View Full Version : Sportster Models
- La Rosa Solo side saddles...do they actually fit?
- fuel overflow valve????
- superlow 883 pipe and fuel programmer question
- Anyone using Harrison Specialties LEDs?
- Opinions appreciated.
- Updated Pictures : 1990 Sportster Build
- 16" Rim & a fat front tire for a 2001 Xl custom
- How screwed am I?
- Oil leakage or normal?
- New paint
- New DK Customs Thunder Torque Inserts Ride Report
- 2005 Sportster 883c jetting question
- dk coil relocation + risers vs new bars
- Clicking noise when starting
- Ticking or tinkling sound from engine
- Rocker gaskets
- The Newer Helments Suck
- Looking to get a iron 883
- gold spark plugs?
- Inverted z bars
- need help
- Electric issues
- 1995 Sportster 883 question
- Full progressive suspension ride report
- Throttle change from to right to left side
- Idle RPM's ?
- 2014 XL883N Fuel Level Sensor + Digital Tach Install (NEW Procedures + Pics)
- 1200 sporster
- Ongoin unsolved issue with exhaust
- Low cost sissy bar option?
- Right pricing for a 2007 Nightster
- just picked up AT100 Auto Tuner Power Commander
- Fuelpak3. !?!?
- Finally! New Nightster
- Clubmans and tank lift
- First Harley!!!
- My $80 2 in 1 Franken Pipes
- Sporster Big Bags?
- Moving Mid Controls Forward?
- 2011 Nightster Oil change
- Annieversary models
- My new Z-bars...
- Any big differences between 2009 iron 883 and 2014?
- Mustang tripper seat
- Gas mileage??
- FYI - Primary Drain Plug O-Rings
- 13 Sportster Custom GoPro mount
- stolen sporty in AZ keep an eye out...
- I want to ride my d*@ned bike!
- Just joined the 2014 48 crowd!
- oil screen?
- SE 2 SP slipons performance issues?
- Harley drag bars
- 21" to a 19" front wheel... Have questions
- My latest stupid thing I did...
- TIP: Coloring the Heavy Breather air filter to match your bike
- Me, my 48 and some Sportster friends and their garages
- Pipes Wrapped
- 06 Sportster cough off Idle
- 883 to 1200 converters please help!
- 2013 forty eight build
- Gas Tank Emblem Removal/Installation
- turn signal issue
- Suspension and handling related
- How to check voltage regulator on '09 sporty?
- 1989 mid controls
- 05 883 acting up
- Bassani muffler and air intake?
- Ellusive starter problem
- Engine revving high when coming to a stop!?!?
- tire pressure on 48
- My first Harley
- Air Intake Disaster from Crankcase Breather - Questions!
- What's with the torx bolts on the sportster??
- Cruizing RPM 2002 883C
- my new bike. wheel question.
- rusty spark plugs
- Dealer wants $200 for horn assembly?
- Stripped shock bolt
- Noise???
- need help for wife's 1st ride
- Helmet
- Jet question
- Easy Upgrades?
- need some help
- spring seats
- HD Forty-Eight and LED Mirrors
- Rear Fender Bolts
- 86-99 sportster laced front wheel
- 2012 Nightster will not keep a charge!
- Kickstand, 2003 883
- Removing rear fender on a 48?
- What kind of brake line do I need to hook up to this? (ABS block, 2014, pic)
- Lowering question
- check engine and battery lights on?
- Kuryakyn mini boards installed
- Rear Brake lever
- Think my clutch needs adjustment?
- Cleaning Wheels
- When to expect super low 1200T in showrooms?
- Nightster rear lights issue
- Hand control connector disassembly for running through bars.
- Finally getting a Sporty
- Knocking from behind transmission sprocket
- Wiretuck with no tank lift
- Custom Forward Controls
- 883 gas tank
- Motorcycle Audio Speakers
- Front fender deleted of all days for it to rain
- 5 3/4" Daymaker questions
- are taller shocks the right call? - '13 Iron
- 09 Nightster Wiring problem?
- 48 the right bike?
- Moving over,,,donated sportster
- 03 sportster wont start rebuilt carb has spark has good gas
- Anyone change bars on a 2014 48 yet? (Stock braided line)
- Front Spoiler
- Great Customer Service from Energy One
- Handlebar question...
- Can i mount my iphone to handle bars?
- Tank and Fender Question
- Strange noises coming from my Sportster
- Bassani Prostreet mounting plate
- First real ride on my '76
- Dead - no power
- Help on bobber build
- Dropped exhaust flange nut, can't find... dangerous?
- Secret gun compartment in the air box
- Bettie got her new bars last night
- Another exhaust question
- Sportster to bobber?
- unbend this brake pedal?
- Ignition Switch problums ?
- Sportster rider completed Iron Butt 100CCC
- Greetings and Questions
- Dealer dropped my bike
- 1200 Upgrade Dyno'd at last
- Upgrade to Mikuni 42 - who done it?
- 1988 sportster 883 dreaded click starter not working please help!
- 180 tire
- New bike, old problems
- Help just bought 03 100th Anniversary Sportster 1200
- The 88" Sportster is almost finished!
- Are 2" Baffles Too Much for a 1200?
- eBay 1200 Kit?
- love dk customs
- Help identifying a bike
- I just love my wife ... soooooo much ...
- Progressive monotube kit on a 09' Low
- Oil Leak Help
- 7 Sporster Electrical Question
- New 48 - First gear shifting noise
- auto tuner
- Sportster models ?
- Vance and Hines short shots db? 09iron
- Stolen Iron
- What sdo you guys think about this bag?
- Was going to Daytona today but -P0108 said no.
- Wheel fitment question on 13 Super Low
- minor tech question...
- Dr Jekyll and Mr Hyde Exhausts
- Chirping
- 750 Street vs 883 which will be faster
- small spot of gas ?
- Sledhead bobbers
- Handlebar Risers for 2013 883N
- Time for the Hammer 1250 Power !
- HELP!!! Indicators Issue!
- Overdrive sprockets?
- 883 seat
- need shocks!!!
- Extended throttle and clutch cable installation
- Exhaust
- And now, more Craigslist fun!!
- 2009 XL1200N HORRIBLE suspension
- HELP!!! No running lights 08 Nightster
- Nightster Fender Removal
- Diy
- '05 Sportster XL1200C Saddlebags
- 10" Licks Z Bar
- New Sportster - Oil Recommendations
- Newb Here
- Anybody running N2 or N4 Cams
- Iron 883: What do I need to know
- Throttle/Idle on 06 sportster
- New Vance & Hines running too hot, please help
- Apparently no one makes a 16"x5" or 16"x5.5" 25mm for sportster
- 48 Handle bars
- Found missing part months after repair from Dealership
- Lower shock bolt (Forty Eight)
- Can't get out of first gear.
- Good Website for OEM or Good Aftermarket Parts?
- Trying To figure out Carb bogging problem
- Tacho
- Vance & Hines Staggered Drual Straight Shots
- Creaking from rear shocks
- 1200T Peg Position
- 1999 883 doesn't start
- XiED were installed but have a question?
- Nothing Major, but it's coming together
- oil dumping?
- Helmet back frim air brusher
- How to test ignition module on 2003 Sporty?
- Crap! What the heck happened?
- High Speed
- Chrome help
- 07 NIghtster is almost finished!
- Battery Overcharging?
- No Packing in Sportster Mufflers??
- 2009 Sportster PCV
- Shock SHOCK!
- New touring Sporty announced!
- 2014 rear caliper retrofit ?
- fuelpak and new bike question
- New to this need some help
- dk customs outlaw 587 or se air cleaner? ?
- 2013 sportster torque specs
- Question about changing handlebars
- Replacing my air filter
- Thinking of buying a 1200 Custom
- Help me decide - New air intake
- will this tire fit?
- Power Commander V help...
- my rubber mount lane splitter
- How to drop forks (installing drag bar) without a jack?
- New 2014 1/2 1200 Sporty
- Speedometer went out after new ignitions switch
- Question on power loss/hiccup?
- 19x3" front wheel with 120/70/19 tire on 08 Sporty?
- New Superlow 1200T now on HD website
- Screaming Eagle vs Rush Experiences
- Saturday is the day
- Rush Exhaust Fitment Question
- 48 Drag bars installed
- EFI remap or fuel-pak/other fuel system
- Andrews N 3 cam
- Grip change question
- 16x5.5 Black Rim (not laced)
- Left blinker acting up . . .
- Could it be my coil?
- Primary chatter??? Not clutch/chain adjustment
- Iron 883 Wheel conversion
- Air Cleaner oil
- Anyone good with WinPV and fuel maps?
- houston riders!
- Sportster 48 derby cover bolts
- spark plugs and wires
- Considering a Tuner - Thoughts?
- Oil blowing out top of oil tank
- Troubling report from Blackstone
