View Full Version : Sportster Models
- Thinking about a Sporty
- mini floor boards?
- Only Norwegian here ?
- Posts
- a question about exhaust wrap
- Forward Controls Drag Specialities
- Leatherneck - Sporty 48 Video
- crank position sensor
- 68 xlch
- 04-up Sportster oil cooler. FEEDBACK?
- cold weather riding gear
- mirrors
- Ready to Ride...
- Clearcoat or Aluminum
- Old guy on a 48
- Weekend Project
- Removing Tappets to paint engine
- New Shift Light
- Solo seat mounting kit recommendations
- Question on Screaming Eagle II
- pics of 883 custom w/ new paint and heavy breather
- Won't start after removing primary cover
- where do you guys get stuff chrome plated??
- Banjo Fitting size
- Bassani Sweepers or V&H short shots?
- New guy on board, with fender Question.
- 09 Sportster 1200C rear wheel question
- decided not to remap, ordered x14ied
- Powder coating wheels do's and dont's
- Newbie
- Large Headlight
- 883 SuperLow vs 883 L ?
- Red spokes
- Strut help Please...
- Will 2into1 exhaust work on my ironhead kicker?
- 08' Nightster ECU relocate?
- 2006 Front Wheel Specs
- 2003 Sportster (S)
- Rocker cover oil leak - Help needed!!!
- Exhaust Performance
- 100ci engine
- just joined from washington state....
- Replacing that giant spring solo saddle with a non HD setup (help plz)
- bullet style trim rings dont fit any idea ?
- XL1200C GPS Question
- cleaning piston heads
- X14ied instead of remap?
- Bearing tool remover and installer
- Nightster Bars
- Charging problem
- forks
- Nightster rims
- tired of the airbox oil leak...
- Best way to gear my 05 xl1200r lower? Need more out of the hole.
- photshop help
- Lifting Nightster on Jack?
- 2010 sportster hub / bearing size
- Style Question
- Stator or voltage regulator PO-562
- avons
- Question about wheels...
- nightster wont start
- Pipes/intake questions, noobie here
- I need some mad Photoshop skillz, please.
- `00 XL Main Shaft Pulley
- Just dreaming...
- Question about 8" Road 6 Customs Handlebar
- Zippers Thundermax
- 2003 Sportster 1200 backfire sputter and not firing
- Quad Ring, How to hold in place - Primary cover, Clutch Inspection Cover
- Fenderless lighting options
- Nostalgic Grips
- 16" apes
- Cafe Racer Compliment.
- fuel remap with new intake
- jiffy spring fixed thanks for tips
- New pipes, opinion? (pic)
- cheap bike lift
- New To The Sportster
- raking
- 04 exhaust on well not an 04
- whitewalls on the 48
- suggestions blacked-out 2 into 1 exhaust for the iron
- Local police.
- How to Install Clip Ons on 2010 Iron
- Iron vs. VStar 1300
- Leaking primary fluid...
- V&H short shots w/ header wrap
- Oil hose leaks on '86 Sporty
- Help Tank won't drain :(
- Zap straps on handlebars
- My Sporty has arrived!
- Anyone seen these yet? 1250 cylinders
- Almost broke into the 11's tonight
- Deluxe Day Tripper
- can you swap a set of 09 front fork lowers out for a 2000 fork lower
- Knife Levers
- check out this site I found!
- Jackets
- '96 Sportster 1200
- Updated pic's
- Installed Burly 16" apes - pics
- Has anyone put a Kenda Challenger 90/100 21'' tire on there bike
- Need answer quick guys!!!
- Ignition Key Problem 2009 Nightster
- X14ieD + ECM stage1 remap?
- Sportster with 23" front wheel
- to paint or not to paint
- seat reccomendations
- Tough Clutch!
- Help with electrical problem
- Will a ME880 120/70/21 fit this rim ?
- So, the X14ieD...
- V twin charging system v original part
- Changes to the Iron for 2011?
- Maintenance
- Recommend Some Mods for My 48
- Frustrated
- Changes to my 48-What do you think?
- Sportster LED Oil Level/Temp Gauge
- Bike dropped
- new to HD
- wheel width question
- Any Place to Get Black Heatshields Except the Dealer?
- Difference 86-91 midcontrols??
- Lowering an XLH Hugger in the rear? Licks? Others?
- 21" front wheel questions
- Clutch question
- First (1000 mile) service question
- Saddle Bag Brackets
- RSD Clip Ons
- Gap after installing ISO grips
- hiccup
- New pics of pipes and custom stripeing
- Dyno test
- Licks Solo Bag Missing Position C?
- Bar-end mirrors installation? ? ?
- Lifting the tank?
- Crossover Fuel line
- Sportster is entry level budget bike
- Flush Mount gas caps on sportsters 04- 2011
- 2011 Sportster Forty-Eight
- Power Commander and MPG
- On the hunt for a 1200 Low
- 1978 XLCH photos
- 2011 Iron883 - Speedometer Backlight Won't Turn Off
- spring fell off jiffy stand cant get it back on
- HID Head Light kit
- There's just something about a H.D. V-Twin
- ECM relocation?
- question needs an answer
- 48 front hub
- sporty front end swap for XR1200 parts
- New Grips for my Iron
- Santa Monica Mountains
- Mustand Cyclone Seat System?
- 50th Ann Sporty
- What does Harley have against RPMs???
- Cable Upgrade?
- Couple questions about my '99 Sportster Sport
- Help!! Need heads for 2005 883
- Nightster speedo bulb?
- Forward controls
- Will these copper pegs fit?
- Screaming Eagle or Joker Machine air cleaner??
- made some new pipes today check em out
- Got a sporty
- advice on shocks wanted
- Anybody install a Burly Slammer Kit on a 48?
- 21" rear wheel info needed
- Power Commander For Iron
- Battery tender leads?
- Sporty front end change
- 23k harley
- This is why I hate Minnesota !!!
- Help! Removing and Reinstalling 2008 sporty engine
- Front fender, what years will fit a '99?
- Is it really 3.3?
- Handlebar Porn!!!
- front fender??????
- 41MM front end on a 1995 Sprotster
- Nova Scotia
- Went for my 1st long ride
- 48 upper belt guard/shock bolt
- 883 vs. 1200
- Removing Primary and Gear Cocer to paint the engine
- Battery cover
- My newest winter project
- My nightster coil cover
- Nightster Wheels
- motor mounts and vibration
- 16" or 18" rear wheel
- Whitewalls on Iron
- 48 Passenger Pillion question.
- 1991 883 sportster trouble
- Newest additions to my 1200R
- Installed Street Glide air shocks on 1200 Custom
- Installed Slip-Ons now not getting enough fuel
- Just had the Sporty in for Crash Bar fitment...
- Weak/Intermiitent Spark to rear cylindeer
- GP shift on a street Sporty.
- Does Avon Venom X 160/80B16 fit the rear of an Iron?
- St. Louis, Mo.
- Help with my 48!?
- Ft. Jackson?
- I need a louder horn
- Anybody have a spare headlight eyebrow?
- Need a Picture of....
- Time for storage
- removing the rear fender on an iron
- rear brake caliper
- "Thank you" to the Veterans on this forum
- Where to get new clutch basket?
- Bent turn signal
- 48 Question
- just swapped my (tssm) out for a (tsm )
- 98 Screamin Eagle Sport
- iron/nightster Wheel Swap
- Don's Cycle Ware Solo Bag (pics/install)
- ft.hood
- WTF?...tire valve issue
- forward to mid mounted controls for xl1200c
- Kick start kits
- Throttle and Idle cable Adjustment?
- FOR SALE: Black Buckshot Belt Guard
- Mixing oil brands
- Ape Hangers and stock location turn signals? Issue?
- A reminder !! how many have broken a front brake light switch.
- Flat Black Paint
- C&C seats
- 2011 xl custom
- Anyone have 2 sportys in there garage..
- White walls
- nightster mini apes on custom - price installed
- Sporty gonna be gettin new paint here soon
- xlh1200 poor starting
- Size limits on Sportster Models??
- Help!!!... Bought a Sportster.. What is it?
- Headlight question
- S.E. Pistons
- Electric starter for 61 sportster.
- How To Make A Flag Holder
- Speedometer issue ..
- New 2009 XR1200
- New Springer seat on the 48
- Made another set of pipes this weekend
- My new lover...
- New Pics of MY Nightster.
- Recent XL purchase
- Exhaust wrap
