View Full Version : Sportster Models
- Exhaust Baffles
- Right hand control reinstall
- Stabilizer Link - Rear - '07 +
- Lifting '17 Sportster XL883L with Orion Motor Tech lift
- Pulleys
- Need Help Identifying Oil Hoses (96 1200S)
- 2008 Sportster 1200 XLK Custom
- Carb conversion
- 4 Position Ignition Starter 2019 Sporster Iron 1200
- Throttle cable issue - very subtle
- Cobra El Diablo on 2004-2006
- Metal Lower Belt Guard
- sportster 2009 883L won't start
- Help wiring aftermarket hand controls
- Handle Bar Replacement
- Screw for battery strap on Iron 883
- Speedo Issue, Not VSS
- New member
- Wind Noise
- Custom leather luggage.
- Replace rubber lines and brakes hoses?
- Clutch spring down grade?
- Evo 4 Speed Chain to Belt Conversion Back in the Day
- Rear brake caliper on a 94
- 1974 ironhead looking for info on raked cups
- V Inner Error Persistent
- Friend put wrong oil in sporty
- 2024 Sportster S Bluetooth Headset Low Volume
- Vance & Hines FP4 fuelpak specific instructions for '17 883 Sportster
- Thunderstar wheels
- 2002 sportster transmission questions
- Kickstand Bushings?
- Intake manifold gaskets
- 21” front wheel
- Roadster turn signal question
- What part is this?
- Rocker cover bolt question
- 883 Drag Speedometer automatic turning off of the signal light
- Buell heads/rocker covers
- Sportster bags that don't required tail light relocation?
- Viking iron 9 inch bars
- Fender delete style fork brace
- DTC retrieval: how when my sportster has a FOB?
- SP Concepts Lanesplitter exhaust
- 2011 883 sportster won't start!
- Driver Seat Back
- Early Evo Sportster Oil Leak
- Iron fork top nuts
- Calling on all James Gasket users!
- Pinion Gear Removal/Install Question
- Fxr/Sportster combined
- 2000 Sporster XL1200C Chirping and Low Compression
- Recommended A Brake Pedal Tip Extension or......?
- Sportster suddenly lost rear brake
- Sportster 1200 Piston vs NHRA Top Fuel Piston
- 2017 883 is running lean after Khromewerks slip-ons install
- rear brake lock up
- Stop It! better
- Looking for service manual, 2017 Sportster XL883L
- Swapped out those miserable DRAG QUEEN feeler pegs
- Has anyone ever seen this cam set before?
- Where Does The Yellow Wire Go?!
- Fuse Box Cover iron 2011
- Intake manifold seals
- CO2 or brick rechargeable pump?
- Compression too high
- Wider Rear Tire/Chain Drive?
- Help what kind of carb is this? 86 sporty 1100 butterfly or cv
- New Owner of Like-New 22 Iron 883 needing seat/windshield advice
- Help deciding what to do with front suspension after accident ...
- XLH883 2007 Fork Oil Amount & level
- Exhaust Choices
- 07 XL1200L won’t stay running?
- 2004 XL1200C rear brake master cylinder
- Newer EFI engine in a 2004-2006 frame, but running a carb???
- remanufactured pulley?
- EVO Sportster is it going away?
- Speedometer is not working fine, STRANGE:(
- Chopped fender tail light
- 3 in 1 rear turn signals european standard
- Leaking oil from engine into primary case
- 1966 sportster coil
- Contrast cut 13-spoke mags?
- Battery Problems
- Sportster Throttle Stopped Responding
- 1966 sportster forks Help
- 95 Bobber Project
- 2008 XL1200 Oil Leak
- learn more about your lifters
- What is this?
- 2006 XL1200 Bottom End Knock
- Black box
- 2012 XL1200X Forty Eight fork oil capacity
- Sportster Wobble, Help please
- wide glide trees on late 48 legs, axle?
- Help
- 2007 Sportster 1200 xl
- 2007 xl1200c
- Vxied - Transistor Tuner - Any stories?
- Tips on selling 2000 Harley Davidson Sportster 1200 Custom XL1200C
- H-D Bikes shipped down
- OIl Tank Cracked in winter riding
- Stripped primary drain plug
- XL833L ground clearance
- New to me 07 Roadster
- 2007 fuel light
- Sportster concerns
- Turn Signal
- Clutch question
- 1984 Sportster trike kit
- Dressing up my sissy bar / luggage rack on 883
- 2006 883 transmission
- Motorcycle Shutdown Issue at Constant Speed
- Sportster Fork Swap
- Are all sportster rear fenders compatible across different models?
- 2018 sportster cycling fuel pump when hitting the start button
- Hardtail advoce
- Sportster Indicator Light Panel not working
- 2003 Sportster wheel compatibility?
- 2013 Iron 883 Brake pad parts number makes me confused!
- 2003 XLH front exhaust removal
- Sporster custom question
- High RPM at idle and riding
- 1989 sportster gearbox removal
- '82-'82 XLS Tank On '84 Sportster
- Mid and Forward controls parts question
- Spt 883 1995 speedometer solution
- 2009 Sportster cuts out right after start up
- 00’ Carb Dynojet Question
- Sporter 1200 p1010
- Key pairing
- Gallop Thunderstruck exhaust questions
- Finally, motor out of the Ironhead.
- Advice on Sportster Pillion Seat & Pegs
- Forwards/Footpeg Dilemma
- I need help diagnosing my 2009 883 custom accessory short
- Thinking of getting a Sportster
- '82 Carb/Inlet question
- What is the width of the OEM sportster Engine Guard?
- 2004 Sporster Roadster project.
- 03 100th Anniversary 1200C stock riser height?
- 2007 sportster 1200 running rich
- 07 1200 sportster running rich
- Clutch dragging with lots of cable slack when hot.
- Inquiring minds
- Carburetor jetting
- PO132, P0152, P0562 on a sportster
- Sportster Banana Seat?
- Worn Gear Dogs
- Yes, Another No Start - Need Help
- 1200 Sportster Engine (oil) & Fuel flush.
- Shift to 1st geat bang clunk !
- Brake light but no rear driving light
- Sportster 883 2009 Python Exhaust Baffle
- How much venting is really necessary for the heads? DK Customs Breather system flow.
- '48 cafe racer project... maybe
- HSR45 Initial Idle Speed Adjuster Screw Setting?
- 2000s Sportster XL 883 Huger speedo not working
- Cashed in all of my HD Card rewards points
- I hate my sportster primary
- Line on bottom of fuel tank
- 2017 Iron 883 Not Starting
- 883 dies when trying to move in first
- DK Catch Can Chrome or Black
- Battery cover removal
- 7 inch headlight on a 48?
- Dual Brakes Upgrade - 1987 Sportster
- Engine identification by S/N issue.
- 2005 sports term 883 with carb issues
- Trouble with 01 Sportster
- Non-HD, non-synthetic 20w50 / 2001 XLH883 w/1200 jugs
- coil wiring
- Sportster mid control options
- 2007 883 xl primary cover, help please.
- Fork Stop Kits for Sportsters
- What Bars?
- Problems mounting mid controls to frame, bolt problem
- Open your eyes
- 1275 kit Issues
- 1973 xlh
- front fork ride height
- Wilwood GP310 Pads?
- Clutch question
- Saddlemen Long Nose Seat for 2012 w/ 2.1G tank
- Rear brake arm pin removal trouble
- 99 Sportster carb tunning
- Code B2121, No crank, and the esoteric 2015 XL1200C
- Forty eight grip
- Sportster chain conversion (setting chain tension)
- Basic CV carb tuning/adjustments
- Sportster wheel swap help
- battery maintaining
- Headlight eyebrow rectangle opening, what do you cover it with?
- seat/tank question
- 2013 Iron 883 Master brake cylinder sight glass.
- Sportster XL1200R Cafe Racer build
- Primary Leak Gremlin(s)
- 2002 883R Fuel Tank Inspection w/vid
- Saddlemen UN07-03-173BR Unknown Industries seat pics ??
- 1995 Sportster Wheel/bearing\axle questions
- Belt rubs on cover
- Sporty Iron 883 2012 Indicators stuck on solid???
- Derby cover Change >?
- Cam Cover Gaskets?
- 2014 sporty rear tire change and chain conversion
- 4500 RPM upon startup after engine swap
- 1200 Custom tire pressure differences
- single fire ignition on Sportster
- EMD casings
- Front brake line crimped
- Iron head VS Evolution
- 1993 Sportster
- Power Vision Head Temp 460F on a 1200
- What to do next ... can't decide!
- Fork Tube Extensions?
- ID of drain hose
- Rear Brake not covering rotor Please Help!
- Scorched, almost melted carb vac slide plastics.
- 2003 coil and ignition details
- Parts may be hard to come by soon
- Heads Up, fake Lowbrow Customs website
- 1989 Sportster 883 clutch torn and transmission fluid leak
- sporster 48 2016+ upper tree risers mount
- Crank no spark
- Mechanical speedo drive on later Sportsters
- '07 XL1200L Estate sale, what's it worth?
- Superlow 883
- 2005 Sportster tachometer
- 40 psi Front Tire XL1200N
- Fork Tubes
- Diagnostic port on sportster s 1250
- I have read many threads, but none ask/answer this question
- H-D to go all electric in 2025, I read
- 1st gear slipping into neutral
- 1200 sportster clutch pack rubbing
- Harley 48 tyre upgrades
- Help please
- 2001 XL1200C fouling and a couple questions.
- '09 Sportster Iron won't crank
- DK Customs Ignition Relocation - where did you mount it?
- Make of Air Filter
- Help with upgrading turn signals
- Surprises during my top end re-seal and help identifying piston … 2018 Iron 1200
- Ohlins Shocks
- fuel tank lift
- HD Newbie - Gearbox Help
- Struggling/frustrated
- Ignition module wiring diagram
- Wheel spacer orientation
