View Full Version : Sportster Models
- Anyone have a speedo w/ around 8000mi on the odometer?
- Drive belt snapped need help
- Looking at another Sporty...thoughts?
- maintenance on a 1200 sporty
- Good source for wheels
- Drag Bars Installed...Need Help w/ Cables
- My Nightster
- Union River
- Side stand trouble, anyone experience this?
- So when people say "Mustang" seats for touring ...
- L front signal/running off and fuel light on permanently?
- Great brake cable resource for z bar/apes/etc
- Value of '03 883?
- beltdrive guard on or off
- rsd 12" vintage bars ???
- New(to me) 04 Sportster
- Energy One Diaphragm and Extra Harley Plates?
- New bike, need ideas.
- Is this a good price for a 13' Forty Eight?
- Which Pillion with Brawler Seat??
- Heat Demons handlebar heater review
- how to intall cycle shacks on my 2012 iron
- Chrome bars on Nightster
- Steering Axle DIY
- A/C Question
- Need a little help, SoCal
- Oil Level Question?
- lots of problems..whats my next step
- Another suspension question
- ok LAST POLL I SWEAR, just put on black fork covers, pics with fairing and without
- Carburetor Help
- Triple clamp/rake help
- Cycle Shacks out, SE IIs in.
- baffle plugs
- Advice: Removing Trapdoor Transmission
- Hands free fob
- pulsating front brake
- dented rim and the dealer
- Haaa !! 04/1200 Bike wont start !
- Dipped the Sportster
- Stage 1 identification question
- Need Help Fast.
- Valve Rattle While Cruising
- Cuts out on highway.
- 2004 Sportster Engine Rattle
- Solo seat that covers the ECM?
- 2005 883R sportster fuse block
- Syn 3 or normal hd 20w50?
- iron 883 owners
- doing burnouts everytime I start off
- Are Baffles necessary?
- How do you bypass the VOES?!?!?
- HELP needed - just installed Arlen Ness Big Sucker left with odd problem
- Adding a Speedo
- HID kit questions
- LED bulbs
- what a jackass
- About to chop fender, got a question
- Where to store disc lock while riding
- I am addicted to chrome
- need help deciding
- Odd 3rd Gear Issue
- Saddle Bags
- Is it possible to get a titled frame?
- 48 - Front Turn Signal Relocation Wiring Question
- Burly Ape's FINALLY ON!!!
- What exhaust is this?
- CV Carb mods
- Any reason shocks from a 2003 will not fit a 2009?
- RK shocks and bike geometry
- Help finding derby cover
- Nightster Battery failed
- Paugcho pipes
- question bout new apes
- cycleshack drag pipes, what else do i need
- Front fender removed
- Question on the transmission chain
- 10" struts with spring seat???help!!!!
- where to buy extended electrical harness for 12" rsd vintage apes
- Alarm and Dead Battery Help
- nothing but problems...need any knowledge
- Can you identify this part?
- First time wrenching...oil filter from hell!!!
- My Scooter has come alive
- Any South Florida riders...
- In Search of a Mechanic in Chicago
- What are your head temps if running a Dakota digitial or Power Vision?
- Difficult steering at low speeds
- Dyna Wide Glide Trees on Iron 88
- Me again, BRAKE ISSUE NOW
- Rear Sportster wheel on front?
- Right foot peg/brake pedal bracket bolts sheared off.
- Setting tickover when warm.
- Name that fluid
- MPG, What are You Getting?
- Progressive 412 Spacer Placement??
- New to the forum and have some questions!!???
- Got it!
- Backfire
- Drag bars with Risers on a sportster?
- How I made my sportser load for 12 bucks
- Broken belt 8500 miles! Why?
- New guy from Maryland
- Set my first car alarms off
- Hollywood Handlebars
- Buying first motorcycle, is this a reasonable price?
- update on jetting "46 & 190"
- Hi all and rear shock settings?
- Chopped the fender on my Iron (pics)
- Road 6 customs apes
- Custom Chrome flush mount gas cap
- Garage door opener
- 2012 48 ignition relocation
- Fatboy front fender
- Am I crazy to ride to the dealership with a leaky tire?
- sportster 48 performance?
- B l a c k c h r o m e ?
- ebay bike, too good to be true?
- Question on tranny fluid change
- New owner
- Hows it going newbie here.
- bearing noise
- Rear Tail light Problem
- Doing bar swap, throttle cable question
- Best year for 883R
- 2001 1200C cuts out after 40 minutes
- What is the difference between 99 and 2000 wheels?
- 04 883 Spoke wheel change?
- Rear wheel on front
- fuel pump issue
- Gold Metal Flake on 48 Too Trendy???
- Thoughts about this one....
- I'm a noob to Harleys and I'm trying to get a new winter project. Is this a good deal
- '07 XL883L shutting off after warm up?
- Anyone riding to or in Santa Barbara this weekend?
- Rear Wheel Bearings Gone Bad
- width of drag bars
- 48 Sportster, 7" Headlight - How to Wire it
- Speedo Removed
- cleaning
- Ignition switch
- 10" Ape Cable Kit
- Required Mods For New Pipes?
- New to this site
- oil leak from rocker covers
- 883 to 1200 Conversion
- Gas Cap doesn't ratchet ?
- Full Bore Tour King tires???
- I found the stock Sporty grips too narrow & don't want to replace them? My answer:
- Hardtailed 883
- XL1200C Questions
- Removing the sub fender from 72' (and similar models)
- forward forward controls
- 10 mpg drop
- tank removal
- Half way through the break in and...
- Almost bucked off my seat on highway
- Won't Idle/Runs Rich
- 130.6 miles on a tank of fuel!!
- 883 to 1250 Exhaust ??
- Few questions about my sportster - carb/wobble/handlebars
- Selling a bike. Any interesting stories
- A different look for a Sportster
- His and Hers Sportsters
- Anybody have an opinion on a price for an FXSTD
- 48 owners
- aftermarket headlight for 1980 xlh????
- India : Superlo(w)ving the Harley Davidson XL 883L
- Skulls & bikers
- wiring help
- Softtail wheel?
- Cables/Risers?
- quietest exhaust
- holy RK shocks batman!
- lets see some mini apes and tall sissies!!
- Winter Project
- EFI Sportster BEST slip-on for POWER
- 1977 Ironhead Sportster
- Help on battery issue.
- My first harley
- sportster drag bars
- What year Sportster was this??????
- Horn Cover
- Electrical problem no power
- Fat Bob headlights on a Nightster
- Introducing.....my Nightster!
- my chain rubs on my tire and my gen. light is on
- New Guy with Questions ...
- Anyone have problems with speedo failing?
- Nightster style fender on solid mount
- Need Help Troubleshooting Problem...Coil or Carb or Something else?
- Mutazu Hard Bags
- Ricor shocks
- Would a chrome tank be cool?
- Updated Pics
- Old bike new seat?
- So I finally read the story about the bell. are you serious?
- Headlight Visor / Fairing
- First Time Owner - First Long Drive To Beach!
- I know I am asking for trouble.....
- Looking for a better passenger pillion
- $500 for tank lift
- Running Lights
- 48 custom painted tanks
- How important are torque specs?
- any one running the Licks Fly Sucker air cleaner?
- XR1200 ... i want one
- Call be Bobby Brown
- late model grips
- Any idea which mount works best for the PowerVision?
- extended hard bags on a sportster?
- Finally found the time
- Sportster 1200S Sport Sissy bar
- P0118 Code?
- How do i move my tank back?
- 2011 Canadian Nightster - Brake Light Conversion
- Pics of my Cerakote'd Headlight housing ring
- Rain and Hail on recent ride...
- Remove gas from carb or not...?
- Running mini electric speedos 04+
- Bought a Cig lighter style charger....question.
- Windshield vs. fairing - 2009 Nightster
- Check out this Sporty
- Ape hanger install help!
- cheap 2 up or pillion for 2012 sporty?
- Starter issue?
- what do i need besides the tire to fit this front wheel? 21x2.15
- Shifting into 1st at high idle
- x14ied & idle speed related ?
- painting engine
- install Mustang Seat on XL1200C
- did diy work now oil leak
- Removing Sprocket Cover
- T-Bar question
- Help me decide my winter mods.
- LSR 2 into 1 Anyone run these?
- Short travel - bag options?
- Jeans flapping
- Seen a 72 with drag bars or T-bars yet?
- 1982 xlh 1000
- Ordered a Fuel Pack
- new owner/mod questions
- Rejetting Updated (#46/#190)
- Anyone kknow how to use the Tach on a Power Vision?
- Need help installing Bassani Sweepers
- Thanks DK Customs!
- 883 possibly converted?
- Need some help with my S&S pipes
- Sportster Tin Interchange - Years???
