View Full Version : Sportster Models
- HELP! 2005 XL1200C Chokes out and dies
- Rush Full Exhaust?
- More complicated than I thought...
- got the parts
- Belt to chain on an 06 883/1200.
- Lower Rear Brake Pedal on 48?
- my hot rod exhaust
- PCV help please
- Slip-on's - any downside?
- How to cut down "C" risers and relocate speedo for nothing
- Longer brake lever to replace stock
- Why do Sportsters sit so high?
- rear suspension upgrade
- Key Relocation from DK
- Help super stupid electrical ? 1999 sporty
- For christ sake....
- Primary chain inspection, adjustmene on newer XL883X models.
- Changed Oil --Amsoil
- Bolt Size
- Almost finished with it...Let Me know what you guys think
- Hard Takeoff from Stop
- Horn just quit?
- How Much wider...
- Need help asap!!!!! Please!
- Has Anyone Tried This?
- My Sportster Experiance So Far 3000 Miles
- Rear blinker problem!!!! 2003 1200
- my sportster updated
- Thanks for
- eliminate fender brake light
- Any 1200C Owners Here?
- Looking for a Kien Carb to fit '64 XLCH
- Drag bars on my 48
- Charging system troubles
- Adding another to the stable
- Just installed the 3.3 on my forty eight
- My DIY headlight mount....
- Does anyone what kind of harley this is?
- Sportster has slip ons, is carb re-jetted?
- front end chirp/squeak
- LED Bulb Recommendation
- socket size?
- Saddle bags on a Nightster
- Switching tires
- How About a Mid-Sized Softail?
- Chain conversion
- Need Help with 87 Sportster 883
- Willville Motorcycle Camp on the BRP
- no charge
- So how do I know if I need mroe backpressure?
- home made sissy bar and side plates ?
- fake harley
- Speedo condensation
- Is my ride considered high mileage?
- Blue speedometer?!?
- Tri-bar LED tail light
- mid controls for 04 and up
- Nightster headlight
- Solo Seat vs. Spring Seat
- sportster info
- Motor rebuild questions
- HD Mechanic in Los Angeles
- Sporty tank we just finished powdercoating
- Apes on a 48 help
- Please help, clutch issues.
- Forward controls
- Flippin' Shocks
- Cripes, it finally happened
- Converting Nightster front end to a Forty Eight?
- Road Tools - What To Carry?
- Help with approximate value, 05 sporty 883c/1250
- Convert a two up seat to a solo?
- Sportster Down
- Custom Solo Seat, Pan, and Springs. Would you?
- noise on 07 XL883L
- 1975 iron head ??? what do i have???
- Cleaning gear advice for new Nightster owner
- gas cap ?
- 1975 Sportster 1000 Ironhead info
- Check Engine & Battery lamp on after start.
- Low fuel light... how much longer to go?
- NEW Crime Scene Choppers Headlight Bracket!
- Hello to All
- Basket case 75 Sporty Compensator removal
- 883 Iron and HD Mini Apes
- Black Box for Your Bike
- New to HD, new to the forums...
- Ethanol?
- washing a denim paint job
- Rocker Cover Bolts - Could be loose ?
- Need to get rid of my risers 0n 03 883
- Santee Apes??
- just designed a new tank for nightster
- D&D bobcat or V&H comp Series
- Broke Spring In Transmission
- What torque cones do you recommend?
- Kickstand fell off
- High air flow ham can air cleaner
- Oil pressure prob. '04 sportster 883c
- Identify this S&S Teardrop Knock off?
- Stage 1 & Heavy Breather ReMap
- Got me a led sled!!!!
- xr 1200's
- low speed wobble on right turn acceleration ?
- mixed Mag wheels ? new forks ?
- Accent Light Installation
- 2003 100th Annversary Sportster 1200?
- Is a sprocket cover needed?
- what do i have?
- 96 1200C build thread as progress is made
- How much is the 1998 Sportster worth?
- kickstand return spring-1988 883 Sportser
- Back from 9 day trip - some photo's...
- '08 Roadster fuel pump sounds nasty!
- Totally Messed Up Gas Leaking
- so what are you guys using for storage on the go?
- ken'z xx2 bike
- Hi
- Rear wheel seems to turn too hard.
- Chrome ?
- NASH exhaust made by SIKPIPES. PICS!!!!!
- No rear turn signals?
- speedometer peculiarity
- 2000 sportster
- Mustang or C&C solo seat?
- La Rosa fork bag
- 16" rally wheel to the 21" wire
- DK coil key relo
- Paint Theme
- new headlight with clear lens and HID lights
- XL1200R backfires in higher gears
- Rusty ol 86
- 2008 versus 2012 Sportster 1200C - worth the upgrade
- New hd owner
- Homade Brass Breather Kit
- Stator Bad?
- Finally got my Iron!
- plugs look ok?
- finally done with sporty (yeah right)
- 883/1200 conv
- X14iED's on stock 1200
- Any pics / info on big guys on 48s
- 883 to 1200 conversion question
- Need adapter for Speedo
- Loctite or Anti-Sieze
- Short shots with no intake or remap
- how does ur sportster handle on fwy?
- Oil Leak from valve cover
- help me again with my Sportster
- First Service - what do they do?
- How long from build date to delivery date?
- Serious Oil leak ....out of vent??
- My faith is restored...
- Bike Selling Experiance
- Lets talk XL883 oil temps.
- New Look. pics.
- carb
- Possible bad stator, looking for verification
- Boost my 883C
- cleaning aluminum hubs question
- Indicator Lamps - T10 type??
- Corvette
- New Scallop & Striping Detailing on my 48 tank
- Which Jets for best setup with V&H short shots
- 92 Speedo & tach in a 95?
- Idle problems after changing grips
- Pictures washington state ride
- Windshield experiment
- XL1200L Seating Position Issue
- Primary Chain Adjust
- Apes: Not That Comfy
- carburetor mounting bracket
- First gear grinding... any ideas?
- New stuff on bike; awesome ride
- Looking for 2008 1200 XLC diagnostic codes
- Setting off Japanese alarms
- intermittent starting head scratcher...
- 21 Inch Front Wheel on 48?
- Le Pera bare bones on a 48?
- new guy here
- Front Signal Comes On By Itself
- NoMar tire changer
- 95 Sportster speedo harness
- Leaky rocker box gaskets
- Electrical prob?
- My headlight SUCKS!!!!
- Air Cleaner Advice
- Messed up
- Carb tuning
- front brake fluid levels
- Remove lower belt guard?
- Drag Specialties Seat
- guardian bell
- Pipe wrap.
- 12" ape owners, is extra cable&wire required for installation?
- Might be needing to sell my bike....I wonder...
- yup, another LED headlight thread
- 81' Sportster -- No Running Tail Light / No Front Brake / HELP!
- Brake Pedal Pad Extension (pic)
- Good buy, what do you think?
- Battery and Engine Light staying on after replacing battery
- Beating an old topic to death
- Primary Oil?????
- Carby Jet
- XR1200 with a few mods
- Joker A/C Rain Sleeve ?
- Question on frames?
- Now I Am Breather Kit Lost Need Help
- Stock air filter backplate too restrictive??
- Screamin Eagles -- What size baffles?
- 2001 Sportster XL1200
- installing pipes.
- Mid Controls for 01 883 Custom
- New Horn
- photoshopped sportster
- Got me a new toy!!
- tail light
- What are the difference btwn the '08 and the '11 1200c
- Broke the spring pin for the kickstand
- Stock exhaust options...
- Cycle Shack MXL-130-T Slip Ons
- Need about 2" pull back on the Iron 883...how to do this?
- Because I love you guys - pic
- pipes for a 06....
- Drive Belt Questions
- synth oil change rule of thumb?
- My AWESOME monday!!!!!!
- Wiring Extension & Cables Problem
- How to clean fork gators
- Mustang Wide Solo review for 2012 Iron 883
- Carb Re Jet/Intake
- Broken drive belt
- Help needed with Iron 883 2012
- Why so loud.
- road 6 custom bars on the way
- clutch problem?
- Upswept Fishtails on a 48??
- oil temperature dipstick question
- Spring for front?
- Where does this hose go?
- Will this work?!?
- spedo help
- Ideas for 48 headlight looks. pics please
- Thunderheader Modification
- My bike mods I learned here
- Progressive models...
- 2002 Needed tires
- tires
- Rear brake pedel not illuminating brake light
- 2nd bike?
