View Full Version : Sportster Models
- Rocker cover leaking.. Howto...
- Horn bracket question
- Headed on on the Sporty for 4 days!
- Braided line size?
- Mini Apes on Sportster
- VH Big Radius question
- Oil Gauge Install on a 883 Evo
- ok guys help me out please looking for answers on a clutch issue.
- Brass A/C Cover
- Tach
- need some advice
- NEED DRAG BARS 32" with 4" Pull Back - BLACK
- Wheel question - Clarification
- restoration advice
- RK Shock Weight
- My 08 Nightster.
- Head gaskets?
- Need advise-Fender Chop & Tail Light Removal
- Stupid question about the HD throttle
- Gas miliage
- Help, advise needed
- 09 Xl1200L Injected Grip change question
- First photos of my 2010 48
- sporster fairing
- Traction Control (pic stolen from /r/motorcycles)
- Axle cover fits??
- want hotshit clutch adjust for evo!
- Cables long enough??
- o-ring bulged out
- Faulty Speedometer
- Vehicle Identification No & Chassis No
- San Diego Riders
- custom linkages?
- clutch time
- Speedometer do i convert??
- Crazy Orange Pipes, I Want These!
- Pushing my bike along the side of the road.
- New (to me) '07 Sportster 1200 Custom
- Sportster XL1200C Speed Sensor Voltage
- Just ordered...
- Speedo mount
- 2001 sportster oil light
- Limited paint?
- help
- Ricor Intiminator Install Questions
- new rider, new '48, new problems....
- Sportster Struts question
- My Nightster So Far
- Sporty has arrived, but to loud!!
- Anyone running a Roland Sands gas cap - cafe in particular?
- Choke/Enricher Cable Installation Question
- favor?? PLease...
- 2006 Sportster 1200C
- Narrow front end C's....need info
- Have an obsession with the new 72 model. What makes it different?
- Who has ridden a Sporster all their life or sold a larger bike for a Sporster?
- 2012 nightster two up seat
- My take on a mini Bagger.
- Biltwell Kung Fu grips.....
- Retention ring
- 2005 sportster 1200 custom - want to get exhaust.
- My first torque wrench: Any suggestions?
- Looking to get my first motorcycle
- Bike won't start, just clicks
- Changing Oil on 07 Sportster 1200?
- Better mirrors?
- Tank swap for 48?
- 2008 xl1200c big engine problem
- some upgrades to the sports
- Back on the road
- Derby Gasket or O-Ring?
- Bicycle Rack for Sportster
- 2002 , 883xl questions
- 1988 sportster cargeing system 883
- Thanks for the DIY's and keep em coming.
- When to repack baffles
- Wife's 1200 Custom Before and After Pics Sportstour
- coil/ignition relocation?
- Advice on shocks for 1200 custom.
- modifying HD speedometer on 2012 iron
- Evo in iron head frame
- Can you troubleshoot my bike?
- DYNOed today
- wiring troubles
- which to get? Progressive 412 12" HD or 13" standard?
- no headlight no tach light nothing when trying to start
- 48 test
- Turn signal, sometime she works sometime she doesnt
- 2003 Sporty tail-lights
- Nightster Mods
- Uncontrollable revving throttle stock on new 48 HELP
- Can't find pegs for my 2012 Sportster 1200 Custom
- Excel Service Schedule For Sportster
- FMB Choppers Bars?
- 1200 Cracked Piston. Rebuild Kit Questions.
- Headlight cover
- Coil relocate for my 06 carb?
- Oil warning lamp glows...
- Ordered new parts but i have a question.
- just got a 07!
- Just bought a 2012 iron!
- Derby cover
- Yeah!
- Rey Mysterios Sportsters
- Traveling Man Tweezer Action Leaf Spring Seats on a Sportster?
- Help -
- Tank mounted Speedometer
- I found an all in one speedo/coil/ignition relocation kit
- Diabolical Nightster Finished. (Info on stock cables and apes)
- New mirrows
- Sportster riders unite-let's put a face with the name!
- 2003 Sportster Project
- Arggg! Sporster won't start.
- 16inch Apes
- 08' XL1200C seems to be running rich, what should I check?
- Interesting dirt track Sportster
- 2012 Bobbed Iron 883 from Portugal
- Tire Air Pressure?
- Tuning necessary or not?
- Removing the baffles on the Shortshots to make bike even louder
- My 48 Sportster Project
- krankvent
- Stumbles when taking off
- Need a mini speedo for an 03
- Too many Intake choices
- nightster cruising problems.
- Does Power Commander V overwrites Harley stage 1 Map/ECM?
- How low do yours hang?
- Kerker Experience
- Original KD's came in today :(
- Bad VSS ground
- 2001 883C Rear Tyre
- Brake light and turn signals not working on 03 1200
- they're totaling my bike
- Whats the right intake for my Iron 883
- Muffler Question
- x14ied
- Dissappearing Engine Light
- bike dies on decel
- Re-installed fuel tank no fuel in engine?
- no go
- Who has 48/nightster tank/drag bars?
- Mods gone wild
- Need help with problems starting bike
- Tank lift, wire tuck, coil relocate
- oil in air cleaner
- replacement piston ring size by measurement
- Iron 883s Northeast Ohio
- 05 Roadster 1200 - Shrieking at startup
- Sparks!!
- need help with charging system
- Mobile 15/50
- Screamin' Eagle A/C vs. Modified OEM A/C
- Easy Pull Clutch Help
- Spedo relocation options????
- what exhaust will work with forward or mid controls
- Anyone see the "C-Dat" video on the main page?
- Tank lift fuel capacity loss on 48s?
- Can I run a 150 front and back on my 48
- The 48 front end - conversion?
- Sportster hiccup
- Mileage Range for 1200 Custom
- do it ypurself white walls, and black rim paint?
- quick question
- Spark prob
- 2012 "72" check engine and battery light on
- Why do I like Sportsters..whats wrong with me?
- rear axle torque specs
- Headlight wiring help....
- 1 year later mods
- Solo Seat with backrest
- Lookin for my first bike - need some input
- Want to change rear brake light 2012 S/low
- 2011 nightster exhaust question
- improving ride update
- Rivco frame mount highway pegs on a nightster
- Newbie
- After Vance and Hines shortstots staggered, bike is starting weird?
- want non mustang rear seat for mustang seat... HELP??
- Battery Tray
- Can someone help with Carb problem,and pricing to sell?
- Question about windshields.
- soot sporty 1200L
- Where to get Big Growl or Hookers?
- primary oil in a pinch?
- 2011 and newer owners, what is your solution?
- And the Lord said "it is finished" but i say "for now" ;)
- Anyone ever bought the drag bars straight from a HD dealer?
- Highway Speeds on your sporty
- Do you have a 2011 Sportster Forty-Eight???
- Hd forward controls
- Sportsters on the highway
- Cleaning gas tank after paint, for hook up.
- 08 1200 Sportster Starting problems
- Reviving A Dead Sporty
- 883 conversion
- The bars for my chop project....pic
- 2010 883 fluids?
- which serice manual ...
- HD to start demo saddle and windshield program
- installed my bars and tank lift.
- what to look for in a used sportster with under 5,000 miles
- Keep or ditch the bags?
- Removing Baffle 2012 1200 custom
- Iron 883 air cleaner - need help
- Speedo going crazy
- 2005 xl883c rear peg question
- First mod - bust out your wrenches boys!
- saddlebag problems
- surfboards and harleys?
- Hello from a new newb...
- What weight fork oil?
- Mini apes and running cables inside?
- New your opinion, Old school or white walls on my New School Bobber
- Any recommendations for small hand grips?
- safe and secure!
- Rear brake pulsing after new tire put on
- Before I order new pipes.....883-1200
- Flat rear tire
- Where can I get these pipes?
- 2012 48 fuelpak problems
- brake pad type question
- risers
- exhaust mods
- DIY Garage door opener
- 1987 Sportster Oil Lines question
- Caught in a Downpour?
- power issue
- Wife wants a bike
- 1988 sportster dies on throttle
- poping when hot
- Want to change Pipes. Good performance/sound?
- Fiberglass Seatpan
- RSD Grips
- Baby's Gota go
- 3.5 Gallon Dished Side Gas Tank
- my custom grind paint and white walls
- Surging/turn off
- VOVS/Carb overflow hose
- About to buy a 1200C, question on changing bars
- fuel leak+fix
- Wrapping short shots
- License Plate Light?
- Shops in south florida?
- Anyone every try Spring Struts??
- where are sportster motors built?
- Anyone have a Skullcrush 3/4 helmet?
- 1200 custom question
- Want a different tank
