View Full Version : Sportster Models
- what is the sign to change the abs wheels bearing
- Hammer 90" kit info?
- Koso tachometer
- Old 883 New problem
- 3/4 to 1 inch bearing
- 2011 48 Battery Fuse electrical issue NEED HELP
- Why do people say the older sportsters vibrated real badly?
- 14 year old bike with 600 miles. Need service guidance
- Xlh 1100
- is it Okay to Drill a Bigger Holes For Breather Bolts
- Fuel Petcock Replacement
- Question about Service/Trouble shooting manuals.
- touch-up texture black
- International gearing?
- 90s risers on a 2009 model?
- Battery switch ?
- Hi & a suspension question
- Carb Air Cleaner cover on EFi bike?
- 09 custom want to get aluminum wheels.
- Flush mount tail/ brake/ blinkers
- convert a 2-piece carbureted Fat Bob gas tank to electronic fuel injection
- 2004sportster xl883c turn signal turns on when reving
- Custom Big Twin style pipes for Sportster?
- Head Lamp Replacement
- Bike sat 8 months
- Harley-Davidson Sportster: Merging The Modern With The Timeless
- V-Twin Kickstart For 1991-2003 Sportster & EMD Electric Kickstart For 2004-2020 Sportster
- Battery box removal
- Status of Baker 6 Speed conversion kit
- Is there a circuit breaker for EFI Sportsters
- One I wish I had never sold.
- 2004 sportster xl883c turn signal turns on with revs
- Bike died mid ride - carb fuel issue?
- White smoke coming from engine
- TC Bros Hardtail vs Low Brow Customs Hardtail
- Naples / Ft myers legit shop
- Removing acetone-resistant tank liner
- 2015 Harley Sportster 48 Fairing
- Risers not lining up with clamp ...
- Cv carburetor upgrade
- Ohms multimeter spark plug cables
- 2004 XLC 90CI build...
- Need help fuel tank problem!
- Issue with EFI sportster wiring
- Side mounting licence plate, were to wire light?
- Riser fit issue
- 95/96 speedometer re calibration
- How to remove ignition module?
- Seat/tank question with 07-09 1200 C
- Sportster 1200 Engine updates 1998-2003?
- Need Help Please, hook battery and negative arch’s crazy
- 2016 Forty-Eight V INNER on speedometer
- My sportster asks pin code after trying to jumpstart
- Rear Belt Drives
- 2019 Iron 883, ECM and ABS error codes.
- Engine Oil
- Forty eight, retune or not?
- Looking to buy my 2nd bike used
- Iron head 900 help
- Wrinkle finish VHT engine…
- Right side footpeg question
- 1993 Sportster carb issue
- Low profile headlight fairing
- Sportster 2022 883 to 1200 Conversion
- Need help
- Starting issues
- 2011 XL1200C Combo Turn/Brake/Run tail light
- GSXR swap & 180
- Switch housing/throttle tube clearance
- Leds and hyper flash
- No Spark 01 sportster 1200c
- 2007 883 project
- hey Sportster owners, they're talking about you behind your back over there in the Softail section
- Sportster jugs
- 2015 Sportster 48 Various Issues
- Sportster Sport vs Nightster
- Do i need to Tune if i add a new Air Cleaner?
- About Wiring Harness Caddy Plastic Cover
- Larger tank on ‘48
- Fuel Tank Swap
- Clutch pull
- White discharge leak.
- Horn relocation on a 1200 Custom
- Finned Primary Cover
- The "What Cams to Run" Megathread
- 09 1200c Front Conversion
- Changing over from forward controls to mid controls.
- ugly kickstands
- 2007 EFI Sportster - Chopper Build
- silver heads & barrels?
- heat sheild?
- Harley Drag bar cables?
- 2022 fourth eight tank upgrade
- Is It Possible to Swap Swing Arm From XL Models to FXR Models
- what is the bolts size of these
- 2009 - XR1200 Parts required
- How do I add a Fuel Gauge to my old Spertster (1990)
- Mikuni carbs
- 2019 Sportster 1200 Shut off while riding and battery light is on
- B116609c | uo4438fp | b11b292c
- Exhaust swap
- New Nightster S owner
- Can I just ride without voes?
- thoughts on buell xb cams in 04 sporty
- 22 forty eight vapor vent hose alt for tank swap
- 1989 Sportster 883 Starting Problem
- 2004 sportster 1200: how do remove the trans from the case?
- XL1200 Custom rim question(s)
- B2161 Brake lamp output open - new BCM installed (2017 FortyEight)
- Speedo light socket sportster
- Bike won’t start after wreck, help?
- Sportster bogs when choke is on
- 08 883 sat for 7 months won’t run
- Oil filter, by pass or no by pass.
- Bored out ironhead
- Pinging after 883 to 1200 upgrade
- Crankcase Breather ?
- 2011 Sportster 1200XL Rear fender replacement source
- intake manifold question
- Well another sporty might be on hold
- Suspension question
- Modern speedo on 1988 model
- 94 sportster with bayonet gas cap need help?
- Turn signals and brake lights don't activate? Also cluster info blank
- Front End "Vibration" under Load
- Evo 1200 Wiseco Hi Comp Pistons
- Choke relocation bracket
- Forward controls
- 2017 Iron 883 Fluid Change
- Self cancelling turn signals
- RE 1200 Custom Sportster
- Roadster experience
- Upper tripple tree black
- I have a really weird idling issue. Makes no sense.
- 2003 Sportster 1200
- Battery change PIA
- Low speed front brake pulsation
- Stalling and choking on startup
- Sportster 883 clutch slipping in gear
- Question wheelbase extension Sportster
- Battery drainage with cold weather
- delete or relocate dash lights.
- Big radius 2-2 vs short shots quiet baffles
- Right sprocket bearing prevented from coming out
- Do Sportsters ever look good with engine guards?
- Complete newbie, not sure what kind and what year this bike is
- 95 and older tank on 96+
- Tons of oil pressure=explosion
- 2017 FortyEight - BCM issues (bike does not start)
- Possible Vacuum Leak??
- Any help on finding the source of this leak or where to start?
- Cool Buell
- ? for Forty Eight Special owners
- 2007 XL1200C Question 20,000 miles
- Cylinder stud removal
- Best slim, sleek guage clusters
- Does my engine sound ok??
- Sneezing, Hesitation Help
- Roadster Wheels, not impressed!
- Sissy Bar install help!
- Traxxion Dynamics?
- new to this
- infinately adjustable shifter
- Looking at a 96 XL1200 - Advice?
- Narrow flange or spool hub
- I need Blast exhaust....does anyone have a *stock* take off Sporty muffler laying around?
- 5th gear removal on 93 XL1200
- 2000 sportster waterproof cover
- My first, 2014 Iron 883
- Ceramic coating exhaust
- High quality chrome engine guard
- Engine races
- 2017 883 Iron wiring issue...HELP!
- Grenade plate
- Help ! Fault code P1608 & P0523 & P1100
- 1200 Sportster oil tank seam leak
- Manuals 2001
- Charging issues 79 ironhead
- Speedo swap
- Rear Tire Size
- MENSSKULL Jewelry
- Sportster won't start
- A pick and a 1200 question
- Reducing Footpeg Width
- Yay, my clutch plate rivets died!
- which online store do you use to order parts?
- DoctorMotorcycle's 1986-2003 Sportster Turbo Kit
- Project Forks?
- Sppedo Woes
- Inverted
- Stolen sporty
- Turn signal module repair
- Questions about handlebars (Drag/Tracker) on a '17 Forty Eight
- Chasing compression issue 1995 sportster 1200
- Trackerdie extended damper rods, DK Intimators
- Do 'reduced effort' clutch ramps really make any difference?
- OEM Premium Emulsion Shocks
- Air filter full of fuel (pics)
- 2000 sportster 883c
- Switch Housings
- Very loud tapping randomly...exhaust leak, lifter?
- 08 EFI sportster primary chain cover
- 1986 1100 No Spark
- 2016 Softail Slim S
- sportster xl1200 forty eight
- Fat Boy Wheels on a 1980 Iron
- 2016 Iron 883 Starter issue
- Timing on 1200xl
- Worn dogs or clutch issue?
- 48 -> Road King shocks
- Intake manifold for carburetor on 2007+ EFI bikes
- Gasket for late model EFI heads / cylinders on a 2004-2006 carbureted engine
- 2010 883N Sportster Battery Recommendations..
- Fuel pump failed on my 883 2014
- How does Hugger differ from other Sportsters?
- That Chinese Sportster don't look half bad
- Sagging Forks but Progressive springs
- Backfiring on my 97 Sportster 1200
- Feuling reaper 505/515 cams
- 883-1200 thoughts
- Cold blooded Sportster?
- '15 Iron XL883N
- 86 sportster 1100 with cv carb, need throttle cables now
- Turn signals acting weird
- 1200 sportster with Thunderstar rims
- 2017 sportster. No speedo no rpm no gear indication
- 73 xlch
- Race pics? Nope, senior pics
- Stock mirrors?
- 48 special owners?
- Bad jump start
- Bad jump start
- Basic 1250 kit
- 1996 Sportster with Big Twin ignition switch problems
- Clutch stuck?
- In-between the V-Twin space, port side
- 2017 48 fork cartridge upgrade for 49mm forks
- Neutral Light
- Choke Cable WTF
- Heel-Toe pedal sportster
- Hesitation before acceleration at full throttle
- Denim paint and powder coat maintenance
- 2012 Sportster 48 something happened trying to figure it out
- When to replace primary chain
- Speed up a ‘99 SPORTSTER 1200C
- Silly question time
- 2009 Nightster Excessive Vibration
- Gangster Lean!
- How bug’s you rear end?
