View Full Version : Sportster Models
- how to stretch the front some
- Ignition to ACC, key removed, Hit starter, bike starts....
- Pleated seat for Sportsters...?
- 08' 1200c sound help please
- I'm Xied-ed
- Headlight switch
- Basic tire question
- sportster swingback air cover question
- rear pulley/ sprocket
- Steering Lock Question
- Can I identify my baffles?
- Should I be flattered -- or insulted?
- Exhaust Bolt Stuck
- 1993 1200 sportster
- Starting Issues
- honda to harley
- Rear Shocks
- Headlight is friggin haunted,,,,HELP
- Where to purchase pipes
- Exhaust?
- 23" wheel on my sporty
- 95 XLH Oil Pressure Switch
- Mt. Rainier Ride
- Ride to Mt.Rainier - August 2, 2011
- My Baby is COMPLETE!
- Forward controls
- Nightster rear tire traction dirt mark
- Pipes
- Where do I buy a clutch cable for drag handlebars?
- Sporty 06 idle problems
- new bars on the way
- Solo seat backrest??
- 89 sportster problem
- 2000 Sportster Speedo question
- My 74 so far
- carb issue
- What type armor protective gear do you wear.
- Fuel Injection or Carb?
- Losing Battle
- rear turn signal relocation , bullet style
- All black motor on 48 w/pic
- Relocated my license plate
- Lower Fork Slider Replacement help
- Aftermarket Shocks for Superlow
- Big Guy on a Sportster?
- Bridgestone Spitfire Vs. Pirelli Sport Demon Vs. Metzeler 880
- part number help! 48 owners needed.
- Small mod to license plate bracket
- can't remove air cleaner cover
- Master Cylinder Angle
- How To: Internal Wiring Handlebars :PICS:
- Z bars
- Primary issue
- Oil leakkk!!! Help
- Risers on 48 question
- Bought a new bike! 1200C
- progressive 412's
- Got a Nightster tank for my 48
- Oil Cooler Recommendation
- What is fork walk
- Won't start or do anything - Dead computer?
- license plat e light wont turn off. key is off
- No reason to "trade up"
- Feeling neglected.
- Sportster owner for two years now :-)
- 92 sportster 21 inch tire needs raked out
- Slammed rear fender while keeping shocks...
- passenger seating on new Iron 883
- Front Blinker Relocation
- Did My First Somewhat Diffucult Repair Today
- Sportster power
- 08 XL883 wont start
- Just bought a Sportster, and am beginning to have problems
- Handlebar options
- Almost there.
- 2011 Sportster 883 superlow highway speed
- Rocker Box Gaskets, Mileage Between Replacements
- turn signal reclocation?
- Intake on the cheap.
- Need Information for used sportsters
- Light bar
- New Iron 883 Owner
- Yearly trip is planned - heading out Aug. 19th...
- Vance and Hines sideshots install tips
- 99 Speedo on a 97
- WTB: Nash Mini-Gimps black
- headlamp visor on 883c
- '95-'06 Sportster Rental
- Warped rotor anyone?
- "Lap of America" trip on my Sporty w/my 11 year old: 14 days/3400 miles & counting
- 05 883 Brake issues.
- cheap batwing fairing for an iron?
- My Sportster arrived in Germany!!!
- Delmarva ocean city bike week 2011
- Pearl White, Looking good! pic
- My '48.....
- Differences between the 2012 and 2011 Iron?
- Do I need New Bolts?
- Cold start
- Converting a Nightster to a 48?
- big thanks to theses threads on this forum!
- 2005 sportster 883C turn signal problem
- New to forum, have a question about handlebars.
- footboards
- Fuel Leaking
- something my 10 year old taught me tonight
- How many times have u filled ur tank in one day?
- Is this a great forum or what?
- springer seat ideas?
- Are the '08 and later models different from the '07
- Installed new clutch cable..problems
- Replacing grips on my '08-problems!
- I'm selling my Nightster
- Engine Noise, Cruising Gear?
- Thanks for the support guys
- Hello All
- Fuel prob
- Flashing key red light
- super low XL883L 2012
- Still looking for the perfect bars...Help!
- * Fat Front End *
- Goodbye Sportster friends.....
- sportster won't hit neutral when stopped
- Speedo quit, indicator lamps lit...
- Test drove a 1200 today ....
- Need Suggestions - Goggles??
- New Member
- how many miles on your tires when replaced?
- Engine Light Help
- Injector Support on 1200 engines
- Head work
- Solo Seat on 2002 883....help?
- New tire and brakes.
- Vintage tires for Nightster?
- Upcoming 1st time rider. Iron?
- Thunderheader Install on 09 Iron
- 83 XLS Roadster question
- Have any of you seen the new 48
- Leather bag
- FL style seat rail on my 48
- Need help with pipes.
- Advice and opinions
- Replaced air filter, now misfire?
- 2010 Sportster Service Manual Confusion
- Fork Gators
- The best Chopper Video ever....ever!
- Play in the rear caliper
- Odometer time travel
- rough riding
- Headlight issue
- Anyone try black heat wrap on Iron?
- Be safe out there everyone...
- Took My Gas tank Strip Off
- Semi-illuminated license plate
- Iron 883 Whinning when hot... & when restarting?
- Pin-Up girl decals?
- My Iron and my dads birthday present..
- '89 1200 Stalled while riding 40mph
- Are non-illuminated license plates illegal ??
- Pics: I painted a few items.
- *** Nobody has this AWESOMENESS!!! Pics ***
- Lighting questions
- Evo Motor to look like Knuckle or Shovel?
- Sporster Choke
- Sundowner Seat Question
- Well this was a first!
- A 48 with peanut tank & Nightster Tank
- where to get longer brake line for dual front disc setup?
- rear wheel installation questions...
- What speed suits your 883 best?
- Oddity w/ Fuel Pak on 883 iron
- Need Specs for 2011 SuperLow handlebar
- Headlamp relocation
- Any pics/comments about broomstick drag bars on Iron
- Ebay spiked chrome air cleaner
- Will the meaty big one fit between the legs?
- Aftermarket tail light for xl1200c
- Weird engine stall issue and the moral of the story
- Transmission Lubricant Change
- Buckshot exhaust guards
- intake for nightster
- Mini Apes vs Buckhorn Handlebars
- Lepara Barebones
- Sporty vs. FXDX
- What should I do?
- FNG here
- Headlight lamp for 06 Sporty
- Pledge on my Sporty
- 2006 XL883C Exhaust leak
- nightster tank on my 48 ?
- Looking for a member, is it you?
- Idle issues: 06 Custom
- 2- 883 Iron exhausts - factory and v/h chrome shots
- 2002 Sporty quit sparkin!!!!
- Best way to black out primary and tranny covers?
- Got my new tire on
- My Next Project Checklist: New Handlebars on 02 883C
- right side shifter
- Help changing primary fluid
- Replacement Horn : )
- has this happened to anyone else??
- losing my nuts riding down the road!
- Picked up another one
- Stock muffler
- Removing sprocket cover permanently?
- Anyone have Joker Machine serrated pegs on a 48?
- Need seat advice
- Are Sportsters considered "starter" Harley's?
- I think I finally figured out the fingerless gloves
- '89 sportster shorting out
- avon grips
- Where can I find this headlight?
- License plate relocation?
- Exhaust Pipe Rattle, suggestions
- New pics
- $10 ebay find.....
- Modern 883 modded out to look like a 40's WLA
- Popping and backfiring
- Beware of Kuryakyn Products
- Should I remove XiED's before dropping off for service?
- A/c Help
- Anyone around Monterey, CA
- Replacing the shocks, what length should I go with?
- Dual Headlight questions
- any experience on upgrading A/C and pipes on fuel injected models?
- Best 2-up seat?????
- sportster rear fender on nightster: anyone have pictures
- sportster rear brake lock up
- powdercoating question
- noises when starting the engine
- Rear Shock setting
- Sportster Seat Question
- 1987 sportster 1200cc carb problem
- Good Deal?
- 2 engine noises on my 08 nightster im not sure about any ideas
- Rewiring Turn Signals
- Starter motor '06
- speedometer
- Where to get a good deal on V&H Short Shots?
- Anybody using Lepara seats?
- Rear end wobble?
- Oil Leaking from clutch cable
- Play in shifter
- Problem installing Rush slip on's on my 48.
- Will 05 stock slipons fit on 08 sporty?
- West Eagle Narrow Apes
- Fluids
- 1984 1000cc ?
- What are the loudest pipes you can put on a 48?
- O2 sensor - Is there a washer?
