View Full Version : Sportster Models
- Rear lights / lamp module
- cylinder barrel and heads 08 sporty
- Xr1200 electrical problem
- Trans/Primary Oil Leak
- Dubble oil problem...
- 08 sporty 883 crank pressure test psi readings
- Sportster 48 knocking sound when clutch is in
- lowering 1974 sportster
- Need Some Help With Footpegs...
- Brake Light Issue
- Upgraded My Sportster in Less Than 2 Months
- Tables for SE 1200 conversion Sportster (2010 model)
- risers
- 2013 Seventy Two Fork Sliders
- 1993 sportster wheels
- IAC Position during riding
- 06 sportster. no spark. bad coil?
- Sportster 48 oil leak
- Sportster Speedo Drive Issue
- !Engine Issues!2007 HARLEY SPORTSTER NIGHTSTER XL1200N. Please help.
- What bike? Iron or Nightster?
- 05 XL coughs just above idle
- Full Circle
- Memphis Shades Memphis Slim
- Pro Street Tuner or Dyno
- mag wheels
- Oil capacity with an oil cooler
- Can anyone figure out who makes these handlebars?
- Sportster Updates
- Rounded exhaust manifold bolt help
- Kawasaki wide glide triple tree for wide glide conversion on sportster.
- Low Miles on old bikes
- Oil Filter ...... How confusing can they make it??
- Sportster Flashing Me!
- Wrong oil filter for EVO Motors
- Oil blowing out of the breathe tube
- Battery Jump Start Recommendation
- Sportster Discontinued?
- New 2021 Sportster Iron 1200 Suspension
- 2002 Front tank mount, ignition, coil mount pics please
- Genuine James gaskets
- 08 Sportster 883 w/big bore 1200 and Power Commander V - where do I get a map?
- 93 sportster Led turn signals
- V&H Upgrade tune question…
- Relocate tach and speedo
- Fender interchange
- Replacing pistons
- front end identification
- 88 sportster 1200 no start
- Windshield Help
- Hammer Perf Cyber Sale
- Thinking About Forward Controls...
- Height and fit questions and one other...
- Spots on a Sportster?
- A brief discussion of bike mods and riders guide to surviving Indian traffic
- I got a Stupid Question
- sportster 883
- 2017 Iron No Start
- Help
- Strange start problem
- Tell me about this Sportster (Iron Head)
- Rajasthan conquers sporty
- Small SUV bumped me
- Lower HARD Farings
- Exhaust Fitment Question
- Start-Up After 7 Years Sitting
- She cleans up nice
- Rear Tire Removal
- 1994 sportster foot peg help..
- My 48 suddenly shut off while riding..and complete power loss
- Ignition problems 2014 sporty-eight
- Led light conversion problem
- Turn Signal lights
- 2000+ brakes on a 76?
- Luggage rack for XL One-Piece Sissy Bar
- 1996 Sportster Rrear Wheel Swap
- what is this??
- Install of drag bars.
- NOT happy, shift problems.....
- 2002 1200 Carb Jetting
- Sportster foot controls
- Teflon tape on tranny drain plug
- Electric or mechanical fuel pump 05 Sportster
- XL1200C vs XL1200V
- Cranks but won’t start?
- Sportster oil system
- How Does the New Sportster S Compare To the Indian Scout?
- Embarrassing - flashers won't stop blinking
- Need help guys. Broke my drive belt, replaced it, now no speedometer
- Decent cheap tachometer?
- Jacket Conundrum
- Starter keeps going out or bad battery?intermittent starting
- Gone in 60 seconds or 1.6 seconds?
- Old man in Zenas.
- LED tail lights from HD website... alternatives?
- XL 1200T rims on an 883 SuperLow?
- Gassing up
- 1991 xlh1200 Fall away / Steering stem bolt issue
- Starting issue
- What am I missing, handle bar swap
- Softail custom or duce
- Stage one upgrade.
- 70's ironhead frame....?
- 2019 Sportster Iron 1200 wiring issues.
- Speedo Cluster Indicator Lights
- 2015 Sportster Superlow 1200
- Consiglio sostituzione filtro aspirazione e sella
- Mid controls on a 48
- Engine running SAE primary is now running syn 🤦♂️🤦♂️🤦♂️
- HP 1275 1/4 mile 16 yo pilot
- Bags vs Back Rest
- Service Manual
- From K to S: the Model that Started Sportsters
- Clunky taking off in first gear
- Help on Progressive Suspension
- 1990 Sportster 883 Will not fire up
- It lives.. and do I.😃
- 1999 883 sportster shifter shaft pawl needed
- Newbie Owner
- About to own a xl883 2006 with some problem codes..
- Now for the tank...
- Sportster speedometer reading extremely too fast.
- Need some seat advice
- Sporty Valve Stem Seals ID
- What do you think??
- How to remove a Bolt Cover ?
- Carb fitting
- ‘21 Forty-Eight Stage 1 Hi Flow A/C backplate gasket issue
- 2002 custom XL883
- separators on a xxl883c 07 Sporter
- P0505 driving me crazy.
- Are my aftermarket pipes causing stalling and backfiring
- A good Sportster History Write Up.
- 1986-2003 XL 1200 15'' Shocks - Exhaust Clearance?
- 1986-2003 XL 1200 S Extended Brake Line Kit?
- headlight wiring
- 1st sportster S dyno on the books
- change the rear tire
- Left Rear Turn Signal
- Touch-up Paint Cost
- 1977 Ironhead question
- Vin #
- 2018 48 ignition ground nut?
- HELP!!! 2019 HD Iron 883
- Tbars
- Seat conversion
- Dropped Part, what is it?
- Best aftermarket LED iron 1200 headlight with bracket?
- California Tune Available?
- Won’t start after a crash
- Sportster: 2009 XR1200 or 2016 Roadster
- Sportster 48 Hollywood Handlebars
- '99 Battery Question
- hardtail pogo frame
- 883 starts but don’t keep running
- Hold wheel to torque sprocket?
- Progressive 412 Shock Adjustment
- I saw my 1st Sportster S today and….
- Brake light always ON - sportster 1200C
- 1972 xlch colors
- Looking for larger tank!
- Almost got rid of the sporty today
- Sporster oil change question
- 07 1200 Vibration
- New bike name for the Sportster S
- Liquid filled Oil Pressure Gagues, Arlen Ness vs Marshall?
- Tracing the Sportster's Evolution From the Beginning To Today
- Sportster Battery terminal melting
- Help! My Sporty wont start!
- Security/Fob Issues with my Forty Eight
- 1989 Sportster XLH883 deluxe carburetor trouble
- Howdy ! Here is my CV carb slide and diaphragm.
- Sportster 1988 Exhaust / Headers
- Brake Light stays on
- Pressure Plate Snapped
- I want highway pegs and my dealer says, “No.”
- Anyone else get their Sportster S yet?
- Help with stator test
- Anyone buy o2 sensors on Amazon? Worth it or not?
- Carrying a Laptop on a Sportster
- Intake Seals
- HD Decals
- Security Code (umpteenth time?)
- 2015 XL1200X Sportster 48 12,000 miles *PLEASE HELP*
- New Sportster S Redefines the Category for HD Offerings
- My Mechanic is puzzled - any help appreciated
- 2015 XL1200X 48 *need input please 😭”
- scrambler flat seat
- Planning a long road trip - pre- requisites??
- Fuel Leak at tank vent tune
- 04 XL883 won't start.
- Barnett clutch in 97 Sportster wont release
- Leak underneath my sportster
- adjusting for loud pipe and free breathing
- Reed switch
- Please help me identify this case code.
- Tire Question
- Anyone use the Bitubo drop ins for 2019 883's
- fuel pump recommendation needed
- 2019 883 Iron front fork question
- So is it just me?
- Sticky throttle
- Duke Out on the Cheap: Iron 883 vs. Scout Sixty
- Matching tires
- Sportster S Engine based on V Rod?
- 883 iron abs and bobbing
- Throttle sensitive
- Bangimg sound during left turn
- 2014 Sportster bucking
- 1994 Sportster XLH1200 Drop Kits
- Dealer maintenance on new bike
- Sportster engine replacement options?
- Where to locate bag
- Replaced Oll Lines now Electrical issues
- New Shocks?
- 02 XL1200 Custom air box question…. Need advice
- Unknown button on 2008 Nightster
- "Spits" back through air cleaner
- Should I Change or Paint Gas Tank on My Iron 1200
- Removing front heat shield from V&H Straight Shot slip ons
- 1998 883 Slight Miss
- Harley oil leak
- Brake Light Issue
- I got a problem?
- Russell Performance Braided Brake line
- 2015 Iron 883 cranks but won't start
- Linkage
- Front wheel options
- 79 XLS Ignition
- Screw in rear tire
- Identify my tank
- 1200T (Low) / Mid to Forward controls
- Iron 1200 avg rider height?
- Rear fender
- 2 things I would do, Hammer, Progressive, Power Vision, Arlen Ness
- Windshields
- 2019 Iron 883 fuel issue
- Issues with ‘86 XLH 1100
- I need a help with my sportster. engine heisting and stall
- OEM Baffle Replacement 2011 XL1200C
- Installing new tank with no vent plug
- rear axle 1200S
- A tiny ball bearing on my 2013 iron 883
- Reduced Reach Forward Controls Kit?
- Switched Power
- Shock help please
- Review- Harley Davidson Quick Release Touring Windshield
- To cam or not to cam?
- Transmission oil 2001 XL1200C
- 883 petcock location?
