View Full Version : Sportster Models
- Rear fender
- Minimum distance to start the bike for commute
- aftermarket speedometer/tach
- Shifting issues
- 2002 Sportster Brake Light Switch Location?
- Went to swap 48 tanks & found this on the stock one
- Does anyone tried the fake engine guard?
- Tank overflow nipple hose on wrong side
- Electrical help
- Rebuilt my '02 this winter
- Compu-fire ignition
- 02' XL883 no start after two weeks running fine and a shop visit.
- Refurb'ed my motor covers
- Running a Lucky Daves seat??
- XL1200l Leak Near Battery Cover/On Rear Brake Reservoir
- Dyna Street Bob To Sportster 72?
- Sportster 48 Hollywood Bars Installed
- Putting mine on the market
- Favorite XL pics
- 2006 XL1200C suspension upgrade
- Rebuild or Replace Engine?
- Bags?
- Resistors
- Mistake ending traditional Sportster production?
- 2001 Harley sportster
- Twisted the grip let’er rip now I’m in a pinch.
- Sportster custom taillight
- 883 0r 1200?
- Mini floorboards and forwards
- sanity check on clutch issue
- Clutch question
- FTP switch in Sportster Iron
- Fuel tanks
- Spark Plug Covers Loose
- Need help with exhaust problems on my ‘14 iron 883
- Kickstand finally fixed!!!
- Steel Replacement Oil tank - for 04 and newer
- Digital Speedo/ Analog Tach
- 883 racing
- Master cylinder question
- 96 883 racer
- 96 883 racer
- Warm up with FI models?
- Advice on The Best Sportster For My Plans
- Anyone successfully installed a bobber style seat on early sportster?
- 93 Sportster No Start no click
- Turn signal issue.
- Headlight mount nut torque?
- To deal or not to deal
- Question
- 1996 Harley sportster xlh1200 s timing issue
- Clutch question on 1997 Sportster XL1200S
- Voes?
- Same pipes, different sound
- 2005 and 2007 Sportster
- 2005 sportster
- New clutch dragging on 2002 883/1200 conversion
- Valve train noise after top end rebuild.
- XL origin?
- Right turn signal
- Head breathers and oil tank pressure
- 1200 Roadster
- Engine block hole
- Saddle Bags Pre- 2004
- New HD flat tracker
- Need help on wiring
- Chugging sportster
- Exhaust question crossover!
- Spark Plugs
- 2007 883 adjustable levers
- 883 iron sportster exhaust mod
- Issues with my 94 883 Sportster
- Sportster pushrod cover seals
- 02 Deuce Cam Chest
- sportster seat question
- More help requested.
- How to get replacement rear turn signals for 2008 nightster
- Searching for a black AC isert, pre-04
- Couldn't be happier!
- need some help
- Torco?
- The deal of a lifetime!
- Quieter exhaust - V&H Big Radius alternatives
- How bad is this situation?
- 883L kickstand?
- Inputs requested - best way to sell a Sportster
- Clutch replacement issue
- Cam cover Question
- Question for y’all
- Speedometer stopped working 2017 Sportster 48
- Kerker 2 into 1 exhaust
- Spedometer stopped working
- Primary oil leak
- hd remote garage door opener installation on sportster
- 2022 Nightster front turn signals
- Stripped?
- Sportster 72 help
- XL1200 CX bottoming forks.
- Signal light question
- Installed new led turn signals on 04 sportster
- Pros & cons of 91-03 and the 04 plus models
- Seat upgrade advice
- Neck bearing replacements
- Sportster shifting problems
- Who Was I Fooling
- 2007 new to me
- 2012 Forty Eight Wheels
- Question for UK riders
- Rear / brake light issue, BCM?
- Oil coming out breather tube on 87 four speed
- Lost power while riding no no power at all.
- 2006 1200 performance upgrades
- 1989 883 clutch cable replacement
- 2003 Sportster - tubeless laced wheels?
- 883 not cranking
- Fault harley roadster 1200 cx 2019
- Cheap ebay O2 sensors
- A "Lump of American Highway Pig"
- 07 sporty front breakes
- refurbish?
- Anyone with a 883 to 1200 or 1250 conversion using a power commander V successfully?
- A,B,C lifters?
- 412 Progressive 13' on Sportster 48
- 2009 harley davidson sportster trouble any info?
- 02 sportster carb backfire, wont start
- Bigger gas tank
- Rear brake issues
- Inner tube, help/advice
- Sportster Registration and Insurance Holder
- Throttle cable hell
- New custom painted tank - Need fuel pump advice
- Roland Sands
- 24" wide drag bars?
- '99 Sportster XL1200C Won't Start
- Sportster Low
- Need help with setup
- Forward Controls on Iron - Offset Clevis Issue
- Low fuel light
- Front brake lines for extended front ends
- 1980 Sportster carburetor
- Figuring out a part
- front wheel size change
- Late Sportster VS 06-17 Dyna shift lever spliness
- Throttle by wire?
- Frame compatibility questions
- New bike: Fuel tank vent tube plug under gas cap??
- 1200C which jet for V&H short shots?
- Oil changed, tank seems over full
- 883 to 1200 Upgrade Help
- Proper Grease for Steering Stem?
- Air filter bolts
- 2018 Sportster 48 Special Clutch Cable
- Speedometer short
- Out of town for a few days now won’t run right
- Dallas Engine Builder
- 1200 custom electronic issues
- S&S cycle
- Primary noise
- Forty Eight High Speed Instability
- bent pushrod
- 2004 Sportster 1200R drops out of first gear to neutral when cold
- LED Tail / Brake Light
- 1980 Sportster XLH1000
- Intake seals cost including labor?
- New 14” Apes, What all do I need?
- Sportster Low and Drag Riser Issue
- Temperature sensor disconnected
- 2015 XL883N Iron - change rear shocks
- 1978 Sportster + adding an electric starter
- Picked Up a 2016 Iron
- 99 Sportster 883
- Brake pedal angle adjustment
- Battery draining
- Recommendations for handlebar compass and/or phone mounts for Sportster 1200 Low
- Sportster s Quadlock wireless charger fitting
- Burly brake lines
- Tuning question...
- Mounted My GoPro on the Forward Control Bar
- 2002 Sportster rear back tire
- 99 Sporty speed sensor BOLT
- Geezer Rant
- Stock Turn Signal not functioning...always
- turn signals wont auto-cancel ?
- Fried Motor?
- Voltage regulator
- Fair Price for 2016 Iron?
- New Sportsters moving
- risers
- 12v Charging Outlet on a 2003 Sportster
- Decel pop....?
- 2018 1200 Iron Oil Cap Won’t Pop Up
- Sportster serial number help
- German Guy needs help! Sportster XLCH1000
- slip ons question for the smart guys
- New battery for my Iron 883
- Oil light stays on.
- Riser Bushing Fail!
- suddenly dropping oil
- Can a rusty tank be reliably repaired?
- 2012 Iron 883 Seats
- LA Choppers Clutch Cable Question
- Intake manifold
- 87 sportster 883
- ignition module options 1986 XL
- Wheel model
- Fuel gauge
- The never ending tire question.
- 07 low XL swingarm replacement
- Standard XL frame vs XR frame
- Ironhead sporty problem slolved
- Top Speed
- Headlight question
- Need help!!!
- Question on controls
- Turn signal issues
- 48 Sportster 49mm fork lenght?
- Weird electrical issue - 2010 XL1200C
- XL883 clutch not disengaging
- Need advice for 95 Sporty build
- 89 883 ignition control module sensor.
- 2022 Sportster S Dead
- Service Manual
- 2002 Sportster 883 conversion to 1200 No Spark on Rear Cylinder
- Electrical Question
- 1986 cam sensor replace
- Front end conversion
- Nano flasher relay install
- 2018 iron 1200 cruise control?
- Bike wont start throwing codes for tssm and ckp *PLEASE HELP*
- Are these Memhis Shades cafe fairings worth the money?
- 1970 Modified 1300 cc Sportster for sale
- '22 iron 883 w/risers FYI
- Back into Harley's
- Question About Primary Drive Belt?!
- Heel toe shifter for XL1200L with forward control kit?
- XL1200X (48) - V&H Twin Slash
- Tachometer on 04-06 XL?
- 2020 883 iron won’t start. Keys missing. Please help!!!!!
- Boging in 2nd-and 3rd
- 3 light dash base wiring setup
- How lean can a bike be before damaging the engine?
- Correct tooth count for XR1200 belt to chain conversion
- 1989 sportster 1200xl
- Clutch stuck
- Help with 39mm narrow glide brake fitment
- 2007 Nighster poor MPG
- Farings on Sporty's
