View Full Version : Sportster Models
- Will some Sportster side plates scratch the fender?
- kicker for 1988 883 standard
- air cleaner fit
- 01 Sportster rear fender
- Drilling the Lower Triple Tree
- After having air shocks
- Power Vision Autotune
- It's a Grenades New year 👍🇺🇸👍
- Custom Dynamics TruWrapz on '14 sporty, load equalizer?
- Harley sporster iron conversion 1200 mapping HELP
- First round of mods to my 1200S done.
- Project iron 883
- Custom Sportster 72 shift linkage rod
- Japan New Years Ride
- Seats
- Help me customize my 883!
- what is the next step after a stage 1?
- Led Sled floorboards
- throttle body -> AC screw thread size?
- A/C upgrade worth it?
- Does the EPA require Motorcycle Companies to have breathers routed to intake?
- Dk customs coil ignition kit differences...
- Aux lamp wiring short circuited
- 91' Sportster Speedo/Tach conversion
- If you're running progressive shocks, i need your 2 cents
- 48 tuner ???
- Is this Right??
- Stage 1 trying to keep stock look
- Hi Guys! Finally time to be rider!
- V&e fp3
- A/C - crankcase breather
- Speedo inversion
- Can rear brake pedal be adjusted
- Mini apes best risers?
- 2005 XL1200C Quarter Fairing install
- 2005 Sportster Quarter Fairing How to?
- Cam cover vent hose leak
- Red key light is always on! How do I shut it off
- Mikuni hsr 42 issues
- Drive Belts-How long?
- Wyatt Gatling slip ons review
- 7 in headlight
- Mustang Fastback Seat Need Opinions
- New member and Harley owner long time rider
- Merry Chistmas
- cam installation question
- New Sporty
- Anyone running wide bottom Holey Rollers?
- Nightster Forks on 883 superlow
- help me decided for my 48
- HELP I am stuck
- Different front Wheel Xl 1200c
- Bigger bars on 48
- Eagle Lights Daymaker ll Headlight/Stock Comparison
- What set of pipes will work with mids/passanger pegs??
- Best 2 into 1 exhaust for Iron 883
- Just Bought 03 Sportster 883. Need To Know?
- 1984 sportster tank ?
- Inexpensive tuners you don't leave in the bike?
- 1988 clutch question
- Windvest fitment on a 2004 Sportster twin-gauge
- Sportster Chopper
- Brake pedal pad
- Throttle sticking
- Question about an used Iron 883 I am buying...
- Front fork sag
- Fork bottom screw size? 2014 Iron 883
- Techno Research
- 883 lowering kit?
- Warning labels on frame
- 7" headlight installed, shorter rear fender & new handlebars for the 48
- 2007 throttle body-to-a/c bolt thread and pitch?
- My 2015 48 Mods
- Used Sportster question
- 1978 Sportster quesiton
- How to change to synthetic?
- Brake control housing rotation limits
- 1200 kits
- price on a 2016 iron?
- Biltwell Stinger?
- winter sucks....
- Sportster Front Fender
- Sportster Tach for a 1989 883
- Michelin Scorcher Tires, Grip ??
- New Sporty
- Saddle bags
- scissor jack that fits under a 48
- 2003 883 stock turn signals
- Question about H-D touchup paint
- Turn Signal Mount Question
- Clutch cable re-diredton a 2016 Iron
- Getting the plugs off of the control wires
- 12" bars on a 72
- Airhawk Seat Cover
- Anyone ever Plasti-Dip ??
- Transmission Fluid Leak via Cable Adjuster
- Battery cover clips part number?
- Rust in tank
- Tech advice - Screaming Eagle exhausts
- jacking up a sportster
- New 2016 Iron 883
- Buckhorns
- Scored a new (to me) 00 Sportster S
- Gas tank
- Forward Control Kit Options
- 2008 1200 Oil Seepage
- Ebay led 5.75 headlight.
- Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
- My Sportster 48 2013
- DYNO results Stage 1 1200
- motorcycle lift
- RAW or chrome sportster tanks
- FP3 or just cold mornings?
- 48 brake pedal pads
- Getting out marks on lower fork tubes
- Forty Eight parts fitment
- Dash unit malfunction
- Circlip (snap ring) pliers at Harbor Freight
- 2009 Sportster 1200 Low for First Bike
- Fitting 16" Wheel and Fat Tire with Stock Forks
- hey new here and looking for info
- Torx settings iron 883
- Exhaust mightmare
- Sportster Custom 2012 Don't accelerate beyond 40mph and making loud noise
- Alright folks I need some help
- Bike died & left me stranded, bad ignition module?
- extended brake lines with abs
- Reverse a tank-lift
- Does the Harley Stage 1 air cleaner need a fuel management tuner?
- Iron 883 Forward Controls
- Two piece tank on a 72?
- Name that wheel
- Ohlins S36E bottom out?
- 30 mpg 1250cc big bore kit
- Getting longer fork tubes, need new longer boots?
- XLC1200 Vibration
- SE Heavy Breather External Breather Setup
- Cleaning Whitewalls on Sportster 72
- SHE WONT START! (includes video)
- December Riding
- Battery ..what other battery can i use in Iron 883 2014
- Stock 883 Iron Shift Lever, Ape Hangers, and Exhaust
- Handle Bar switches
- Tuner Question ? (Dead Horse) ??
- Rear Turn Signals
- Putting the Hammer down
- 1990 883 tank replacement
- Tires for the 48
- Patriot top fueler reviews?
- Need Help/Advice
- Custom Iron 883
- Looking for extended or long forward foot pegs, 6" +
- Pack Animal Bags
- DOH! i made a stupid mistake, no clue how to fix
- Patriot Defender on a 2015 Sportster?
- Patriot defender install trouble
- Help with accessory power
- Bit of tip regarding removing the primary cover.
- Blacking Out - My '15 Sportster Forty Eight Project
- Headlight improvement started
- Turn signal delete
- Cylinder logo question
- Starter Relay part number?
- 13 spoke alloy wheels
- Headlight Replacment Help
- Oil Filter Question
- Big Sucker v HD Question
- New 2016 1200 Custom
- intake/exhaust fuel management upgrade question
- 02 1200 Sportster Help
- My 2007 Won't Start. Please Help!
- Swingarm options
- My 2016 48
- DK Custom Solo Seat Install Help
- Installing New 0.010 O.S Pistons
- Canadian Tail Light Options
- Changing the Oil
- 48 Fork upgrade questions
- new member
- DK coil relocate help
- Riding Jacket help
- Power Vision for the Sportster
- 48 seat on a 2006 XL1200R. Will it fit?
- Got a line on a RSD Cafe seat but is it more comfortable than the stocker?
- Holley Roolers and moved turn signals
- FireBrand exhaust
- Please identify this seat
- Recommend me a throttle tube please.
- Flasher Switch Extensions
- tire size 1988 883
- NRHS 1250 kit
- Need new pegs with ground feelers, suggestions?
- zombie stainless sportster cable guide
- Increase lean angle
- Stage 1 air filter upgrade on my 2014
- Lowering a 1200C
- Battery removal for winter - necessary?
- Help: No start, low compression
- 2015 sportster 883
- Headlight wire removal
- Made my own seat pan
- New 1973 Harley Ironhead Sportster Owner
- Buying and Selling Sportsters
- Sportster Appreciation!
- Recently Shipped 2009 883 custom has No Ignition even afer fully charged baterry
- Installing Forward Controls on Iron
- Lifting the bike with an engine crane...
- 883 help!!!!!
- How to remove speedo from bracket?
- Battery replaced - still acting up, a few questions
- Primary chain maintenence
- Lean angle and cam for 1200
- Most comfortable one piece two-up seat?
- 05 883 custom wheel change ?
- 09 Sporty
- Frickin front brakes
- Couldn't resist the Iron
- Need help with an 883!!
- DK Custom oil filter thumbs up
- Custom CNC Derby Cover
- Length of XR1200 pushrod tubes?
- Vertical license plate
- Has anyone used this kit from Kinetic before?
- 13" and 15" rear shocks
- Picked up to resale
- Rev to toot!
- Shots in the dark
- 2014 883 to 1200 kit
- 13" air shocks replacement for stock
- Front turn signal options/mounts for 80 Sporty
- Coil/ignition relocation & tank lift.
- Hollywood handlebars....
- I need a quick favor to a question about my rear brakes.
- Installing a New Front End on 89 Sportster
- Engine bogs when accelerating hard on throttle
- Blue exhaust wrap
- Thunder Torque Inserts vs. Lollipops
- Where to put my registration?
- Further forward mids with V&H short shots
- Oops! Dropped something in the gas tank...
- tires
- So, the big K&N air cleaners that DK sells ....
- HandleBars for a 48
- Sportster 48 Engine Upgrades
- Speed Sensor or Speedo
- Options for Rear 18" or 17" rim for 2008 Sporty
- What is the ECM Reference voltage for 2014 XL1200
- Headlight Problems
- Need Help On Electrical Issue
- Iron shocks for 2 up riding ?
