PDA
View Full Version : Sportster Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298
  1. LED Help
  2. What are these called? Hould coud I remove them for painting?
  3. lets talk grips
  4. passenger seat
  5. Dropped Exhaust Flange Nut
  6. a little TEST for you
  7. Wheel bearing removal trick
  8. Yost needles
  9. Turn signals dont flash (but hazards do)
  10. Idle mix screw seated but still runs
  11. New 72 in my driveway!
  12. Stumped on backfiring/ popping out of carb
  13. Nrhs
  14. 2003 1200 Crank no Start
  15. Need help 74 ironhead
  16. Wicked shimmy
  17. Will this La Pera seat fit my 883 Custom?
  18. New tank,petcock,airfilter... help?
  19. 60k service and road trip FL to upstate NY
  20. Rich Phillips solo spring seat advice for 48
  21. HELP! Exhaust Wrap? Am I retarded?
  22. Hells Bells Helmets
  23. Nightster Riders.....
  24. Removing chrome tank center strip
  25. Le Pera or Otherwise?
  26. Advice Requested (Power Vision)
  27. 08 Nightster Rear Wheel to Front?
  28. 2012 Nightster - Harley Sound
  29. need some ideas and some help
  30. Front tire question
  31. I searched-shifting and trans issues-with video
  32. no fuel thru the fuel valve
  33. Any ideas for battery cutoff switch for Ironhead
  34. Cleaning fuse connections
  35. What kind of exhaust is this?
  36. la rosa saddle bag
  37. Oil tank recommendations
  38. Brake light activation by rear brake pedal
  39. Just installed drag pipes, 2 questions
  40. Low RPM stumble..
  41. What Oil for the Year Round Rider?
  42. Raked out Sportster, have you done this? Opinions are welcome
  43. Switch from Kawasaki zx6r to 883 iron
  44. Need help with risers
  45. She tops out at 124mph
  46. Buying a Sportster HELP
  47. Confusing Problem
  48. drag bars other crap...
  49. Gear Oil Issues....
  50. Plate relocation - how?
  51. starter engaging while driving?
  52. Rear wheel removal question
  53. new bars mean..
  54. Puzzling problem
  55. Review: Burly Lowering Bracket (using stock shocks)
  56. Thinking of a purchase
  57. 05 sporty acceleration problems
  58. turn the key off
  59. Joe Florida lights question?
  60. 2005 1200 XLC Opinions
  61. Rocker Box Cover - Oil Leak
  62. Bassani road rage 2 into 1
  63. too much oil in my sporster
  64. apes to clip on's on 72
  65. D&D Bobcat vs Stock Exhaust
  66. Sportster Carb / Plug Issues
  67. Converting to carb
  68. cam timing help
  69. So Far So Good With Sick Saddles
  70. Bad Experience with my main dealer.
  71. Bassani Pro Street...Upgraded A/C...PC3 or PCV & Professionally Dyno-Tuned! HELP!!!
  72. 4.5 gal Replacement Tank
  73. bending chrome plated metal
  74. Sputtering then nothing - electric problem???
  75. Collectibility of Patriot Edition Sportster??
  76. I need somedback from you guys! Please read this!
  77. New shocks: need for adjusting belt?
  78. wacky jiffy switch
  79. Should our Belts have dressing applied at intervals?
  80. Homemade bars fail ...
  81. Bike down- stealer or indy for inspection?
  82. Extended Kickstand 2012 1200 Custom ?
  83. ironhead oil drain plug leak
  84. Sportster handle bar Help
  85. Pics of my "New" Harley!
  86. Master cylinder rebuild tip
  87. speedometer drive unit
  88. My Biggest 72 Gripe
  89. 72 versus 48
  90. Changing the gasket on the rockerbox
  91. 2012 Sportster head pipe size
  92. Font fork bottoming out
  93. Can I lower my 2008 Sportster quickly?
  94. Which Jets for a Stage 1 Upgrade?
  95. 06 Sporty Custom Change Front End Help...
  96. Tank trim removal
  97. Hard to turn 06 1200c
  98. OK the manual doesn't say
  99. 04 to 07 Sportster seat
  100. New clutch cable... Now what?
  101. cleaning my 883 iron
  102. What To Do Next: Performance Mods
  103. Taking the Baffles Out of Thunderheader Exhaust...
  104. Finally got my first Sporty
  105. Quick wheel compatibility question:
  106. Home made copper stash tube!
  107. Mini apes
  108. Forward controls
  109. Removing reflectors
  110. charging help
  111. Drag Specialties Predator Seat
  112. Exhaust question
  113. Oil leak out of Air filter
  114. Clutch Adjustment
  115. New A/C Cleaner Cover - Home Cookin'
  116. FNG from The Show-Me-State
  117. Rear shock time
  118. 03 Sportster suddenly not starting
  119. Why not run straight 50W oil in these temps.
  120. Running lights not working....HELP
  121. 2012 Iron 883 stock exhaust vs American Custom vs DKCustom Thunder Torques Review!
  122. VH Short Shots
  123. Front brake question
  124. Done the Ton?
  125. Iron just died..... please help
  126. Affordable Chrome Highway Pegs...? Non-Engine Guard type!
  127. 98 dyna wheels on a 93 sportster?
  128. Turn signal wired for turn signal only help.
  129. First bike, first harley, 1000 miles... still in one piece!
  130. Best Shock to Lower Bike
  131. Solo Seat Advice?
  132. My work in progress '09 Custom 1
  133. Rush 1.75" vs CS MXL-130 for 1200N
  134. New to Sportsters
  135. Spongy front Brakes
  136. best shock change 1200c
  137. Running rough
  138. Scott
  139. starter not disengaging
  140. newbie
  141. Still think I'm running lean with x14ied's
  142. bleeding sportster brakes
  143. Where can I buy 8" Z-Bars with KNURLS?
  144. Does Nightster or Iron seat fit Forty Eight?
  145. seat fitment
  146. Rattle
  147. Help finding a tank.
  148. Looking 4 long range sportster solo seat, lepera bare bones comfortable?
  149. Charging system 98 Sportster
  150. Oil Tank Fix or Replacement?
  151. Derby & Timer Cover DIY
  152. Pimped my ride! Trot out your bling!
  153. Stock seat
  154. Another handlebar thread
  155. New seat for 2-up riding
  156. LA Choppers Outlaw z-bar
  157. Travelers sporty project is complete... PICS
  158. After a good rain, the belt is squealing
  159. My forty eight got recalled
  160. Looking for other Sporty owners in NW Ohio
  161. Making your own forward Controls
  162. 6 3/4 base for sissy bar?
  163. Yet another vibration post
  164. Thinking about switching to solid state voltage regulator
  165. horse power/torque RPMs
  166. 15K Service
  167. 48 in laguna
  168. New and of coarse questions
  169. Iron Gaiters Fade from Black
  170. I sure hope she likes it...
  171. xied + fuelpak
  172. THE optimal 'bags - with or without supports?
  173. Installing 2" Rush Pipes on 2008 883 Sportster
  174. Exasperated! Desperate for tyre info.
  175. Noob introduction & question about straight handlebars
  176. anyone make their own bars?
  177. Oil leak 1200??????
  178. 82 Sportster Question
  179. sportster comfort flex shocks - opinions?
  180. silicon spray
  181. 2012 Iron 883 Pics!!!
  182. How do you change this part out. Pictures
  183. Front alignment question
  184. relocating exhaust
  185. 84 ironhead; intake/carb problems please help
  186. What Years are Interchangable on Parts
  187. 2001 1200 Sportster turn signal problem
  188. Heat shield
  189. Powervision
  190. A bg clunk!
  191. Just Purchased a 2012 Nightster
  192. Zero Engineering Headlight Relocator
  193. Extended forward controls
  194. What gas?
  195. need help setting timing.
  196. Rear tire for cheap
  197. Nightster Tank?
  198. How big are my nuts ????
  199. 2012 - Forty Eight - Vented or Non-Vented Gas Cap
  200. Powder coated (grey) engine case and WD40
  201. Dealer Service Writer, Royal Purple Max Cycle 20W50
  202. thinking about changing my belt to a chain
  203. FIRST Harley 2006 Sportster 883C
  204. Biltwell Tracker bars
  205. Biltwell - High Drag Bars. Anyone got em?
  206. 1988 sporty carb prob
  207. Sportster cafe-racer exhaust
  208. Went to get my sticker today.....
  209. Engine noise getting louder
  210. help me with my list
  211. Anyone switch out Iron Headlight for a 48 or 72 version?
  212. screaming eagle slip ons
  213. Carb Adjustment
  214. Better to trade or just buy exhaust?
  215. Sportster hardtail
  216. If You Slam It, It Will Ride...
  217. Sportster issue
  218. throttle cables
  219. DK Customs, Unbelievable!!
  220. 14" road 6 bars
  221. Wiring the handlebars
  222. "72" Wire Tuck/Plastic Shed
  223. Pics of my "72" hanging around town
  224. sprocket lock tool/ brass in my tranny fluid
  225. Rebuilder safety tip.
  226. Bought My First Harley
  227. 93 sportster dies at idle
  228. cigarette lighter for a sporster
  229. Sportster poor accel problems
  230. Can someone run a VIN?
  231. Starter issues
  232. Lower wind deflector
  233. Jardine Front Highway Bars
  234. Bullet style headlight on sportster
  235. oil leak? 2011 nightster
  236. Question regarding AC/exhaust and X14iED
  237. Nightshades on blinker covers
  238. iron handlebar ?????
  239. helpful DIY's for 2012 iron please
  240. 48' seat on 2012 iron
  241. How important is a download
  242. 07 nightster died at 70mph
  243. Memphis Shades Bullet FX Fairing?
  244. 07 sportster 1200 custom gone wild
  245. shock bolts
  246. Can the drive belt make a howling noise.
  247. No oil in the tank
  248. Spring/shock question
  249. Need Help Install HD Tach/ Speedo kit on Nightster
  250. Newbie & Finally Ready for Some New Mods! Advice-Help-Knowledge Please!
