View Full Version : Sportster Models
- First things to do when getting a new sportster
- 2007 trigger levers?
- Frozen Breather Screw (bolt)
- Gasket oversight!
- Should I replace exhaust gaskets? And which type?
- Help / Opinions
- Fairing or Windshield
- SuperLow advice
- Possible O2 Sensor Issue?
- 85 ironhead issues
- 2006 sportster weak spark
- Oil splotches??
- Sportster 883 advice please!!
- Iron 883 vs 1200 Custom
- Ironhead electrical question
- Shifter to Nowhere
- Oil Level Confusion
- Drive Belt Pully Cover Clearance Question
- Top clamp / speedo gurus
- DKCustom's 2" forward control extensions
- wind gusts to 25mph
- 1400 Conversion
- Fork Skins
- Battery bolt tightness issues.solutions?
- Indicator lights
- Anyone with Ebay sissy bar???
- Questions about exhaust
- Messy wiring With handle bar swap
- Rebuilding Front Forks on XL1200C
- Guaranteed to make someone laugh...
- Installed my short shots today
- 2001 883 Sportster Losing Power
- Remove passenger pegs? Ideas??
- Speedo relocation help...
- License Plate
- Dr Jekyll and Mr Hyde : My 2004 Sportster 883 Custom
- Anybody wanna weld me up an aluminum tank? $$$$$
- Getting rid of riser
- Will 48 forward controls fit 2000 883
- Broken noise reduction kit/quiet baffle, will it cause probs?
- How to choose the right Sportster?
- To wrap or not to wrap
- Passenger peg relo
- Need to quiet down my new Bassani slip-ons
- Biltwell High Drags
- Are ICMs mated to bike?
- Pitted rim - advice please.
- Handle bar risers
- Saddlebag Support Bracket Bolts
- New Sportster In The Garage!
- Rear Axle Adjuster
- Fuel Tank
- Where do you guys mount your cameras on your Sporty?
- 81 XLS Roadster
- Xl 1200c 2001
- Cut and grind the speedo housing / top clamp?
- Superlow 1200T?
- Stock Iron Headlights!
- Bike's Not Running Right - Cobra Fi2000 PowrPro
- Factory alarms
- Sold my Sporty
- 2006 883 overheating recall??
- Lightening the clutch pull?
- My New Iron!
- Video, is this normal idle? for a warm bike?
- Couple of minor issues with new bike...
- Front Turn Signal Relocation Kit
- 2016 Iron 883, 3 colors. Which color would you prefer?
- Leaking fuel
- Header advise
- 125 lbs riders- rear PS shock setup
- 2002 1200 custom?
- Saddlemen TS1450R Standard Sport Tunnel Bag 9"
- Peanut Tank Bag?
- Mustang Wide Touring Solo Seat Vintage with Driver Backrest
- upgrades to my sportster 1200XL Custom
- Failure Post Mortem
- Near miss on the freeway
- Rear Brake Pedal Removal
- Carburetor vacuum hose
- installed dynojet power commander v & S&S air cleaner
- Any 00 Sportster owners here
- What clutch for 1250 upgrade??
- 2009 Sportser wont shift
- Brake Lever Change
- 2016 Iron 883 gets SE spark plug wires!
- New Member! 2016 Iron 883
- sissy bar with pad
- Anyone bought one of those cheap fork braces from Hong Kong?
- Right front motor mount. 2001 1200custom
- leat coat eating my paint away! Need help!
- 1200 sportster
- Carb pissing out overflow?
- Hammer 1250 kit
- How to stand a sportster vertically for servicing?
- Can I get Your Opinions?
- Bad TSM? Bad Lights!
- '14-'15 Forty Eight speedo relocate
- FAQ: Installing Air shocks on a sportster
- Key Code with an "H" at the end ???
- 2001 Sporster Motor - Gas Filter leaks Gas
- Need help mounting V&H FP3
- Forward install question
- no maintenance replacement shocks for a 48?
- 76 sportster project
- Frikking Side Stand
- Saddle bag lock bezels needed
- LED Headlight
- Sportster new vibration
- Trans don't shift properly
- Need Help! 2009 sportster 883 custom
- Need some wisdom
- Tank knee pads...
- Make my shocks Black - powder coat?
- 1985 Ironhead
- New to sportsters project
- Got a new seat made
- Screamin Eagle Street Performance Tuner
- throttle cable options
- 240 tyre on a 883!
- Hagon shocks - Thank you Grbrown
- Nightster Whitewalls
- Nightster wheels
- Tank Removal Help!
- Maybe a dumb question but here it goes.
- Size question
- Took a spill on the sporty!
- checked out the 2016 48 seat & battery cover...
- Getting shocked by my sporty
- Possible ignition issue
- 2015 forty-eight only getting 30MPG!!!
- Two Up eBay Package - Thoughts?
- Red Light On Speedometer/Tach Combo
- 0 to 60 mph
- Cold Natured
- No Left Signal
- 2-up Seat for 2013 48 Sporster
- 10 inch Z bars on Iron
- Did I lose a front wheel spacer?
- 2012 HD 883 iron struts
- crossbones springer
- Torx size on rear shocks
- removing rear tank bolt
- Kevin's Build Thread (Complete From Start to Finish) PIC HEAVY!
- 1988 sportster no spark
- Those with lowered Sportys..
- Ticking sound near the tank?
- Just noticed previous owner removed baffles, affecting performance?
- Exhaust seems louder than usual. Clacking
- How many miles do you have on your sporty?
- 100th Anniversary 883
- Help - Drain plug confusion
- Any Touring with the Sportster 1200 Custom?
- 2004 Sportster 1200 Conversion Question
- Too much Crankcase pressure?
- Sportster ignition module question
- Progressive Drop In Front Fork Springs
- Oh em gee! Help!!
- Put These in Order of Loudness
- Tank Lift FRUSTRATIONS! HD 48
- Axle/hub assembly question; 1990 sportster
- replacing 2005 roadster 1200 gas tank with a 2006, possible?
- Mystery Hose
- How much does it cost to install 10in Aped Z bars on stock 2009 Nightster
- Advice on 01 Sportster 1200
- 2000 Sportster light issues
- 48 bottom out two up!
- What's in your daily/trip tool roll?
- Memphis Shades Gauntlet review.
- Saddlebag Question
- Shock lowering block question
- Ontario Canada to Lake Placid NY on a 48
- Experience Installing Target Tune on '11 48
- Mini speedo install
- HD drag bars installation help
- Gas tank question
- 883 Superlow larger front tire?
- Pro Pics of my XL Custom by my local bike shop
- Drive Belt
- 2015 Sportster forty eight Fairings?
- Upper chain guard
- Turn signals
- Engine revvs up all by its self.
- Help new risers with dragbars
- selling my 48
- 2001 Sporster 1200 Primary Noise
- Lost another part of the highway
- fuelpak issues
- 2016 Sportster 72
- Clutch lever question
- Looking for help in Louisiana (New Orleans area)
- Air cleaner
- 3.2g King Tank on a 2015 48
- Seriously something wrong with me!!
- Biltwell HB Seat Killed My Rear Fender
- How to mount a second headlight?
- Identifying Engine and Serial Number
- First Accident that technically isn't.
- Battery issue ruined my ride to mountains today
- My seat is a pain in the rear
- pulling to the left
- Clutch adjustment
- Puncture - first time newb
- Experience with Target Tune on 2011 Forty Eight
- Extra tiny bulb in my new headlight assembly?
- Small rubber plug, I don't know where it came from
- am I crazy for wanting to "downgrade" to a sporty?
- Chrome cover help!
- S&S Sidewinder 103 Kit on a 2004 (how do I do this)
- Rinehart Exhaust
- Interesting sporty!
- Brake lights constantly lit
- Sputters on roll on when hot. Please help.
- Show your garage fabrications.
- oil pipes 1200 1994 sportster
- More Pics of the Slim S
- Fuel help?
- Vance and Hines Fuelpak fp3
- Knobby Tires for Street Use?
- Confusing: 2004 or later, 2014 and up...
- Spark plugs?
- Speedometer rant and rave help me!!!
- Love/Hate relationship with my Hugger.
- Mustang Seat Question for a short person
- 883 w/ 13" progressive shocks, need a new kickstand?
- Defender or riot?
- Drag racing pics on the HAMMER EXPRESS
- 98 883 coughs at 2000 rpm
- Hammer 1250 running hard
- Passenger question...no bike yet...
- Installing rear shocks on a nightster
- Pricing Question
- Progress on my Iron 883
- Mods so far to the 48
- Servicing my bike, this is normal right?
- 1200 Sportster Issues
- Newish Sportster Oil Conumption
- 2009 883 Won't Start
- Installed the LAF pipes, AC + Bars in the '72
- Twin cam woes, inspire a sporty build...
- Auxiliary Brake Light/Running Light/Turn Signal Conversion Kit for 2015 883 Sportster
- 2016 48
- Roadster rear shock replacement
- help the bike keeps shutting down while riding.
- Sportster belt noise
- First post
- 5,000 service and bikes runs strangely
- FatBoy 7" headlight on a sporty?
- 97 1200 quick bob speedo
- Rear brake squeaking before and after new pads
