PDA
View Full Version : Sportster Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299
  1. Show your best unique & custom mods
  2. 2000 sportster 1200 bogging issues
  3. 883 torque
  4. 2nd bike
  5. Am I too big for a Sportster?
  6. best mod yet
  7. just got arlen ness orginal 1/4 fairing help
  8. black denim clear coat
  9. ran the 48 out of gas just to see...
  10. Mystery Module
  11. 07 sporty runs rough at slow speeds
  12. Queen Mary bike show?
  13. Highest Oil Temps?
  14. Help identify license plate mount - 48
  15. Harley 883 Iron STOCK Headlight Eyebrow...where do I get one?
  16. Pipes, Air Cleaner, Jetting
  17. near-new '09 - - should clean Injectors?
  18. Fuel Pump Whistling!
  19. Question re Iron Head blinkers
  20. Better Mileage after upgrade
  21. Kuryakyn Grips question for 99 Sportster
  22. Progressive 412's, moving towards cafester.
  23. A little annoyed after my dealership 1k service...
  24. 4 speed owners....when to shift / rpm questions
  25. Combo Speedo Tach and Turn Signal Extension Caps
  26. sportster service manuals
  27. "No ECU Detected" with Power Vision
  28. will an engine guard fit on my bike?
  29. thank you bykas spoke wraps
  30. Engine guards- HD round vs. lindby vs. HD mustache ?
  31. Project: 883R/C
  32. Newbie
  33. '03 1200S leaking oil/gas out of exhaust..
  34. Taller Sporster
  35. 86 sportster 883 bigger tire new fender
  36. rear fender reflectors
  37. In defense of the Sportster
  38. My Seventy Two
  39. 48 or Nightster pic.
  40. solo seat with clip-ons
  41. Oil Problems???
  42. Burnt on plastic on powder coated heat shields! HELP!!!
  43. Fitting deuce style turn signals to older sporty
  44. thank you Rich00748
  45. Pinging/detonation when hot
  46. Electronic timer/points system
  47. Going from stock to ape
  48. Lowering a "Low"
  49. 1994 1200 Sporty
  50. sportster seats, let's see the pics
  51. Higher Speed Limits I want a 6 speed
  52. 2008 1200C cuts out
  53. 2006 XL883C Front Fork Length
  54. Need help restoring a 95 XL1200
  55. sportster trans lube
  56. First ride, sore behind!
  57. Forward and Mids and Highway Pegs
  58. Anyone else have an issue with pullback angle?
  59. Performance Machine Grips - Throttle side Rattle
  60. Breather Kit Options for '97 1200C?
  61. sportster starting problem
  62. Clutch Failure at 11,000 miles?!
  63. Limited Edition Fuel Tank or go Primed and spend elsewhere?
  64. Intermittent horn
  65. Anybody knows anything about Buell's?
  66. Chain loosening up
  67. pistons for big bore
  68. Battery problem?
  69. Just went on the best ride
  70. Bike Stalls When Hot??
  71. Sportster owners looking for long ride comfort!!
  72. New handlebars, need examples
  73. UPDATE on heat issue and decel popping post 2013 883 to 1250 conversion...
  74. Starter issue
  75. Fair price for this 2005 883C?
  76. ME 880's
  77. Here is how to shift without the clutch
  78. 1992 Sportster XLH1200 Parts
  79. DK coil relo issue
  80. Speedometer stopped working
  81. First ride without baffles
  82. belt.to.chain.conversion
  83. Chasing a NOISE...Primary? Transmission? HELP!
  84. Anybody try custom dynamics universal light bar under fender?
  85. couple updated pics of my new to me 97 1200S.
  86. Urgent help needed, or next post is XL for sale!
  87. Where do you get your custom parts??
  88. Transmission Noise & Trans. Oil smell
  89. engine question?
  90. Another question for the day
  91. Auto tune run quest
  92. Sell stock parts, or stockpile them?
  93. Catalytic converter or no catalytic converter, that is the question!
  94. Considering A 72?
  95. Sporty Grips
  96. miles
  97. Anyone put a 48 seat on a 2009 Iron?
  98. What bars did you put on your 883/1200 Custom's tall risers?
  99. Changing Wheels
  100. Road6Customs 14" handlebar on 48
  101. wheres the chopped fender?
  102. Stock Muffler
  103. '48 done gone (nearly)
  104. wheel balancing
  105. Mustang Vintage Solo vs Fastback Seat
  106. Joker Machine speedo relocation bracket for an 07 nightster
  107. Changing Rear Indicators - 2013 48
  108. Plasti Dip & My 48
  109. 48 passenger pillon on an Iron 883?
  110. JPcycles custom street low handlebars
  111. Sportster throttle cable adjustment
  112. Thinking about an 86 Sportster...
  113. Got my Bassani Firesweep's on
  114. Khrome Werks 2.5" or 3" slip-on?
  115. Is harley diamondback clutch cable worth?
  116. Biltwell HD Tuck n' Roll Seat
  117. So what is this "fun factor" of riding a Sportster?
  118. sporster brake light switch
  119. 2013 iron 883 question
  120. 93 1200 sportster exhaust nut torque specs please help
  121. Back To Accessorizing...My List
  122. Power off when trying to start engine
  123. Lots of metal on Primary Plug
  124. speedometer does not shut off
  125. Dumb Tachometer/RPM Question
  126. Stupid question???
  127. My 883 Iron
  128. Re-assembly after 1200 work
  129. Harley Diag Program?????
  130. vibration
  131. Newbe question on 2013 Iron
  132. my 72
  133. 2003 XL1200CXNRDB Build
  134. Plate Relocation on 48
  135. Front sprocket redesign?
  136. Sporty fork help.
  137. DK customs
  138. swapping from xieds to tuners? ?
  139. Weird noise, cant tell where its coming from
  140. Sissy bar HELP??
  141. Sportster 2005 883 - 1200 Conversion power problem when hot
  142. Switchback Hard Bags on a Sporty?
  143. OK Sporty riders Sell me one...
  144. Lower rear shocks for old Sportster
  145. did a wheelie today!! VIDEO
  146. Sporty Speedometer problem
  147. New fob battery, will start with code, does not recognize fob
  148. suggestion for detachable windshield for 1200 XL
  149. ECU Question
  150. How to carry an extra face shield on a Sportster.
  151. Sputters & Stalls when warm
  152. Replacing Rear Brake Pads With Integrated Caliper
  153. Pluging the sportster
  154. Sissy bar mounting bracket measurments
  155. NIGHTSTER reduced forward controls
  156. Windshield fitment
  157. Re working the factory seat
  158. cutting out
  159. Solo seat comfort?
  160. Finally ordered my PCV !!
  161. 98 Sportster Headlight Wiring
  162. XL1200C engine "stutters/misses" at 'neutral' throttle
  163. 2013 48 handlebar swap
  164. Bad Battery Tender?!?!?!?!
  165. Exhaust help!!!
  166. fast sportster..?
  167. quick question about shocks
  168. Ironhead vin trouble
  169. TTI 118W Install
  170. VS or not to VS....
  171. Superlow 883 XL Perfect Lift.
  172. Is a Sportster a good bike?
  173. SE Heavy Breather
  174. Lookin for new apes
  175. 2007 exhaust problem quick fix?
  176. What is needed for Fatboy Wheels on a 48?
  177. hellbend custom cycles
  178. Cleaning Primary Case
  179. Good cleaner for bioot marks
  180. Cycle Electric parts ?
  181. What are the loudest pipes you know of
  182. BCT head pipe baffles way too loud... now what.
  183. Fork seals, what do you recommend?
  184. HELP PLEASSEEE! Bike Won't Run!
  185. How do you adjust this shock?
  186. Few pic of my bike.....:)
  187. are you kidding me?
  188. Has anyone seen the new HD backrest for Sporty models? (pic inside)
  189. 2004 883 Directional Trouble
  190. XR1200 in the movie spotlight
  191. Newbie Purchase Question
  192. Need shorter shifter and brake arms 1200c
  193. upper rebuild need opinions
  194. What starter?
  195. Why doesn't my Choke Cable stay in place?
  196. Let's see 1200 sporty's with trunk and bags.
  197. 09 Nightster lugs in low RPMs
  198. Got bored this weekend
  199. new Sporty 72
  200. 48 pinstripe
  201. New guy choosing a sportster
  202. Accidentally downshifted without clutch engaged...
  203. oil light flickers at random
  204. my sportster so far!!
  205. Solo Rack Bag Ideas
  206. New headlight
  207. 48 tank on sportster custom.
  208. Sportstouring today!
  209. vance and hines short shots
  210. Went for a ride.
  211. Got my sick saddles seat on the 48
  212. The Little 883 That Could
  213. windshield, speedometer / tachometer, highway bars, etc.
  214. DK Customs coil and ignition kit question?
  215. Roland Sand Air Filter 2010 883 Iron Install Questions
  216. Help! Overflow oil leak under the seat - 2000 XL C
  217. Steering head bearing adjustment
  218. sportster primary cover
  219. best relaxed style bars for 48
  220. pipes, velocity stack, fuel pak now or can it wait?
  221. Tires for 48 laced rims
  222. Thinking of new bars
  223. My 4th of July Mod - Front turn signal Relo
  224. Burley lowering question...
  225. 1000 mile service
  226. Rear fender hole???
  227. Got in a wreck
  228. Interesting Wet Sump Question
  229. 1999 1200 sporty runability
  230. Friend's Bobber Build - '83 Sportster
  231. what year tanks will fit my 97?
  232. Playmate for my 48
  233. Clearly, a Master Mechanic!
  234. Help please- Chrome Glow LED rear light on Nightster.
  235. Emergency- stuck on side of the road!
  236. Curious Rejet Quesiton...
  237. 97 Sporty Rear Brakes
  238. Fork shroud pix I took last night for Tyler at Lowbrow
  239. V&H Double Barrel Staggered - Baffle Question
  240. XL Drag Handlebar Question
  241. My new 2013 48, drilled baffles *video*
  242. Quesion from a Newbie on PIPE Upgrade
  243. Just a rant about fuelpak
  244. 3.3 tank scratch
  245. Finished my new build Harley Cafe
  246. 1983 Iron head clutch issue
  247. no power to starter button! blows ignition fuse as soon as you turn key, help!
  248. Rolling Untrue
  249. Friend took a tumble on his Sporty, help with a fix..
  250. ATTENTION: DO NOT BUY RSD / Vance and Hines 2 to 1 slash cut for forty eight
