pipes before re-jetting?
  247. Fuel pump problem
  248. Harley Forty-Eight Special: 7 Fun Facts
  249. Luggage rack with detachable sissy bar?
  250. 2011 883N CKP Trouble Code (P0374)
