View Full Version : Sportster Models
- Philly Ride To Skate 6
- Wheel Group Buy
- Nightster with visor, too Sons of Anarchy?
- 07 883 rearend
- Tank is looking good, but starter is giving me grief
- 1250 or 1200?
- My 2012 iron
- EFI to Carb. on 2011 883 Superlow
- Exhaust braket ideas?
- 02 sportster trans problem
- S&S Super airbox...
- 2002 sportster battery xl883
- 07 Turn signal help
- 04 sportster 883 custom
- Good affordable battery
- 83 xlh trans problem
- CHICAGO AREA-nice weather this week
- 2012 Xl1200C Really stinks and sputters especially warm start up
- Sportster 48 foot peg change help
- 2012 Iron
- Low end Air Cleaner / Breather review
- First crash, flip goes the Sporty
- Which Front Tire
- Transmission fluid question
- New seat.
- Brake/Turn Signal Help!
- Custom to Low speedo mount questions... I'm almost there!
- Anyone have any ideas/thoughts on these bags..
- 48 xied
- Air intake suggestion
- Finally I got it. Sportster Sport 2003.
- Rear Fender on sportster.
- did some stuff
- Fender swap seat question
- Changed battery and security light stays on
- HiFlow Air Intake???
- Loudest - Best sounding slip ons for 883?
- 48 Tank new paint
- some new 48 mods
- Just Painted Derby Cover..
- Side by Side speedo/tach
- 1200C exhaust options... what to get.
- Belt to chain conversion.
- Back Rest
- Dead sporty.....need some advice
- Spitting a lot of oil into air cleaner??
- Mustang Touring Seats
- Fender Swap and Spring Seat finally done.
- Vied vs PC5
- Just paid the Streetfighter off.
- 883 Iron Black Exhaust options?
- Modded stock air cleaner
- Wont turn over
- Sportster 48 Clip Ons
- Performance Machine Paramounts
- 19" to 18" front wheel? good/not?
- ignition switch->face nut removal, how to
- Shocks on a '72
- Bar swap question.
- Getting ideas for paint job
- iWhats the best looking wide glide triple tree conversion kit for 09 sporster custom?
- Mini apes on a 2011 883 Super Low installed
- Rear spoke wheel, riser/speedo
- Homemade Joker Machine style speedo relocation.
- Theobald Leather
- newbie question
- Potential Starter issue??
- Running rough
- Chain adjuster dripping oil
- thunder torque
- Ignition Module Compatibility (The 7 pin to 8 pin Blues)
- Considering using front fender in rear
- Modding 2012 Sporty 48 gas tank
- 1/4 fairings
- Large object in oil tank $HIT!!!!
- Teal wall tires
- Big rake, stretch needed?
- Question's about lowering Nightster
- free spirits 27 tooth on my nightster
- Tail Light Identification
- Nightster rear light bulbs
- 1st time Harley Owner having problems with the turn signals
- fender strut bolts?
- remounting for 05 1200c speedo
- My Sportster is leaking gas from the carb!
- Engine noise?
- Rough Crafts: Anyone order from them? WTF?
- mounting bracket part number
- adjusting carburetor at higher altitudes
- Fun at the parts counter.
- 1200 Cusytom, struggles to start after sitting for a couple of hours
- Joker machine turn signals
- 12K out the door ?
- a/c decision
- Quiet baffles
- 883 on the highway
- Exhaust and intake combo??
- Things that squish in the night
- Matte Black finish on pipes?
- How to clean the grey part of the motor on Nightster
- 883 Iron V&H Shorties
- '48 __photoshoot__
- Big ride coming up!
- Riding a Sporty in the Rain?
- 1988 Hugger 883-1200 Conversion???
- DK customs ViEDs and outlaw air cleaner installed
- More Speedo Problems
- Post your Past Sportster Challenge Pictures
- Flat black 48 Plasti dip
- 21 x 2.15 stock replacement questions
- Latest Nightster Mods
- Dessert heat Shut down?????
- swing arm bag?
- Widest rear Tire - Stock Wheel
- S&S jetting for ironhead
- ignition problems...maybe??
- My first Harley! pics!!!
- Leaking Grease
- Mini Apes- Dealer quotes $788
- 88 sportster problems
- pointdogg48 Spitfire Struts
- Rush slip-ons for 2012 XL1200C
- Spoke rear wheel added
- Custom fender bib?
- 07 Sportster runs bad in hot weather
- 04 Sportster runs bad in hot weather
- Running a rear tire on the front of my 48, bad idea!
- sportster 883 engine light battery light issues
- Mine so far. Yours?
- Starting problem - 2007 Nightster. Suggestions?
- 883 Iron New Owner
- Spoiler
- Nightster Battery Replacement
- Inverted nightster/iron bars?
- 2012 Forty Eight bobber, start to finish
- strut inserts - can't find 'em anywhere
- 2007 Pipes installation on custom 2003
- Engine light & battery light = dead battery
- What to look for in a Sportster
- tank lift on larger tank
- Bike running bad, dealer says its me?
- 1987 sporty mechanical cam to crank timing
- Primary Drain Plug Bolt Size...
- Help me with a dilemma buying a Mustang seat
- Whats a 08 nightster worth?
- Oil Light
- Auto Clutch - Anyone out there have one?
- Upgrades for '04 Sportster
- Shifter shaft seal replacement.
- Just Bought my 1st Motor Bike and its a 48
- Hi there, new member. 2005 Sporty 1200 Roadster
- Quick question: bar ends, etc...
- Dummy Lights Cover
- Ironhead Front End Swap!!!
- Why didn't I do this earlier?
- 1979 ironhead valve seat
- Before and after lots to go
- Lowering a 48
- broken belt
- oil pressure problems
- No 2013 Nightster?
- Looking for rear signal options
- Bike Finally done
- Has anyone used Nite Shade on their tail lights?
- 1995, 883 won't start
- 2003 Sportster 883c - 12in Ape Hangers
- removing baffles
- Helped a down biker yesterday
- 2003 Risers????
- tts mastertune file for 2012 48 sporty
- rivets vs. rivets
- 72 Ironhead rear tire question...
- Canadian Vol. Firefighters and courtesy lights
- 1200 conv. warning
- AutoSwitch install on a Sportster
- Speedometer just died
- 2008 xl1200c new pipes, AC, and PC5 and it runs like crap
- Does anyone know,,,
- Error code problem
- Nightster 3" Risers
- Z-bars w/ knurls, risers and extended brakeline. Where?
- GPS Mounted for HD Zumo
- 2006 883C Brake Pad Issue
- 2006 1200 Custom Tire Pressure
- Transmission sounds
- 883 iron larosa sidebag install w/passenger peg
- 21" Front Tire on a 1200?
- Sporty a "Real Harley"
- Primary and clutch adjustment ?
- Difference between 88-03 and 04 and later exhaust
- Front Brake Weirdness
- Tranny oil change and engine oil
- fuel question
- When lengthening my rear shocks do I need to lengthen the fork springs too?
- E3 spark plugs a
- I love my bike but...
- screaming eagle 2 into 1
- Who got these bars?
- black smoke idling
- '11up xl1200c - taillight kit
- Iron/Nightster front fender
- Tachometer?
- Noob
- kuryakin hi five mach 2 air cleaner help
- Pictures of my finished silver iron 883 stunt bike
- modding a 2012 iron
- The Day Has Finally Come.
- Wind Sheild and Mirrors
- rough ride
- So it was the vss!
- Driver's Backrest
- XL 1200c Shock replacements
- Nightster Factory Exhaust on 883 Iron?
- drive chain problem
- ghost in the electrical system?
- What jets would you run?
- got rained on now squeaks
- Stock Jet sizes for 1200C?
- don't bother with a hair dryer
- PcV vs XiED
- 2010 1200c runs rough just off idle
- Best 1200 Conversion?
- Strange Problem.
- Owners Manual
- Cobra pro or PCV?
- starter bench test?
- 2012 Ape Handlebar Install
- bars keep moving on me
- I love pay day's!!!!!
- At the drag strip?
- 03 stalls out
- 2002 sportster Tach trouble
- Exhaust/Muffler mix options, any help appreciated
- 48 brake light problems
- 2007 XL1200N Not Starting...Need Advice
- FYI for Run-Turn-brake on XL1200C (good news)
- Tool Kit
- "72"
- Alternative name for "Petcock"?
- regulator/stator replacement
- spoke adjustment
- Mother Road Customs Solo Seat Installed
- Lowers
- Dealership concern...
- '89 Sportster for $1800?
- Fork width on 48
- What z bar hangers & kit?
- 09 nightster clutch question
- Stage 1 for 883?
