View Full Version : Sportster Models
- 2008 (25 mm) wheels on 1989 sportster (3/4") axle
- Sportster 72 Tank Swap =)
- Set of tires
- Daymaker is flickering
- New 1200N owner questions
- 1999 Sportster 1200xl Rims and Tires
- 2000 & up front wheel sealed ball bearing spacer?
- 2017 Iron XL883N Stock Exhaust Drilled Plugs (Before/After)
- My Humble Iron 883
- noise from primary area
- Brake Squeel
- More torque for the Roadster?
- Alright! Dumb question
- 79 ironhead or 91 883 sportster
- Starts and Dies
- Skull horn cover for a 2011 XL883L?
- 2011 XL883L Gas cap
- Cafe seats
- Installing a 1250 kit advise
- Bake light flickers over bumps in the Road
- Exhaust
- 2003 1200 cough and stumble
- 1st time HD Owner From Ithaca NY
- Error code 0?
- Sportset Bobber Help
- Iron 883 Drag Bar Install Question
- Mounting help with Mustang Pillion & luggage rack
- Roadster Forwards controls and bars
- Fat front tire on Iron833
- Won't start.
- '86 Sportster adjusting the clutch help needed!
- Trading "down?" from Touring to Sportster
- 48 exhaust retrofit
- ecm problem
- So when does the 4-valve per cylinder Sportsters come?
- efi tuners
- Throttle assembly cable adapters
- 2014 1200 sportster cluster issue
- RSD Velocity Stack Issue
- Oil issues remain
- Bobber registration question.
- Need help! Oil in the clutch
- Small fork extension this winter
- Seat compatibility question
- 08 nightster flush mount gas cap
- Definition of a Stage 1 please for a HD Roadster 2016
- Sissy Bar Feedback
- Exhausts
- Help: 1971 900 kick to elec conversion
- too high of idle?
- Hammer 1275
- Screamin Eagle
- Quick release windshield iron 883
- cafe racer fairing on 48
- Iron 883 with flashing gas fuel light
- Front End Swap
- sportster xl883 anniversary custom
- 93 XL1200 bar change
- 2016 Sportster Shifter Arm Replacement
- Replacing the clutch cover. I found oil there
- 2014 xl1200c foot controls and suspension
- Missing Plastic Cover
- Replacement for offset clevis
- Siren Battery drain?
- Sportster forward controls shorter clevis?
- Cobra slip ons and FP3 tuner question for a HD Roadster 2016.
- K&N hi flow fitment
- New to Me 2011 Iron
- 2005 Sporty 16" rear laced wheel
- DK Customs Low Mount Headlight Relocation Kit
- primary chain
- XL883L seat for tall guy
- Battery of Harley Davidson Iron 883 2014
- 30a Fuse side panel '11 XL1200n
- Any ideas?
- Race tuner
- Negative battery cable
- Avon Road Safety 5.00 x 16 On front of 48?
- 2011 Iron B/T/R Wiring help
- Road 6 Customs bars on HD 48???
- 1st gear klunks
- Just wanted to share....
- 2017 Iron XL883N Startup/Revs Stock Vid
- Goodbye, Ham Can!
- 05' Sportster 1200 custom - won't start
- Early style footpeg ?
- Brake light blinks with directional
- car turned infront of me and went down hard
- Taking off slip ons
- WOT high speed hesitation...
- 2016 roadster 3.5 inch pullback riser question
- Usable fuel in a 4.5g tank?
- need some help
- Chin Fairing Questions XL883N
- Valve Clatter - How much is normal?
- Eletrical Issue
- 13 spokes from a 2000-2005 dyna
- 2007 XL1200 popping after mods
- Progressive spacer
- 06 sportster winter project
- Speedo gauge back light?
- mods for my sportster
- Indicator lights 2013 Iron 883
- 1K Service in AZ
- TC Bros reduced forward control kit?
- Sportster won't start
- Reserve, where to find it?
- Flat Cable for 2016 XL1200C Handlebar switches, replacement?
- motor oil vs motor cycle oil
- Low end noise/ Sportster
- Sportster seat. A novice asks.
- 03 Sportster XL1200S
- Controls Somewhere btwn Mid and Fore.
- Should I save my stock mufflers?
- Best Solo Seat For Nightster, Female Rider
- Any thoughts on Amsoil
- Whats it worth
- 1985 FXRS fuse box?
- 09 883l
- After Tank lift and Coil relo CEL shows
- Cape Coral new member needs to barrow jack stand
- Kill switch sound normal?
- Carb cough.
- Widest front tire size on a stock '01 sportster
- front brake rattle.
- Le Pera question
- 2016-2017 Front Fender RIVETS..
- Gray smoke and rough idle at start...
- Are these shocks adjustable?
- 08 1200 Custom fuel filter
- 72 clutch going crazy
- 1st gear to neutral
- OPT7 LED Head Light Bulb
- Big things coming
- Passenger Footpegs
- West Eagle Bikini Fairing Installation questions
- School me on wheels
- Pipe Wraps
- removing the rear fender bolt to install saddlebag brackets.
- Powervision auto tune screen colors
- Changing handlebars on 2016 roadster
- Custom Sprocket cover design?
- What will V&H slash slip on do to performance?
- Haven't had a Sportster since the mid 80s ...
- Sportster 1250 kit oil breathing query
- Will 2016 iron 883 mags fit my 07 nightster?
- efi tuners
- Rear brake rotors and stuff
- tires
- ,,,heated jacket question,,,,
- Extended Cables
- HELP! Apparent Injector leak?
- Sportster 1200C Bar/Riser Swap: Basic Guide w/ Parts/Tips/Pics
- Last changes ... happy and worried
- Riser help
- Screaming eagle super tuner pro
- New Roadster Roll Call
- Dyna Beads
- engine oil change 2006 1200r
- Motor swap
- Ecu relocation
- Picked up my Sportster
- Winter/Snow tires for 883?
- New rider in hurst, tx!!!
- Clearance problems with wideband O2 Sensors? What I did...
- Picture/experience request
- my new bike, 2012 sportster 1200
- Anyone with a Iron?
- Just ordered a Forty-Eight, first Harley
- Ignition Coil Specs
- Tail light elimination
- Might be in the place
- Problem pumping gas
- Best cell phone holder?
- Lcd speedometer xl1200cx unreadable in daylight
- Thinking about a Sportster - opinions needed
- Rinehart slip ons 2014+
- Clutch cables
- Anyone take their Sportsters off-road?
- Sometimes wont shift to neutral
- Installing Chainsikle rearsets - leftside mounting question
- Cracked hose
- why does my Sportster roll when in gear
- Changing My stock bars and all cables to HD Tallboy bars on my xl 07 883.
- Front end hits hard
- Looking For Opinions
- Burley kit
- 2010 883XL Battery Cable Replacement
- What I did to my Sportster Today
- 2016 iron 883 exhaust
- Misfire under load? Thoughts?
- Oyster run on Sunday
- 883 to 1200 conversion
- Where to buy chopped painted fenders....
- Need to replace Iron 883 speedo mount with 1200T mount
- How many miles are the sportser 883 good for?
- Sportster transmission
- My First Harley/Sportster
- 2013 sportster
- Tank swap on a brand new '48?
- FuelMoto question
- fob problems
- '11 883N Fork Lock Stuck
- Rear wheel fitment:
- 2015 forty eight blackened fork
- Lowering an 883
- New pics
- Breather tubes suddenly puked oil
- 2017 48 Cam upgrade
- 03 Sportster stuttering
- New exhaust on 2016 Iron 883
- 1997 sportster problem
- Removing chrome strip from Sportster 1200c tank
- Shouldn't an 80 Sportster have a battery strap?
- Speed Bleeder for 2011 883 SuperLow
- 2004 Sportster 1200, new gas cap doesn't click
- Sportster CV carb top
- Swapping OEM 2008 Sportster 883 Shocks - will 54565-97C Road King shocks fit?
- Hello ( Introductions and a few Questions )
- Load Equalizer?
- Why can't I find pegs that fit xl1200x except at the dealer?
- Harley seat or Le Pera seat
- Pulley swap
- Adding passing lamps with a generator
- Anyone tried these ebay shocks?
- Stage 4
- Tire Mounting/balancing
- 1988 new to me running basketcase
- Help with wire harness
- Adjusting rear shocks for rider weight
- Sportster throttle loose
- 05 883 custom being a pain in the Ass
- My 1968 Ironhead... Info please?????
- Metal collar pulled out of plug wire
- New guy with a not so new roadster.
- Shinko 777s
- Sportster Top End
- Anyone, have an oil pump fail?
- Progressive 444 shocks
- 96 to 10 front wheel
- Sportster Project
- Rear shocks
- New 07 Nightster Owner
- Does one really have to remove fork for this?
- carb adjustment?
- Rear Shock question for Sportster
- clutch problems
- How is it going?
- 1200 Nightster Throttle Loose
