View Full Version : Sportster Models
- oil light came on after riding
- Removed the XiEDs
- Slipstreamer Tombstone Installed
- picked my bars need my lines
- Got my bike (Nightster)
- 2009 Iron 883 won't start after inverting / flipping stock bars.
- My 48 Complete
- 95 Sportster wont shift past 2nd
- passenger pegs (mounting)
- Gas explosion
- Sportster speedometer options
- dragracing my bike
- sportster 48 HID's!
- How do I remove cables?
- 48 DK Custom Coil and Key Relocate
- Helmets
- Rear turn signal / running lights
- labor rate quote compared to actual cost
- Finished with carbon fiber-like vinyl to front forks/rear shocks
- Sportster oils help please
- re-sealing a gas tank
- 79 sporty timing issue
- brake light problem
- noob question
- Drag Handle Bars
- Mirrors
- help with 1250 conversion. Going for the 100HP mark.
- Need Help - '96 883 Keeps Losing Power
- For All of Those That Like a Blacked Out Sporty
- How is V&H Big Radius exhaust for Sportster 48 ?
- Fuel pump part #
- Running Internal Throttle
- Front turn signal relocation please help
- hd dealer almost killed me today
- Stock Brembo Front Brake Pads safe for Chrome Rotors?
- adding a tach to 06 sporty?
- Somewhat Lucky Today Still More Money Spent
- Sportster/dyna speedo?
- first bike!!
- Switching Front Ends
- 1998 Sportster
- new 16's on the 72
- pimped
- 12" or higher riser help.
- LED Lic plate frame ;)
- Decel Popping
- EVO engine owners.
- I love My Sportster
- Need help!!!
- Which sportster shocks?
- HID shuts off when starting
- need hel chosing the right weight oil
- Bike won't start...Help!!!
- Two Sportsters in the Garage
- Any 1100 owners?
- How to remove dent from Harley 3.3 Tank Question
- Problem reaching clutch/brake levers
- 2013 iron and 48?
- 06 xl1200c recalls
- Surprise Surprise! 1200 vs 883
- NEW metzler me 888
- had some scratches on my tank.
- The Hammer xpress 1250 dyno
- DK Custom (Coil and F6 Ignition Relocation, and Tank Lift)
- best/cheapest LED w built in resistor Dual fil. bulb
- loose clutch magnets
- Performance Machine Grips
- Stator/Regulator plug issue
- Vertical side mount plate you've probably never seen
- Another "Backfire" post
- Sportster electronics problem
- Problem! not sure what its called (Newbie)
- taillight + turns upgrade
- used Sportster store?
- What's the story behind the solid rear wheel?
- Rineharts?
- 883 Superlow Forward Control with "Crash Bar"
- How to make turn lights also brake lights?
- Finished Project
- Stock bolts work with rigid mount HD sissy bar ?
- New DIY seat.
- New To HD, Need Harley Advice!
- Brake Pads?
- Performance Air Cleaner
- Mythbusters - Sportster Style
- Sporty Rear Shock options
- Hot off the press: Just finished 04 sporty/bobber project (pics)
- First service for new Motorcycle
- Looking to buy a Sportster. What years/models are best?
- Advice on spring install
- Best seat to replace stock 2-up.
- Exhaust Bracket...gaskets?
- Break pad pin
- Drag bar question
- stock operating pressure
- 95 Sportster & Memphis Shades Batwing
- Sporster xr mods
- 883 poor gas mileage
- Windshield on sporty
- 48 vs 883 std shocks
- Custom Dynamics TruWrapz LED Turn Signals!!!
- 2012 "72" Makeover... Yeah lets call it that
- Break Rotors
- Dark Red 1156 bulbs at Dealer?
- Speedometer Sensor
- Help w/ fuel tank change
- My 48R..
- dumb question about new tires
- Wire Tuck (DK Custom), looking for advice
- fuses and circuit breakers on a stock 92 883
- messed up on vance and hines installation?
- New wheel
- 48 side bags
- Spitting out gas from a/c
- Drained 4 quarts from my 05 sportster 883c
- owners manual
- license plate bracket
- back brake light not lighting up
- Need some help with a fender
- Electrical Preparedness Questions for Trip
- Toxic Inc. Daggers
- XL1200v Gas Cap 75097-05
- Forty Eight V&H short vs bassani sweepers
- What size are the points cover rivets 94 sportster
- Back brake light only pulling .5 volts. Any suggestions?
- Joining the Sportster club
- Sportster's ride... meet up Northern NJ
- 250$ screw up
- 1979 iron head how tight should the primary chain be
- Low fuel comes on at 100 miles ?
- New Air Hammer a/c just introduced by Hammer Performance for $150
- New levers on my 48
- 06 xl1200 C Change Handlebars and Speedo Help Please
- removing bracket for exhaust install
- chopped the rear fender tonight
- Top Rocker Cover Won't Seal
- Temp Sensor Brands???
- Windshield reccomendation?
- Adding pipes and C/A - Help requested
- 2012 Iron Hand Controls Hardware
- Sportster won't go slow?
- noob question: o2 sensors
- Sportster Off Road Mx 1200....
- sportster 144max power 116.60 torque
- Pics Needed
- Running a 170 rear tire...if I mod the swing arm what else is needed
- How tall can you go?
- What is the "6" on the speedo face for 48?
- oil change what the -----
- Wiring Problem
- Daytona Twin Tec 2
- Leaving Bike Paranoia
- Lowering and tank lift ????
- cold exhaust and spark/misfire problem
- Flatiron: My Always Evolving Sportster
- Progress Pics of My Sporty
- Varying idle RPM's
- Air filter question?
- Wide glide low profile bars on a xl 1200 c?
- coil wireing
- Where to find Sportster parts
- WTF? 883/48 hybrid?
- Tcainers 2004 Sportster
- Couple new DIY videos for you guys.
- Multiple problems... Please help!
- My 2013 Iron 883, With lots of new parts and Limited run Paint (137 of 200 )
- Throttle to light
- Questions regarding handlebar swap...
- CV jet needle adjustment
- new Iron - valve train noise normal ..?
- Sundowner seat height?
- 01 xl 1200 rear tire rubbing
- Installing 6 gallon gas tank on Sportster 883
- Newbie XL1200X vs XL1200C-B
- Seat size question
- 1992 883 no start
- biltwell keystones
- Turn signal relocate, tank lift
- Installed drag bars on the 48 & Nightster
- Irons and 48's??
- sportster 48 stalls and rough idle
- calling all TEXANS...AND OTHERS
- crying over spilled oil
- michelin tires
- Any pics of blue Irons?
- Stage 1 download works
- Black and Brown? (pics)
- Turn signal question
- Seventy-Two Screaming Eagle Slip-On's
- Son wants a Sportster
- Backfire and engine light on/related to loose battery cable?
- Paper weight club
- Gas Indicator Problem! help! (Newbie)
- Kuryakyn Hypercharger pro or standard?
- Cruise Control
- Power vision maps question
- Bassani Road Rage installed. niiiice.
- Ok need advise
- 86 bad clutch hub
- Decided the rear shocks on the 48 needed a facelift...
- 88 Sportster 1200 not firing right- stumped...
- more forward, forward controls
- dk lowering blocks
- Stage 1 Questions
- Need part numbers
- Buying new wheels
- Put my Progressives on today...wow!
- Let's see your solo seat Sportster's !
- Changed Rocker Box Gasket now bike is not running right
- First ride on me sporty
- Need Part Number for spring
- XL-Caff Finale
- Bike stand not lift
- Noisy lifters after rocker box removal...?
- New shocks, fork springs, and re-jet
- bike for a friend of mine
- lowering block install
- Electrical mess
- Bleeding front brakes, new brake line, no pressure.
- Touring on an Iron
- 7/8 Drag Bar?
- hd forward control install Q
- New intake and I have some questions
- Hard decisions to make...
- What's the torque specs on handlebar clamp?
- help figuring out this headlight part number
- Carb tuning
- SE clutch vs. spring plate delete?
- first mods done, big sucker, bars, risers, pegs. serious tech.
- Amps from Stock Stator ? ? ? 1200XLC
- Bulb help plz.
- Nightster 2 up Ready
- spark knock ?
- Better seat
- New chrome acorn nut covers, cheap
- Which front springs for 09 low
- Maxed out 883
- Stuff keeps on falling apart.
- Electrical Issue -- Charging System -- thank gosh for search
- Soild Struts
- Back pegs for 01 sportster
- Is this backwards modification?
- New front rim
- cam spacer plates
- Finally nearly finished my garage today.
- Low idle, bad TPS, bad O2 sensor, or bad...
- SpeedBleeder for iron?
- big sucker II installation problems
- My 05' 1200c has the Hick-Up's
