View Full Version : Sportster Models
- Main jet replacement help
- Fall Away
- Mid vs Forward Controls
- Turn signal bar?
- Cut speedometer cable on 97', can I get a new plug?
- Almost was able to bring my Sporty home today...
- my pics
- Next set of mods finished
- Already jetted?
- RevTach DFO generation 3.5 part II & A/C
- Raised tank, possible lines chaffin under tank?
- Showa Air shocks
- Oil consumption for new 48 - how much is normal?
- Sunday Ride
- what to expect?
- Air Filter......
- nightster forks
- Tell me about Iron 883
- Delmarva Bike Week
- Got a Zumo 550 for the red mistress (pics of mount)
- Swingarm lenght, pulley distance......
- Pics: My first poker run.
- Pics of the bike
- Issues with the Nightster
- Fairing lowers on a Sportster engine guard?
- Frisco Bars, Biltwell, for 2007 Nightster - Help with cable lengths
- shocks
- Newbee...oil change
- suicide clutch/jockey shift. w/pics
- Air Cleaner Upgrade on a 2010 "48" xl1200x
- Any suggestions on a cheap good looking sissy bar or luggage rack???
- New tank and headlight
- 2006 1200XL C with carb farts
- changing from foward to mid controls
- Flipped My Bars Mega Novice 2 1/2 Hours ^.^
- My Sled
- Is this a joke?
- 77 Ironhead Oil Lines
- Air filter cover?
- Intake manifold oily build up
- Reduced Reach brake handle
- have you relocated your rear blinkers to the rear axle?
- Starting it for the first time EVER!
- Hey all you handlebar inverters...
- '04+ Sporty Owners in Houston, Tx
- Shorted ignition timing modual?
- Radiantz Brake Strobe
- well you asked and her they are pics of my moded. nightster
- school me on 97' 883 Hugger also help me cutomize with the right parts/links
- 48 Rider Pegs
- We did it to the grand caņon
- Pics: Chopped Fender 2.0
- Mini Floorboards with forward controls?
- anyone lowered their iron?
- Wanting to put on mini apes on 2004 XL Custom
- 2007 1200 Custom sounds Like Crap
- What is the purpose of the clutch lever electric switch??
- Road 6 Customs
- Seat trade?
- Sportster Valvetrain rattle
- Finally relocated my rear turns and mounted my bags...
- nighty 08 brake lights
- Shock adjustments?
- Fork Damper Tube Bolt - Hex Wrench Size
- Best way to make clutch lever lighter
- Removing cover off exhaust?
- Sealing spoked rims to run tubeless tire?
- '97 xl 1200
- street racing
- My 07' Nightster
- Looking to get new Handle Bars??
- CHOPPED clutch cable---
- how do i clear the diag codes
- portable bike enclosure
- Hairbrain idea - sporty saddlebags
- RevTech DFO generation 3.5
- Proved the Sportster is not a girls bike
- 2003 883 shot gun blast out the exhaust
- Brake line measurement
- Dyno for my 48--I'm pleased!
- Yes, finally got it finished (Iron)
- need advise...2007 xl1200c for 5k
- dropped my bike 2day
- bent my handlebars , how too id them
- Warm up problem
- Calling all Nighster owners with Drag Bars!
- New To Sporster Section
- Clutch Inspection Cover
- Confusion has set in...
- Warning newbie here, sportster 883 to 1200 conversion
- Spark plug question from a non-gear head...
- installed LED.. pics
- Tried to order dakota digital for 2011 48
- Mini Ape Bars
- Idle high-Choke Stuck?
- charging the battery
- How rare are those Olive Green Nightsters?
- What's the song in the new Harley commercial?
- 1980 sportster generator problems ?
- Demon Cycles....
- Drag Bars... Where to buy & What to get
- New to me 97 883 hugger, I might have lost money..
- 06' sportster 1200 xlc prim. chain inspec. cover leaking
- To paint the engine or not? Hmm...
- Kids are back in school....time for a road trip!
- Speedo Relocation - My take
- no tail light
- 01 883 Sputtering the Dieing
- Dropped the speedo down on teh T-Bars...
- Dent removal and paint referals in Wisconsin...or suggestions.
- Made a Points Cover for my Forty-Eight
- Speedo/tach product numbers codes
- Spewing fuel under hard braking?
- My Tank Lift, Coil Relocation, Engine Paint for @ $100
- Coil and ignition relocation help please
- Thanks Joebotics :)
- Iron - D&D Bobcat 2-1, etc.
- Looking for advice
- need seat that moves me back
- cap rattle
- Engine whine
- 07+ Parts Manual Pages
- Sweet, tank lift kits, only $125
- need part # for front master cylinder.
- WANTED: LED Taillight for Dark Customs!
- What degree drag bars?
- Finally pics to share of my bike...
- stage 1 download v. fuel pack v. tuner for 2007 EFI Sportster
- rattle canned the iron...twice
- Rear blinker hanging off
- 09 fxdl wheels on 05 xl
- 02 sporty no start
- sportster 48 upgrades
- Got to be kidding me... New Horn
- Removal of Front Fender on a Forty-Eight
- Must tuck wires if ignition coil?
- So it is a true Harley, after all. (it leaks)
- Custom cup holder
- 1987 XLH1100 Valve issues.
- Intake/crankcase breather question
- update ecu with slip on mufflers?
- Question about coil relocation
- oil leak
- 2005 XL1200 C relay next to fuses, Have pic's Opinions?
- Help me understand: do longer shocks increase ground clearance?
- Which one?? 48 or Nightster?
- battery and engine lights on???
- 48 seat on a 09 iron??
- Drag Bars
- engine dying at the traffic light ?
- Baffles
- first service now or next year
- Installing a Sidemount Plate holder
- 2 up for the first time
- "Lifeline" products are junk?
- hello
- New Slip Ons Causing Popping
- too many spare parts too much time on my hands
- Why did Harley recall Buckhorn handlebars on 99 Sportster Customs
- Touch up paint
- nice cover for screw on back of the sissy bar rest?
- Good place to buy trendy risers?
- Exhaust Flange Bolts on rear jug stripped
- Engine Upgrades
- Custom Air Cleaner
- Where can I find a tree housing??
- Crime Scene
- stage 2
- Handlebars Pics Request
- Gel pack inside of seat
- Pics: Choppy Chop Chop and stuff.
- Torx Plus Bits
- How to internally wire 8" West Coast T-Bars with pics!
- HELP!! With tank Lift and Coil Relocation!
- Bitwell Frisco
- Force Pro Series Dominator XL Forcewinder
- mid foot clutch/hand shifter/ window bars installed!
- adjustment
- My Take On License Plate Relocation for Nightster, after fender chop
- Are upside down mirrors really better?
- Sounds Great... a littie too loud
- Mid Glide steering issues
- Can't downshift (clutch problem)????
- Anyone from Chicagoland?
- Winter Upgrades - Need Input
- where the bike meets at in north jersey area this weekend?
- Apes or Drags? Whats better for longer reach?
- Installing drag bars, wires chaffing?
- Off Road Sporty??
- I finally have been getting pretty lucky!
- scraped the exhaust on my '10 Iron...
- Low speed rough running?
- rev limiter
- Mid Glide Conversion
- Great acceleration, Stumbles while cruising
- Need some input..
- 07 1200r turn signal conversion
- PIAA Extreme White H4 Bulb
- A quiet performance exhaust...who makes it??
- Licks solo bag instructions
- PICS Extensions installed
- newbie 1200 custom maintence questions
- Iron 883 w/ a 48 seat
- Leaking Fluid From Shifting Spline
- The Pegs on a 48 are Offset
- Usable Fuel with Tank Lift on 48
- My New 48...
- Any trouble to put a 150 on the rear of a '97?
- Wide White Wall tire availability?
- rear turn sig relocation
- Got My 10K Service Done
- positive battery cable problem
- Chrome cleaner
- Whats needed for Mini Apes on a Nighster???
- picked up a sportster today and need a little help.
- 2011 "48" Grip Question
- 883 iron - Removing Reflector trouble
- Ironhead Sprockets
- new to iron heads
- 2009 883L Passenger Pegs
- West Coast T-Bars on the 05 883L! Pics! I love these bars!
- Seat for 883L
- need gaskets information
- selling my fuelpak- is the sportster good for all soft tails too?
- primary fluid check?
- Making a seat pan for my iron
- Fuel Pack Help Needed
- Bike shuts off while riding!!!! WTF?
- lookin for nightster headlight ideas....
- Fulmer V2 Helmet
- pics of my dads 1200 with my lowrider
- FYI for DFW riders and all surrounding riders - free charity run
- Wind/Head Bobbling
- Brake light on all the time
- Need some opinions
- tach for 2006 1200xl custom
- RPM drop
- Will this fit?
- Iron - Loud "Ticking" Noise?
- Questions for Joebotics
- Neutral light
- chopped rear fender
- 07 1200 low engine seems to stutter
- Exhaust fitment questions (SE Pro's)
- Debating a Nightster purchase
- Screamin' Eagle Heavy Breather?
- Chopped rear fender question and handle bar help?
- Retro Helmets
- New slip ons
