View Full Version : Sportster Models
- Suspension upgrade and report (Progressive 444 content)
- 2007 Sportster Tires
- 1200L handlebar question
- Adjustable Brake Rod
- 2017 Iron and a few questions
- thinking about getting a softail slim
- Sportster 883 Low 2008 // Changing the Air Breather without the Fuel Pack makes any difference???
- changing handlebar on 07 XL1200R for better reach
- 77 ironhead choke
- Sportster windshield
- 883 sputtering at idle
- Good seat for 2015 Iron 883
- Sportster 883 has Misfire on Front Cylinder
- Superlow tank size
- Tips of selling my sportster used??
- Leaving
- Mid Controls
- Speedo relocate from Biltwell
- Restricted Iron with aftermarket Air Cleaner
- Exhaust Stud Removal and Replace - Advice?
- Front Wheel bearings 79-83 hub
- Fuelpak
- 2014-15 Iron 883 rear brake switch
- Oil leak behind battery cover
- Sporty acting up
- box build
- Got a new 2017 48...
- 2017 HD Fourty Eight 1200XL
- Engine/ Fork Paint
- Windshield for 2012 883 Superlow
- Key fob repair
- Running lean after hammer 1250 basic conversion
- instrucktions on installing HD hard saddle bags
- How to remove Saddlebags from 2015 1200T Sportster
- Riser removal 09 XL1200C
- how to check if numbers are good
- 1994 HD Sportster 1200
- Air Cleaner Help
- "Old School" Oberon Adjustable Clutch & Brake Levers
- When I do diag on my 883 Harley Sporster it pops up with code P0603. What is this referring to?
- Need some help w/ Drag Bars
- First road trip on my Sporty
- Need help with my 95 883
- 2011 Sportster 48 Turn Signal Module
- B1154 code
- 2018 Sportsters?
- Failing gaskets?
- Steering head Fall away test
- '98 Tach on a '05 Sportster
- No spark, sportster
- Recommended oils for XL1200C
- XL1200C Front end swap, or, just options?
- 2007 1200 sportster will not start
- no rear brakes
- Led front turn signals from custom dynamics
- Road King/Street Glide Shocks For 04 XL883C - Help Please
- What else to remove?
- Searching for front wheel...2005 XL883L
- 95 sporty hypercharger back to stock?
- hypercharger to stock air cleaner
- How to install hard saddle bags
- Mini bagger in the family
- Clutch issue???
- For those the a toggle ignition switch
- Sportster article in HOG
- 2004 speedometer to 2002
- Torque wrenches
- 883 Low?
- shocks vs seat for comfort
- dent in 2004 sportster and up gas tanks
- 170/70-16 on 14 or newer sporty?
- Left Turn Signal switch
- Hard time starting with backfire
- Spark plug change now bike is backfiring
- 06 1200xlc rough running & knocking off at stop
- Shifting Hard can't find the gears.
- School me on the 2009 XL1200N
- Need help with chopper lingo
- 883 to 1200 kit
- Tail Light Conversion...
- front brake lever on 2016 48
- Fork Oil - how often to change?
- Power Commander V Installation on a Nightster for Dyno Tune
- Won't stay on
- IRON 883, FORTY-EIGHT, NIGHTSTER......for first street bike.
- Any tutorials that work on 2000 year Sportys?
- Got these handlebars
- Installing Seat on 03 Sportster 883
- Reassembled carb -- Extra part??
- Primary fluid
- EFI Sportster Maintenance/Repair Manual
- DK Custom Ironhead build - Photo Heavy
- I did a thing......
- What's The Problem?
- Major oil leak help
- 93-94 tank on 05 883L
- Clutch hub nut 37527-67
- My 883 isnt getting power from the ignition with the key in and in start position
- rear signal ? dual light, red & yellow
- La Pera Bare Bones Solo seat (question)
- 2014 48 sportster loss of power/ reaving up
- Timing Light
- sportster XLC 2004 always ON. The engine doesn't starts. Front light and the horn works
- 01 Sporty Vacuum issue?
- clutch help
- 2008 1200 Custom riser swap, keeping top clamp and speedo?
- Crash 2015 Sportster 48
- Flat front tire
- Whistle sound and vibration
- need some help
- Sportster died and won't restart
- PV Autotune vs Dyno tables
- Iron 2013 sportster please help
- 2013 883 Iron Seat on 2007 883 Low?
- Heeellllppp
- Forward controls question
- Narrow Glide 21" caliper upgrades
- Question about Sportster EVO Rocker Cover Size/Compatibility between XL883 and XL1200
- What is this?
- Shinko 240 Classic MT90-16 Dual Whitewall Front/Rear Tire Fitment
- exhaust/carb question
- Exhaust Conflicted
- 2014 Iron surging. Please help!
- Tuners
- Looking for graphics/decals for '62 panhead
- Handlebar Help
- 2004 xl883 speedometer wiring HELP
- Help with some popping
- Help electrical problem?
- Oil Leak
- Got my first bike
- Help - lost nut from 48 XL exhaust
- lowering a Harley
- Water ingression in warning lights.
- saddlebags for 883 iron
- 48 suspension upgrades
- Opinions on XIED vs full Tuners
- HELP! Sportster not running right after riding for approx. 15-20 mins
- Does Sportster have 3 configurations?
- Sportster on Amtrak Auto Train
- Exhaust compatibility?
- CKP Sensor Synch Error EFI
- '94 Sporty LED headlight probs
- rear shock travel ?
- Sporty runs rough @55-65 mph.
- Do all stock seats suck?
- Minor slip on repair
- SE/K&N Stage 1 Intakes
- 2007 1200c other year tank fitments
- Highway peg bracket mount for 99 Sportster
- Ordered some Biltwell Chumps.....
- 2011 Sportster 1200 won't start
- check engine ligth
- Chrome Heel Toe Shifter Kit, Mid-Controls, Sportster (HTS-SP1)
- Motor Mount???
- Motorcycle Lift
- My 2014 Sportster did just one click and won't start.
- Street Glide Best overall SQ/noise at 65mph+
- Need Advice RE: 4.5 gal replacement fuel tank for '04 Sporty
- 2008 1200n Nightster rear integrated light inop
- 2016 Headlight Grill
- Sportster problem
- Seat pan fitment fab help
- Are these 2 supposed to jiggle around like this??
- Gear position indicator possible on a 2002 carbed?
- Gear position indicator for 2002 carburated Sporster Possible?
- codes in place of milage in speedometer
- 2007 loud clunk no start
- sportster sissy bar removal
- 2017 Iron 883 Peg Vibration
- 883 Lowering question
- Brake Pads & Sparkies
- Questions on a potential purchase
- 2007 doesn't like neutral
- Mustang Wide Vintage Rear Seat (Pillion) and HD detachable sissy bar clearance?
- 95 Sportster.
- Cool Sporty Rebuild Video
- Shifting problem
- J&S Jack owners - '01 1200C suggestions
- Looking to start customizing
- Anybody got a Corbin Hollywood Solo? Particularly for '07-'09's?
- Installing alarm on 2009 sportster 1200xlc
- 06 883C not idling, and black smoke
- speedo wiring
- Sportster Speedo and Tach Needles Don't Work
- Finding TDC using a soda straw
- Sportster 883 vs 1200. How can you tell the difference.
- New Sporty Owner!
- Recommendation for auxiallry port.
- Rear light
- Fuel injectors
- solo seats
- Solo seats - '07-09's - Comfort vs. Looks
- Darn potholes
- Thanks for having me!
- Displacement of 883 Evo engine
- Weight Reduction List
- How much room do I save?
- New XLH 883
- Anyone have a National Cycle quick relase bracket!?et
- TMAP Sportster readings
- Heel-Toe Shifter for Mid Controls
- Roadster seat swap advice please
- Ironhead push rod cover O-ring size
- Trying to figure out exhaust
- 2013 1200C oil change???
- Custom Dynamics Load Stabilizer & Triple Play Install Help Needed
- Memphis Shades?
- Intermittent speedometer issue
- Your thoughts on engine guards
- Tall Rider with an Iron
- Leaking Push Rod Tube
- Forward Controls on a 2016
- No power
- Intake sensor Bypass or Intake with No sensor
- Turn Signal Issues
- sporty stops while running
- Clutch lever grabs at handle
- 06 front rim options
- What else?
- Keep or sell stock parts?
- Help
- Cracks in Sidewalls
- 2008 Nightster help please
- Oil problem
- Boom Audio handlebar speakers
- led lighting 2009 sportster what is needed?
- Power difference xl1200 vs. xl1200r ?
- rear cylinder spark plug wire ?
- No pressure in front brakes
- Fender fitment question
- New/Old Member with Stage1 Questions
- 883 to 1200 conversion
- Stator replacment on '08 Sportster 1200
- New Harley 48 underside of petrol tank bubbling weld splatter?
- 2007 Project: To buy or not to buy?
- best place for tires
- brake upgrade ?
- tank lift
- I've settled on a model
- 1200C need more power.
- Now, this is a Sportser
- Help with springer on 75 sportster
- Gaskets needed for lifter replacement
- Any Celebrations going on in the US
- 87 sportster 1100 signal issue
- New exhaust
- Fairing and wind shield on Sportster
- Please help!!! 09 nightster rear brake/turn signals are not working.
- Mileage with 1275
