View Full Version : Sportster Models
- mini floorboards
- Swing arm bolt FELL OUT!
- Need help. . .
- Charge system wiring diagram
- vreg output
- credential storage solution
- Proud New Owner of a Sportster
- v&h str. shot slip-on baffle mod
- Marine Corps vets
- Weak Bottom ends on 07-up?
- looking for a smaller battery
- Help with SE pipes
- New Harley Sportster Rider With Motor ? Mechanics Please Chime In
- coil relocation
- what length cables do i need for hd mini apes on an 08 sporty
- Has anyone...
- Rear Signal Relocation Help
- Oil pressure gauge
- Detachable pillion 08' nighster? Ideas
- FYI How far can I go on my 48 with a full tank
- help! bike wont start.
- Vance&Hines Fuel Pak on 08 1200C
- Shifter Peg Modification
- Summer Nights
- Rear Rocker Box Leak
- Passenger choice...
- Rear shock adjustment
- Saw my first 48 in Strongsville, OH last night...
- First Harley (well nearly) - advice needed please!
- Question about the 2008 XLH
- Avon Distanzia Supermoto tires...
- '67 XLCH stalling out after 15 minutes of riding
- Anyone running Windows...?
- Primary oil
- Would a 99 sporty 883 have O2 sensors in the factory exhaust?
- tank lift ? - can you do this mod to a '89
- question about rear fender
- What's the vote on the new 48...
- nightster front end
- Cables for Nash 14' Midget Gimps
- Billet Wrap-around LED Fork Mounts
- Using a Battery Tender
- Small Tachometer????
- 05 883 xlc slip on mufflers
- Tach not working...
- front spocket cover
- WTB rear fender without tailight hump
- 96- and up wiring
- Post you Bar Specs!
- 2008 Nightster...too tall?
- Need help deciding on bars.
- Qts for the 48's
- Thanks to Everyone
- next question on 592 code
- Nightster turn signal wiring connector
- Low fuel light coming on within 20 miles of full tank
- what size are the fork tubes - to mount signals
- tank lift, wire tuck, coil relocation... i got myself into a mess!
- What do you think of my new/old exhaust system
- Dilema
- PHASE II of MAXIMUS Complete!!
- What Mirrors Do You Have?
- remove fiberglass from shorshot baffles?
- 48 w mods
- RK shocks for sportster need info
- what shocks are these
- how do you take care of flat black paint??
- Do you keep stock parts?
- Luggage Rack?
- Question on changing 883XL's tank & handle bar
- Ignition coild relocation kit?
- Do you have a 2nd choice for a bike?
- 883 hugger shocks vs Biker's Choice shocks???
- Throttle Problem
- coil cover install
- New Iron rider
- 1 month old Iron and already changing parts...(pics)
- New tires for my Nightster, suggestions? Side note on my V&H shorty quiet baffles
- Nash 12" grit hangers....cable length etc?? Need your opinion.
- If your Sportster won't idle right
- Ordered the apes today
- LED info
- Newbie needs some help!
- 65 Sporty Ironhead
- Welding precautions on a Sportster
- Enricher/Choke cable replacement help
- 1200 conversion on the cheap???
- Mod's & Miles....
- New Rider... and a new 48
- ck engine and battery light
- gas tank 95 sportster
- rear fender strut covers
- Sportster Speedometer Problem
- '94 883 pully change
- Found a connector that's not connected...
- My 2010 Iron will arive soon!!!
- Question for folks with tank lifts
- NHRS now producing round kits
- Premium Oil Cooler Kit 62996-07 // Thoughts ??
- Performance pipes that look awesome!
- kinda of a stupid question
- Quick Question about a 1200 Custom
- Another newbie question
- what year forward controls?
- What is the largest tire to go on a 99 sporty?
- Annual Sportster Rally... ?
- Is my sporty running too hot?
- Flipping mirrors, Removing Saddle bags and Rear backrest brackets
- ?s for the sportster crew
- Sportster Exaust Recalibration
- Nightster updated pics
- 2008 harley davidson sportster
- New pipes
- Sporty bobbed saddles....
- Pics of C models with drag bars?? And 1 question
- What do you have planned for June 12???
- Smaller Front Wheel on Iron
- battery terminal
- New to Nightster Questions.
- My Fabbed Up Apes!
- Fuel moto vs d-load
- Getting a bike! what one?
- Air Shocks on Nightster, washer size?
- chopped rear and your brake light?
- springer seat conversion how to?
- need help with remap
- Cables rubbing
- lick's slicker exhaust baffle Question
- Hooray.. Dyno sheet
- Added Vance and Hines shortshots staggered and Duke air box to 1200N
- Nightster changed to a Bagger!
- Oil drip from clutch cable
- Creative solutions for tall riders?
- My 883/1200 conversion looks to be heading towar another rebuild!!!
- got my joker led's done today...pumped
- Probably a stupid question???
- For those of you with a solo spring seat on your Nightsters...
- Won't Start Once Warm HELP!!!
- Wow...What a Difference
- Question for folks who have air shocks?
- torx size?
- Drag Pipes and Baffles?
- DNA Springer question
- Need help with a hub kit.....Thanks
- Upgraded
- Stage I Setup (D&D Bobcat)
- 2004 XLC Leaking primary oil
- owner tranny repair?
- Bars Questions
- Cheap Trailering Option???
- changing primary.trans fluid with no stand?
- Finally! Pics of my Iron
- sportster exhaust
- swingarm nut size and front motor mount nut size?
- New Pipes on my Iron
- Help required...
- Helmets... AGAIN
- What's the Best?
- the carb has a cough
- Progressive Suspension 412
- Passenger peg question
- Nightster Passenger Seat and Pegs Help Please
- Pic hoing the Iron!!
- Handling & Luggage on a Sporty
- Sideshots with passenger pegs?
- Pictures of 3" Risers on their Nightster
- Battery Draining on 05...
- My First Sporster... Help with basic mods?
- 05 - 1200 Choke Cable...
- Sportster local rides in Northridge
- New Member, New 09 Nightser, rust on delivery?
- Best bars for a nightster?
- Suspension adjustment
- Where the *bleep* is my registration supposed to go?
- 20k Service + Detail
- looking for mini apes and cables
- Headlights
- Rate my ride
- "Diag" came on today
- Your Sportster Picture Post
- Sporty Basher
- speedo stopped working ne ideas?
- Can you help identify these pipes?
- 25648-01 cam istallation instructions
- New Handlebar
- Tach install issues
- 89 belt drive conversion?
- What cams to use??
- 88ci Kit from NHRS
- Mirrors for Tach
- No Speedo?
- Another Sporty project brought to you by...Beer
- XB or 04 heads, where do ya get keepers?
- Nightster pipes
- Detachable pillion kit
- 1200L with seat and bags
- how many mirrors?
- stiff clutch options
- Clutch
- brake/run/turn module
- 2005 Sportster Seat on 2008 Nightster?
- The Nightster is now the "Beachster"
- Which should I do next?
- Tranny fluid question
- New to the HD family with my Nightster!!!
- My Nightster...
- Finally got the Iron!
- Ricor Suspension for Sporty
- 883 to 1200 Conversion Instructions
- If I get Paul Yaffe X-Pipes...
- stock exhaust
- Bike dies, no electricals
- Comfort: Progressive Shocks vs. Stock
- Iron 883 flipping the mirrors?
- Had an accident
- wash&wax
- Getting ready for the ROT rally in austin
- New to HDF 07 Nightster
- Ape hanger size and comfort?
- Screamin' Eagle Jet Black Buckshot exhaust or V & H short shots
- Kuryakyn Grand Touring Bag
- front end bolt-on?
- please name this part
- 2005 883 sportster with factory custom paint
- question on a seat
- Oil type?
- my dumb oil change question
- Rear Shock Question
- 10k Maintenance, Do the Job Myself?
- New sportster battery side cover clips.
- What size is the rear rim?
- Neutral Switch/Light problem
- WTB parts for 05 Sportster 1200C
- Need help on cable replacement/extension
- 95 883/1200 sporty exhaust change???
- Screaming Eagle? How to tell?
- Fuel Pak vs. Power Commander vs. SE
- pic of my 883
- Lowering a 1200 Low??
- Licks Slickster Exhaust
- Brake light cap on an Iron 883 Sportster
- Warranty Thoughs: 28 days left on the warranty, just got XL1200L, throttle concern
- Nightsterized the rear fender
- Looking for new rear rim
- Under $5, no wiring needed, 12 volt cig adapt.
- Micro-Bubbles in my oil.
- nightster luggage
- Most comforable bars
- First Modifications to my Nighster
- 2 hours!!
