View Full Version : Sportster Models
- Will a newer Sporty seat fit my '01 1200 converted 883?
- RSD Tracker Exhaust for 2011 48?
- Will 05 screaming eagle slip on muffler fit an 09?
- Where are you guys buying your fork bags?
- want mid controls from a 2007 sporty?
- I've become a Prospect! LOL
- Turn signal malfunction
- Nightster problem with gas cap
- Phillips MotoVision 9003/H4 Bulb
- Removing Plastic crap
- specs on sportster handlebars
- Exhaust leak...Crank position sensor?
- Classified
- adjust shift rod linkage
- drag strip times
- Choppers Cycle forward controls
- exhaust
- Which bigger tank and newer seat will fit my '01?
- Picked up another sporty last week .
- Nightster Exhaust Stud Snapped
- help! dont know if its a battery issue...
- Dragging the Jiffy Stand
- Mounting headlight where fender use to be?
- 883 iron exhaust change
- What seat is this?
- Warranty questions before I take it in...
- 12" HD Apes and HD Spring Seat
- Hand grips
- WTF, Primary case full of gas.
- **Serious Help w/ Starting**
- Broken Exhaust Stud
- Fuel additives ???
- ****, rear wheel weights fell off...
- Exhaust pipe dent/damage repair
- Lowest or second lowest shock setting??
- 13" RK Airshocks $50
- Some advise needed on next round of mods
- About to change my bars out...
- Preloading 1200C front end
- brand of gas
- Who (else) rides with their plate tilted out of sight?
- tail light
- Removing battery on 07 nightster
- Hey Guys you ever run octane boost or mixed race fuel in with your pump gas?
- Anybody who rides an Iron or any fuel inj Sporty please read
- Simple oil change for my 1200 XL Custom?
- Nightster Handlebars Mounted on Fork
- Night Rod Headlight Visor
- V&H side shots
- Anyone running Chubby Outlaw'z 14" on sportster?
- did i get ripped off
- Wheel Questions
- Installed drag bar on the Nightster, brake banjo question...
- More vibration after Sideshots install
- Need some good advice!!!
- Springer Front End
- Throttle grip dissection. DRUNK.
- Recharged battery, now won't start
- Cost of parts!
- Handlebar Advice Sought
- Sportster Horn Not Work
- 08 Nightster wouldnt start
- I need to be flat footed...a little advice.
- Polished Aluminum Care
- throttle freeplay
- Nightster Seat
- Rake the forty-eight?
- Brake Pedal Pivot Shaft Woes on a 2000
- for sale 05 sportster 883
- Introduction
- Money!
- In '97 were hugger fork tubes the same as a xl1200?
- Sportster 48 w/drag bars
- BUB 2into1 exhaust at a smokin price
- HD Solo Spring Saddle
- Rear cylinder cooler than the front
- 04 Sporster 883 idling n low rpm problems?!?!
- 2006 XLH or XL?
- Brake & Clutch Levers
- Name that part
- need help with the primary and trans. fluid.
- My bike made LICKS website blog
- modified baffles in vance and hines short shots.
- Might be a dumb question but im gonna ask anyway
- Tires for 48?
- Spoked Rear Wheel
- Front Wheel Repair
- Engine knocking
- can i use parts from a 883 on my 1200?
- Maybe I'm not burning oil - oil tank filling?
- Tacho/speedo connector
- Aftermarket riser to fit factory 'custom' speedo 883c / 1200c
- makin my own custom bars
- Change my Air Filter 05 Sporty
- Green slime and the Nightster tire
- Speedo going crazy
- Another front end rake thread & questions
- How to tell a 883 with a 1200 conversion kit?
- major issue
- Well, now I truly have a Harley garage...
- Any Huggers out there??
- 02 Hugger
- Make your own Forward Control Kit
- Oil change intervals?????
- will they fit?
- Got smoked by a CBR 750
- Different type of Quiet Baffle for V&H?
- tires for gravel, dirt, sand etc.
- Wide-Glide conversion questions
- Cool ideas for a rear taillight?
- ugly headlight "visor" mount / wanna replace it
- Fender hole plug
- Chopping 4in off my Iron Rear Fender any sugestions?
- Speedo condensation
- bags
- 883 vs 1200?
- Forty Eight axle size...
- New Seat : )
- hello all new here and looking for some ideas and opinions
- Wanting Bigger Capacity Tank
- Apes on a 48
- Harley Demo Days
- rode the trike- whole new experience!
- Removing leather residue from paint.
- S&S Air Cleaner on a 2007 sportster
- 07 sportster hesitation help
- Wire Management
- Micro gauge set for Sportster
- 1200 sportster fuel economy
- transmission clunking while rolling along
- mini apes
- nightster drive line lash
- Need a photo!
- Difficult projects?
- Wires Tucked, but feel a little "empty"
- New here
- Question about my carb?
- A few more mods...
- People with springer seats..
- Sportster 2004-2010 chrome rocker covers
- Why are Nightsters cheaper than other Sportsters?
- What Scoot to Ride ?
- Forty-Eight 1200 good beginner bike?
- clutch mech needed.
- XR1200 dash
- Power Commander V
- Please help...spitting and sputtering
- Drive Pulley
- Exhaust Nut Installation Problem
- Service Manual or Fix my Hog DVD
- Replacing mount kit springs with shox?
- XL1200N New Pipes/ Air Cleaner & Painted Engine Case
- 883 Iron - FWD Controls, Scraping, and New Rear Shocks
- Speedo Issue,
- Super Tuner or V&H Fuelpak?
- Can I fit this rear on my Nighty
- Spitfire windshield?
- Switch Housing Kit - 1200C
- before I had a clue (super tuner question)
- NEW 48--CAN't WAIT
- Relocated the coil and key-question about the wires
- My 02 883C (Pictures & Bio)
- Licks Cap'n Black Gas Cap?
- Rarest Of All Sportsters..One of 54 Made In 2003
- My 48 featured in the J & P Blog
- I just made a speedometer relocation bracket.
- Internal wiring for my clip-ons this weekend. FED UP!
- Old school single saddlebag
- 2 into 1s
- "Frisco" Bars on Forty Eight
- wider rear tire for forty-eight? possible?
- Relocating the ECM on 07 and new Sportsters
- $300 for a remap?
- Screaming Eagle or K&N?
- tires- when do you replace?
- Chin spoilers...who's got one?
- Questions for you 48 and other sporty owners
- Recommended Reading
- I've Reached Sportster (Motorcycle) Nirvana
- Need some help/advice
- Lets see your modded orange and black nightster
- 3 degree kneck bearing cups
- looking for a Triple Tree from a 04-07 xl1200c
- who
- Kickstand spring WTF
- Replacement Gas Tank
- 250 Tire Kit
- need help, alarm light on
- Gats9
- Sporty Brakes
- starts up when cold...after run, takes a while to start hot sometimes
- Spending some $$$$
- Saddle bag guards for sportster
- best rocker box gaskets ?
- tye pressure in sportster 48
- Clunk when I hit a bump...
- Might seem silly
- pass seat bolt for Nightsters
- One more nightster that won't start....
- 2005 Hardtail Build
- Stiffening up front end? How to?
- Anybody put a V & H Fuelpak on their 48?
- Daily Rider or Pipe Draam?
- poor man's rear turn signal relocation
- will the lower triple tree off a 48 fit a 08 nightster??
- Handlebar options
- rocker tops
- 883-1200 cost
- did I break my clutch??
- Harley-Davidson Sportster 883 will not start!!!!!!!!!!!?
- Is it possible to check the level of transmission fluid in my nightster???
- Handle Bar Clamp????
- Thinking of buying this Sportster. Please Help
- For those running 'Wet Dreamz' pipes...
- Shocks
- Head lamp/light ideas?
- Clutch issue with my '65 XLCH
- Any other SuperLow riders?
- Rush Slip-on
- 2004 Sportster Conversion Troubles
- Riding again
- What's my 2008 sportster 1200c worth?? Help!!!!
- Removal, Removal, Removal
- Road 6 Bars on, Mods done! (for now)
- Mid-Mid Controls XL883L - Someone?
- Need help with a Jetting problem
- Not like the sky is falling, but Keeerist..
- Help What would keep frying my ignition cylinder?
- improving 883L lack of comfort?? Help
- Blinker relocate trouble
- Thousand miles for dad
- Engine light Question
- More on seats....
- smoke lenses on a nightster
- HELP.......quick
- Side Mount Model "A" Plate Issues....
- Tire Pressure 04 883C
- shit eatin grin!
- Spark plug replacement suggestions
- Part Numbers?
- Let's see your XR's
- New to the sportster bike.
- xl is like...
- HELP.. identify this Seat......
- strange oil/ coloring on the engine on the IRON
- Rear Pegs with Licks Solo Bag. Anyone have this?
- Question: Swapping '05 XL1200C tank onto a '95 XLH1200
- 16" apes tips
- speedo relocation
- help sporster 1200r 07 wont start
