View Full Version : Sportster Models
- Ape hangers
- clutch perch and rear turn signals/ brake lights
- Some Night Ride Pics
- speedo removal.
- speedo quit working got check engine light..
- Sporty Bobbers
- What now?
- thinking about selling what u think I could get?
- Odd oil leak off upper motor mount??
- Nightster Riders how tall are you?
- What model is this 883?
- Seat options on my Forty Eight - Please Help!
- Quiet pipes help
- Do you ALL feel the NEED to modify?
- Carb versus FI 1200
- Drag Bar?
- Happy Fathers Day to all Fathers on this Board!
- FNG with light questions
- 96 1200 Custom Pipes?
- which Sportster?
- x14/ac done
- Drag bar questions
- New rider needs help!
- Any one with licks clip on's ??
- Rear Shock Bolt sizes?
- Rant: HD can stock Chinese made clothes, but not parts??
- forward control extensions
- speedo/odometer
- Iron Headlight Options
- V&H Sideshots - advice needed
- V&H P-14 Bracket
- Idle when in traffic jam
- 883L Handlebar Risers?
- Nightster front mod
- Banana Seat
- rebuild gone wrong ?
- SG air shocks help
- nasty trans oil. 2010 iron.
- Pitbull lift and Iron 883..????
- Throttle cable question
- Bike Not Holding Charge ? Help
- hmm any idea?
- New Sporty owner here
- 89 EVO 883 carb re jet?
- Headlamp Visor hardware?
- New Rider - What are some sick Mods for my bike?
- replaced clutch cable , now cant get it adjusted
- Spark in 87 Sportster
- New guy here, looking to get an Iron...
- Rear brake / Quick stop
- Remove that warning label from the air intake?
- Motor Factory Solid State regulator
- Exhaust for 48
- 48 front end
- Thank god for engine guards?
- 2012 Iron w\ a 6 speed?
- Nightster almost broken in, just ordered the upgrades.
- Wheel Truing/Spokes
- 48 spoked wheel tire change
- Mustang Solo Vintage Wide on my Iron
- Mobil-1 15w-50 ON SALE - Heads Up
- Mustang Vintage not fitting....
- question about relay in fusebox
- Max weight for 883?
- Crank case breather bolts
- Hello all
- V&H big radius
- Need New Handlebars for my 2001
- Need some wheel size advice from the board. Cant make up my mind on wheel size.
- Need help with front end on my iron please.
- Forward Controls & Handlebars HELPPP
- Front brake light switch not working
- quick accelerate, explode back to airfilter
- Bracing myself for the stealer's call, what's your dealer charge per hour?
- Choosing an AC upgrade...
- 2011, why so quiet?
- Almost done
- 09 sportster seat
- ft walton beach florida here i come!
- Describe 5th Gear on an Iron 883
- need advice after wreck
- Whats the first thing your took off your sportster?
- New guy, questions about 04 XL1200R
- intermediate misfire when downshifting
- The Rush
- Idle Hang Up
- Sissy bar bag/case
- DK Customs Coil Relocation Question
- Tire wear
- Nightster Seat
- Finally Took The RK Shock Plunge
- LED Lights
- '91 Sportster turn signal problem
- clutch cable fiasco
- 1998 fxr wheels on a sportster
- Cable measurement?
- Sportster Turn Signal Module
- Your Sportster gender
- gonna change lower triple tree
- what's the Height, Width, and Pullback of these stock bars (photo)?
- How Come The First Five Post
- Trans/Primary chain case oil
- Stage 1 mpg
- Well guys, it's been fun
- Nightster Derby Cover
- speeddometer
- HDForums Sporty Ride - Smoke Out XII
- Laconia
- 05 sportster fuel line diameter
- will the stock seat from a 48 fit an '05 883?
- Finally Have The Sportster The Way I Want It To Look
- Lowering a 2011 Iron 883
- whats the best stage1 bolt-on cam set for my 89 xl1200c
- Gas Tank Width for a 2011 Sportster 1200 low
- Clutchlite Installation
- Windshield bag for a Memphis Fats windshield
- Aftermarket Spark Plug Wires Help
- Touring with your sportster
- battery drained
- New Bars, what do I need?
- Double Clutching?
- Relocating mirror
- LongShot
- Primary oil question
- What do you clean your Iron 883 with?
- Intro & 1st question (here)
- forwards for the 883n
- 09 Nightster security system?
- Input wanted on exhaust for my 48...
- Do I need to jet different? Added baffles - lost power.
- ill freedom ride
- Can anyone identify this windshield?
- 10" shocks vs 12" shocks w/ 2" lowering blocks ??
- Front Fork Size
- screamin eagle????
- synthetic oil
- New paint on the tank
- Price Match non-sense
- Rigid Mount Bags
- which generic/walmart/autozone battery for an '05?
- Primary Cover Oxidation?
- best/cheapest (legit) source for Service Manuals
- 48
- Anyone that's ridden a forty-eight...
- Can U help with some info on this bike
- Baffles for SE I
- 40k
- WTB: intake system for 2011 Forty Eight
- Ironhead Bottom end Question
- A milestone for me - 10000 miles in a year
- Fwd. controls &/or Hwy Pegs w V&H Sureshots exhaust..what fits?
- New Seat Advice
- Mustang vintage solo or Saddlemen Renegede Solo?
- wheel fit on a 2005 sportster
- 09' XR-1200 Low end bogg !
- Mustang Vintage
- 12 inch Air shocks or 12 inch Progressive 412
- Help Me Fine Tune My Roadster Ride
- F@&$ chrome!
- XL1200C fender vs XL1200N fender
- Fork upgrade for 48
- Pls help...are these slipons compatible?
- Torque Cones
- Late sunday night and Penzoil....
- Darkness 2
- please advise...1200R test ride in few hours
- Gel Pads
- Rear pully and rotor torque
- Did The Americade Loop
- Fuel cut off question
- I want a new gas tank
- Let a friend ride?
- Smoking All Over my pipes!!
- Speedometer quit.
- New Owner has ?'s
- Just Got an Awsome Deal
- New to the forum and to HD
- One signal and tail light out
- Transmission oil level check on 883n
- New Pipes Install Question
- Other model Harley parts fit sportsters?
- Which shocks are these? 2006 1200R
- what did I do! (clutch cable)
- Speedo ? For Custom Owners
- RSD tracker 2-1 Vs D&D bobcat 2-1
- Short Shots vs Bassani Sweepers
- bike won't start
- DTC P0505 - My Solution
- First long ride on the Nightster
- 2010 Iron mid glide conversion + new headlight!
- Saturday and sunny,,
- 1200 custom with ape hangers
- Screaming Eagle Slip ons.
- Push rod tube leak
- nightster lighting issue?
- air filter help
- New lid - pics
- HD salesman about Sportys
- anybody have this helmet?
- eBay Deal of the Week - Bling Bling Sporty for a Mere $30K
- Video of my Nightster
- forward controls
- Switch residing
- 2011 Forty Eight and intake
- Kinda POed...
- 1987 Sportster 883 bored to 1100. I just would like to know more about this bike
- Magnum Cables
- Bike is sluggish
- Did I blow a fuse?
- Testing the ignition switch?
- 2008 Nightster 12" ape hanger concerns
- Adventure Sportster
- I Am Lucky Somewhat
- a "takes a strong leg" kickstart-only '68... what can be done?
- dyno run, how does my sportster rank?
- O2 sensor bungs, what size?
- Drive belt 883c
- 1st and 2nd gear downshift clatter
- Some pics of "Domina" as she sits right now.
- best polish
- Throttle tensioner adjuster
- Old School Handle Bars...
- XL1200C Sportster Custom as a Starter Bike?
- 2007 1200R Roadster
- X14iED ordered!
- If I put 13 inch air shocks on my Iron, will...
- HD Forty-Eight accessories question
- Bagger 16's
- rear pulley bolts coming loose?
- Are my pipes illegal?
- Help with carb and mods
- 2009 Iron 883 intake/exaust
- HELP: Leak Between the Rocker Cover and Head Cylinder
- Sportster Seat Bolt Thread size??
- Why did you end up buying a Sportster?
- better front tire situation...?
- Jim's Exhaust Stud Removal Guide Plate
- new bike and rider
- adjusting steering head
- 1200 conversion head gasket leak
- primary drainplug oring
- wiring question
- 87 sporty rim swap
- Rich Phillips Spring Seat?
- Air filter
- Stripped out o2 sensor and/or exhaust leak?
- Changing Brake Pads
- Starter grinds and smoke out the carb
- 02 Sportster starting/warm-up issues
- 1200 conversion---what jets??
