View Full Version : Sportster Models
- Rear blinker caps
- Step Jack
- Iron 883 to 1200 29836-10A kit tune questions
- heated grips
- Replace the piece or the whole part?
- 883 Hammer Kit Issues w/ Timing and TDC
- Kuryakyn velociraptor and external breather?
- 2003 Sporty 100 year anniversary starting issues
- 2005 Sportster Wheels
- Help with the end-to-end length dimensions of MY2013 HD-48 Throttle Cable and Clutch Cable.
- Bobber Wheel Set-Up
- 883 iron overcharging
- Rear Shocks
- 883 Suspension
- Cams
- Ham can insert dimensions.
- 2004 883C not starting
- Fuel line
- xr1200 stock fork spring rate
- My progress so far
- Son's Xmas goodies for his Iron
- Change from OEM to LED lights
- looking for source for older kit instructions
- Merry Christmas and a FP3 question
- Sporty got mentioned in Revzilla's Five Biker Myths
- Merry Christmas.
- Directional Relocation Rear Turn Signals
- Took a bigger hog for test ride
- 1200 Nightster Tyres/wheel up size
- Anyone Here Running a Lectron?
- Fuel, fire, but no start
- Canadian 'Panster' Keeps it Simple
- Continued Nightster issues
- DK stage 1 air system
- 2003 Sportster Tapping sound
- Experience with Joker Machine Omega Air Cleaner
- Tune or not to tune
- 06 XL1200C - no forward drive
- Saying goodbye to my 16 Sportster 48
- JSK Custom Design Makes Cafe Racing Sheik in Sportster 1200
- I'll be back in the saddle soon!
- Oil pump question
- 2019 Sportster Roadster 1200 Won't Start
- Another rear tire size question (883 and Avon 170 on rear)
- 06 Sporty Battery cables
- Brawny Built Transforms Sportster Into a Real Intimidator
- Iron
- Integrated taillight for 2009 XL1200L
- Akrapovic slip-ons
- FP3 map with stock exhaust and air filter
- 2005 1200c
- Crank position sensor
- Daymaker Headlight
- sterling chromite 11 clutch cable
- 2 in 1 set up
- Phone as Odometer Speedometer Tachometer ?
- Dragonfly Green Cafe Racer Sportster
- Rocker Cover Leak - Wrinkle Black?
- 2014 Sportster LED Tail Light Not working CANBUS?
- Battery
- XL883C Turn Signals Issue
- Bank Angle Sensor info, especially for those running aftermarket ignitions
- TraskTurbo... Oh lord! I was running away.. now I see this lunacy....
- '17 883 IRON Speedometers relocation, over the eyebrow or flat over triple tree
- Purchase Clutch cover
- Braking Is a problem ??
- primary chain adjustment without moving the wheel
- ABS is possible
- 30th Anniversary 1250 Build
- 1200 upgrade
- 98 sportster runs great and revs up in neutral but When riding and given gas dies
- 05 sportster mystery sensor
- Exhaust slip ons for 1990 sportster 1200
- Screaming Eagle intake emblem
- Dual Headlights for a sportster
- 3 hammer powered bikes
- Kuryakyn by Kellerman Atto's?? - Cafe Roadster
- Motor swap
- Help
- 2000 Sportster oil leak
- Custom Cafe Racer Sportster Leaves an Impression
- 04 Sportster: Hot wires but no power to starter
- Need info about my forks
- Wide tire conversion
- baffle upgrade?
- Progressive Monotubes, worth it?
- Rear fender
- Strobe Brake Controller Module Wiring for 2009 Nightster
- Backfiring
- License plate holder with bobbed fender
- Swing arm on 2005 Sportster
- Progressive cartridge question!
- 1989 sportser 1998 motor swap
- 1998 Sportster XL1200
- SPORTSTER 2019 49mm FORKS
- Electrical problems 97 xl 1200
- Odd running light/ turn signal problem
- Skid plate
- Which brand clutch cable?
- Odd 1st Gear Slip Issue
- New-to-me 2012 1200C exhaust issue?
- Suspension upgrades !!
- Price for 2003 Sporty
- Iron head fans
- Hammer performance 883 vs 1200
- Roadster Speedometer Light Sensor
- What Octane do you run?
- Need advice on exhaust
- When Should Low Fuel Indicator turn on?
- Saw this 1200 Iron on YouTube
- Upgrade troubles
- Sportster no spark. About to throw my toys out the cot.
- Forward Controls on Sporty Part ll
- Made a seat from scratch for my Sporty
- 21” front fat spoke tire
- My 97 1200 I custom built this sporty.an it gets so much attention I'm almost jealous
- Iron 883 - periodic stutter/stall when starting after Stage 1
- Air Blowing Back Through Air Intake
- Rear shocks bottom out
- 2001 XLH 1200C Rear Fender Wiring
- Progress on my 883 so far, and winter plans
- 07 Sportster rear end Questions
- It’s time for some Sportster revisions Harley
- 00 XL1200C riser change.
- Electrical Gremlin
- Rubber mount motor in a '95 frame?
- Trans oil
- What main breaker or fuse
- Rear brake help for Sportster
- Sportster classification?
- Twenty Twenty drag racing 1275/1250/500
- Care Package from DK Customs
- Air cleaner replacement, Unknown hose
- 1995 Sportster 883 Hugger Starter problem
- Sneak Preview
- Need help with carb adjustment..
- 1980 xhl Chopper style wiring charging system
- Breather bolt
- Adjusting the Air Fuel Mixture Screw
- Tach?
- Help with 86 Transmission.
- Air suspension setup
- 1999 swing arm axle kit.. bearings,spacers, ETC
- 84 xlx-61 cranks but won’t start.
- Sportster 180 Tire 17x4.5
- Please help me buying a battery
- Steering head and swingarm grease repack
- 20mm Belt Drive Comversiim
- Pump Jet
- 2009 Nightster Relocation Coil Plug Wires
- Lighting Issue
- Short daughter
- Rear cylinder leaking
- Calliper problem?
- Where oh where am i?
- 2 Finger Levers
- battery fitment fitment
- Rear left turn signal light dim on my 2016 iron 1200
- Round Nostalgic air filter cover for 2015 XL1200C
- Is this a Harley Sportstrer Fender?
- '03 Ident
- 2000 sportster turn signal problem
- Handmade forward controls
- Tires
- 11-year-old bike with only 4,000 miles?
- Want to buy a vintage Sportster
- Iron 883
- Can you use HD OEM gaskets?
- Head torque sequence
- Raked Cups?
- Sedate 883 Sportster XL Becomes Dirt Worthy Scrambler
- 2009 1200 Nightster No Crank issues
- Missing something??
- Rear master cylinder
- 2012 Sportster 1200 Nightmare issue!
- O-Rings for Check Valve, Male End in Tank.
- Front fork seals shot ??
- Front Fender Not Straight
- 2007 Nighster 1200 No Start
- Vibration at 2800-3200
- Bike died on interstate
- Headlight Grill Removal Forty Eight
- Throttle Cable at handlebar loose
- DK custom EBS and Outlaw 587 install
- 05 Sportster 883 Custom Won't Start
- No starting bike
- LED Blinker & Break Lights
- Brake Upgrades - Rotors Necessary?
- 89 fork question
- Vicious loud constant vibration noisec from bike even while coasting with engine off
- sportster year identification
- Received new speedo/tach, need verification please!
- need help
- Gas Question
- O2 Senor colors are the same?
- Iron 1200 Is Pure Inexpensive Fun in an Attractive Package
- What are they like to ride---Sportsters?
- Sportster 48 vapor canister (delete?)
- Throwing some parts at a Forty Eight
- Rust, 2020 Iron 883
- 04 sportster 1200R what is the best all around seat for long rides
- sportster wiring
- sportster wiring
- Vance and Hines Short Shots.
- Mpg
- Weird Rear Master Cyl Issue
- Progressive 444 or orlins hd145
- Sudden increase in engine vibration 01 1200C
- 86 Sportster Transmission Questions
- Noise in the clutch , squealing at take off
- 1200 Custom
- Hope it's in the right forum
- Roughcrafts air cleaner question
- Headlight mount
- Wheres my wellnuts?
- Well , that’s clear as mud !
- Exhaust Fumes
- Handlebar for Roadster 2005
- Oil tank breather pipe
- Iron 883 seat
- Cell Phone Holder
- Fork tubes 2 inch longer
- Sportster convert to softail
- Rear break issue
- Sportster 883/1200 power issue
- ‘09 roadster 1200c locked throttle
- 2020 HD sportster 48 weird gunk in fuel tank (upper area)
- 2007 sportster spoked rear wheel
- Speedometer.
- Sportster kills at speed.
- Which did you choose?
- Windshield on a Superlow
- Frame wierdness
- High temp paint causing excessive heat?
- 2002 883 Starting issues
- 30th Anniversary Present
- Raising Sportster Ride Height
- Installing Custom Dynamics Magic Strobe on 2018 48 Special
- Good deal ?
- Drinking oil .
- VOES Vacuum Source
- 2005 Fuel pump adapter plate?
- Dunlop Giving Away New Sportster for a Good Cause
- Ground bolt stripped, help!
- Forty eight with 4 gallon tank
- What constitutes “high flow” air cleaner?
- larger Sportster tank
- jfg racing megaphones any one fitted them
- bearing retrofit question
