View Full Version : Sportster Models
- Santee exhaust for 2014 sportsters ?
- Looking for tips on replacing Stator.
- mini ape install
- Gear fluids, reading about ATF in the gear case?
- XR1200 front caliper on Iron 883
- 883 vibration
- FI Sportster Motor Question(s)-48/72/883
- Air cleaner, exhaust
- Advice on Sportser XL833 2004
- 10 inch apes for $100 Should I buy?
- 2014 forty-eight help...
- 1991 883 Transmission not shifting
- detachable sissybar and bags
- Looking for decals
- New Bars don't fit...need help!!
- New to me 48
- changing a map on a pcv? help please
- 2015 iron 883
- V&H 3" Twin Slash Slip-ons
- 2012 72 with Frankenstein trike kit how to value it
- Clutch adjustment?
- How's this Bobber rear fender
- 48 Seat on a 2003 883?
- Headlight
- 883 exhaust.
- Hand Guards
- 2014 sportster 48 part help...
- 2014 Forty Eight Yellow to Red Signals Swap??
- 94 sportster 1200 oil pump swap
- Tire balancing question
- how much oil should drip out of my stright pipe
- Parts for a '78 Sportster
- spring solo
- 03 Rear wheel on a 08
- Need help guys... Brake pedal question.
- Half a Jeffy Stand
- AC Question
- 1250 build not going to plan. Check out these pics...
- oil seal in 86 pump
- Sportster paint issue?
- Long time user, first time posting
- 1994 sportster clutch grinding
- 2007 Wide Glide Nightser Chopper-Finished Build
- Holy crap what a morning I had
- Air shocks, Viking bags next
- ride with power visio attached?
- new from indiana
- Measuring shock length
- Rear Brake pressure switch
- Anyone have 13" shocks on 48
- Now a Brass CatchCan to match the Breathers
- Battery won't recharge
- Traded the Iron on a '14 1200C
- Big guy on a 48 Seat Delimma
- HD Saddle Bag Support Removal Help Please...
- metal flakes in oil....
- Wear it with pride....
- OEM/Aftermarket Rear Hub help
- Avon foot pegs don't fit?
- Peg question
- How much handlebar vibration is normal?
- Frame thickness
- Lowest seat for a 1999?
- emulators
- Scorpion Billet Clutch Install
- Seventy Two Owners Manual
- definitive5 oil filtration sys..$20.99
- backfiring, bogging issue!!!!
- new handlebar recommendations
- Need help/info i want to ride!!!!!
- Few '87 XLH questions
- Engine size?
- High Revs During Start Up
- my 2012 Iron
- 06 roadster battery cover
- 2012 883 iron istrument relocation
- Just wondering how often/miles you have to add oil
- Shopping for fat tire 1200 Custom ('11+?)
- Thinking about Burly 14" Narrow apes, but they aren't knurled. Should I be worried?
- can I turn short forks into normal forks?
- 2007 sportster exhaust
- Oil consumption, 1 qt to 200 miles
- Did a stupid thing today...
- Stator only or rotor too? 22 amp or 33 amp?
- what set up are you running with your short shots?
- Exhaust gasket question
- The 48 is on the road.....!
- Mid controls on my 48 question
- Get a bump when on throttle...primary chain?
- Autumn in the NW (UK) with my Iron
- 2009 XL88c rear axle nut size?
- Short Shots Bracket?
- does the pv-1 power vision touring model work on sporsters?
- Wheel BEarings
- Side Plate/Battery Cover Falls Off Constantly
- Short shots and XIED help
- Looks better with or without the sissy bar?
- oil pump bushings
- so what makes for a poor exhaust?
- 07 883l wot start
- '14 Iron, rear brake squeal?
- Have any of you painted your Iron's???
- 2015 '72 Gear Ratio Change
- Tuner?
- RDW-92/61 0067 is Not a part number
- Trap stype foot pegs ???
- Synthetic oil change mileage
- Anyone know what this bracket is?
- Weird oil issue on a 2013 72
- Sticking Valve on A Sporty
- Can anyone with a 96-03 sporty help me?
- New pictures - 06' Roadster
- Saddlebags
- FuelPak FP3, Arlen Ness Big Sucker, Bassani Slip Ons - 48 - Quick Review
- bell500
- Sporster 1200 Stage one or ? - Setup for Future Trike
- New owner!
- Painting tank
- Idle cable
- Farewell Sporty
- pullys
- White smoke from intake?
- Burning oil smell
- Burning oil smell
- New Seventy Two
- 49 MM Front End on a 07 Low
- My 10 sporster iron883 dead.
- Dogmeat's Sportster Project
- 2011 48 seat on 09 custom
- My New Used 94 Sportster 1200
- Anyone know how to open up Drag Specialties Speedo?
- clutch problem.. quick question.
- Front Turn Signal Relocate Ideas
- Tank lift for sportster
- Considering trading My Forty Eight front end for a Nightster or Iron front end.
- Cylinder leaking oil?
- Which grips?
- '14 iron w/DK 2.5" lift, coil/ignition relocation, wire tuck, Biltwell Sporty 8 seat
- Painting bike
- Sportster FAT front tire
- 2004 1200C questions
- Help! Dying Nightster
- SuperLow 883 tire alternatives & options?
- Problem Rear Master Cylinder 48
- Shifter Shaft Oil Leak
- Handle bar and speedo??
- Hollywood handlebars....
- Help with a 1981 Sportster Carb!
- 1200 roadster
- My 2012 Forty Eight Build (Pic intensive)
- 08 custom Powder / paint wheels. Pics
- Picture Sticky
- New guy with sporster 48 2014
- Locking gas cap for XL1200T Superlow
- Elevation Adjustment - Need Help
- Electrical Problems Help!!!
- 2001 1200 custom front wheel change
- 81 sportster
- relocating foot controls and pegs
- Tire advice
- 1250 kit from 883 reviews
- DK Customs and the Thunder Torque Inserts pull through again
- 13 Inch Rotors
- Weekend Project Update
- '76 IronHead hard starting,'UpDate'
- What tires are you all using?
- Rear brake Sprotor
- Custom end caps
- Handlebar help
- New Harley owner!
- figure machine a/c
- My New Sporty 48
- Advice as to which mod first
- My first bike
- Decibels in stock sportster horn
- [b]wheel question[/b]
- Need a rear brake caliper - What years will fit?
- Need to put on turn signals and horn!! HELP!
- ABS breaks or Not?
- Possible Lifter Issue?
- an other happy customer with a 170 on the back
- from red to green...
- converting kick only to electric start
- HD 48, where to start with customization, and what?
- Help mounting a fat bob tank to a sportster
- Question: 39MM Wide-glide conversion
- cold idle RPM
- Newbie General Question iron 883
- Good battery tender
- Sportster apes
- A worn torq :-(
- How loud are my Cobra Slip ons?
- Wheel Change for a 'project' 883
- My 67 Ironhead
- Nightster Front Turn Signal Options
- What is this under my seat?
- DIY ignition swap for under $35
- Made a really stupid mistake
- Changing tires and wheels on a 1992 Sportster
- 89 Project
- Riser question
- New to Sporty's ..Been wrenching the past few days
- 2009 1200C Sporster Stage I mods info needed
- How to get to battery ?
- Thinking about a 48-need advice & help !
- 12" ape on 2014 iron
- Seeking Wisdom
- 2011 Turn signal plug
- Love it: Harbor Freight Tools Motorcycle Lift!
- I pulled the trigger!
- NW England sure is beautiful!
- Got my new exhaust - Cobra PowerPro HP 2 into 1
- Lost Compression '05 1200 Roadster
- Auxiliary lights with Daymaker LED?
- Rear Turn Signal Relocation
- 19" front wheel for sportster 48?
- Bucking/shaking in handlebars/front fork when taking off from a stop?
- Primary case cover
- Time for a new regulator, should I upgrade?
- Need Some Help On Seat Fitment
- 2003 883 roadster exhaust
- Will it fit? Whatcha think?
- Wheel Bearing Puller / Tool
- Returning the Sporty to a Stock Configuration
- No mess fork oil change
- AMP connector pin removal=DIY
- Service manual for sportster 48
- Title?
- pull back or straight drag bars?
- Rear light and turn signal replacement
- Custom swingarm for wider tire
- Where to buy an ignition switch
- Am I doing it wrong? lol
- Model 48 fork project
- How to add a springer front on 1999 1200 Sportster
- Wiring and more wiring
- 883L Mod questions
- Speedo not workimg
- Headlight grill cover opinions
- Explain this clutch behavior
- All hail the mid controls!
- 2 up seat fitment question
- Why is my Sportster 72 making this noise? (help)
- Squeaking front forks
- best tires for the buck?
- '07 OEM seat compatibility
- Push starting my 883, maybe clutch adjustment
- Sportster Speedo Data Link
- Bike Won't Start - Big Sucker / Fuelpak FP3 Problem
