View Full Version : Sportster Models
- 2002 Oil Issue
- Ape hangers installed & more !
- 883 conversion kit 1200cc from harley dealership or 1250 cc from s&s
- Help with left turn signal
- Replacing rocker box gaskets - any tips/tricks?
- short chaps
- solo rack for sporty
- Searching For Upper Clamp for Triple Trees on Forty Eight
- Stage one kit
- HELP - Harley Shop can't figure out my problem
- new rear shocks
- Finally did it!!
- Ignition toggle install
- Starter Switch Amp Load
- 2005 Sporty starter problem
- 2016 Roadster
- Advice buying battery
- Limit riding until MSF?
- HD Iron 883: Clearance between rear fender and tire
- Hi from Belfast w/fuel-mileage question
- I think I need a LOT of help..
- 04 883 jetting woes
- Shift shaft
- Wisco kit
- Sportster Dead After Carb Rebuild
- What AM Tank is this.
- Anyone have Mammoth spoke wheels?
- Motley Crue Girls Girls Girls Exhaust Tone
- Ultima electronic ignition wiring 85 XLH
- Stock exhaust pipes (with crossover pipe) better?
- front end wobbles when i let go of bars
- Taking off clutch cable
- weird IACV problem
- weird IAC problem
- 1990 Sportster issues
- Rain Sock ?
- 2016mod xl883n iron -cutting out
- Throttle cable and inverted mirror clearance
- First Post, Need Help!!!
- Gas lines
- 2012 sportster tune?
- Dunlop Trailsmart Tires/16 Roadster
- What years will interchange with 2000 XLH
- Fuel Line Routing
- Mustang Vintage Solo or Corbin Classic Solo
- Won't go into 1st or 2nd
- 2015 forty-eight problems bug me for a while
- XL 1200 forty eight 2015 exhaust
- Lowering Kit?
- Need to relocate ignition switch 1994 Sportster
- 1999 Sportster 1200 Starting problems
- Figure Machine air cleaner
- Hammer 1275 Super D
- Sportster speedo mount
- 2014/15 V&H Exhaust on 2010 Sportster
- My DK Customs Outlaw Seat
- 2001 extended forward controls
- Speedo Mount 85 XLH
- Comfortable seats for the Iron 883
- YSS PD Fork Valve
- 97 1200 won't turn
- XL-ViED settings for 2015 iron
- New guy sporty problems!
- Wide whites
- SE clutch
- I broke the plastic back plate.. filter kit.
- 2015 HD 48, installing passenger footpegs and full system exhaust
- battery, charging, draw???
- New and Help needed!
- Brand new Roadster. Blue smoke at startup?
- Strange wear on belt drive rear wheel
- turn lights not flashing
- My 2017 Iron 883 Denim Black
- Iron 883 forward controls??
- 1k service
- 96 Sport pulley alignment
- Power Vision
- What Passenger Seat is this?
- '14 Iron 883
- 98 1200 evo
- Brake pads on 2014+
- 2000 xl1200 sputtering worsened over time, now dies if too much
- Dead Battery? No power (2016 Iron 883)
- 883 start up
- Redline Primary Case Oil ?
- cv re-calibration kit
- Won't Start After 1275 Conversion
- Custom Dynamics warrantee experience
- Cant seem to seal crossover, 05 883C
- 2005 883 Miles Between Fills
- petite girl needs handle bar suggestions
- '79 IronHead pushrod adjustment problem
- The Harley-Davidson Catalog Cafe Racer Custom Sportster (photos)
- My 2012 Sportster 48, 1200XL
- Ironhead Footrest
- 5'9"-Need relaxed bars for a 2014 Forty-Eight
- Steel Braided Brake Cables (XL1200CX)
- Forward controls for an 08 Nightster XL1200N
- Advice on buying first Harley Davidson
- ironhead brake torque arm/brake bracket rubs disc
- early to late control switch and housing swap
- 76 ironhead rebuild - Cylinder replacement V-twin 11-2607
- Speedo/Tach question
- loose battery terminals
- Jiffy stand problems???
- Sportster 48 handlebars
- Torque wrench
- New guy
- DK Customs Thunder Torque Iron 883 question
- I'm feeling new exhaust in the works!
- Need some help.
- Chickened out on the DIY handlebar swap
- Starting issue fueling
- Tank lift YAY or NAY?
- Best Sporty Cable Kits
- Synthetic oil in primary
- Knocking in motor somewhere
- kickstand alternatives for 883
- Can I run dual fire cool with single fire ignition?
- Ring gap for turbo 1200
- Sportster Kickstand Clearance
- Power Vision Tuner Help
- Bolts on Cylinder Heads?
- Teachable Moment: How Does Oil Get Under the Pistons?
- 2010 iron 883 grips
- 2016 HD Forty Eight X1200X
- More sportster mods
- Chin Spoiler...please help!
- Seat that positions you slightly forward?
- New to me 2010 Iron 883
- 1996 883 XLH question
- Trigger finger clutch and brake levers ???- 05' 1200C
- shift fork question '80 ironhead
- Right peg won't stop spinning?!
- new fuel tank pump advice
- air filter question
- Starting Current
- 2000 Sporster Sport Wiring Diagram
- Replacement Battery Suggestions...
- 1979 xls roadster ironhead won't fire
- wiring a power outlet how to
- Removing tank emblems
- Viking Bags question
- 4.5 tank lift on an iron
- got my new seat
- 2010 883 Iron in gold metalflake
- Rear wheel install on a 2013 Iron Sportster
- Leaky petcock
- does anyone have the RSD PROSTEP HANDLEBAR 12" on their 48?
- 2002 1200 Custom
- 883 with 1200 kit?
- Giddyup 2017
- knock off day maker. which one?
- FOX Shocks
- Best Anti vibration foot pegs?
- Speed sensor location '03 883
- Where is Sportster 72
- Tire Recommendations
- 1994 Harley 1200 sportster bobber... right turn signals solid instead of blinking
- Need a little help.
- Sportster rear brake no pressure
- Nightster Tire Tube
- Making stock pipes louder method
- in need of some advice on possible upgrades
- Frame I.D.
- help me identify this headlight.
- Adding brake lights
- Rear Brake Help
- 2016 Sportster 72 tuner???
- Where are all the 1200 Lows?
- Gas tank removal
- Looking for advice upgrading pipes and air kit
- New Battery Good Ignition Push Start Button (Silence)
- A problem?
- Paint matching
- New Member
- Need some exhaust education from a expert
- 14" Legend Revo A shocks fit?
- 2016 Iron 883
- 2012 Forward Controls on a 2017
- Missfire troubles
- front turn signal wire routing question
- 2013 Brake upgrade
- Throttle "snapback" issue after drag bar install
- Redlines, springs and trouble
- Starting to like the 883r
- Dyna Shocks on 883
- Iron 883, 2017 - 15" Rear shocks?
- Seat that brings me forward?
- Wont start, cranks and can hear fuel pump but wont start
- new to the site...engine trouble
- Some goodies arrived today
- What needs to be done to put a 21 inch spike front wheel on mY 2015 superlow
- Let's talk reupholstered factory seats
- Sportster Solo Seating
- What frame is this?
- Front brake light switch without using housings.
- Belt snapped
- Cafe Racer Kit
- New Roadster Bars on a 2003 883R
- 2006 Stalls/Dies at Red Lights/Stop Signs
- Jump starter / portable battery
- 2016 Iron 883 Wiring
- Front and Rear wheel axle
- 2011 HD Sportster 1200
- 1275 install underway
- 883 to 1200 conversion
- I put new handle bars on 2003 harley flhtcu
- Rear exhaust bracket delete...ok?
- Clutch cable leak at primary case
- touring gas tank
- Sportster details needed
- Stock H.D sportster oil tanks
- Young Guy - Bad Back
- sporty 1200
- My first minor wreck
- wiring: about to set a match to it!
- Got a nightster.
- 2016 Roadster Flyscreen?
- One Engine Shutting of after I start Bike
- Bought my first bike mistake or no?
- removing front pulley cover
- Do I need to inspect clutch disks
- Stage 1 Problem
- 2 up Comfort on Roadster
- Mikuni Install Issues
- Tour pack mount
- xl1200s Turn signal help
- SG shocks and Viking hard bags
- size of the motor with serial number FF146659466
- best tyre for 16 up 48?
- 2001 storster 883 on highway trips
- 05 HD oil dipstick with Temp gauge leak
- Throttle gets stuck
- 2003 hd 883 hugger 100th anniversary newb questions
- Help need to pass rego
- New Sportster Owner
- Taking off the California Charcoal Canister
- Is this normal?
- Paint or Powdercoat
- 07 sportster tail lights
- Purchasing my first HD... help!
- Battery: Best vs. Most Practical
- fuel tank
- 883 Piston head after only 1000 miles
- Analog tach/digital speedo update
- 2014 48 14" ape hanger info
- Sportster 883 not starting up.
- ideas please
- 04-06 King & Queen Seat
