View Full Version : Sportster Models
- Anyone around Monterey, CA
- Replacing the shocks, what length should I go with?
- Dual Headlight questions
- any experience on upgrading A/C and pipes on fuel injected models?
- Best 2-up seat?????
- sportster rear fender on nightster: anyone have pictures
- sportster rear brake lock up
- powdercoating question
- noises when starting the engine
- Rear Shock setting
- Sportster Seat Question
- 1987 sportster 1200cc carb problem
- Good Deal?
- 2 engine noises on my 08 nightster im not sure about any ideas
- Rewiring Turn Signals
- Starter motor '06
- speedometer
- Where to get a good deal on V&H Short Shots?
- Anybody using Lepara seats?
- Rear end wobble?
- Oil Leaking from clutch cable
- Play in shifter
- Problem installing Rush slip on's on my 48.
- Will 05 stock slipons fit on 08 sporty?
- West Eagle Narrow Apes
- Fluids
- 1984 1000cc ?
- What are the loudest pipes you can put on a 48?
- O2 sensor - Is there a washer?
- WTB: Licks Z-Bars
- 2000 sportster 1200c
- Sportster 883
- Bike control
- Bad Shocks Install?
- Customizing costs vs future resail value
- 1980 iron head with a starter problem
- anyone running biltwell friscos?
- 06 Sporty Custom n00b question
- Front end vibrating when brake squeezed??
- You can lower forks, can you raise them?
- S.E. II mufflers and baffles
- Handlebar/grip info
- Need help with FI
- Sprayed with gas
- Another Speedo Question/ Codes
- Who's getting ready for sturgis?
- New Harley Owner - Downshifting issue
- Ride ideas in Myrtle Beach
- Question for those of you running Licks Z's
- Leaking Oil Please Help
- Go figure! Battery cover meets its end
- Where do I buy a battery?
- Brake pedal on 10 nightster
- mustang tripper fastback
- Zero power
- Need Exhaust suggestions for an '07
- What I've done so far
- Bar swap DIY or let a Indy?
- Sportster Low
- pipes and brakes
- Paradise HD in Tigard Oregon: My story about an exemplary Dealership!
- Sh***y Saturday ride rear wheel bearings??
- 2up seat options for a nightster
- 3rd place isn't bad
- My New SuperLow
- sportster xl1200x compatible oil filter
- Gas Tank Question
- Front turn signal relocation
- XL 1200C starter
- Too Hot to Ride? HELL NO!
- engine case LEAKING OIL
- My finished ride
- 2004 XL front master cylinder issues
- My local dealer kinda pissed me off
- What Bars Are Those?
- 2003 Sportster
- New Bars/New Pics
- 48...smallest sportster?
- Handlebar vibration numb tingly hands
- Sporty - cruiser or sportsbike ?
- DIY rear seat bag ideas? No sissy bar
- Oil blow by and the aftermath
- Flipped Bars
- New exhaust install and chrome protection questions
- NAPA Synthetic 15W-50 in sportster
- cafe racer parts
- **Handlebar Swap Question**
- 883 1200 converson
- Are these the correct size tires?
- 2012 Sportster 1200 Custom Ride Review
- 03 sporty backfire please help
- Older Sportster Turned Bobber/Chopper
- $25,000 2012 Iron!!!
- (New?) SE Sportster Stage 1 Air Cleaner Kit - Round
- Name that aftermarket part, if you dare.
- Wager - how long until my paint chips/flakes?
- New owner of 2003 883 Custom, what are must do mods?
- Remap vs Xied
- One of these days I'll understand shipping...
- Evo era 9 spoke cast wheels on 04 Sportster
- engine light
- Adhesives?
- tire upgrade, rear...2010-48
- 2006 1200L wont start
- Help me modify an Iron 883... on paper
- Keep scraping pipes?
- Tires and tubes
- Shock Ratings for Sportster
- take off problem with my xl1200c , after warm up
- '89 Sportster neutral switch location
- Baffles?
- HF Yellow Bike Lift
- Tell me I'm not the only one
- 05 sportster
- Fwd Controls/Foot Peg Question
- V&H exhaust
- How short of struts
- 1989 XLH 883 Crazy Clankin' Noise
- Difficulty starting up
- Running Lights
- My $10 rear signal relocation on the 48
- a pic..
- 883 front disk noise
- Torque specs for engine mount?
- small windshield on 48/sportster?
- Stock to 11.5 412's on 1200L
- 3 Sportsters... with pics
- Stealership wants $70 for plastic? WTF!
- apes not tall enough: Risers?
- Front Shock on 2005 1200c
- 2009 1200r Roadster Sportster, not XR
- Owners Manual
- Xelement Zip-Off Slant Saddlebag Review
- Best place to get Avon Venom WW
- 1200C riser swap out help
- Another engine noise topic
- Screamin' Eagle 2's fitting on newer model?
- Iron Head Rebuild
- Powder coating heat shield question
- ? For anyone with a bug sucker stage 1
- Shock/lowering question
- A nice ride to inidan larrys in Brookyln *pics*
- 2009 1200L Solo Seat Options
- Is this a good Price for a 2007 1200 Custom
- Seat Options
- Tank trim removal
- Figure Machine XFLOW-R5 ok for stage 1?
- S&S gear drive for sporty cams?
- 48 Speedo mount bracket part #
- 2011 nightster vs. Fat bob
- Front Tubed Tire
- Ape Hanger Styles
- oil lite coming on
- joker air cleaner + rain = ???
- joeyb last show jbxfreestyle
- first harley 883 VS 1200
- Nightster forward control extension kits
- 03 seat on 11 ?
- dimensions of a solo bag
- Crappy Silencer grips
- Show us your Mirrors (Under mounted)
- carb advise?
- '48 seat issues...
- Sportster seat
- 1993 Sportster 2100cc
- Sportster Lowering Kit
- New Pipes & Heavy Breather help
- Paranoid creativity....
- fat tire conversion for xl1200c
- Extended rake/chopper kits
- 2009 XL1200L gas mileage
- Paughco Z
- My homemade Stem Nut Cover
- tank lift/ reserve issue
- Adjusting the clutch
- problem with my road king air shocks
- 2010 HD Iron 883 Red Key Light Flashing/No Speedo/Starts Fine
- speedometer doesnt work, just replaced the sensor
- 1200 conversion
- Low oil in tank, no apparent reason
- help guys... difference between forks?
- turn signals and flipped mirrors
- Finished
- Transmission oil level - help please!
- Clubmans on!!!
- Help with brake fluid
- 96 Sportster, weird slow frequency noise
- Mounting front signals to handle bar
- finally put springs on the seat
- Regulator problem?
- 13" vs 12" air shocks
- I think I'm cooked
- anyone tried to remove wrinkle black !!
- Progressive 412's are great
- Anyone familiar with these pipes?
- Some prick keyed my Iron 883
- "look right" hardtail
- Hydraulic Tensioner
- my sporty just died
- Handlebar Dilemma: Apes or Bad Boy on 883C
- Road6Customs Now Has "Frisco" Bars
- Why are both my local dealers hatin' on the V&H Fuel Pak
- Just stopped working...
- 2011 Sportster Floorboards??
- New 48
- Spark Plug Wires for Coil Relocation
- Kuryakyn iso-pegs?
- I need help with xl 48
- Newbie Sparkplug Question
- Tank Lift, Coil and Ignition Relocation, my version
- rebuilding top end? 1200 88 sportster
- hello fork shifter
- Big radius vs Competition series
- WTT Black '48 tank for nightster tank
- Screamin Eagle Slip Ons with stock air cleaner
- Quick question on removing rear fender...
- Painted my side covers
- New HOG
- Nightster Ignition Relocation (thats not between jugs)
- Z bar install question
- Bdav's Nightster Hardtail Build
- lean/ jetting questions
- Windshield buffeting
- Seat options and opinions wanted
- progressive fork springs ?
- Rear wheel options for my 77XLT
- Is the Brake/Clutch Levers Adjustable?
- Adding a King Tour Pak to a Sportster
- Iron headlight mod
- Where to buy new tire?
- no blinkers/eratic tach
- not shifting right
- if I have xied's and want 2 buy a new ac...do i still need to remap the bike??
- Anyone else got an 883R?
- help with gaskets rings
- Turn Key No Red Light on Gauge no Fuel Pump noise
- Advice needed
- 10 " Z bars for Iron 883
- Belt to Chain conversion. Where to get the parts?
- Gas Tanks
- Sportster sport adjustable suspension. Reservoir shocks
- akrapovic full exhaust now available
- stock pegs on the new sportsters
- Curious Question
- High Miles XR1200
- Progressive Suspension Install
- sportster turn signal question dealer couldnt help me
- 1988 1200 sportster AMF parts??
- Grenade pegs
- Quick and Stupid Question
