View Full Version : Sportster Models
- Efi to carb questions
- High Idle then dies
- Push rod oil leak - need help/advice
- Question on 2015 Pricing...
- Just a few questions about Fork Tubes
- Rush Exhaust Pop When Cold
- Ideas for 2014 exhuast decat
- Anyone have an EMD Vortex air cleaner?
- The Sporty will live! (Rebuild Thread)
- Trading in for larger bike
- '99 XL 883 H-D (Keihin) CV 40 Carb Upgrade Review.
- California Canister and my fuel system.
- Tallest bars?
- Starter Grinding On Startup
- Heavy Breather or Similar Air Cleaner
- Shield Turb.
- Hammer Air filter and VH FP3
- Bit the bullet - VH fuelpak for 08 low 1200
- Iron "baggage" options.
- 2015 Forty Eight.. Vance and Hines install guide. Tons of Pics!
- mods are done
- DK Customs Bullet Turn Signal Install on 2015 48
- Fork Bag for Iron?
- wire harness guard question
- 2 in 1 exhaust question
- 883 Iron speedo backlight issue
- HARTAIL Sporster
- Officially Licensed
- little help/info please
- Sportster ABS clarification
- 2011 Forty Eight
- Air shocks question
- How much to pay for a 12 Forty Eight?
- Shock recommendations for 94 sportster
- switching back n forth between syn and dyno gear oil
- Electrical issue. Help
- Warranty voiding
- Any info about this custom Sportster? White & Blue with a springer front end
- 2014 Iron with first round of mods
- 2015 48 Custom Spring Seat
- @05 Sporster 1200C
- frame mounted solo seat question
- HELP!!! need to replace oil in Primary but don't know how. Please help
- 2014 Sportser: Looking for springer front end
- 72 Stock Round A/C
- Low fuel light always on??
- Windscreen
- Quick Question !
- Wholy J&S Jack Stand!
- Time sert
- Similar pipes to Bassani Sweepers
- Some advice please
- Top speed limiter in ECM or Cobra FI 2000 R?
- Grips
- Just finished my slip on install
- Proper Lift for the 48
- Oil from breather tube.
- speedometer issues
- bad noise from starter after changing coil..please help!
- Just bought a new 1200 t, need a lil help
- Highway bar bolts
- '01 883 - Noise from primary (?)
- Standpipe vent on new sporty tank is sealed
- EFI?s.
- biltwell frisco's
- DK customs velocity stack on 48
- Engine Cut Out
- What air intake should I get after I put V&H straight shot pipes on my 883 Sportser
- 2014 iron 883
- Anyone else fitted Vance & Hines quiet baffles?
- Wyatt Gatling Slip Ons
- 2003 Sportster 883 "48" - Swap info
- Mustang Vintage Solo Seat...my two cents
- Digital Speedometer on old Sportsters?
- It was nice, but I had to make it "mine".
- Couple engine cover questions
- 19" Wheel Question
- Hammer power 10.60s
- 883R Squeal
- Handlebars (HELP)
- Hoppe industries fairings for 48?
- 48 Front Fender Removal
- Sidemount Licence Plate Options..
- Bloater's Harley 48
- Sportster 48 2015 Shock bolt rear tailight conversion
- Old school look on 14 Iron
- Sporty Rebuild
- What tune are you running on your PV?
- Steering Column Lock Malfunction - Dropped my Bike
- Speedo & Tach Glass Cloudy
- First real ride with all my new stuff!
- 883 Tank Bag?
- my coxis...MY POOR COXIS
- 2002 Speedo
- Sportster down...
- installing stock star throttle lock
- Maybe I need to stop wrenchin'
- Ironhead Sportster Project
- Just got my 883
- starter just clicks HELP
- 2008 Sportster Turn Signal Problem
- My Sportster restoration!
- Grrrr......darn it. Leaky or no leaky?
- runs like crap after 20-30 mins riding
- skinny clutch oh yeahhhhhhh
- 2013 Sportster Rear running light out
- Are all mag wheels tubeless?
- Bolt replacement locator
- can anyone tell me what a 1967 xlch is worth
- just a new guy
- New Question old problem
- Cobra, Rush, SE, VH,.....I think I'll go with the snake
- UK Guys; Anyone had a dyno tune by Powerglides?
- Big wheels for Iron 883
- 1200C won't shift
- Hard starting, Choke must be out mostly to stay running, Bubblers, and more
- Progressive Fork Spring Kit - installed!
- 2010 Iron - Noise from gas tank ??
- Engine Temperature...what iare you running?
- Biltwell Keystone bars with 4.5 gallon tank- Anyone got?
- New Master Cylinder
- 883 vs 1200 The real story?
- Street Cannon Replacement Baffles
- Operation fender chop
- Tail light modulator install (2015 Forty Eight)
- almost done...update
- Mini boards?
- Removed rear passenger peg brackets now a ?
- Little info on Sportster's please.....
- H-D Chizeled handlebars on a 48 with risers?
- Water spot stains on rocker box cover
- Rear shock lowering blocks
- Best sounding slip ons?
- Functional 1/4 faring?
- Carburetor cleaning? / choke cable replacement?
- 77 Ironhead weird turn signal wiring problem
- Iron 1000 rear cylinder issues
- Blue pipes
- After a month of spannering...
- HLX 883 owners out there
- DoI really need a tuner?
- Finally some pics
- Has anyones intake seals looked like this?
- Bags with passenger pegs on 883
- question about pipes for my 48
- DK 587 installed....smoooooth runnings
- 2014 Iron wet oil tank cover
- Burly Slammers?
- 98 Forward to Mid controls right side issue?!
- Question about a seat
- 2012 sportster 72 wobble???
- 2009 Iron 883 startup issue
- Seat and mirror
- Sportster 1200C Voltage Issue
- Rear lights keep burning out... Please help
- Mods to my sporster 883
- Part Numbers for CKP and VSS
- Highway Bar Install
- question for Sortster 1200T or (1200c) owners
- Ideas for covering up Nightster ECM hole
- stiffer rear shocks
- heat shields
- Hard time finding actual #s for 883 to 1200 upgrade kit?
- Handlebars handlebars handlebars...the sequal...
- rear brake light
- What a day on my Sporty :)
- Wiring Woes
- rear fender cut
- what luggage rack will fit my sporty
- Tank Fitment Question
- Oil cooler threaded for AN fittings?
- Softer clutch controls?
- New exhaust running hot with black smoke
- new guy, need to get in touch with a member
- Removing Rigid Leather Saddlebags
- Compatibility, 06' and '08 Controls
- 2014 iron with high rpm
- Introduction and question
- Hi-flow air filter with stock exhaust?
- Fork oil drain screw-bolt, size & thread please?
- V&H Vo2 Covers
- V-twin mfg highway bar install
- Best non-marring tools to use?
- Any tips before removing stock exhaust and air filter on sportster?
- Need some help with new bars?
- Time for a CV rebuild
- Summary of Bassani exhaust installation - Iron 883
- Cult-Werks Front Fender
- Oil leaking on fins
- Pretty stoked
- Drago's exhaust
- Dinged up 2014 sporty
- Sea Foam = amaze balls.
- 1989 Harley-Davidson XLH1200 Sportster
- Transferring speedo between bikes
- Vacuum petcock
- Does this look normal
- New Bars
- Gearing
- Wanting to wire a GPS
- Spiked Grips
- 2009 Sportster 1200 custom
- My 72 Riding Impressions
- ~3/4 gallon fuel left, engine seems starved
- Magic Day - I bonded with my Sportster
- New '15 Iron 883 Owner
- Wire tuck, no lift, no coil relocate
- Front end squeaks over bumps.
- After market gas tank vent valve
- Ignition Module ?
- Slip-ons vs complete system?
- Picking up my new '15 Seventy Two tomorrow!!
- 03 883R first road trip
- ignition control module
- 08 tank on a 13
- Removing Rattle Can Spray Paint
- S&s carb
- I'm an idiot...what ViED setting am I running?
- Buying used, mileage unknown - Need Advice!
- Do batteries go dead from inactivity?
- Hammer Impact vs. DK Outlaw 587
- Reading plugs
- top end noisy
- Accent pain on Black Denim
- Deflector DX - on my 48
- how too do the tank decal/logo ????
- Exhaust Help Please
- Hello from TN
- Cable Kit Extention 2013 48 W/ABS 14" Apes
- My first drop...
- clutch cable
- How long of shocks can I get away with? 5'4"
- P1352 DTC after 1200 conversion/coil relocation
- 1250 Kits and the modern Sportster
- sporster 48 and springer help
- Hammer Express 2015
- Looking for input 2003 883
- Longer jiffy stand?
- Need help again
- 2012 Iron 883 exhaust decision
- Should I Chrome Or Buy Another Jiffy Stand?
- Anyone recognize these Ape Hangers?
- Swing arm bolt looks loose
- running like crap
- '14 Forty Eight transmission issues
- Will it break?
- What is this plug under the seat?
- Questions before I buy a 72
- nj sportster Fb group
- My first Harley: A 2015 XL1200T!
