View Full Version : Sportster Models
- newby here!
- problem with hose hook-up 94 xl883
- Ricor for the XR1200
- $$$$ for handlebars and labor
- sraight pipes
- Raising the fork suspension
- How clean does a head surface really need to be?
- 2002 Sportster 883 Hugger rear shocks
- Front suspension
- A first for me!
- LED wiring advice
- Anyone knows who sells these tires?
- Iron 883 Pipes
- License plate location
- Custom Iron 883 Build Inspired By King of Kings Winner
- TPS , SPARK PLUG WIRES, Iron 2014.
- 1987 1100 swap
- Rear brake failure.
- My bike wont work please help!
- Sportster 883 Wiring problem - need help
- my Sporster has a knock! Please help!!!!
- 91-03 Sportster w/ Shortshots and Mid-Controls?
- Sportster hub spacer
- Question about shifting speeds
- Mini fairing options for inverted fork 2016 Roadsters
- 2007+ fuel injection coil wiring plug
- Intermittent electrical problem? 2005 883
- Want to put a bigger motor on my sportster
- Sportster Two-Up Seat for Small Passenger
- 08 Sportster xl1200c CAN'T SEPERATE FORKS!
- hammer 1250 update 1500 mile
- 12inch apes and controls and cable sportster nightster
- Jet size for straight pipe?
- Newby question. 2012 XL1200c
- New Bars for 48. Cable Question
- 2020 sportster 48
- Head breathers
- New Sportster Seventy Two Owner
- XL1200T very high revs
- Sporty Check Engine and Shut Off
- 883 Top End Work
- Sportster problem, please help!
- Looking at a 1997 sportster 883
- HSR42 carb worth the money on basic 1250
- 1200 gears on a 883
- Slight bogg
- XL1200CX Roadster Transformed Into a Custom Racer
- Compatible Gas tanks
- Belt wear it 1800 miles?
- Sportster swingarm compatibility
- On tour .
- Once upon a time she was a XL Custom
- Need help. 2006 1200
- 2005 Sporty 883C Backfires
- not getting any spark.....
- 1987 Xl883 motor Identification
- High idle code P0505.
- New Bars but Help!
- V&H Short Shots- no tune, stock filter
- 08 Sportster Mid Axle
- 05 custom custom
- Sportster Rubbermount Excessive vibrations
- Bike just shut down while riding
- 1998 hugger 883
- Needle shims?
- Regulator/Rectifier electrical test
- 1997 Sportster Rear Base Gasket Leaking Still
- 2008 Sportster Roadster NEED HELP
- Vacuum piston troubleshooting
- HD Cafe Solo replacement
- new air intake system
- any drag racing sportster fans out there???
- Smaller front wheel
- 2006 speedo shorts out
- What to look for on wrecked sporty
- What year?
- Mystery Part
- Help Needed Bells Ringing while Riding Iron 883 2015 @ 6600 Odo
- I think my ‘17 Roadster’s forks need attention...
- Dyno tune vs. plug in tuner
- 2002 Sportster XL1200C Clutch Cable leak
- TMAP Replacement
- Ride height picture request
- Battery Lived on Tender, Now Dead
- Carb issue
- Another oil leak
- 1998 1200 Speedo LED display repair tips
- Help with a belt!!
- Chain Conversion? for 200mm
- Ignition issues
- I have a couple Sportster DIY videos to share
- Weird shifting issue
- Intermittent sticking speedo
- Intermittent shut downs/ diagnostic port to ob2 part #?
- Turn signal/Brake light/Speedo issues
- 2020 Iron 1200 is Riding Stripped To Its Bare Essence
- Need tune help fp3/way too lean
- Iron 1200 w/Fairing owners
- Removing transmission pulley nut
- 2017 Sportster 48 Triple Tree
- Weird Electrical Problem
- 2014 xl1200c taillight
- Washers vs. PCV Pipe for fork preload
- Seat fitment question
- Having rear tire rubbing issues
- 2012 Iron 883 Left blinker problem
- Short shots LOUD POP on hot start, normal?
- dirty injectors?
- New k&n air filter from stock, 01 sporty
- Sportster Softail
- Internally wired handlebars
- what size tire for 16x3.5 front wheel
- 2012 Suprerlow Harley Alarm ?
- 2012 XL1200C Rear Running Light doesnt turn on
- Botched oil change
- 1979 Ironhead Starter thrust washer
- 2016 Forty Eight - Signal Flasher Relay Location
- bill1200xl
- High torque starter
- Desperately need help
- Racing Orange 883R Pays Homage to Dirt Track Victories
- Question about removing Primary Cover
- ive tried contacting burly but they never get back to me so i need some help from you guys
- Does anyone know what this is?
- Rear Brake Trouble on 2010 883 IRON
- 1999 1200 sportster
- 2012 Superlow 883 Suspension Advice/opinions.
- N9rmal? Sportster exhaust loud POP on warm startup. Vance and hines short shots.
- Mind Boggling fuel/air ratio issues.
- 1979 ironhead clutch install
- Fork Brace arlen ness method or superbrace
- Modifying shortshots to 2-1??
- Sportster monoshock
- VOES switch operation with new gravity petcock
- Taller bars on a 04 1200C
- Oil weirdness! Has this happened to you?
- xl1200t sportster superlow road noise
- Repaint Gas Tank and Fender?
- Xlh 1100 Carb help!
- Another Handlebar Question
- Street fighter wheels on
- No lights???
- ordered my hammer kit
- XL1100 Sportster Gets Retro Tracker Treatment
- Help with brake pedal
- Throttle not responding correctly
- sportster 1200 carb problem?
- Stuck in neutral when shifting quick
- G40M Brake Grease
- Harley wont start
- 17 Sportster runs great but not in gear.
- Blockhead
- Stealing wobble on a 4 over front end and burly slammers
- T Bars on a sportster
- Tank Design update
- New wheels ready
- Smart Security Sportster Keyless Ignition
- 1972 XLH real brake lever return spring.
- New to me sportster has been sitting for 4 years
- 6.98 @ 103 Hammer 1275
- '06 Sportster no rear brakes
- 2015 48 questions...
- Sportster exhaust question
- Looking for a 21” wheel with 25mm axel
- Front turn signals
- What do you guys think?
- Checking Breather Valves
- Need a 21” front wheel for 2008 Nightster
- extension on front end
- wider tire on 2016+ sporty
- Cracked induction module?
- 2019 oil tank bezel
- 02 Sportster Forward Controls Shifter Lever Question
- 2003 Sporty 1200 DEAD
- X1 Lightning Scrambler from Holland is the Perfect Storm
- Anyone add kick start to a non kick start?
- Tachometer drive.
- Quick disconnect leaking
- Thirsty 1200R .
- Gas tank
- Swing arm bag
- black bags
- Changing Battery(with factory Alarm)
- 1995 Sporty barely runs, what is it?
- won't start
- XL 1200C Neutral light and some else
- Can anyone identify this part?
- Riding in rain and sputtering/hesitation
- 96 Sportster gauge removal?
- Sportster 1200 Nightser Bars
- Another fat guy who needs a bigger seat thread
- New Excel wheels on the way
- Tuning
- Help with handlebar wiring
- The rebuild continues...
- Now I'm a Sportster guy too!
- Help with cables
- Question about 48
- Roland Sands Solo seat info...
- 07 1200XL - Starts then Won't Idle
- Can I eliminate my horn and use the horn button for??
- raising forks on 2016 48
- 2014 48 - Service/Rebuild Required?
- 98 Sportster 1200s Ignition Coil
- Is a Coil Relocation necessary?
- Iron 883 2013 vs 2014 or newer
- Speedo, Tach, and Odo are not working on an 04
- Help!! Joker machine rear turn signals problem
- Front, Upper Motor Mount
- My bike is too "low"
- Rebellious XR1200 is Out of Control
- Sportster 72 Hard candy custom logo
- Tire & rim swap
- check engine light, battery light no codes
- Turn signals are crossed and I shocked myself.
- Screaming eagle racetuner, map for Hammer 1250 kit
- 2015 Iron 883 Running issue
- Loud pop from exhaust on hot start up
- Brake line replacement for new handlebars
- Need help, newbie
- What is the name and brand of that seat?!
- after market Air filter Sportster 1200 nightster 2010
- Air cleaner/Filter recommendations?
- 2000 XL1200C Sportster Oil leak. HELP
- help with 2 into 1 exhaust systems?
- completed my suspension today
- Bike isn't start
- 2010 883R wont start
- Jagg oil cooler lowered temps by how much?
- Help Installing Rizoma Brake/Turn/Running Lights
- Brand new 2020 Forty Eight small oil leak?
- Screamin Eagle Air intake
- Ironster 883 2012
- 2003 Sportster with an exhaust O2 sensor? What is this??
- Upgrades for my 72 sportster
- Carb rejet suggesetions
- Removing bearing from rear wheel
- Nightster 1200 2010 forward controls
- Ebay taillight wiring??
- 2013 Sportster 883 Iron - Ignition and wiring size
- Derby cover won't stop leaking?
- sissy bar fitment with rear turn signaL relocation kit
- Sportstar 2016 Iron 883 Increases Engine RPM drastically when Clutch is Engaged
- Engine Revs when coming to stop with clutch engaged
- First Harley
- Flagged no warranty?
- Fork brace and fork cartridges
- Sissy bar luggage advice
- Need help ordering cover
- Ironn883 front wheel drop size.
