View Full Version : Sportster Models
- Ticking upper front of engine
- my 48
- Luggage/Solo Rack
- Torx Size - Rear Fender mount
- Rigid frame starting problems
- oil/filter for 2009 Sportster 1200C?
- My Dilemma.
- Springer seat for OL?
- Mounting brackets
- Custom Chrome forward controls
- Anyone using these bars?
- Bigger fuel tank?
- LA Choppers Rear Lowering block BENT after only 1 month!!!
- Brake line extension
- lost battery cover
- spring seat
- Exhaust leak + oil leak
- '11 XL1200N PV rear 02 sensor open
- Sportster 2006 1200C speedometer stopped working.
- Lets see your DRAG BARS!!!
- "popping" sound from big radius pipes. Normal???
- should i stop riding until
- Have you hit the rev limiter?
- 2nd Gear Mystery....any ideas?
- Xied
- 03 sportster on speed passtime
- 2008 Nightster rear wheel bearing shoot !!
- Form or function???
- Xied installed. Getting check engine and battery light
- Gaskets?
- Wiring led strip to turn signal
- To drop or air shocks???
- Tank skin
- Primary oil change in 2010 Sporster...Questions
- Damsel in distress! Nightster won't start!
- battery/charge
- Air Filter Leaking???WTF
- 02, 1200 sporty making oil!!?!!
- Bag above the handle bars?
- Red Key Light
- for the cafe racer crowd
- Strange vibration
- custom paint job $ ?
- Exhaust decided, question
- Red tail light bulbs
- Floorboards
- Making the Sportster bigger, not smaller.
- Left foot peg too loose.
- Sportster Dyno tune
- Sportster Pulling Trailer
- New 883 Iron question
- sissy bar mounting
- vintage tires for the 48 need you opinion
- 2004 XL1200C as a 2nd bike???
- Primary/trans service
- Opinions on best seat for Sportster
- xr1200 vs Sportster seat
- Oil and fuel leak
- $27,000 Sportster 48...LoL wUt!?!
- Victory Judge vs Sportster
- engine wiring schematic for 1979 sportster xls
- Old Issues can be a pain in the A$$
- yet another issue with my sporty no spark...
- rush muffler
- getting scratches on my front fender
- 07 Sportster 883 baffel question
- swingarm mounted fenders
- Bottom end newbie
- More vibration with engine guard installed?
- Extra plate clutch installed, 1st gear issues???
- rust on stock 2012 iron pipes
- Iron 883 Vs Yamaha V star 650
- putting my tank back on and broke a tube - _ - help?
- 2 into 1 header exhaust with mid controls
- beginner rider with valve noise
- Back to the basics
- I bought a Harley for crusing not speed
- Replacement bolts for lower shocks?
- WG tank
- New grip installation
- Does '12 Iron 883 have a throttle lock?
- I want run a wider tire, next size is 180/65/16 !!!
- Tire info please help! 160 tires
- 1989 Sportster 883 w/ 1200 kit
- fighting against the wind?
- Mustang Vintage Solo , adapting to fit 4.5
- 1994 Sportster 883 ?
- anyone recognize this ignition?
- Screamin Eagle Stage 1 (round)
- Scratching top of battery cover with my jeans
- Best Tool Set for the $$
- 1200 - week 2
- High Mount Exhaust options
- Fast Forty-Eight
- my 1200c
- checking for codes
- tANK FIT FOR 2010 48
- Shock Recommendation for 2up
- ultima drag pipes
- Uh, oh!
- 93 1200s tick
- input on jocky shifter, give me your input.
- fender for wide glide conversion
- Oil capacity
- Speedometer glass fix???
- Sand in parking lot.
- new pipes dilema
- 2012 iron 883 ECM location
- Get a kick out of stealer quotes
- What kind of Drag Bars..Help!
- Custom Exhaust
- put new apes on wont start
- Downshifting
- Engine shut off in stopped traffic!
- Finally starting the process!
- Wearing my key out
- Sick Saddles 2up Review
- Re-custom paint job!
- First time rider-2004 sportster XL 1200 Custom
- stranded at work
- V&H Q-Series Double Barrel 18005 "anyone have them"
- how much for a used thunderheader?
- Finialy got it
- Sportster has 1st gear protection?
- Cheapest (but reputable) place to order V&H Short Shots?
- How much oil do you add between changes
- why ride?
- Fuel Enrichner
- tank rattle
- Do you believe in miracles?
- Pics of Black Bike with Chrome Headlight?
- Help with Selling!
- First world problems - my oil filter is chrome on my Iron
- side mount tailight.
- HD highways pegs
- How much PSI front tire
- Lowering front end
- Licks Visormatic Opinions
- Gone N Done It!!!
- Won't Start - Checklist?
- "This is my Iron"
- ANY 3-4 inch forward controls for a Seventy Two? HELP!
- 883 Owner's Manual
- I want to eliminate rear tail light...which module?
- For the guys running no front fender
- Might of made a mistake
- Backfire
- How much vibration is to be expected
- which seat/pan is this???
- Mustang Daytripper vs. Stock Seat
- Patches on leather?
- Wider front wheel fitment
- Exhaust without reprogramming?
- custom gas caps
- I spent $600 this month on windshields
- Recommendations for wrapping exhaust
- The Rain Sock U Want for oval is....
- Let's see your DRAG BAR / TANK LIFT combo...
- Where to get rear-sets
- LED turn sig. direct replacement???
- Needing info on HD Sportster
- Droped the bike & learned a lesson
- battery problems
- Bit 'o rust
- OK now have 100 miles on my 2011 XL1200C
- Puzzle for you to solve
- cycle shack phd160ss?
- Odd Rear Tire Clearance Problem
- Sputtering at low RPM's
- Milk Jug?
- Sportster Misfire, Speed-o In Opp.
- Hard Mount Saddlebags Without Signal Displacement?
- 71 iron head ( need a little help )
- Brand New 2012 or Used 2009 Iron??
- Fuel gauge kit on 2006 Sportster
- Slip-ons, X14IED's and HiFlo Air Cleaner...What do you Think???
- OK another NOOB question.
- where can i buy a smaller tank for an '04?
- Lower gas tank
- Akrapvic exhaust on 05 883 ?
- Another handle bar question....
- Future of my Iron - springer front end?
- forward controls/hiway pegs sportster
- Simple Handle Bar Question
- loud samsons need advice
- looking for a deal on iron 883 in los angeles area...any good dealer recommendations
- Road Glide Rear Shocks???
- Weird Sway
- Anyone in tampa, florida area ????
- Thinking about painting...
- how much oil typically drains...
- My new doll - 2005 XL1200C
- No spark - changed sensor - no luck
- Wide glide for a Nightster
- Primary cover SHOT..
- wet weather, sportster misfiring problems
- Got myself a truly custom Samson pipe setup! LOL
- 08 Nightster Passenger peg mount question
- Nightster Charging issues
- National recall for Voltage regulator
- looking for a sportster
- Sportster catastrophic electrical problems
- DK Custom???
- Valve train noise 95 EVO 1200
- problems starting
- 2012 Voltage Regulator Service Bulletin
- ignition module/coil/carburetor problem 03 sportster LONG STORY - NEED HELP
- Pics: Got my new Rough Crafts Seat.
- has anyone done this ?
- Michelin Commander II tires
- SoCal Riders?
- Shocks - replacement suggestions
- New rider looking to buy a Sportster
- 883 to a 1200?
- Need help setting my bike up for a passenger
- lowboy fender
- Not to happy with my dealer at the moment.
- Ricor Intiminator
- Street bob seat on a 48??
- Weekend Bike Run
- Backfiring, running rough
- slip-on mufflers?
- rear tire change
- Cafe Iron
- Clutch slipping in 5th gear
- passenger foot pegs
- Model A tail light - only 2 wires - can I use the stocker parts?
- Just got back from the Smokies!
- 06 Sportster 1200xl won't start
- I need some info on my Iron!!! please read and give replys
- Starter grinding when trying to start
- shut right off
- Windvest 14 or 16 inch on 1200C
- Sporty Rigid Bobber...."Betty"
- Need Help Diagnosing
- Transmission oil change and center jack lifts
- carb gas leak
- rocker box gasket leak
- 77 choke
- Is this anyone's bike? (Los Angeles area)
- Can't find a 2012 service manual anywhere
- need a windshield recommendation
- Street glide rear shocks for my nightster?
- Your dumbest moment ever
- v&h big radius in california
- External Ignition
- 02 883 SPORTSTER gas tank scratches
- just pushed this home
- how clean is your bike?
