PDA
View Full Version : Sportster Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299
  1. xr1200 suspension
  2. Gone Digital
  3. Monster baffles
  4. just added a Sportster to the stable
  5. Help parts for 48
  6. Sportster Models
  7. What do you recommend??
  8. Anyway to adjust T.S.
  9. Will Kuryakyn gran throw over bags fit?
  10. Mounting tabs and bushings for a Sportster tank?
  11. Vance&Hines Twin Slash 3" Slip-ons
  12. Ham Can breather and my knee
  13. I need to upgrade the shocks. Air shock install.
  14. Harley Stroker?
  15. Crotch Cooler for a Sportster..
  16. xena xx14 alarm lock
  17. Those empty holes---mmmmmmmm
  18. New Turn Signal Relo Option...
  19. 1200 carb jet sizes?
  20. topend compatibility 01-07
  21. Which docking hardware fits the Nightster?
  22. Duece Rear Wheel Mod
  23. Skyline drive Thanksgiving week
  24. Pipe help please
  25. Rear shock adjustment
  26. D&D Bobcat Exaust????
  27. Anyone seen the new low in Merlot?
  28. What to do in case of cross threading?
  29. Tank lift quirschun
  30. Over from the Touring section and in need of guidance
  31. What baffles do I need for SEII slip ons?
  32. Sportster Advice
  33. Dr. V-Twin is rolling back prices!
  34. advise, shortcuts, surprises etc
  35. Have you installed aftermarket parts on your Sportster? How'd it work out?
  36. Need help please
  37. 48 help!!
  38. Taking the plunge! 883-1200 kit advice needed
  39. 48 question
  40. 883 to 1200
  41. Good Deal for an 883?
  42. My 09 Nightster- Updated
  43. brake light flasher
  44. Exhaust question (burning)
  45. Bad Motor Noise
  46. How to install HI-4 Dual Fire Ignition Module on 2003 Sportster XL1200C
  47. Exhaust Manifold Bolts
  48. 883 - 1200 coversion worth it?
  49. 1999 hard to find exhaust for
  50. Burly Slammer Kit: Front or Nor Front?
  51. Big Sucker Oil Leak... WTF!?
  52. High Mileage 883 Iron
  53. Sportster Trips/ Touring
  54. Sportster axle adjustment bolts????????
  55. v&h fuelpak map
  56. Bored of Riding around Town
  57. Sporty motor interchange ?
  58. Need help with suicide shift clutch cable
  59. Exhaust heat wrap question.....
  60. Tiny beads of moisture in my primary.
  61. Cheap nightster
  62. Question about voltage regulator
  63. Have you installed an Easy Pull Clutch?
  64. Progressive Shocks
  65. OEM Air cleaner
  66. Looking for a peanut tank for a '05 883c
  67. Night Rod Headlamp visor on 04 to 2010 Sportsters (pictures)
  68. Spark Plugs
  69. Please post a picture of your 48 with longer rear shocks
  70. To Wrap Or Not To Wrap That Is The Question??
  71. New Bike Needs New MoD
  72. Need more Lean angle on the Forty-eight!! Please Help!
  73. lick's solo bag...takes so long
  74. To all of you "bobber" guys that want to run just a metal seat pan...
  75. Handlebar Question
  76. smoke on ignition startup
  77. found my vibration
  78. superbrace for nightster and iron. different?
  79. Relocating ECM sure is a pain in the ass..
  80. Newbie Handlebar question
  81. Windshield question
  82. Dealer burn ?????
  83. Well... I did it (new Forty-Eight purchase...)
  84. Okay, getting a little pissed off here...
  85. did you know that Calif has a new exhaust law?
  86. New 48 Pics
  87. My Little Sporty
  88. XR1200 riders
  89. Price of a tear down...
  90. Swing arm bag nightster
  91. Exhausts....why are they so expensive???
  92. Fork tube length?
  93. Nightster light bulbs??
  94. '08 Nightster Newby
  95. Winter Storage,,,
  96. Part# on 48 seat ?
  97. Looking to put a Tach on a 04 1200 Custom
  98. Cheap Cup Holder
  99. Finally got the 48 some new bars
  100. cylinder exhaust fixation bolt break
  101. My first real MOD
  102. rhinehart slipons for nightster help
  103. What stage 1 intake did you put on your EFI sportster?
  104. Putting Nightster headlight on 1200C
  105. New to harley
  106. Saddle bags for a 2009 Sportster Nightster
  107. Bub 2 into 2 exhaust on a sportsster?
  108. Installing saddlebag supports / oil plug question
  109. Sporty Springer
  110. want different grips...foam, vintage, kurykan???
  111. Got BUB 2into1 installed on the 883
  112. dakota digital gauge installed
  113. Sportster windshield
  114. My 48 Thanks to this forum
  115. Muffler clamp size?
  116. Maybe you need a Goldwing
  117. Gearcase cover question
  118. Forward Controls for Nightster
  119. First Mod
  120. won't start
  121. Tail light problem
  122. z-bars
  123. Test rode a few Sportsters today...
  124. So, once you chop your frame/rear fender, theres no going back eh?
  125. Nightster Mods and suspension issue..
  126. XL1200 R modify to nightster look?
  127. Anyone tried a 12" shock on a Forty Eight?
  128. I need an exhaust bracket for an 03 sporty
  129. father and son project...05 stock sporty to this
  130. Choke on a Sportster Nightster?
  131. Dumb question?
  132. Problem with slip on exhausts?
  133. 1200 Low tank fit on a forty-eight?
  134. 2004 and newer pipes on a 87 sporty
  135. Drag pipes on 92 1200 sportster
  136. cleanning the engine
  137. Guess I won't be doing the poker run
  138. Simple fuel light question, XL1200
  139. 883 owners, Do you tour, or long rides??
  140. time to rebuild?
  141. 2010 Forty-Eight vs. 2011 Forty-Eight
  142. Help, this line goes where?
  143. Emission standards from USA to Japan ????
  144. thumb screw cruise control????
  145. lean angle increased with taller springs?
  146. Floorboards for a Sportster?
  147. 1200R seat question
  148. Fender Removal
  149. Carb vs EFI
  150. Question about speedo cable and (maybe) rear sets
  151. Thanks
  152. Wanting bigger apes. Kit or build own?
  153. Seats
  154. S.E. Baffles
  155. 3.3 Gal. Tank
  156. Can I clock the shift lever on my Iron with no ill effects?
  157. Wheres all the XR1200Rs???
  158. Shortening break lights?
  159. New stuff on the 1200N: T-bars, tank lift, wire tuck, ignition relocate and sissy bar
  160. Start up Backfire?!
  161. 90ci NRHS kit anyone?
  162. 09 iron electrical box
  163. new to forum
  164. 09 iron
  165. New Rider Advice
  166. Mini volt and fuel gauges?
  167. '00 Sportster cuts out and dies on the road
  168. Question about rear pulley
  169. Having a problem starting my XL883R '03 everyday
  170. Which rigid struts to choose?
  171. Timing Question
  172. Should I??????
  173. Greetings & question
  174. 883L gearbox getting "stuck"
  175. Tire pressure on Nightster
  176. life expectancy
  177. XL1200S Riders... 2-1 exhaust options?
  178. Recommended milage for synthetic oil change?
  179. Wont shift
  180. New bars possibly
  181. Hey you silly sportster loosers!!!
  182. Headlight Visor For 03 XLH883
  183. Super Low Seat???
  184. Burly slammer kit problems.
  185. What spray paint to use on Fork lowers and wheels?
  186. How often do you service?
  187. Any 883 Hugger owners out there??
  188. New modification to my oil bag.
  189. Sickest Hardtail Nightster on youtube!!!!
  190. Selling my Nightster :-(
  191. 883 to 1200 conversion
  192. Horrid loud noise and won't start! Please Help!
  193. FXRS Patch
  194. Starting to get frustrated
  195. Key Switch Relocation??
  196. 3000 miles on the 48 - some observations
  197. lost the KICKSTAND in his 1200 C Sportster 03
  198. If I only change the mufflers, do I need to re-map?
  199. Ignition module 2003 XL1200C Sportster
  200. Screamin Eagle Ignition Module for 2003 XL1200C
  201. Turn Signal relocation instructions Nightster
  202. bars with no dimples?
  203. Pipes
  204. Headlamp Visor for my sporty
  205. axle mounted license plate questions?
  206. I there a way?...
  207. lifters replaced
  208. FOBs standard?
  209. Almost Died TODAY!!!! :(
  210. forward controls question
  211. head gasket leaking on 87 sportster
  212. Gas Cap Medallion/Headlight Trim Ring
  213. 82-86db @ 50 ft. What rpm?
  214. Whats the best wheel bearing?
  215. S.E. Exahust
  216. 1978 Iron Head for sale
  217. Front end info help please.
  218. Iron front turn signal relocation - done
  219. '74 Sportster XL 1000
  220. 1000cc Engine Case
  221. Good Deal?
  222. I saw where the guy was asking about the olive green nightsters
  223. Pegs to Boards
  224. Gear shifter peg fell off, road side repair
  225. Screamin' Eagle street performance tuner kit
  226. Suggestions for new pipes...
  227. Question about carrying a skateboard on the iron
  228. Dumb ass on a crotch rocket
  229. 883 Motor Question
  230. Piston slap/cold knock?
  231. 883 run on / run backwards
  232. Anyone used the Bike Barn before?
  233. Pretty sure I got an awesome deal on Sportster Nightster...
  234. Anyone running 883 heads or something otherthan stock 1200 heads?
  235. Side mount license plate brake/running light wiring
  236. Swap a 73 head with a 80 head?
  237. harley led headlamp p/n 73273-11
  238. a new 2010 iron with some mild mods
  239. 1200s cutting out
  240. Front forks, trans question
  241. Cable length questions
  242. Should I buy this Sportser?
  243. Iron 883 prices
  244. Have you regreted getting your sportster and not something else?
  245. Shifter peg rubber on 48 wearing out 3k miles?
  246. shifter shaft seal leaking!!
  247. Lightning Upgrade?
  248. Other Exhausts!
  249. Before RSD A/C and after
  250. Touchy throttle
