View Full Version : Sportster Models
- Sportster Bronx
- Fuel pump issue
- Starter engages when you step on the rear brakes
- Need a new pressure plate for scorpion clutch
- Pulling my hair out
- Modified Sportster Leans Towards the Weird Side
- HD Quick wash
- 2017 1200 sportster spark plugs
- Mini Floorboard screw
- Primary cover chip/grind
- Diagnostic Port for 01 1200
- What tanks can I direct swap on my 48?
- Custom Sportster Forty-Eight Was Built To Raise Money for Charity
- Sportster 883R tail tidy
- Spark plug firing voltage
- Fuel leak - plz help
- New exhaust
- New whinny noise from primary
- Helping out a young Soldier : Day time running light failure
- Sportster 1200 issues
- 1983 XHL1000 has no power
- Sportster problems
- Error; B2226 - 69994-128 BAS i/p open
- New Sportster Engine
- Jammed Starter. .??
- Electronics are dead
- ignition module replacement
- Help with ignition module for 2001 sportster
- What is this bolt??
- Drag pipes
- 2004 883 custom for CAD$5500 - worth? What to look for before buyin?
- I accidently bought exhaust for the wrong model
- Unattached clip
- 2016 sportster starting problem. Won’t prime?
- Do people really think the 883 is slow?
- 2006 Sportster gas/possible carb issue.
- Looking at getting a sportster.
- real shocks for 883
- 2010 hd-48
- Tell me About this Sportster
- 99 dual plug head to 2005 sportster
- First sportster.
- Thanks for the Help
- Cable and line kits
- Slip ons?
- New clutch and clutch basket. Bike whistles now
- HELP!! Barnett clutch with extra plate issues for 03 Sporty
- 883 bought over weekend what’s stock?
- Lower compression in rear cylinder
- carb, engine, exhaust, help
- Mother Road Custom seat recommendation
- Build Update, it's road-trip ready!
- Front pipe soot?
- 2006 drivetrain into a pre-03 frame
- 88 EVO Sportster engine clatter
- Timing mark diagonal?
- Replace rear brake pads on 2014 48
- regulator/rectifier
- 67 Ironhead starter problems?
- Nightste Tail Light Installation
- sportster 48 year 2015 engine cant run
- Swapping out cam and cover
- Replace belt guard on 2016 883
- Dakota Digital speedo gas gauge question
- Unique Corbin Sportster seat?
- Pricing of 2001 883 sportster?
- Hesitant 883 on acceleration
- Solo seat
- 883 oil leak
- Engine Guard Placement
- 2002 XL1200C Top End Noisy?
- Stock air filter element cross reference
- Oil Drain Hose
- Iron 883 cable recommendations.
- Solo Highboy Seat Thoughts
- 2016 1200 48
- 2016 883 exhaust black to chrome question
- Oil and fuel hose lengths and size
- 2014 Forty-eight rear rotor size?
- Help finding this plugs partner
- what to use ???
- Sportster Seat Compatibility?
- had no chargey
- V&H Short Shots too loud, need 2 into 1 suggestions
- Chain conversion seal removal??
- How hard do you tighten a bolt?
- Kickstand 2014 custom 1200 sportster issue
- Where to begin?
- Fresh HP1275 at the strip
- Sportster ?
- Primary oil change .
- 883r sportster rebuild! (Motorcycles make terrible aircrafts.)
- Barnett clutch problems in 2009 Sporty 1200C
- SE or Big Sucker?
- Has anyone spent the $$$ and put Ohlins on their Sportster?
- 2006 Sportster Parts in RI area.
- Vin id?
- Evolution industries clutch basket?
- 2005 1200C Sportster. NEED experienced advice please!
- Is this dangerous?
- Going Crazy (bars, banjo, brake line)
- What tank do I have on my new Roadster?
- The iron 76 ironhead is back
- primary case hitting clutch
- Rewiring rear signals
- problem with my forty-eight
- Shocks and springs. Really???
- Sportster Takes to the Sand in Epic Crossing
- peg mount pins
- Advice on fork spring replacement
- Loud primary noise
- Starter problem!?
- 2000 Harley sportster starting issues
- '96 883 turn signals and parking lights
- Hey guys I want your help
- Hardtail Sportster with Sidecar
- 96 EVO Sportster w/ no spark
- 1965 XLCH Help
- Snapped bolt when removing exhaust pipes
- Gear switching kick-back
- Throttle won't move/stuck
- Front End
- Will Sportsters go up in value after HD ceases production?
- Slightly larger rear tire
- Sportster 1200
- Two brothers comp 2 2 into 1 stainless?
- Hammer 1250/1275 for 883 Sporty
- 87/94 Sporty having electrical issues
- Starting the motorcycle i hear a knock sound and burnt smell
- Need frame Advice
- Trans tube leak 92 sportster
- 07 Sporty 1200 ECU issues/ compatibility with big twins
- My 2018 sportster dipstick won’t close back again
- 98 Sporty cutting out
- new battery today
- uh oh - Clutch time....
- 1971 xlch forward controls
- Oil leak under 97 Sportster
- Ignition switch
- How many different width sissy bars did Harley make for a 2003 1200c?
- Broken Adjustment Shoe in Primary...Shrapnel
- Paint can Rattle
- 06 883 won’t idle when hot
- 1200c sporters signal lights flash with ign on
- Sportster sales in the UK (& Model K series) before 1960
- Does this o ring fit?
- New Sportster owner
- Swing arm bag
- No more sportster?
- Rear LED Tail light
- 1991 sportster 1200
- 2006 Sportster 883 rear Break light
- 1200 Sportster for a newbie
- Difference Between 883 and 1200 Sportster
- Wheel Lacing / offset question
- 99 sportster 883 Key tumbler stopped working
- eazy-pull clutch
- 1969 xlch
- 1998 Sportster XlC1200 help
- Lowering a Roadster?
- Electric Draw?
- Sporty T-Bar Setups
- 883 Sportster XLH 2000 Fork Slider Compatibility
- forward controls issue
- Shorty on a Sporty (smaller rider tips)
- What happened to this '95 XL1200?
- Which air cleaner to get?
- Which progressive rear shock iron 2014
- Stuttering issue at low RPM
- 1992 Harley Sportster Wheel interchangeability
- Sportster 1200
- Added This To the Garage
- 06 sporty rear lighting
- HD sportster 72 1200
- Bad button module?
- Oil pressure light issue
- Primary cover question
- help with sportster build?
- Clutch engagement
- 2013 XL Iron 883N shifting problem
- Odd backfire, bike ran on 1 cylinder
- Vehicle Speed Sensor ‘18 XL883N
- Intermittent Spark
- Damaged Frame (weld or replace?)
- Spitting oil
- Sportster Production to end in 2021
- Old Guy...Old HD
- Leaning at higher speed problems
- Iron 1200 in the rain
- Does this need immediate attention?
- ‘09 883 Stalling Issue
- 09 XL883C keeps falling out of gear.
- LED lighting questions
- Sportster Forty-Eight Low Fuel Light Question
- 883 died and won't start
- Iron 1200ns
- Stressed the #+&* out. 99 sporty not firing
- after seating for a week no oil in the tank?
- Idiot with a 2007 Nightster. Please Help
- Tranny oil leak from clutch handle
- 883l bolt size
- Morning ride to work
- Primary Fluid
- New (to us) Sportster in the Garage
- 90 model sporty, no taillight, blinkers not flashing
- 2013 1200XL Custom forward control
- New pipes
- Front brake Caliper
- Replacement bolts
- PLEASE HELP! wont turn over and no click red key light on indicator flash 6 x's
- 05 XL883L Tank Size
- 2002 Sportster 883 Custom - speedo and brake lights
- Quiet *** Deleted ***
- 05 XL883c Primary Oil Change Question
- 97 XL 1200C Noise
- Speedo Bezel
- Any ideas for a wider/ longer brake pedal for my 95 Sporty trike?
- 1997 1200c Primary vent or gear box vent
- 1200 not starting
- forward control problems
- 22T front Sprocket
- removing axle issue
- Fuel off to rear cylinder when hot
- 1996 Sportster 1200 crank/ no start
- 2008 883 Custom Acting Weird
- Sissy bar mounts
- Convert 2004 XL1200R to mid controls.
- Front LED Turn Signal Lights, 2 Inch Bullet
- Sportster Solo Seat - Help please
- Forward controls
- Rear rim interchangeability?
- Detachable tall sissy bar
- oil dipstick on 05 Sportster
- New to Harley Davidsons
- Larger fuel tanks for sportster/ even if min to mod fab is required.
- Tes covers
- 1200 T suspension?
- I've got a hankerin' for a Sporty
- The new sportster made in china
- 74 Sportster sprocket shaft extension
- Cycle visions twisted sissy bar
- 2017 1200 idle speed
- Handle bar raise
- Any clue who made these forwards?
- 1991 883(1200 kit)
- Service manual changes, year to year
- The Touring Sportster is Getting Big Changes
