View Full Version : Sportster Models
- 2013 Iron 883 WIP
- Installing a air Kit on my sporters
- Primary Chain
- Bobbed rear fender
- Static timing evo sportster
- Clutch engagement question
- 2004 883 chock needle wont stay?
- Question about handle bar swap?
- Changing Brakes/fluid on 03 Sportster.
- Shifter shaft seal replacement.
- Can you put LED lights all around??
- Update on suspension upgrade: Swapping Racetech in for Progressive in the front
- Wrecked Bike Engine Quiestion
- been out of it for a while...looking for a new to me ride
- Clutch Adjustment 2010 XL883L
- Engine Guard Chaps
- White wall tires, "wide?"
- Installed jets on 96 883 and now leaks gas
- questions about 1990 1200 sporty
- Cleaning/polishing Products
- 1 baffle ok?
- Just ordered a Memphis Shades Del Rey for my 48
- My new chrome flake 48
- red idiot light shaped like a key in speedometer.
- New Bike
- How do I know if my 2014 48 has Hd Smart security?
- My 883....
- My 96 xlh200 before and after
- Does anyone know....
- Stripped Thread #$%&
- Get your software updates!
- retro wiring indicators on a '99
- Actual cost OTD??
- 2004 Sportster 883 no start today
- Front Signal Light Relocation Question
- Lowering ??
- Fuel caps
- 2009 1200 nightster problem
- thuner torque inserts sound question
- Sportster opinion
- Another Break Question
- rear brake light
- Goodbye Sporty!
- 2014 FLHX problems
- Foot Peg Extensions - very nice!
- 48 riser question
- Frustrated rant about products ordered online...
- Auxiliary Brake Light/Running Light/Turn Signal Conversion Kit
- Suspension questions related to raising a 883L
- 2009 883 Clutch issues?
- A couple of dumb ass newbie questions
- Brake pads?
- Thought on mixing oil in primary/engine?
- Breather kit install question
- Front fender
- Good deal on a sissy bar bag, while supplies last.
- Spark plug?
- My 2008 nightster is bogging down...
- Sportster fuel tank dashboard with odometer
- HD spring seat on mother road customs mount?
- Has anyone replaced their oil tank
- Springer front end for forty eight
- New game! Called "wtf is this I found in my primary!?"
- sludge in oil :(
- Tuner, xied, fuel pak?
- Quick Question
- 1200 Sportster spark?
- Looking to replace my rubbermount oil tank
- place to store insurance and registration
- HD-Sidekick, or Mustang Fastback seat opinions?
- Stock Exhaust? Nightster
- SC3 Adventure Dual Sport
- Xied...Vied?
- Horn
- Rear brake light harness
- My bike got hit!
- Wife's Nightster not starting
- Newbie with questions!
- Possible Seat Upgrade - which one??
- How long was your longest ride?
- Sportster Challenge II is on
- Does anyone else mark bolts on their bike?
- my xl1200c and mods so far
- Quick seat interchange ?
- Softail Sportster
- frustrated on battery/ charging issues
- Total suspension overhaul complete: Some thoughts on upgrading an Iron 883 to corner
- New Member -- Saying Hello
- stator test
- 883 lost ignition
- Harley 883 Iron Air Ride Pressure
- long rear shocks on a 48?
- Dirty Old Ironhead
- Nightster Mods
- How to Get Rid of Knee Pain?
- Best replacement battery for 1200
- Turn Signal Removal
- Hand guards
- wheel fitment from other models for 07 sporster with wide gide front end?
- DK Customs coil and ignition kit question?
- Question about Shocks
- Biltwell Frisco Bars on 2007 Nightster
- Recommended add on's and accessories
- Mean City Cycles Seat Mods?
- banjo bolt question
- Pls help ID issue...new noise. Bearing? Tranny?
- 08 xl883c vibration, sometimes
- Tank off bike. How can I drain?
- What do ya think of this one guys
- 2"or 4" over fork tubes??
- Bad Fastners 2013 Sportster! anyone else?
- Negative battery cable holder
- sportster flyscreen
- Hesitation on cranking/starting
- Passed my safety course today!
- Pain while riding..
- My new ride!
- sportster side mumber plate and sissy bar?
- Chopped or laydown taillight and plate mount 97 Sportster
- NEED HELP gnition Switch Wiring Help
- Nightster Project
- Best 2-1 exhaust for my application? Nightster, lean angle. performance.
- 1991 headlight
- HD's new chizeled ape hangers on 06 and earlier Sportster
- Sportster 1200 C Cuts out when hot
- help with shocks
- Touring type seats
- Damn brake light
- 08 Nightster won't start need help!!
- 96 XLH1200 ignition issue
- clutch problem, rivets came loose and gouged basket
- New directional LED mirrors and Digital Speedometer!
- Idle Question
- Riser question
- 72 Bigger Tank
- Sportster Nightster and seat height
- I'm in!!
- 2004 iron 883 forward controls and bars
- Possible change for 2014
- Gone but not forgotten
- Is this a good deal? 09 Sportster 883 low
- Sporster basic maintenances
- LED Fuel Cap ANYONE INSTALL ONE??
- Fitment of the LED Daymaker on the 48
- Nice last week of summer....
- Lowering a 03 XLH
- DK Customs Stealth Highway Mount Kit
- HELP Stuck Clutch!
- La Rosa 16 Inch Spring Seat On Sportster?
- Tire life of Dunlop 401 rear & front, and belt too? Also, where to buy
- Oil change interval? Mileage or yearly?
- Brake light and rear turn signals wiring question
- Who has 2006 XL1200 C with Drag Bars?
- questions on gearing and exhaust...
- Click click click
- Need Advice on V&H exhaust fix
- 1200S experts? Rotor cup issue
- Rear Wheel bearing
- 48 Rocker Box Covers - Clear Coat or Bare?
- 09 iron parts on an 04?
- XR1200 - Tipped Over - Bike Wont Start and Stiff Throttle
- 2011 48 with 24" Drags & New Joker Machine Upper Triple Tree
- Primary whining.
- Michelin Commander II report
- Harley Davidson 48
- Installed V&H slip-ons last night
- Chopped Fender Added Light Mods
- 1973 sportster
- fender bag?
- Is there a tool for removing Wires from Plugs?
- Conventional wisdom
- Red Spoke Wheels?
- 883 to 1200 question
- 1984 XR1000 Carb issue
- engine and primary fluids
- 97 883 valve train noise
- Kinked Front Brake Cable
- HELP!! 08 Nightster
- 2nd Gear Rattle
- Harley Sportster Problem, Transmission?
- front brake like a rock
- Biketronics BT-300-Tailbones Help Please
- Throttle grip glued?
- lifting?
- Another New Guy
- air intake systems
- Fairing question
- Power Commander V Update
- My first big group ride on the Superlow...
- Cutting a painted fender
- Do you think it's time for batt change
- Before I buy. What do you guys think
- messed up throttle cable when installing grips
- Anyone have one of these?
- 05 883 custom battery cover
- 08' 883L Forward Controls
- Customizing '02 883
- RPM behavior
- Shocks on my 883Low
- 07 tail light bulb
- Forty Eight Oil Question...Too harsh?
- RSD vintage short stack
- Turning clunk question
- Compact Sport Wind Deflector - Installed
- "XLT" Help
- Ride height;
- Sons first Harley (proud dad)
- Any tips on how to ride a Harley 72?
- Magnetic Traffic Light Triggers
- Power commander V question
- front wheel bearings broke
- Oil leaking from oil fill hole...
- Real saddlebags
- Points cover
- help with installation 69463-06
- Towing a sporty
- Nrhs vs Hammer Perfromance
- My Harley Davidson Superlow XL883L 2013
- 48 Fairing Question....
- Lesson Learned.......
- Few questions about the 2013 forty eights
- Buying sportster old idea new approach
- Want a chopper look
- The "daisy-smelling" rider
- Antibobber my seventy two
- What schrader valve for street glide shocks
- LED Turn Signal Wiring (2 wire vs. 3 wire)
- Triple clamp with risers welded on?
- latest mods on 72
- turn signal, kill switch, highlow, and horn buttons
- Electra Glide Air Shocks
- whats the 3 holes? and method of refilling gear oil?
- A wish for the Sportster (and maybe Dyna)...
- Thinking about a Day Maker headlight...
- drive belt adjustment
- Do you think a 1250 conversation will cure me of my Ducati craving?
- DIY: DK 587 Intake + Outlaw breather install for Iron 883 (or any sportster)
- 1200 conv issues...please read/help
- Can't Start, but have Front Lights, Help!
- Xr1200 - rip
- A rather in depth question on exhaust & air filters
- Ape question....
- 'DEEP' seats
- Trouble with exhaust flange bolts and decel popping
- drag bars question
- How many of you ride all year/all weather?
- 96 Sporty Valve stem ??
- One Bike Between Three Kids
- 2000 Hugger spec question
