View Full Version : Sportster Models
- Forward controls
- Sprocket cover belt guard tool fits?
- what is it worth
- 1200 kits
- 48 stock exhaust to Slip-ons?
- Thinking of ditching my 48 for an XSR900
- Harley-Davidson Sportster XL 1957 tire and rim
- 1996 1200 Custom
- Super slow airleak?
- I built a skid plate for my 06 883/1200 Sporty
- Relocation and Tank Lift
- tom
- Aftermarket or Stock?
- Any experience w/ Accel COP Steath coils?
- Size Deka Battery
- Cycle Visions Old School Attitude Stick Sissy Bar - XL883C
- mufflers
- Can anyone tell me how to Chopper wire xl 1200 s
- Pros & Cons Of Same Size Wheel Front & Rear?
- 1996 Sportster Electrical issue should be simple!!
- D&D Bobcat 2:1 Sportster exhaust install headaches
- Another light not working - about to blow my brains out
- lifter noise
- Docking Kit Button Head Screw Size
- 2007 1200C wiring - what the heck is this?
- Fender Edge Light as brake light on 2008 883
- Highway Bike Died
- Tire Life
- D&D Bobcat Exhaust or Two Brothers Racing Comp-S Exhaust
- Beefing up the clutch?
- Need some shock advice
- Is this part essential?
- 06 sportster issue
- Prime the Oil Pump?? 1993 XLH1200
- XL1200CX Roadster
- Parts required for chopped fender replacement
- Hammer 1275cc for street use??
- Sportster Manuals
- Gas Leak Mystery
- 1988 Sortster Axle Nut Size
- sportster 48 clicks but wont crank and starts..
- 883 to TC88
- Aftermarket Replacement Gas Tank? Iron 883
- New battery dead after 20 days.
- Wheel weights?
- Handlebars - TC Bros Speedline vs. Biltwell Window
- No Patriot Defender Pipes for Sportster?
- High Idle
- Ape Hanger Question 2017
- ShortShots w. baffles VS Twin Slash 3" slip-ons
- Anyone installed a proportioning valve in their sporty
- Black plastic thingy over my headlight
- Electrical Issue
- Good price to pay for a '94 Sportster 888?
- 1987 clutch basket rotor magnets
- High Idle
- fuel light and neutral light on my 2013 sportster 48 xl 1200 x
- Roadster 2016 throwing up dirt after installing side mounted license plate holder
- Help with handlebars
- '04 Rear Brake Dragging
- 2017 Sportser 1200t low rider
- Help find these parts to post to uk
- Frame Replacement Cost w/out insurance
- replace master cylinder rear axle
- 70 ironhead timing problem
- Uneven compression on top end rebuild.
- 2008 nightster 1200 XL won't start
- rear brakes
- On and off noise from rear brake 2004 1200c
- Forward controls on Iron
- 2016 Iron 883 - 1200 conversion
- Sportster seat
- Alarm issue
- 883 sportster
- Increasing GC in Superlow
- new to the forum and sportster
- windshield for 2017 48
- Iron 883 or Forty-Eight. HELP!
- Turn signal troubles - 2002 Sportster
- New and worrisome sound this morning...
- Rainy Ride
- Tires for 99 1200s
- 1997 Sportster 883 - No electric power
- P code 562
- After market Calipers
- 97 Sportster 883 idle/tuning question - New to Harleys and CV carbs
- swapping forward for mids & shocks question
- Rotor Wobble
- Brake Install Help???
- First HD - XL883C - What To Check?
- New w/Sportster Question
- Turn signal running light wont come on
- Breaklight and Running Light Stuck on
- Killswitch stuck on off bike wont start
- Make a silk purse out of a sows ear...
- 2008 Nightster 1200 Advice?
- Wide Glide Chopper (XLH 2002)
- Footboards Full vs mini
- 48 comfort
- Need help with 2000 sporty 883
- Harley 48 Passenger Backrest
- No Taillight or Running Lights
- Re-mapping
- JPCycle Forward Foot Control
- New Guy
- rpm at highway speed
- Any short riders?
- stock exhaust question
- Tuning Pre-Stage 1 Worth It?
- belt drive drum installation
- belt drive hub installation
- Best tail bag for 883
- 91 sportster 1200 xlh
- How do I tighten this rod?
- Sportster Turn Signal Relocation DIY
- Trouble shifting gear while bike is running
- Dropped my bike and tips on how not to stall?
- 21'' front wheel caliper problem
- 4 Speed Sensors in 2 years
- 2007 Harley Davidson sportster 1200 xl custom
- Picking up today 2009 XR1200
- Upgrade feedback request. Pipes and seat.
- 1999 1200 Sportster Blue and Grey
- 1978 xlh, tranny. No gears. Questions, advise
- New member from colorado springs CO
- Remove seat post 13' Iron 883
- Suspension 883R '02 question
- Rear Shocks
- Help, Stripped Screw in Handle Bar Control!
- 1996 Sportster need help with wider front end
- 07 XL1200 Rocker Bix Gaskets / Smoke
- Corrosion on break disc/forks. HELP!
- Speedometer swap
- new bars! (Switches question)
- Rear pully
- 10 Best Harley-Davidson Sportster Models of All Time
- 08 Roadster - replacing rubber engine mounts
- Getting Ready for the Season
- 87 Sportster Scrambler
- Iron 2010 rear left turn indicator
- Sportster 883 EVO noise from gearbox?
- Sportster pillion seat for Nightster
- Sportster 72 maintenance book?
- disconnecting turn signals without cutting wires
- Rear brak/tail light fuse keeps blowing
- 99 sportster 1200 first gear slip
- rough running at low speed
- 2-1 exhaust for Ironhead
- Seat change
- Bike shuts off when I stand it up
- SE stage one air cleaner oval vs round
- Two critical questions
- New Sportster Owner
- What happend to my tire????
- Low fuel Light
- 2003 XL1200C - Transmission gear tooth count
- Forty Eight 2017 Can Bus Error.....?
- Sportster turn signal issue
- Rear Turn Signals Light Bar
- Lots of popping during decel
- Price of a 16 Sportster Iron?
- Alan Grossheim
- Need help finding this tank
- Tank Bag?
- 2006 Sportster Custome battery cover mount
- Iron 883 can't find basic HD logo black license plate frame
- New 1200 custom 2017
- Spring inside primary cover
- Help!
- More torque
- Iron exhaust (s) , new ideas ?
- 2009 883 custom clutch problem
- Breaking in my 2017 Iron.
- Luggage Rack Doesn't Fit my Sideplate
- '17 Roadster. Big Sucker, V&H Slip-ons, FP3: My take
- Help 98 sportster wont start
- What di I need?
- Can't Decide: 883 Iron as is, or 1200 upgrade, or 48?
- New 14" apes on the sportster 48
- 1200 S Riders?
- Forward controls
- Ride with caution always
- 2001 Sportster S exhaust question
- efi sportster woes
- 2015 48 running lights/blinker problem
- Hello from Minnesota
- 2016 Sportster
- Still have not received exhaust from Licks
- Pipe Question.
- What size nut for sensor
- 1979 Ironhead XLCH
- My rear shocks arrived today! Ohlins HD145E (S36E)
- 2002 1200 Custom Shifting Issue
- Rear cylinder misfire EFI?
- 2012 Sporster XL883L Turn signals working only 1 of 4.
- Tail/Brake light Wiring
- Michelin Scorcher 32 good?
- Chain conversion 2003 sportster 883 1200 converted
- 2002 sportster electrical question?
- Hey everyone
- Stock clutch, or what?
- LED turn signals
- noise coming from primary drive
- Saddlebags w/o Turn Signal Relocation
- 05 883C throtle cable length
- Speed Sensor Problem
- iron head vs EVO
- Sportster fuelpack
- Is it just me or...
- 48 speedometer problem
- Roadster 2016: Cowl fairing, Cant find one for Roadster, Anyone installed one?
- My Sportster just died while on the road.
- Crap! I got rust
- So a little baffled about something
- Any one else here riding a xl1200r
- 2016 Roadster; Diameter of front forks?
- Colin armstrong
- Need advice about changing my bars
- 1st 106 miles on the new Roadster, observations
- TARGET TUNE Installation on 2017 Iron XL883N
- Roadster and XR1200 forks the same?
- 2002 Sportster 883 stalling
- Roadster footpegs
- Sporty owners @ Arizona Bike Week?
- Short shots on an 01 Sport. Need new intake???
- Vance & Hines on 2015 iron
- Braking question
- So, how long till the magic of Redline 75W90 kicks in??
- Rough running 1200 Low
- 2006 sportster 883 tranny fluid question
- Stage 1 mpg
- Xr 1200
- Xr1200 power vs reliability
- Stage 1, FP3 - sputtering at low rpms when cold
- Swing Arm Bag
- O2 Sensor wires 2016 sportser 48
- Quick Writeup/Pics of DK Customs Outlaw Filter & HD 4'' speedo/tach combo
- Fork pinch bolts
- Help! : Thunderheader or Road Rage?
- Looking for seat suggestions!
- 2017 sportster saddlebags
- Primary chain noise
- HELP! 2011 Harley Davidson Iron 883 , Front Brake Lever
- New upgrades arrived for my 17' XL883 today!
- Forward controls on 883 IRON
- Cobra fuel management
- Difficulty removing bolt for 2up seat
- Project or Part it out????
