View Full Version : Sportster Models
- Namz wire extension kit. Recommendations for you
- I went down on bike...........
- Rear running light out
- Sportster mod ideas
- Badlands Module and Constant Flash Module-Can I have Both?
- 1000 mile inspection necessary?
- 14 iron w/1200 con. head work question.
- V&H vs. S&S 3" Slip-ons with baffles
- Ceramic headlight connectors
- New tail and signal lights now weird flashing between right turn and brake light
- Vance & Hines Grenades.....damn.
- cycle shacks oh yea baby
- My 2014 48
- are mustang wide tripper seats even close in comfort to wide vintage?
- undermount turn signal bracket... Why can't I build this?
- Roland Sands Gauge Relocation with Joker Top Clamp
- wild 1 outlawz bars
- Burly Slammer
- Lost my nuts!!!
- Thanks To All
- How often do you change your fuel injectors
- bobber seat ..does it hit the back guard on rough roads
- power vision intel
- 79 ironhead sporty shifter arm HELP!
- o2 sensors
- Quiet a 2000 Sportster Xl1200C
- 2014 VROD or Fatbob style fender on XL1200C?
- Deadman's Throttle/Return Spring Issues
- Distance between shifter and foot peg - need ideas
- Greatings from Italy.
- I dun goofed and dropped a nut inside my Sportster.
- Rear tire alignment
- exhaust mods-patriot & thunderheader
- 1200 series custom or 48
- Finally got to do my electrical and oil cover paint job.
- speed sensor
- Changing Slip-Ons
- Highway peg options? - Iron 883
- Vance and Hines Fuelpak
- More power out of my 883n
- Joined your world
- Finally...got some parts on order
- 2011 48 Ignition Removal and Key Fob
- Speedo Change
- Iron 883 oil question
- Homemade sissy bar
- 2014 72 - Forward to Mid Controls (which parts?)
- Tsm removal
- 2 bikes, 1 cup
- Internal wired bars reviews?
- Wide Glide front end on 1200C
- Speedo relocation questions for those who have
- 09 iron seat
- sportster vin??
- Need Help! Removing Slip-ons with crossover pipe
- 2006 Sportster 883 Custom
- Wire tuck
- dennis kirk any good online exp
- 2015 Harley davidson forty eight
- Motorcycle Mechanics Institute. Thoughts?
- HD Detachable Quarter Fairing
- Xl14xied
- 2006 Sporty 883 carb fuel issue
- nightster idling high
- 12" handlebar wire/cable kit options.. Need suggestions
- DIY Passenger Pegs
- losing speed uphill
- Sissy Bar Compatability
- Carb removale tips
- New parts on the way!
- Which Top Motor Mount??
- 883R/Roadster
- 2008 Sportster 1200 Anniversary Edition
- Rear Wheel Question 1975 XLCH
- Harley noob stumbles upon big money bike?
- 180 rear tire conversion
- Should I buy this?
- Sissy Bar for a '90 ?
- Wiring question (probably dumb) for aux lamps
- EBC Rear Brake Pads-or which ones?
- Gas Tank Bags For Sportsters
- Vibranator and a damn cool pic :)
- Paint choice delimma
- Pillion seats on 72
- carb help
- Need a Comfortable Seat!
- Do I really have to do a stage 1 flash/eXID
- 2014 48 stage 1
- 2012 sportster 1200 custom. Primary chain adjuster broken
- Gas Tank fitment I NEED HELP
- Nightster gas tank question
- do I need an equalizer?
- 04 & up hardtail
- Spoked wheels for 2008 and newer Sportster
- cannot get headlight out of bucket
- Stage one download. CRAP!!!
- Jockey/Suicide shifter
- D&D Bobcat exhaust ?
- Cam Change FOR towing
- Fuel pack doubts
- need to find that rear bar thing lol
- 2014 sportster lever question
- 48 with fatboy bars
- Mustang Solo Day Tripper Seat.....
- Iron owners, help me name this piece...
- New Member from Georgia
- Sportster Tire fits
- Sportster Tires
- My sons 72
- 1997 Sportster wheels
- Extra Length Chain-Spare Links?
- 97 sportster backfiring!
- Stage 1, to dyno or not to dyno
- Stock Seat on 1975 Sportster XLCH
- SuperBrace 2010 Nightster
- 1986 sportster wiring.
- Smoking gun/ front cylinder
- Hollywood handlebars on 2014/2015 48 (w/ ABS)
- paint flaking. how best to fix?......
- Sportster 72 accessories needed
- Best Aftermarket Clutch for 1200 Low?
- Biltwell Whiskey throttle and Kung-Fu Grips?
- Pac-Kit throw-over saddlebags
- Croming my 2014 Iron 883
- anyone done the letters on their tires in color?
- Returning Ironhead to Stock Condition
- Front brake line for mini apes
- Suspension & Front End Question
- For my info , Do all battery covers on sportster
- Draining fuel tank
- Which Exhaust for 883?
- SE CNC Pro Ported Factory Heads
- Harley Solo Spring Saddle?
- sportster rats
- Burly shocks?
- Old footpeg mounts on a new bike
- My sportster 72 project
- Throttle not returning to idle when let go
- air touring shock.
- TTS Mastertune
- Stock muffler baffels
- Can anyone describe how Biltwell Breezer bars feel?
- WIRING HELP pls......
- fuelpak with a custom exhaust?
- AUX Fuel Container-Which One Should I Buy?
- Need Some Advice On Forks !!!!
- Sportster build planning
- Harley dealership wont install my tires!
- Crash Bar storage on a Sportster
- 2013 Iron 883 to NRHS 1250 KIT Power vision
- Installed: Primo Rivera LED Headlight
- Iron 883 dimensions
- Driving lights
- Kuryakyn zombie levers
- Finished my speedo install tonight
- MSR Fuel Bottles ?
- to drill slide or not
- Mystery Solo Seat
- Squealing noise
- Bar Risers Help for 48
- Passenger footpeg mounts
- transmission install
- 883 Iron issues
- 1991-2003 Sporty frame question
- (VIDEO) Head bolt leaking
- 1975 XLCH Sportster Oil leak
- 883
- 2013 pipes on 2001
- 2014+ Sportster 48 Changes/Woes
- crossover pipe gasket or no
- Peanut Tank Question
- Bad way to end a great weekend
- Only spark on release ign button
- petcock blues
- Speedo relocate
- Harley finally has a turn signal relocation kit for the 48
- sportster battery
- sporty 1988 xlh1200
- air
- HID projector retrofit done
- blowing ignition fuse after handlebar install
- Burly Brand Shocks
- Brown Seat Cover
- Let’s HEAR what you got! Post your exhaust sound videos...
- Custom Forward COntrols
- 06 sporty 1200c will not start
- Iron passenger foot peg install help
- Soft tail tank on an sportster?
- rich to lean
- What to look for on an 1984 XLH 1000?
- 2014 48 - Battery/ Electrical problem?
- Dogbone Star bolt size
- Sportster 883C clutch failed pls help
- exhaust for 2014 and 2015 sportys?
- Greetings from Irving, TX
- Forward to mid controls
- slip on baffle swap?
- Tools along for the ride?
- Anyone running fishtails on an EFI bike?
- 2009 Nightster Rush 2:1 installed
- no oil to the head, sportster 1200
- Rejetted, but now it dies when going uphill
- Anyone have tank lifts without the wire tuck????
- Will a Sportster solo rack also fit a Dyna?
- Give Them A Second Change ?
- Rear tire size 97 1200c
- Adding Mini LED's to Stock Tail Light ??
- Luggage rack that fits my sissybar
- My new "customization" to 48 tank
- Is it Spring yet!??
- Question about LA Choppers clutch cable.
- What is this and why is it not attached?
- Need help with a parts list !
- Need To Eliminate Security 07' XL50
- Mid or forward controls on a '72
- Silly question on oil level.
- FXD Gas cap
- Auxiliary Cooling Be It Oil or Fan...Overkill?
- SE or NGK iridiiums sparkplugs,,,
- 2006 spark plug wire crimp ends.
- primary cover off for long time...is it ok?
- Shock Lowering Kit
- How far would you ride a 48....
- Sportster Iron front suspension
- 48- running wider tires on stock rims.
- Throttle replacement on a '14 48
- sporty build. new to the forum. not really sure what im doing on this interweb thing
- 08 nightster mini apes.
- custom heel/toe shifter for Harley 48?
- need help with led tailight
- The plastic bearings are shot
- What gear do you ride with
- cv carb changes
- I need smoother ride, better shocks
- Accessing Battery With Solo Spring Seat
- Forty-Eight Project Bike Report w/ tons of pics
- Question on Joker Machine Air Cleaner
- Lifting the gas tank
- 883 Iron, Noob with noob questions.
- window bars?
- 68xlch
- USB Charger installed but what about this light?
- Photo request
- 883 to 1200 Bore or Kit?
- Quick question - front brake rotor related
- 1986 1100 hardtail?
- Wich bars ?
- What type of module
- Custom forward controls relo
- 07 Sundowner seat to an 03 100th Anniversary?
