View Full Version : Sportster Models
- Beach bars
- Crime Scene Choppers rapide headlight
- Anything H-D
- Riser bolt cover?
- Good place to look at headlight fairings
- tired of the headlight visor? my new jokermachine visor
- 96 Hugger Transformation
- Leaving carb'd sporty fuel setting on reserve
- 01 Sportster new DK a/c and Drag pipes rough running now
- LSR 2-1 installed/review
- No fuel...please help
- high speed wobble
- New member and a new bike
- throttle cable "c" clips in switch housing
- 2009 Sportster xr1200
- dk solo seat
- wrapped side shots
- little help installing a gas tank?
- 2013 Sporty- Listen UP
- Anyone used a jack/stand like this?
- Jetting question
- cleaning oil
- Spotted a 72 on SOA
- Length of clutch cable
- Picked up my new Sportster today...
- Plasti Dip question...
- new spin on my old helmet
- Questions re 883 to 1200 Sporty conversion
- suction cup pass seat
- Rejetting carb for a Stage II air cleaner
- 1200 Custom + Power Vision
- Fitting a 1994 clutch casing to 1993 sportster
- nightster tail light broken
- Tassels on a 883...
- Commuting and most comfortable riding position drag bars or clip ons?
- F.n.g.
- Too big for Iron 883?
- Nightster gas tank removal
- Sportster Chin
- XiED, X14iED, ViED Questions
- Installing LSR 2-1
- Anyone engineered a lay-down solo backrest?
- Very Confused Stage 1
- DK Customs air cleaner Installed (video)
- Harley Ride Planner Problems
- Upgrading to LED's, wiring same?
- HELP.... 48 on APE ...WHICH ONE PREFER 12 inch or 14 inch
- 96 XLH1200 Cold accel problem
- Going from 1200 to 1250 or cams?
- Biltwell 12" apes or Lick's 10" Z bars?
- Changes through the years
- What is this and where do i find it?
- risers
- Leaky leaky Oil getting on my tire
- 03 883 RR turn signal not functioning
- I'm an idiot...
- Tired of the UGLY sporty eyebrow!!
- Wiring power to new Dyna 2000i Ing Module
- Sporty wheels
- Changing Up Risers on 883C
- HD two up lowers shocks
- I need need some help with a wire..
- Help Purchasing Used Sportster
- 2009 XL883C Sheet Metal
- Truth or bs - screaming e pipes u stamped
- screaming eagle ecu flashing question
- Fuel Tank Fitment.
- "creative pics" of your bike
- My Seventy Two 2013
- new to Sporty's
- Chattering in heads
- Floor Boards
- Bike Dies.. it seems to be the fuel pump...please help.. :-)
- What do you guys cover your bike with?
- motor swap
- Will the RoadKing's front wheel fit 48?
- Running Lights/ head and tails not turning on
- what. is it worth
- Noob in land o lakes fl
- can i fit a k&N a/c aswell??
- Wire/plastic clean-up 2013 48?
- 883r inserts
- 5 gallon tank with access port issues on my sporty
- VO2 installed. couple of tips
- Upgrading '03-earlier exhaust to '04-later?
- Anybody riding to Ray Price today?
- Battery Tender Suggestions
- DK Customs air cleaner kit
- Black Denim Dark Custom Tank Help
- Any of you running the Roland Sands exhaust and air cleaner combo?
- Who likes Power Vision
- Project/Makeover...need ideas and opinions (long post)
- Changing handlebars, need help
- V-Rod front wheel on a 883?
- 2011 and later xl1200c windshields
- sparks shooting from underneath ignition switch on fuel tank
- Seat question
- clutch or chain or what?
- suggestions on shocks
- show your roland sands speedo mount on your iron
- Dealer Sold Me Super Tuner for $98
- Stage 1 EFI Question
- Short Shots
- TailLight ideas?
- 2 1/2" Khrome Werks slips ons & XiED's
- Bike runs, shifts thru gears - but doesn't move
- No clutch interlock with ISO grips?
- Iron heads and engine cases cleaner.
- Eliminating Ham Can from SE A/C?
- Mid 90's FLH WHEELS
- led sled pipes?
- Xmas Pressy's
- Thread pitch on '09 rear axle?
- Road6Custom Side Mount License Problems?
- Mixed answers about first service??
- installing forward controls on a 2007 XL1200L
- Anyone with a black thunderheader, has the coating held up?
- Are all Roadster seat the same?
- Mid controls with forward pegs
- Clutch lever issue...
- Hot??
- Friso'ing an EFI sporty tank?
- Front suspension sag?
- Clutch cable
- HD Combo Speedometer & Tach -4"
- My custom sissy bar
- Custom rear wheel pulleys / XLN?
- 48 seat on Nighster mounting ?
- Queries on the Iron 883
- any tips on using acf-50?
- getting more oil pressure to the head of an ironhead sporty
- Drag Bar With taller Risers?
- Oil breather tube
- HELP Please! Installed a PCV and now the bike won't start
- Screaming Eagle intake questions
- 45 vs. 46 Jet
- Tires for a 2004 883
- Throttle/Clutch Cable lube?
- Custom Painting
- 5,000 miles maintenance question
- Cool custom Sportster Bagger
- Rush 3" mufflers on Sportster Seventy-Two
- How soon do xied,s work??
- How much oil for the oil change?
- Decel Popping after Stage 1 upgrade (Power Vision, Short Shots, S&S)
- air cleaner
- Zero fork brace
- Throttle Issues
- my dk speedometer relocation!
- Bike Running Rich
- 16" apes, sky high attitude!!
- thunder torque inserts and short shots
- Picked up the new Hard Candy helmet today..
- Fuel Reserve
- 1991 Sportster In gear will not move??
- Exhaust noise reduction kit?????help please
- Rush Pipes
- Mustang vintage vs. Sundowner
- Is ac and tuner worth the money?
- Bobber Wire Harness Needed
- 1200C price?
- Helmet Cleaning
- Removal of chrome covers on front shock lowers
- Tips for fogging glasses?
- New Manifold Seals - No More Carb Farts !!
- Front turn signal relocation
- Primered gas tank?
- post your aftermarket gas caps,
- Winter project begins
- Blown head gasket.
- New A/C and Drag pipes time for rejetting
- Best price V&N Short Shots Black
- New member question on SEST
- ape problems
- 2 noob questions for you :)
- Ironhead rocker arms.
- Older model sportsters, where to store pad lock?
- Dealer download?????
- Vibration Madness?
- Feathering the clutch
- New here and New to HD
- Which Battery
- Dealer wants 2800+tax for se stage 1 883 to 1200 conversion complete install
- Price check
- Battery Grounding Wire Help
- Why do people rev their engines at stop lights?
- Question on Forward controls with Vance and Hines Short Shots (nightster)
- 93 Sportster lectrical help needed
- Which air cleaner and filter combo best keeping dirt out
- 1200 valves in 883 heads????
- Help me ID some parts please?
- Hard candy
- Go Pro Mount Pictures
- How to bridge the gap smoothly? From Stage 1 to 1200 Conversion
- Why are bolts vanishing?
- DK Coil/Ignition Relocation Kit Needed Additional Modification
- Found DOT non-mushroom helmet (pics inside)
- Sprocket swap...Short Shots in the way?
- 883-1200 head differences
- Console for my 1200c?
- 2005 Sportster Tank Change
- Removing Turn Light Help!
- 06 Sportster 1200L won't Start
- Running rich, bike seems to run fine though...
- Fair price for a new 2012 72?
- 2 into 1 and Saddlebags How?
- **Turn Signal Relocation Kit Install Help**
- Used Sportster buying tips
- Carrying a standard 5 Gal gas can on sissy bar/pillion? (Im at NJ shore)
- Stage 1 Dyno Results
- 06 with 08 wheels...axle size & brake questions
- Hard To Reach Exhaust Bolt
- Kinda stumped???
- I'm pretty sure clutch is shot... is this what I need?
- electrical problem 2009 nightster
- Help a girl out?
- cam bushing inspection
- Road King shocks and saddlebags
- trigger levers
- Question about Sportster Fuel Gauge and Gear Indicator use together?
- Which Progressive shocks
- Hey all, I found a place to put pictures
- One of our members?
- This elderly woman is badass!
- Sportster 883 with 1250
- adding another gear
- Oil coolers
- Heat deflectors
- Lets see your XL Customs XL833C XL1200C. Pics Please
- Need Advice on First Harley
- New exhaust for the new cams
- Sportster Recarb
- Help..2005 Sportster Xl883
- Biltwell DIY Exhausts
- Peanut tank
- Riser on an 09 Custom
- Who's running a Cafe style fairing?
- seat help! 2009 sportster low with a new 48 seat? ... possible?
- New member to the forums
- Cracked throttle body after installing SE Stage 1 round A/C
- Found these wheels on craigslist
- Lower pinch bolts - weight or no weight?
- Is there a method for starting bike in cold conditions?
- Help bike won't start!
- Sportster Fender Trim
- Short Shots and Heavy Breather installed!
- Installing 4" Risers
- Early 90's sportster need a few pics please
- Cleaning engine cases
- Vibration question
