View Full Version : Sportster Models
- Baffles
- quick question.
- Rear Turn Signals Wiring
- 48 Owners/Experts Please Advise
- Dealer Used Bike Markup Is Double
- New bars on my 08 Sportster
- sportster service manual
- Kevin's 1250 Build
- 07 1200 Custom Tank and Tin Swap...
- Gaskets used in Exhaust: INFO
- Unsure what to troubleshoot
- College student/new rider
- Show us your peanut!... custom paint :)
- 1997 harley davidson sportster 1200 custom
- New seat mounted
- A little help please? :)
- sportster 72 front turn signal wires
- 2011 Forty-Eight odd fuel pump noise
- Handle bars
- Rear fender bolt size
- Rear Brake Issue (probably uncommon)
- Vance and Hines naked vo2 intake
- Screamin Eagle stage 2 kit, don't waste your money...
- 883 Iron Mods
- sporty rear brake pads?
- First Bike Advice
- unpluging o2 sensor
- Some people are just sad..
- Install
- Aftermarket 48 signal lights??
- FuelPak
- Speedo relocation help
- Digital Speedo/Analog Tach Gauge
- Installed Screamin Eagle stage 2 kit....Not happy!
- 883 Heads
- LED flasher load equalizer
- Torx bolts keep stripping
- Buying first used bike...need help for what to look for!
- New Forty Eight owner with suspension and fairing question
- 2014 Iron 883 4/5 gear issues
- Summer disapeared after serious injury...
- Survived an accident...now what?
- sportster clutch broken
- Trickle charge
- what is Exactly CARPROG FULL V6.80?
- RSD Mid Controls
- Pick Up The Pieces & Build A Hot Rod
- What is the best way to adjust the rear brake so it has more bite?
- Fat Boy Lo Headlight ?
- Iron 883 Suspension Overhaul ....for light rider 500$ budget
- Moving hand controls somewhere else??
- Streetable compression ratio and 1200 convertion kits
- 1988 sportster starter caught on fire??
- Recent 48 modifications
- Scorcher 31 slides
- rear view mirrors.. suggestions
- can a quick detach cargo rack be mounted with a saddle bag mount?
- 72 mod project - bobber
- Speedo stopped on my 2006 XL1200C
- 883R cost upgrade to 1200?
- Sportster handlebar riser help !!!!!
- Bell RS-1 Full Face Helmet
- Memphis Shades Cafe Fairing
- Sportster with a Nacelle headlamp - What windscreen/woindshield can I get and where?!
- One side handle bar vibration
- H-D helmet lock... Frustrating....
- Clutch install issues
- I think my rear brake is stuck 'on'..adjust?
- attempted idle drop method
- Carb adjustment screw
- Fussy little gremlin
- Hiding the ecm?
- Solo seat question with chopped fender?
- 41mm or 39mm forks??? HELP
- Local HD Dealer Repair (LONG RANT)
- Forward Controls
- Just got a '03 883R (kept the Street Glide and Softail)
- Primary/Trans and Engine Oil
- What did you pay for your 2014 Iron 883?
- Volcanic Orange Flake 72
- 48?
- Back on a Sporty
- Almost forgot
- Buddies Girlfriends Bike
- Sportster Rally
- Engine cut out
- couple cheap mods... Under $5
- 2009 Nightster 1200 Stator Assembly 30 amp service.
- FrontFork improvement on low budget ?
- Difficulty Finding Rear Signal Relocation Kit for 2012 XL 1200 C
- sweating the small stuff...
- my bassani sweepers
- Nightrider XL-VIED-14
- DK Customs
- Hindsight is 20/20
- parts and accessories in England
- Brake lights staying lit
- Best intake system for my 1200 kit with cams?
- What's the Quietest Open face Helmet you have had?
- Solo Seats...pics?
- bike shut off while riding
- plug wires for rsd coil relocation
- need help on my sporty
- 88 Sportster Tail/Brake Light Upgrade
- Figure Machine A/C
- Low fuel, half tank
- Iron 2014 ..10K update from Colombia
- Almost bought the farm today, cage runs a red light
- has anyone done this?
- 883 weird troubleshooting results
- '09 Nightster project
- New tank ?
- Is $550 for an OEM Iron 883 gas tank too much?
- 2014 48 Aftermarket Exhaust
- Mustang seat with chopped fender?
- Getting ready to replace stator. Anything I should add while i'm at it?
- Skips speed and custom cycles info. Winchester, VA
- 2nd sporty!
- 48 Gas Tank Swap
- Combination Digital Speedometer/Analog Tachometer 70900274 Bezel question
- lowering bracket on xlh1000
- Exhaust question
- Taking my first long road trip on the 48
- Paint shop in San Diego
- Helping a friend with a bar swap
- Lets see your Sedona Orange XL
- Brake line cable help
- Check engine light turns on for 4 seconds at start up
- input on burley slammer rear shocks
- 883 help!!!
- 89 harley sportster charging issues
- XL1200T Exhaust / vibration problem
- as anyne put a larger rear rotor on a 2014 48 ?
- analog stock speedo able to be put on another bike?
- Not my usual, but a fun bike anyways
- Chopped fender + Pillion Passenger (Iron 883)
- helping neighbor with sporty stumbling in mid range
- She's All Clean....ready to ride
- What would be your Second Bike after the Sporty?
- HELP: 1999 Sportster Stumbling at upper RPM's
- Hammer parts, doable yourself?
- I thought I had heard it all
- HELP!!! Trouble starting
- i dont hate this exhaust...
- Saddle bag dimensions for XL883L (2011)
- New tips with factory header pipes and heat shields
- questions on lowering my sportster 72
- 2000 883 electrical problem. Help
- new guy here
- Too Hot?
- Sportster 48 tank
- Is this sound normal?
- mocking up tank lift and fuel line just pops out
- Custom Dynamics Load Equalizer
- Starting a home made 2 into 1..........
- Painted some stuff!
- oil leak 87 1100
- Turning glass paint into matte finish questions?
- shifting speed for sporty
- 1,000 Mile Service
- what do you do
- 12" or 13" air shocks
- Fabulous Day in Hollister July 4th
- First Bike purchasing questions, Help please!
- 2nd place in show
- PLEASE HELP: Need ideas on how to best repair my damaged iron
- Who has Keystones on a 2001 883?
- i dont know where i'm going, but i'm on my way...
- Went down at <5mph in water
- Please advice -- Max speed is decreasing
- $11 mirror and indicator relocation
- gas mileage
- Highway Riding
- 06 883 to 2001 buell x1 heads
- New pipe gaskets smoking!
- 08' XL1200N Rear brake linkage bolt size HELP!
- Roadtrip video
- par for the course, bumps in the road when doing mods on the 48...
- Exhaust question
- Short shots
- sportster riser height ???
- Is it safe riding in the desert heat?
- Screaming Eagle stage 2 kit installed....Question about exhaust?
- Down she goes!!!!
- Hot and Muggy.. 883 running like shit
- Random start-up issue. 070614
- Weird start-up
- Stripped bolt for outer rocker cover
- Carb tuner kit; Jet Fuel jit; or just a main jet?
- Rush 2 into 1 exhaust on Sportster 48
- Buell swingarm on a sportster?
- Sportster/Dyna speedo compatibility?
- Custom LePera came in!!!!
- 2010 street bob trees on iron 883 ?
- HID installation HELP! DDM tuning
- ignition switch relocation
- Carb issues
- What makes a Sportster Low, low?
- Forward Controls with rearset pegs
- 20K Service
- 2004 Sportster Front Forks Leaking
- Rear wheel technical questions...
- 2006(ish) 883 custom
- AfterMarket LED Headlight
- Evolution vs Twin Cam
- Vance & Hines Widow XR 2-1-2 Exhaust System
- The Badlander Seat 51749-07
- Headlight Relocation Ideas
- Possible clutch issue?
- Superlow brake pedal too high
- Here she is - dressed and naked!
- Buying 76 sportster
- Backseat for Iron 883 Sportster
- Harley says 170 won't fit.
- rine hart racing 2 in 2 stagared question
- Exhaust Question
- Need help Id'n my forks
- Cable lengths
- Viking saddlebags
- Check Engine Light on with codes P0131, P0506, P0507
- Right way to ck eng oil on 2005 1200
- Removable Passenger Pegs
- Coil relocation using horn bracket
- 883 Sportster Losing Power
- Spitzies HD Albany NY.
- Probably should let it warm up but...2014 efi 48
- BDav's Nightster Hardtail Build Take 2
- Need help finding these exhaust tips!!!
- Fitting Hollywood Bars to 2011 48 anyone?
- 2014 Sportster 48
- speedo swap possible?
- my 95 1200c
- ignition switch replacement options
- HELP needed: National Cycle Light Bar, model # N935, for HD Sportster 04-10 models
- Got a leak, need info...
- Bassani Road Rage 2-1 is On
- vh with bassani
- What year seats will fit 2014 Sporty 883?
- Problems running
- 18" Sportster wheel swap
- Pros and Cons of a rethread
- Progressive Monotube's - Feedback from anyone using them?
- big exhaust+high flow intake=?
- Local HOG Chapters
- Vacuum switch
- New superlow 1200t
- 7in LED headlight install 1200C
