View Full Version : Sportster Models
- Switching to synthetic next oil change, question about filter.
- V and H fuel pac for So Cal
- 1200C Turn signal issue
- Need help
- Mid Control Swap...Lesser of Two Evils?
- 1989 sportster rear pipe?
- Maximus's 2012 Black Denim 1200 Nightster Progression
- New member
- Observations of a New Rider (final installment)
- Backfiring problem
- XL 1200 Custom
- Polishing rear shock bolts
- Question about progressive 412 cruise shocks..
- Lifting a Hugger?
- Allen Head Socket Size - 2009 Iron
- Mini apes vs reach handlebars
- Trying to Change Primary and all went to hell...
- My Riding Day Was . . .
- Bad ground at Speedo - '10 Nightster
- Maximum time 'on clutch'
- After 20 years riding Sportsters comfort is really becoming an issue.
- '16 48 bar question (sorry)
- Sporster forward or mid controls
- 2016 Sportster 1200 Custom suspension
- Any 72 owners running lower handlebars
- Power pulsing when cold below 3000RPM
- two brother comp-s exhuast question?
- Not all 'indys' are created equal... A short rant.
- Just ordered the PowerVision, removing PC-V piggyback.
- 2016 48 sputters on take offs after fuel fill ups
- Fly Screen
- 2005 xl1200 idle mixture screw
- Chizeled Handlebars on 2014 Sporster 48 XL1200X
- Brake upgrade question: Another "What MC with Vrod/Touring Brembo Swap"
- The Harley Davidson "5"
- Problem after handlebar install
- 1974 Ironhead XLCH Electrical Issues??
- Just bought a 1997 XL1200 Sport...
- Finally posting pictures of my 48 build....
- Before and after
- sportster gearing?
- Wife's 2014 Sportster 1200 Project
- Clutch compression tool
- XLCR Starter button
- scorcher v commander11
- Sportster value??
- Sissy Bars on Superlow 1200T
- Help removing voltage regulator with stripped screws
- Scorcher tires
- Point float or limiter?
- 77 Ironhead: Any problems?
- Plug wires for a 1200S
- replacing rocker box covers on a 1200 custom
- Can someone measure their forward controls brake rod???
- Please help identify these unplugged wires.
- Help me identify which wires these are?
- Whats been done to this bike?
- dyna tune prints on SE parts
- 2016 883...questions
- Sickboy516 w/question
- Memphis Shades Bathing for XL1200C, 2016?
- Sybill???
- Weird Sound After Oil Change - Video
- Mustang seat owners, does yours hold water?
- Wanting to buy...
- looking for 48 fairing...
- Need advice on installing engine guard on 16 Iron
- Showa Rear Air Shocks on 2008 Sportster XL1200C Documentation?
- TruWRAPZ turn signals installed/reviewed
- More vibration questions ?
- 2016 air filter cover on BS?
- Which rear shocks 09 1200 sportster
- Front brake fluid
- 05 1200 Started then shut off, dry plugs
- Mid Air Frame Deflectors?
- Installing tall boy bars on 2016 48
- Schaeffer oil
- Knocking and pulsing under load...motor or trans???
- Gasping Iron 883
- Short shots baffles and stage kits
- Need help
- 39mm forks droop unladen
- Possible flooded carb symptoms?
- Shifting or gear problems
- Need help!
- Anyone using HID or LED headlamp
- please help brake light and turn signal problems!!!
- Electrical issues
- Torque wrench
- 86 Sportster, whats this thing for?
- Sort vs. standard
- What I did to my 08 sport 1200c
- Need a little help here
- leaking tubes and life in general
- 2 questions 5" v 3" barrel springs, 15% v 25%
- Mustang Throwback Seat
- VSS signal
- Upgrades
- Hammer 1250 vs Nhrs 1250 heads up!!!
- 2016 48 Fairing options?
- Front Brake Master Cylinder Rebuild
- Whats up from south jersey
- Thoughts on Arlen Ness Big Sucker air cleaner kit
- Coil relocation w/o ignition relocation
- Cannot find neutral at idle, clutch is jacked up
- My new Sport
- 05 no blinkers and want smaller bars
- Any viewss on spark plugs and cables ?
- Exhaust for '03 and '04
- 1K on the Roadster. Ride report
- 07 DTC B1143 error code
- Foot peg scrapers
- Help with part number please!
- Fuel Moto Micro EFI tuner shows throttle at 100% when idling...?
- Rear break stuck..
- Quick trip to The Alps
- Big City Thunder Baffles for Short Shots?
- 08' xl1200c 19" wheel & tire
- What kind of wheels are these
- How many miles are on your factory clutch?
- 2016 Roadster info finally posting in dealer systems! : Wheel P/N
- MAP SENSOR part number 2014 iron
- clothes pin on the choak, what?
- Thunderstorm top end
- Switch housing with extra switches?
- Throttle got tighter overnight?
- Broken front turn signal mount: How to replace
- 2016 iron 883 getting bars but have a question.
- 2016 sportster 48 drag bar torque specs
- Local Motors
- 16 -> 14 Air Filter Compatibility
- Nightster right blinker not working
- upgrade suggestions/opinions
- Back in the Sporty Game
- Idle for a year > Best practice
- Integrated headlight with turn signals?
- Dakota Digital Speedo/tach Mcl-3204
- New to me bars
- sportster service manuals
- Getting V&H Shortshots on 2016 Iron 883, will K&N filter addition be enough?
- 5k service
- HOW-TO: Fork Slider or Fork Oil Seal Replacement
- 2005 Sportster Stage 2?
- exhuast NUTS
- New rider, first bike is a sportster 883
- anyone have the HD part number for the new 2016 Roadster or 48 Timer Cover?
- ID this tank?
- What bars will fit?
- Quick question about oil temp.
- Clutch cables?
- 2012 harley sportster Forty Eight XL1200x overflow gas tube
- fender chop help
- 94 1200 pinging when warm
- 2002 sportster rear turn signal issue
- Vied install question (ground wire related)
- Maximum riser without changing any line ?
- Evolution diamond termintor or barnett scorpion or extra plate clutch pack?
- Recommend a comfortable 2 up seat
- Issues taking off brake rod...
- Anyone else have this problem? Rear brakes...
- My Sporty Low
- 2016 - 48 Turn signal Relo and Ignition Relo
- Front parking light water
- '03 Sportster XLH LePera seat pain
- Power cut off, HELP!
- Forty-Eight and Seventy-Two both Discontinued?
- Iron 883 2014 - ABS front Brake Pads
- Decent lift for the bike?
- 2014 harley 48 crack in engine casing
- Bike wont run when standing upright?
- New to riding
- Replacing header pipe gaskets
- Short service life of 883 Superlow tires ?
- Don't run to the Harley Dealer; clear Po562
- Is there a recommended or proper order to install stage 1?
- 1991 Exhaust Stud Torque Specifications
- 1200 custom speedometer trouble
- ROT Rally 2016
- New helmit
- cable inquiry
- primary oil
- Canbus?
- Speedometer/odometer question.
- Gas in oil 1994 XLH 1200
- Air filter; another DYI success story!
- Speedometer relocation
- What bolts for super e carb
- 2016 Sportster Iron 883 Battery Cover Fix
- Pulled the trigger!! Ohlins HD 145E Rear Shocks on the way!
- Are Burly Brand Cable Set good quality?
- Tank question
- Misinformation
- My new ride!
- In the process of loweribg my bike, and this happens
- G/F got a new 883 Iron. Need some opinions
- rear brake issue
- Suspension upgrade, well worth the $$$
- Headlight cap that covers bolt
- Hello from Peoria IL
- Back Pain
- High Idle?
- Sportster solo seat suggestions
- Starter Motor
- Transmission Oil Drip/Leak Help
- Did I just get robbed?!
- Sportsters at the Bonneville salt flats
- Smoke from the intake manifold!
- sorry beeen away ...2 road trips
- Sportster heat shield 1989
- Combination Digital Speedo/Analog Tacho #70900274
- How much gas at Low Fuel Light?
- How you guys fix this tangle ecu cover?
- Stock exhaust vs. SE II:How much difference?
- exhaust drone
- Kirby's Ignition Switch Drama and Project
- DK question
- How makes the best cable kits?
- NOT good vibrations
- Switch Placement
- Chopped rear fender
- Brake Pads - Which and Where
- Rear Wheel/Tire Clearance on Right Side w/Chopped Fender
- 1989 sportster 883/1200
- Biltwell Whiskey Throttle
- 05 Sportster Electrical Problems
- Viking Lamellar Hard Bags installed
- Not leaving for any forum
- Questions for the Veteran Dudes....
- Throttle boss with apes?
- 21" Front Wheel, Sportster Low model
- 2004 Sportster 1200 leaking from Base Gasket
- Height question
- Roadsters
- Help locating where this part goes
- Leaving for the Dyna forum
- 8" mini apes extending wires
- Bluetooth Speaker on Iron 884 with V&H Slash Cut slip Ons
- Changing filter and not oil question...
- Info on a motor plz??
- Problems with shifting into first
- Has anyone put 12" handlebars on a Sportster 72
- Handlebar Electrical Issue
- max stock narrow glide wheel width?
- Need a new cover
- Just Some New Rider Observations
- Caliper Relocation for Larger Rotor
- 16.5 Roadster - first 150 mile ride
- Have a safe Memorial Day
- Clutch Slipping After Primary Oil Change
- Sportster rides again
