View Full Version : Sportster Models
- Exhaust Opinions (You know the Routine)
- Engine performance improvement tips
- Crane Cams Fireball HI-4TC
- Vance and Hines Exhaust
- Can't get new speddomter cable to work on 1986 harley davidson 883 sportster
- New Owner 2005 Sportster 1200 Custom
- My bike sounds like a chain saw
- Front Rear Turn Signal Swap
- Anyone relocate headlight on Iron? New bracket?
- Opinions please...need ideas and a few answers
- Iron with PCV
- Chicago paint job
- QUESTION; Shifting on Sporties
- Probably beaten to death but.......... Burly 14" apes
- shock compression tip
- New Picture
- Stock pipes
- Coastal 80w90 gear oil
- UM ok-you have to see this
- 2011 Iron 883
- procedure for bleeding dual discs on a 2002 1200s
- Risers with frisco
- amount of oil
- Help me fit better on my 48...
- Lollypop baffles and torq cones?
- My new iron 883!
- Red key light?
- My Iron 883!
- no spark??
- Vibrations above 60mph
- Again with the "Girl's Bike"....
- New handlebars for My SuperLow
- Foot Pegs for Comfort
- 2006 Speedo Bulb
- 48 Tank removal..... Is this correct?
- Test Rides Done, decision made
- SEII's are loud!
- Removing the front muffler..
- Color Combo?
- So Im about to receive 2 Free sportsters
- ***The Forum Mascot needs to hit the road again asap***
- service manual
- X14IED question
- Help me convert to 1200
- 08 Roadster
- 883-1200m conversion EFI tuner experiences
- Oil Change Questions
- Bike died, won't restart
- cam choices aka i need opinions
- Finally got my first bike
- first "wreck"
- Updating Intake System
- Ride of 1200:
- Iron 883 problem
- 2009 Nightster Whitewall's
- Stalled today, didnt turn right back on...
- The best performance engine mods for my Sportie 48!!
- Intermitent Starting Issue with my 2003 Sportster
- Rush shorty sporty
- Where to Hide...
- '11 48 Seat Removal
- Well here she is all updated
- New owner, first question
- Choke/"enrichener" relocation
- Sorry, about my motor ringing again..
- Air Cleaner difference?
- Custom ForkBags
- Pipe burns.
- Struts To Shock?
- Custom Sportster dealer in Canada
- Footboards for Sportster
- Urgent Help Needed!! Possible clutch issue
- Coversion Help
- Downsized to a XL1200C - May be the best yet, why all the negatives?
- Speedometer
- 2006 Sportster Front Fork
- Shock absorbers
- I,m Looking For Some Show and Tell On Your Sporster Softail Conversions
- Wide Glide front end on a Sporty. Anybody done it?
- b1008 Reset Switch Closed Instruments? DTC
- S&S main jet for 883?
- Just Did The Swap
- Shinko E270s
- Top Rocker Cover Replacement?
- Bleeding the Brakes??
- Black soot in one pipe
- Harley Anni Value??
- Balancing
- 96"Fatboy air cleaner on a 1200 Nightster. Anybody done it?
- iron 883 narrow front end...
- Sportster saddle bag support question
- Heavy Breather alternative - K&N Aircharger (pics)
- i looked everywhere
- Oil pressure
- Speedo bracket ?
- Keys
- Changing grips on a Sportster the right way (How To)
- I Dont Care Anymore...3.3 For Me.
- handlebar vibration is numbing
- First ride in a good FF...
- Kuryanyn/ Iso Grips guys, need your help!
- Oil Leak in Shocks - Useless or Refill?
- Pics of very cool custom rigid K Model Sporty
- High Voltage Battery
- Step by step for Slip On Muffler Install?
- What RPM?
- motor cutting out...
- Cleaning windshield...
- new to the forums (pics)
- Should I paint my tank?
- Licks novdot
- Road King Shocks, How to put air in ?!?
- Need new rubber
- I found the one. A Forty Eight
- My 883 Iron is done
- sportster drag bars
- Trailering... I know, I know...
- installed my new leather seat and p-pad today.
- Smartpartz Quiet Baffles in Cycle Shacks?
- Good, affordable spring seat bracket
- 1000 miles service - need help!
- First Ride
- Sportster Battery Question
- Removing Front Tire Problems
- broken exhaust pipe clamp bracket
- Evil Twin Skull horn cover
- cafe conversion
- More issues... sorry
- My $1.50 jockey shift foot clutch build
- Iron 883 2009 back tier not center with fender
- Sportster shocks!
- Crankshaft assembly help
- video of "Top Fuel II"
- Silencer brake pedal pad
- Bike Died On Highway Tonight Twice
- Accutronix gauge mount
- Sportster Speedometer Visibility
- Advice for Backyard Builders
- where to buy cheep stock shifter for 02 sporty?
- Swapped horns on my SuperLow -- highly recommended for 883 owners
- Buying first bike ever!
- conversion complete
- Another forward control question
- I love my bike
- Accident 9/20
- getting started on my travel tank! non-traditional :)
- More comfortable seat on a Forty Eight
- Badlander seat
- O2 sensor and bung issue
- Flat Black or Flat OD Green Sportsters...... Please post pic's here!!!
- Bike just quit.......
- Lowering Front Fender
- Questions: Using scotchbrite on chrome & painting tank
- Rattling Noise.
- Starting issues on a 08 Nightster
- Buckhorn bars on recent models
- Installing an EZ Bob Tank and Want to Know the Headaches
- 95 sporty
- Upcoming HDForums Sportster Ride & Party
- Lower my 2011 Nightster
- Burly Bars
- '87 883 sportster rear chain
- More bloody questions
- I'm back, and can't wait...
- Back from the dealership
- Project "Bandit"
- Which Sportster Windshield
- Twin Velocity Plus by Kuryakyn.... possible on 07 Sportster?
- Speedo not working right
- Sportster Club
- Advice needed on Indy shop's advice
- Installing new rear shocks with no lift.
- Ignition Mod
- Removed the front fender off my '48...
- Fender I.D. Help Please
- Pipes interchange
- Raising Rear Suspension
- Lookin For That Kind of Seat
- Project Post?
- CV carb poppint backfiring thru carb 05 Sportster
- Question about turning block
- Anyone know where to get black spiked grips?
- Winter wx oil change
- 48 Second Thoughts Help
- finally took pics w/new bars...
- key stuck in ignition
- Anybody trailer thier bike?
- Whistling sound from 2nd cylinder exhaust pipe
- Exhaust...
- Using Rebar
- First Ride on MY Bike
- BornToRide3641
- Mobil 1 15w-50 $3 gal !
- HD black dragbars
- Cut my front fender for more clearance on motor mount.
- Riders edge complete
- nightster 1200 fuel consumption
- Pic request: Custom painted Sportster tank/fenders
- Funny stories of your Sporty
- Does Harley have a secret part room?
- Stock exhaust 2-1-2 vs Screamin Eagle slip ons
- 02 Sportster Short Shot Staggers really that bad for low end?
- PCV Installation Help
- need help finding a fairing
- Has anyone used these bags on a sportster?
- 2008 started hard today
- Below Bar Mirrors on an XL1200C???
- My home made sissy bar
- Will stock cables fit these set ups?
- Replacement Lower Belt Guard
- Cycle Shack Slip-Ons - First Impressions
- 2007 Nightster won't start
- Added to the stable and my N is no longer my cool bike. SR500 added to the stable.
- High idle
- Kuryakyn Chrome Clutch Cable Adjuster Cover
- How are sportys in cool weather?
- What tuner to get?
- Anyone got one of those black headlight visor things?
- Advice on nightster shocks and sissy bar
- Safety Switches?
- Painted Helmet
- Roadster wheel on a Custom
- 2001 sportster 1200 oil leak
- short video
- Fuel Tank Emblem or Decal
- Wattage stat
- Cycle Shack S/Os
- Roland Sands speedo/headlight re-locator on a Dyna
- Help with Bassani sweepers way too lould!!!
- 48 1/4 mile times
- New Battery already dead
- Jack Points
- '05 883 Starting Issues
- Wife wants a saddle seat
- Sportster Exhaust Drag Pipes Sikpipes
- replacing the turn signal/brake light on the Iron
- quick question, tire fitment?
- Nightster vs 1200C
- Thunderheader rejet question
- 01 883 carb farts
- question about mid mount controls
- tranny wants to stick while downshifting
- Need Advice Quick Please
- where im at on my modern retro
- Lugging
- Iron 883 tire options?
- Clutch Tension Adjustment (repeatedly looses tension)
- 2006 Sportster XL 1200 Custom Carb Problem?
- Wyotech motorcycle program opinions.
- 100/90-19 replacement tire? HELP!
