PDA
View Full Version : Sportster Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299
  1. Questions about picking up an '07 EFI 883
  2. Installed my 412s
  3. Mileage
  4. Options
  5. Options
  6. New member, new owner, old questions.
  7. Hotrod 48 done for now.
  8. Roland Sands/mustang Seats poor fit ?
  9. Options??
  10. Bassani sweepers?
  11. New bike return or exchange?
  12. Anyone using/have issues with 2 1/2 - 3 1/2 pullback risers?
  13. Peanut Tank Question
  14. accidental downshift/over-revving, aftermath?
  15. Greetings
  16. Changed grips, now a few ?'s
  17. Not Lurking any more
  18. Help with riser install
  19. Corrosion at spark plugs and white plugs
  20. Spoked Wheel warp issue
  21. 2010 Iron - Rush Slip-on question
  22. help
  23. NOOB FROM SOCAL! Trades & Q's??
  24. Need Help - Any clue?
  25. opinions on 883to1200 components. 2011 883N
  26. New Pipes Install Question
  27. Side mount license plate on 883c
  28. What is this part?
  29. running loud
  30. Rear Wheel Spacer
  31. Mounting a 2003 tank
  32. How much?
  33. battery bracket??
  34. to gear or not to gear?
  35. windshield
  36. (Pics) Chrome forks and fender rack on a 48
  37. Will painting my 04 Sportster from red to black kill the value?
  38. (NOOB) What kind of bike should I buy if I eventually want to get an IRON 883?
  39. Exhaust leak after fwd control install?
  40. New Member - Just bought Nightster!
  41. Stock Shock length on a 1998 883?
  42. I'm stuck--48 or Street Bob??
  43. 07 Nightster Transmission Issue?
  44. Arizona's "Tail of the Dragon"
  45. It's that time again..................
  46. Fuel Light on when traveling 55mph or higher
  47. Which round cover for a 2002 Sportster with a Ness Big Sucker Stage 1?
  48. Z bars
  49. Any pro's with knowledge on my 75 xlh
  50. Removing aftermarket glued grips
  51. "single" speedo/ tach bracket + new bars
  52. 96 - 03 and 04-present forward control question
  53. Samson Slasher install/fitment problems
  54. Exhaust guide by decibels?
  55. V&H Short Shots
  56. new to the site
  57. Ladies; If you cannot find Pink Wall Tires, do Pink Rims
  58. 04 Sportster 883 Carb issues
  59. Forward to mid controls
  60. Oh cool, an oil leak. Is it still ok to ride?
  61. 04 sportster oil tank cover question
  62. multiple ?? for mini ape users
  63. front fork leaking
  64. Finally sounds like a Harley
  65. wire not fully seating into/clicking into connector
  66. wiring location question
  67. Airclener gets hot at idle
  68. compatible mid controls
  69. Production #'s
  70. 03' 883 suspension help
  71. Good deal on slip-ons
  72. from XL1200C to FXDC - review
  73. Overseas - HELP - 2012 XL1200C no mods, 1250 mi P0264
  74. Adapter bracket for Screaming Eagle pipes?
  75. First ride tonight
  76. 2004 Sportster 883 Custom Rebirth
  77. Removing paint on motor?
  78. First Harley. Many bikes before
  79. Can I add gauges?
  80. Ironhead has a cold and coughs
  81. Trade 48 Handlebar for Nighster Handlebar
  82. Help carb leak
  83. My First Harley
  84. Speedo Question
  85. 2003 XLH1200 Sportster spark problem...
  86. what are some cheap upgrades? 2000 883
  87. Damn This Forum!!!
  88. 1979 Sportster 1000
  89. grips
  90. Avon or Kurk?
  91. OIL Check
  92. Can I turn my sportster iron brakes to ABS?
  93. Hot bike makes horrible sound sometimes when starting
  94. Broken mount for kickstand
  95. How often do you wash your bike?
  96. Iron (heavy breather, Straight shots & supertuner installed)
  97. PM calipers & breaks
  98. jp cycles......
  99. wife's first Harley
  100. Brake Light
  101. Bigger Petrol Tank for a Nightster.
  102. Unplanned Happenings
  103. dead battery on 2007 sportster
  104. 01 Sporty 1st Chop
  105. Sportster Engine Covers
  106. factory pegs-stock vs anti-vibration?
  107. Why I ride...
  108. Iron 883 - 1250 conversion build pics
  109. Bought a windsheild for my Nightster ** PICS**
  110. Melted ppositive battery cable
  111. Metzler 880's
  112. cycle shack and x14ied
  113. Are my turn signals malfunctioning?
  114. AC and Exhaust
  115. Anyone had a MAP sensor fail on a carbed bike?
  116. Shock differences by year
  117. 73 xlch electric ignition kits?????
  118. Nighster Springer Kit and ECM location help
  119. Burly Help
  120. front fender removal question
  121. Spitfire windshield
  122. EFI idle question.
  123. First Harley / Intro...
  124. Iron883 p-pad help
  125. Blinker Install
  126. Which bars can I use??
  127. Movement normal when removing oil filter?
  128. Mooneye Air Cleaner on my Sportster
  129. Personalized License Plate?
  130. Threaded insert?
  131. Just ordered new midget gimps.. Let's see how long..
  132. Oil bag conversion?? Does anyone know how
  133. HELP Bike not starting
  134. possibly painting my nightster, any ideas?
  135. 06 sportster 1200 speedometer problems
  136. Quick Question
  137. Noise from rear tire
  138. Adios Amigos.....
  139. thunder torque inserts????
  140. Internally wiring bars, to hell with it
  141. IRON 883 for short guy
  142. tail light probblems
  143. Home Cookin' - Foot Pegs
  144. New old oil tank
  145. Back firing when turning off
  146. Clip on bars advice please
  147. Front Brake lock up!!!
  148. Sportster or Nightster?
  149. roland sands shirt stack
  150. Harley Newb - Jetting for stage 1 wannabe 1200R
  151. V&H Short Shots vs SuperTrapp Paul Yaffee X Pipes
  152. need torque specs
  153. 12 or 14 inch Nash midget gimps
  154. smoke and oil from engine breather
  155. Help - Almost stalls when warming up/possible knocking
  156. Going to check out a 883 --> 1200 Iron... Questions
  157. 2012 Sportster 1200 Custom
  158. 48 Rear Shocks?
  159. My 48 is finished for................now!
  160. Starting and possible charging issue
  161. Condensation in the morning
  162. v&h big radius pipes
  163. Sticker on headlamp brow
  164. 03 883 Idle fine but as soon as give gas it dies
  165. New Seat for 2007 1200L
  166. How was this wire tuck done?
  167. amsoil 20w50 for primary/ transmission
  168. no power in run mode
  169. Raised headlight visor
  170. Hard bags
  171. 11' or 11.5' Progressives-- visual effect?
  172. Best Riding Glasses ~ Your opinion ~
  173. 6 inch straight riser w/ 24 inch drag bar
  174. 883r windshield and air cleaner
  175. 1977 xlt
  176. guesstimated horsepower ?
  177. leaking master cylinder banjo
  178. 23mpg ?
  179. Getting new pipes for my 2012 Iron 883
  180. upper clamp, lower clamp and bar bolts
  181. Clutch hard to pull
  182. Ape Install with Dual Disk Brakes
  183. 1992 Sportster 1200 HSR-42?
  184. Joker Headlight Bracket?
  185. any Miami riders here?
  186. Let's talk petcocks!
  187. Speedo, coil, key switch reloc and 1 inch tank lift
  188. new speedo problems
  189. Max Weight for 883 conversion?
  190. wide tire kit?
  191. 1992 Sportster that has been sitting for 2-3 years
  192. Buy own tuner or get it tuned by dealership?
  193. Pullback install. Need some advice
  194. Why my Nightster had to go
  195. Let the Apes begin!
  196. 12" Or 13" Touring AirShocks On Your 48 ?
  197. Is my dealer full of ****?
  198. shifter shaft
  199. Saddlebags and Lowering Blocks?
  200. Feed Line on evo sportster oil pump?
  201. Forty-Eight Stage 1 Setup
  202. 2002 Sportster won't start
  203. Forward controls, mid pegs?
  204. Gearing Q and Gas tank Q
  205. Blowing fuses AGAIN!!!!!!!!!!!!!!!
  206. 1,000 mile maintenance questions
  207. Avon gangster's?
  208. K&N Air Filter HELP!
  209. Uk afftermarket dealers
  210. SF Bay Area Sporties
  211. need help naming my sportster
  212. 2011 Iron upgrade
  213. Show us your 72's
  214. Choice to make, opinions not only welcome, they're wanted!
  215. turns over no spark
  216. Kuryakyn Swingwings
  217. Wide Glide Rear Wheel
  218. V&H Short Shots
  219. In the market for tires... Suggestions?
  220. dyno tune-kansas city?
  221. My version of Lollipops
  222. Just bought a Harley... Clueless
  223. Austin, TX - Iron 883 Customization
  224. LA ROSA SEAT KIT instal problem!!! Help
  225. 412s for 2 up
  226. Whistle suddenly appeared
  227. Bent rim on 48
  228. dummy lights making me look like a dummy
  229. Rear Fender Ideas
  230. Comfort?
  231. Yet Another Tank Lift (Not your average one though lol)
  232. 883-1250 upgrade issues
  233. Thinking of buying a 48 - will I be disappointed?
  234. Older SEII pipes on 07up nightster?
  235. xl883, red oil light, won't start
  236. Biltwell keystones
  237. 2007 Wiring Diagram?
  238. Bigger tank on an 03 where to find one and what is a good brand and direct fit?
  239. 08 nightster wanting passenger sissy bar
  240. Problem with starting
  241. what just happened
  242. Smoked lens bulb trouble- '11 48
  243. Forgotten how much fun sportys are..
  244. Nightster Winter Makeover
  245. M2 cyclone engine/transmission into a 90 Sportster frame?
  246. Am I psyching myself out? Need some advice about installations!
  247. Speedo location help
  248. Why won't forward controls interchange 4spd and 5spd and post '96?
  249. Carb Weirdness...?
  250. Windshield Advice for a 07 Sporty Low
