View Full Version : Sportster Models
- Part number needed!!
- Attempted theft
- Part number Question Harley Combo Digital Speedo
- 03 Sporty Solo Seat
- Mustang vintage solo seat
- Vibration in the left mirror
- 2004-2007 Front Wheel Spacers
- My 2017 Iron 883
- drag pipe questions
- bar opinion
- Shutting off security...
- replacing front tire on 07 nightster
- Drag bar/Speedo problems
- Vance & Hines Short Shot nameplate?
- randy hd
- Chrome air cleaner
- Help needed. Residual glue removal
- Anybody riding Biltwell keystone xl
- How to change your Idle Settings with Vance & Hines Fuelpak FP3
- NEW to Me 2012 Custom
- 1997 883 Hugger
- Hesitation/stalling issues on low throttle
- Need battery
- Bought used sporty, not run for a while
- Whats the best product to clean salty bike?
- New Iron - my 3rd HD.
- Passenger opinion/opinion's
- Bobber bars
- Need opioions
- Exhaust safety question?
- lighting/electrical question - rear
- Craftsman pro or harbor freight jack
- Sportster Pipes
- Sportster upgrades
- Draining all the oil from the motor
- 15 controls on a 16?
- fix for oil out breather bolts?
- LED headlamp options for 2017 48 XL1200X
- Reliability of "Stage 4" Sporties
- Video/Sound Clip of $92 Slip Ons
- Classic Sportster Becomes Flat Tracker Restomod
- Speedometer Extension/Lollipop
- Seat for 3000+ km on HD Forty Eight
- 2017 48 or 2013 72
- 883 mid controls stick way out!
- How do you ride in the cold?
- Sportster on j&s jack
- 2014 883 - Powdercoat issue / Paint with wrinkle black?
- Sportster 48 Stage 1 upgrade
- Sportster 1200 Cams
- Broken Drive Belt
- Motogadget M-Switches
- Memphis Shades Gauntlet with Trigger Lock Mounting Kit
- Heavy vibration
- High mounted oil drain hose?
- rear wheel problem
- Spark plugs
- Shuddering over 70
- All Christmas parts installed!
- Rear signal removel question
- Installed DK Custom floorboards
- What is this plastic connector thing?
- Doubled up docking hardware ?uble
- sportster seventy two rear wheel issue
- Bought a Sporty!
- Ugly factory hardware
- can i just install slip on muffler to my sportster 48 2017?
- Added 4' risers
- Efi tank on my carbed sporty?
- Frame compatibility
- What sort of long term issues/problems should I expect?
- S&S woes continue...
- Bulb swap?
- Parts List for Primary Sprocket Change - 883 to 1200
- Custom riser conv. using Capttawes method
- 883 cylinder heads -2003
- Gasoline smell coming from EBS??
- 88 Sportster 1200 won't start
- Used sporty help
- Happy New Year, start it right...
- Hammer 1275 kit
- sportster front end swap
- Advice on a NEW leftover 2016 (48)
- Wiring diagram for switch delete
- Hey guys I'm new here and I'm in need of some help
- Fast idle sitch
- Christmas Hammer 1275
- Aftermarket 21 in front wheel for Iron 883
- Iron 2017 fairing
- 2006 xl1200c
- FP3 Map Help for Remus adjustable Exhaust
- HD XL1200X Forty Eight & Brembo brake floating rotors doubt
- Front fork springs installed...
- Anyone out there happy with an 883
- Shortshots with mid controls, 1996 sportster
- Superlow tank lift Problem.
- Sportster clutch cable bungle
- bike crash and aftermarket parts
- A Harley Tracker is...
- Floorboard kit
- What new riding toys did you get this year?
- No tail light 2015 XL1200C
- Touring model hard saddlebags install
- 01 sporty pinging : update
- Christmas present leaking fuel
- Merry Christmas
- Anyone get one of these in the mail ?
- Where did this rear fender come from?
- 2012 Sportster will not start
- Mirrors don't stop moving
- HELP ! Need input on rear turn signal relocation set up
- Plug needed to stop oil leak
- Opinons on beginner bike
- Power Vision re-map help
- Help with sportster knock/tick
- New cables needed to switch to apes?
- New Vance & Hines slip-on mufflers for 883 Iron
- XLST3 from Shaw Speed & Custom
- Need stopping power
- replaced coil ran for two days coil bad again,any ideas
- 2013 vs 2014 clutch levers
- Inspection Port Bolts
- I'm fairly certain that this is my fault, but
- 97 xl1200 gauges
- 2004 front wheel - other year fitment?
- Exhaust leak and performance?
- Yes. Another electrical mystery.
- 2006 Sportster Speedo bracket/bezel...
- 1200 r
- Tracking an oil leak
- In too deep
- What size tire will fit on my bike?
- NEED A HARLEY MECHANIC, Tampa, Wesley chapel
- Paint color match
- Where are you folks routing your pig tail?
- 1999 883 Becomes a Scrambler
- Got a new riding buddy.
- Speedo removal, Tampa, Sporster
- How to diagnosis a TPS.
- Reset bikes computer.
- 1995 Sportster XL1200 lower mount bolt sizes
- Motogadget stuff
- Iron head Over flow
- OEM Fuel filter
- DK customs floorboards
- Hello
- Shudder over 70
- Swingarm Bag
- Sportster sport forks
- Weird Substance 2012 iron 883
- Loudest Slip-ons?
- My iron 883N 2011 *Black Guy*
- Clutch and brake clamp torque
- 2003 Sportster 1200 anniversary
- Threaded throttle cable issue
- 06 Wheels on an 09
- Vibration
- Electrical riddle....08 sportster xl883l no power to Speedo
- Need some comfy handlebars for my 2017 Iron 883
- Star wheel under throttle housing?
- The throttle on the bars is about an 1" off
- '04-up Speedo question
- 2014 48 has charging problems
- Anyone Ride a Vintage Sportster
- LED bulbs don't fit
- Lessons Learned After Forward Controls Install
- Protecting custom paint from 2up seat
- Adventure Style Roadster
- Willie & Max By Dowco Swingarm Bag
- Alternate source for factory Harley parts besides dealer???
- Rear Fender Interchange
- 1983 roadster shuts off while driving
- 10” Z bar, stock cables
- Extra part while installing barnet clutch
- The Hammer Express II
- HD Auxliliary turn signal conversion kit
- Any Ventura County, CA Riders?
- Thunder Torque Inserts on Street Cannons
- 1988 Sportster 1200 Wiring Diagram?
- Rocker cover leaking
- Battery strap bolt fell out, where do I get a replacement?
- Turn Signals Not Working Right
- Runs great cold then bogs after it warms up
- Easiest Way
- “Big Red” motorcycle jack
- Exhaust Question
- 17 Iron Bag Ideas
- How much longer will the Sporty be a Sporty?
- Nightster transformation
- Issues with my front rim
- Help me figure out what’s wrong please!!!!!
- Sportster 883 burning oil fast
- Fork Tool Bag Question
- Superlow 883
- Someone near dallas Texas looking for good dyno tune
- 2014 1200 custom v sportster
- Is this Forward Control Set Complete?
- 73 ironhead questions
- Wisamic front light
- sportster rear shocks help please
- HELP...handlebar wobble
- Cafe seat on your 883 Iron
- Need help, what is the root cause for battery discharge?
- 1997 Sportster 1200 forward control slop
- Looking at a 1995?
- Craigslist 883
- Dual disc to single disc "Help"
- Iron footpegs on a SuperLow
- Roadster wheels?
- 2003 sportster footpeg c clips loose
- FXRT (touring) Style fairing for Sporster 1200 Custom
- Uneven belt wear
- Battery question
- 97 xl1200c..finished
- NEEDED: 07+ Sportster w/4.5 gallon tank near Hollister/San Jose Ca
- Sportster - Screamin' Eagle Stage 1 Question
- Nightster rear hub
- Fluid question
- Abs
- Sportster loses power and dies
- Understanding bike breathing?
- 2013 Iron 883 - Gas Light Issue
- 2008 1200 Anniversary Edition
- V&H Shortshot bracket fail and customer service
- new headlight bulb fitment?
- Engine trouble after installing Slip Ons
- Fuel pump not priming
- Luggage Rack to fit existing sissy bar?
- Battery Fuse Failure
- Need Your Sportsters!
- 2008 nightster dying
- Driving Strategies
- 2016 Iron 883 PLEASE HELP!
- No lights
- Headlight
- V&H and J&P filing for chapter 11 bankruptcy
- oil Cap leaking
- '05 fuel issue?
- Any Ventura County Sportster Riders?
- Turned 10,000 today
- Just bought my 17 Iron - Lovin' it!
- Transmission Question
- 1982 Anniversary Sportster
- 48 won’t start with new tank
- What year is this sporty?
- Internal wiring - how tall can I go?
- Used the wrong gear oil (Is that okay?)
- New wife bike
- What do the hollow screws in an air cleaner do?
- Happy Thanks Giving
